hie,
i trying to storage the data in flash and read it. i am unable to read the flash .i have attached my code.please correct me if there is any mistake.
* Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_uart_over_ble_main main.c
* @ingroup ble_sdk_app_nus_eval
* @brief UART over BLE application main file.
* This file contains the source code for a sample application that uses the Nordic UART service.
* This application uses the @ref srvlib_conn_params module.
#include <stdio.h>
#include <stdint.h>
#include <string.h>
#include <math.h>
#include <ctype.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
#include "nrf.h"
#include "nrf_drv_timer.h"
#include "bsp.h"
#include "nrf_wdt.h"
#include "nrf_drv_spi.h"
#include "nrf_fstorage.h"
#include "nrf_fstorage_sd.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME "DIGANT2" /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL 32 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define BLE_UART_LIMIT 240 // size of UART sub packet
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
#define TX_POWER_LEVEL 8
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
uint8_t DATA_PACKECT[28];
uint8_t data_array[512];
uint16_t uartIndex = 0;
uint16_t uartSubIdx;
uint8_t NEW_FORMAT[160];
uint16_t one_sec_flag;
uint16_t two_sec_flag;
uint16_t three_sec_flag;
static int time=1;
uint16_t BAUD_4800_flag;
uint16_t BAUD_9600_flag;
uint16_t BAUD_19200_flag;
uint16_t BAUD_38400_flag;
uint16_t BAUD_115200_flag;
uint16_t SN_FLAG;
uint8_t S_ID[2] ="S:";
uint8_t T_NAME[5] ="TEMP:";
uint8_t B_NAME[5] ="BT_V:";
uint8_t F_NAME[3] ="FH:";
uint8_t DI1_NAME[4] ="DI0:";
uint8_t DI2_NAME[4] ="DI1:";
uint8_t DI3_NAME[4] ="DI2:";
uint8_t DI4_NAME[4] ="DI3:";
uint8_t DI5_NAME[4] ="DI4:";
uint8_t COMA[1] = ",";
uint8_t N_LINE[2] = "\r\n";
uint8_t SPACE[1] = " ";
uint8_t UID[4];
uint8_t buffer[8];
uint8_t buffer1[6];
uint8_t buffer2[4];
uint8_t buffer3[4];
uint8_t buffer4[5] = " OFF ";
uint8_t buffer5[5] = " ON ";
uint8_t DEVICE_CFGNAME[10];
uint8_t FUEL_HEIGHT[4];
uint8_t BAT_VOLTAGE[4];
uint8_t WR_CONFIG[4];
float F_HEIGHT;
float B_VOLTAGE;
float TEMP;
uint32_t num;
uint32_t num1;
uint32_t num2;
union ui32_to_ui8 {
uint32_t ui32;
uint8_t ui8[4];
}u;
float temperature(void);
float adcv_volt_f,RTD_TEMPERATURE;
void MODBUS(void);
#define TX_D NRF_GPIO_PIN_MAP(0,6)
#define PAIR_LED NRF_GPIO_PIN_MAP(0,27)
#define IN1 NRF_GPIO_PIN_MAP(1,15)
#define IN2 NRF_GPIO_PIN_MAP(1,13)
#define GPIO_1 NRF_GPIO_PIN_MAP(0,13)
#define GPIO_2 NRF_GPIO_PIN_MAP(0,29)
#define IN4 NRF_GPIO_PIN_MAP(1,10)
#define IN3 NRF_GPIO_PIN_MAP(1,9)
#define IN5 NRF_GPIO_PIN_MAP(0,14)
#define SPI_INSTANCE 0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE); /**< SPI instance. */
static volatile bool spi_xfer_done; /**< Flag used to indicate that SPI instance completed the transfer. */
static volatile bool config_done = false;
#define MAV_SAMPLE_WINDOW_SIZE 4
