project fails to load after I used git to update nrf9160 SDK from 1.0.0 to 1.1.0
I am using windows 10 and have been able to work with the FOTA sample for the nrf9160 for several months.
I needed to update the SDK from 1.0.0 to 1