#define MAV_TEMPER_WINDOW_SIZE 4
#define MAV_SAMPLE_WINDOW_MASK (MAV_SAMPLE_WINDOW_SIZE-1)
#define MAV_TEMPER_WINDOW_MASK (MAV_TEMPER_WINDOW_SIZE-1)
long mav_samples[MAV_SAMPLE_WINDOW_SIZE] = {0,0,0,0};
float mav_temperature[MAV_TEMPER_WINDOW_SIZE] = {0,0,0,0};
uint8_t mav_sample_indx = 0;
uint8_t mav_temperature_indx = 0;
uint8_t mav_sample_ready = 0;
uint8_t mav_temperature_ready = 0;
uint8_t m_key[20] = {'D', 'I', 'G', 'A', 'N', 'T', '_', '_',
'T', 'E', 'C', 'H', 'N', 'O', 'L', 'O', 'G', 'I', 'E', 'S'};
APP_TIMER_DEF(Sip_timer);
static void fstorage_evt_handler(nrf_fstorage_evt_t * p_evt);
NRF_FSTORAGE_DEF(nrf_fstorage_t fstorage) =
/* Set a handler for fstorage events. */
.evt_handler = fstorage_evt_handler,
/* These below are the boundaries of the flash space assigned to this instance of fstorage.
* You must set these manually, even at runtime, before nrf_fstorage_init() is called.
* The function nrf5_flash_end_addr_get() can be used to retrieve the last address on the
* last page of flash available to write data. */
.start_addr = 0x3e000,
.end_addr = 0x3ffff,
/* Dummy data to write to flash. */
//static uint32_t m_data = 0xBADC0FFE;
static uint8_t m_data[20];
static uint8_t m_hello_world[] = "hiiiiiii";
/**@brief Helper function to obtain the last address on the last page of the on-chip flash that
* can be used to write user data.
static uint32_t nrf5_flash_end_addr_get()
uint32_t const bootloader_addr = NRF_UICR->NRFFW[0];
uint32_t const page_sz = NRF_FICR->CODEPAGESIZE;
uint32_t const code_sz = NRF_FICR->CODESIZE;
return (bootloader_addr != 0xFFFFFFFF ?
bootloader_addr : (code_sz * page_sz));
if (p_evt->result != NRF_SUCCESS)
NRF_LOG_INFO("--> Event received: ERROR while executing an fstorage operation.");
return;
switch (p_evt->id)
case NRF_FSTORAGE_EVT_WRITE_RESULT:
NRF_LOG_INFO("--> Event received: wrote %d bytes at address 0x%x.",
p_evt->len, p_evt->addr);
} break;
case NRF_FSTORAGE_EVT_ERASE_RESULT:
NRF_LOG_INFO("--> Event received: erased %d page from address 0x%x.",
} break;
static void print_flash_info(nrf_fstorage_t * p_fstorage)
NRF_LOG_INFO("========| flash info |========");
NRF_LOG_INFO("erase unit: \t%d bytes", p_fstorage->p_flash_info->erase_unit);
NRF_LOG_INFO("program unit: \t%d bytes", p_fstorage->p_flash_info->program_unit);
NRF_LOG_INFO("==============================");
/**@brief Sleep until an event is received. */
static void power_manage(void)
#ifdef SOFTDEVICE_PRESENT
(void) sd_app_evt_wait();
#else
__WFE();
void wait_for_flash_ready(nrf_fstorage_t const * p_fstorage)
/* While fstorage is busy, sleep and wait for an event. */
while (nrf_fstorage_is_busy(p_fstorage))
power_manage();
//function to set up the flash memory
void flash_init()
ret_code_t err_code;
nrf_fstorage_api_t * p_fs_api;
p_fs_api = &nrf_fstorage_sd;
err_code = nrf_fstorage_init(&fstorage, p_fs_api, NULL);
/**@brief Function for assert macro callback.
* @warning This handler is an example only and does not fit a final product. You need to analyse
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
void timer_timeout_handler(void * p_context)
uint16_t count=0;
uint16_t count1=0;
count++;
count1++;
if(count == 2)
two_sec_flag = 1;
count = 0;
if(count1 == 3)
three_sec_flag = 1;
count1 = 0;
one_sec_flag = 1;
static void timers_init(void)
err_code = app_timer_create(&Sip_timer, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
static void application_timers_start(void)
/* YOUR_JOB: Start your timers. below is an example of how to start a timer.*/
err_code = app_timer_start(Sip_timer, APP_TIMER_TICKS(60000), NULL); //1000 ms= 1 seg
* the device. It also sets the permissions and appearance.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
unsigned str_to_decimal(const char *s)
int result = 0;
for (; *s; ++s) {
/* Only process recognized digits */
if (isdigit((unsigned char)*s))
result = 10 * result + (*s - '0');
return result;
void delchar(char *x,int a, int b)
if ((a+b-1) <= strlen(x))
strcpy(&x[b-1],&x[a+b-1]);
puts(x);
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART BLE Service and send
* it to the UART module.
* @param[in] p_evt Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
/*static void nus_data_handler(ble_nus_evt_t * p_evt)
uint8_t ID_BUF[8];
int digit;
uint8_t time1[2];
uint8_t ACK_DATA[20];
uint8_t S_ACK_DATA[13];
uint8_t *matched;
uint16_t lenn = 12;
uint32_t err_code;
uint32_t i;
u.ui32 = NRF_FICR->DEVICEID[0];
itoa(u.ui32,buffer,16);
for(int ii=0;ii<9;ii++)
ID_BUF[ii]=buffer[ii];
NRF_UART_TASK_STARTTX;
nrf_gpio_pin_set(TX_D);
time=0;
//matched = strncmp(ID_BUF,p_evt->params.rx_data.p_data, 8);
matched = strstr(p_evt->params.rx_data.p_data,ID_BUF);
if(matched != 0)
for(int i = 0; i < p_evt->params.rx_data.length-2; i++)
{ACK_DATA[i] = p_evt->params.rx_data.p_data[i+2]+ m_key[i];}
delchar(ACK_DATA, 1,9);
delchar(ACK_DATA, 1,10);
for(int i = 0; i < 13; i++)
{S_ACK_DATA[i] = ACK_DATA[i]+ m_key[i];}
ble_nus_data_send(&m_nus, &S_ACK_DATA[0], &lenn, m_conn_handle);
if(p_evt->params.rx_data.length > 13 && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '}' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 2] == '"' )
if(p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 5] == 'm' || p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 5] == 'M' )
time1[1] = p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 3];
if(p_evt->params.rx_data.length >15 && p_evt->params.rx_data.length <=19)
time1[0] = p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 4];
app_uart_put(time1[0]);
app_uart_put(time1[1]);
time = str_to_decimal(time1);
else{app_uart_put('N');app_uart_put('O');app_uart_put('O');}
for ( i = 0; i < p_evt->params.rx_data.length; i++)
do
// err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
} while (err_code == NRF_ERROR_BUSY);
char* matched;
char* matched_SN;
int digit,c,position=12,length_SN=0;
uint8_t time1[2];
uint16_t LEN = 18;
char Network_Name[2] = "SN";
uint32_t err_code;
uint32_t i;
//time=1;
matched = strstr(p_evt->params.rx_data.p_data,buffer);
matched_SN = strstr(p_evt->params.rx_data.p_data,Network_Name);
app_uart_put(p_evt->params.rx_data.length);
length_SN = p_evt->params.rx_data.length - 12;
if(matched && p_evt->params.rx_data.length == 18 && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 3] == ':')
time=0;
for(int i = 0; i < p_evt->params.rx_data.length; i++)
{ACK_DATA[i] = p_evt->params.rx_data.p_data[i]+ m_key[i];}
ble_nus_data_send(&m_nus, &ACK_DATA[0], &p_evt->params.rx_data.length, m_conn_handle);
if(p_evt->params.rx_data.length > 10 && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 3] == ':' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 4] == 'E' && p_evt->params.rx_data.length <=20 )
app_uart_put('O');app_uart_put('K');
time1[1] = p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1];
time1[0] = p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 2];
if(matched && p_evt->params.rx_data.length == 18 && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 8] == 'R' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 9] == 'B')
if(p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 3] == '2' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 4] == '5' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 5] == '1' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 6] == '1')
BAUD_115200_flag = 1;
if(matched && p_evt->params.rx_data.length == 16 && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 6] == 'R' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 7] == 'B' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 3] == '8' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 4] == '4')
ACK_DATA[16] = SPACE[0] + m_key[16];
ACK_DATA[17] = SPACE[0] + m_key[17];
ble_nus_data_send(&m_nus, &ACK_DATA[0], &LEN, m_conn_handle);
BAUD_4800_flag = 1;
if(matched && p_evt->params.rx_data.length == 16 && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 6] == 'R' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 7] == 'B' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 3] == '6' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 4] == '9')
BAUD_9600_flag = 1;
if(matched && p_evt->params.rx_data.length == 17 && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 7] == 'R' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 8] == 'B' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 3] == '2' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 4] == '9' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 5] == '1')
ACK_DATA[18] = SPACE[0] + m_key[18];
BAUD_19200_flag = 1;
if(matched && p_evt->params.rx_data.length == 17 && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 7] == 'R' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 8] == 'B' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 3] == '4' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 4] == '8' && p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 5] == '3')
BAUD_38400_flag = 1;
if(matched /*&& matched_SN*/)
app_uart_put('S');
app_uart_put('N');
while (c < length_SN) {
DEVICE_CFGNAME[c] = p_evt->params.rx_data.p_data[position+c-1];
c++;
app_uart_put(DEVICE_CFGNAME[c]);
sd_ble_gap_device_name_set(&sec_mode,
DEVICE_CFGNAME,
strlen(DEVICE_CFGNAME));
// ble_advdata_set(&advdata, NULL);
/* for ( i = 0; i < p_evt->params.rx_data.length; i++)
do
uint32_t err_code;
ble_nus_init_t nus_init;
// Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module
* which are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply setting
* the disconnect_on_fail config parameter, but instead we use the event handler
* mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
uint32_t err_code;
nrf_gpio_pin_toggle(PAIR_LED);
/**@brief Function for handling errors from the Connection Parameters module.
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected");
nrf_gpio_pin_set(PAIR_LED);
NRF_LOG_INFO("Disconnected");
nrf_delay_ms(1000);
nrf_gpio_pin_clear(PAIR_LED);
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
// Pairing not supported
/* err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
APP_ERROR_CHECK(err_code);*/
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
// No implementation needed.
/**@brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
* @param[in] event Event generated by button press.
uint32_t err_code;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for handling app_uart events.
* a string. The string will be be sent over BLE when the last character received was a
* 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
#if 0
static uint8_t index = 0;
uint32_t err_code;
switch (p_event->evt_type)
case APP_UART_DATA_READY:
// if(rs485_communication2 == 0)
nrf_gpio_pin_clear(TX_D);
index++;
//rs485_communication2 = 1;
/* if ((data_array[index - 1] == '\n') ||
(data_array[index - 1] == '\r') ||
(index >= m_ble_nus_max_data_len))
// if(rs485_communication2 == 1)
// if (index > 0)
do
} while (err_code == NRF_ERROR_RESOURCES);
index = 0;
// rs485_communication2 = 0;
// nrf_gpio_pin_clear(TX_D);
case APP_UART_FIFO_ERROR:
case APP_UART_TX_EMPTY:
NRF_UART_TASK_STOPTX;
UNUSED_VARIABLE(app_uart_get(&data_array[uartIndex]));
uartIndex++;
if(BAUD_115200_flag)
BAUD_115200_flag = 0;
NRF_UART0->BAUDRATE = (UART_BAUDRATE_BAUDRATE_Baud115200 << UART_BAUDRATE_BAUDRATE_Pos);
if(BAUD_4800_flag)
BAUD_4800_flag = 0;
NRF_UART0->BAUDRATE = (UART_BAUDRATE_BAUDRATE_Baud4800 << UART_BAUDRATE_BAUDRATE_Pos);
if(BAUD_9600_flag)
BAUD_9600_flag = 0;
NRF_UART0->BAUDRATE = (UART_BAUDRATE_BAUDRATE_Baud9600 << UART_BAUDRATE_BAUDRATE_Pos);
if(BAUD_19200_flag)
BAUD_19200_flag = 0;
NRF_UART0->BAUDRATE = (UART_BAUDRATE_BAUDRATE_Baud19200 << UART_BAUDRATE_BAUDRATE_Pos);
if(BAUD_38400_flag)
BAUD_38400_flag = 0;
NRF_UART0->BAUDRATE = (UART_BAUDRATE_BAUDRATE_Baud38400 << UART_BAUDRATE_BAUDRATE_Pos);
/**@brief Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
uint32_t err_code;
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
.baud_rate = NRF_UARTE_BAUDRATE_9600
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
uint32_t err_code;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
nrf_pwr_mgmt_run();
static void tx_power_set(void)
ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, TX_POWER_LEVEL);
void Delay(uint16_t count)
uint16_t ii,jj;
for(ii=0;ii<count;ii++)
for(jj=0;jj<10000;jj++);
void reverse(char *str, int len)
int i=0, j=len-1, temp;
while (i<j)
temp = str[i];
str[i] = str[j];
str[j] = temp;
i++; j--;
int intToStr(int x, char str[], int d)
int i = 0;
while (x)
str[i++] = (x%10) + '0';
x = x/10;
// If number of digits required is more, then
// add 0s at the beginning
while (i < d)
str[i++] = '0';
reverse(str, i);
str[i] = '\0';
return i;
void ftoa(float n, char *res, int afterpoint)
// Extract integer part
int ipart = (int)n;
// Extract floating part
float fpart = n - (float)ipart;
// convert integer part to string
int i = intToStr(ipart, res, 0);
// check for display option after point
if (afterpoint != 0)
res[i] = '.'; // add dot
// Get the value of fraction part upto given no.
// of points after dot. The third parameter is needed
// to handle cases like 233.007
fpart = fpart * pow(10, afterpoint);
intToStr((int)fpart, res + i + 1, afterpoint);
/**@brief Application main function.
void wdt_init(void)
NRF_WDT->CONFIG = (WDT_CONFIG_HALT_Pause << WDT_CONFIG_HALT_Pos) | ( WDT_CONFIG_SLEEP_Run << WDT_CONFIG_SLEEP_Pos);
NRF_WDT->CRV = 9*32768;
NRF_WDT->RREN |= WDT_RREN_RR0_Msk;
NRF_WDT-> RR [0] = 0x6E524635UL;
NRF_WDT->TASKS_START = 1;
void spi_init(void)
nrf_drv_spi_config_t spi_config;
spi_config.frequency = SPI_FREQUENCY_FREQUENCY_K500,
spi_config.mode = NRF_DRV_SPI_MODE_3,
spi_config.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST,
spi_config.ss_pin = SPI_SS_PIN;
spi_config.miso_pin = SPI_MISO_PIN;
spi_config.sck_pin = SPI_SCK_PIN;
spi_config.mosi_pin = NRF_DRV_SPI_PIN_NOT_USED;
// APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config,spi_event_handler, NULL));
APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config,NULL, NULL));
uint8_t ID_BUF[8];
uint16_t DI;
uint16_t PREVSDI = 0;
uint16_t PRESSDI = 0;
uint16_t DI2;
uint16_t PREVSDI2 = 0;
uint16_t PRESSDI2 = 0;
uint16_t DI3;
uint16_t PREVSDI3 = 0;
uint16_t PRESSDI3 = 0;
uint16_t DI4;
uint16_t PREVSDI4 = 0;
uint16_t PRESSDI4 = 0;
uint16_t DI5;
uint16_t PREVSDI5 = 0;
uint16_t PRESSDI5 = 0;
{ID_BUF[ii]=buffer[ii];}
uint16_t value1,value2,value3,value4,value5,value6,value7,value8,value9,value10,value11,value12,value13,value14,value15,value16,value17,value18
,value19,value20,value21,value22,value23,value24,value25,value26,value27,value28,value29,value30,value31,value32;
uint16_t dlen,dlen1,dlen2,dlen3,dlen4,dlen5,dlen6,dlen7,dlen8,dlen9,dlen10,dlen11,dlen12,dlen13,dlen14,dlen15,dlen16,dlen17
,dlen18,dlen19,dlen20,dlen21,dlen22,dlen23,dlen24,dlen25,dlen26,dlen27,dlen28,dlen29,dlen30;
uint16_t len=18;
nrf_gpio_cfg_output(TX_D);
nrf_gpio_cfg_output(PAIR_LED);
nrf_gpio_cfg_output(GPIO_1);
nrf_gpio_cfg_output(GPIO_2);
nrf_gpio_cfg_sense_input(IN1,NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_HIGH);
nrf_gpio_cfg_sense_input(IN2,NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_HIGH);
nrf_gpio_cfg_sense_input(IN3,NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_HIGH);
nrf_gpio_cfg_sense_input(IN4,NRF_GPIO_PIN_PULLDOWN, NRF_GPIO_PIN_SENSE_LOW);
nrf_gpio_cfg_sense_input(IN5,NRF_GPIO_PIN_PULLDOWN, NRF_GPIO_PIN_SENSE_LOW);
bool erase_bonds;
uint16_t length;
// Initialize.
uart_init();
log_init();
spi_init();
timers_init();
flash_init();
nrf_fstorage_erase(&fstorage,0x3f000,15,NULL);
NRF_LOG_INFO("Writing \"%s\" to flash.", m_hello_world);
nrf_fstorage_write(&fstorage, 0x3f000, m_hello_world, sizeof(m_hello_world), NULL);
wait_for_flash_ready(&fstorage);
NRF_LOG_INFO("Done.");
nrf_fstorage_read(&fstorage, 0x3f000, &m_data, 12);
for(int i = 0;i < sizeof(m_data) ; i++)
app_uart_put(m_data[i]);
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
// wdt_init();
application_timers_start();
advertising_start();
tx_power_set();
for(int ii=0;ii<100;ii++)
{temperature();}
MODBUS();
for (;;) {
idle_state_handle();
//NRF_WDT->RR[0] = WDT_RR_RR_Reload;
nrf_gpio_pin_set(GPIO_2);
MODBUS();
if(uartIndex != 0) {
Delay(100);
uartSubIdx =0;
do {
do {
if(uartIndex < BLE_UART_LIMIT) length = (uint16_t)uartIndex;
else length = BLE_UART_LIMIT;
if(uartIndex == 35 || uartIndex == 27)
{ memcpy (DATA_PACKECT, data_array, sizeof(data_array)); }
{memset(DATA_PACKECT, 0, sizeof(DATA_PACKECT)); }
//err_code = ble_nus_data_send(&m_nus, &DATA_PACKECT[0], &length, m_conn_handle);
(err_code != NRF_ERROR_NOT_FOUND)) {
if(uartIndex < BLE_UART_LIMIT) uartIndex = 0;
else {
uartIndex = uartIndex - BLE_UART_LIMIT;
uartSubIdx = uartSubIdx + BLE_UART_LIMIT;
} while (uartIndex > 0);
uartIndex = 0;
jagadeesh
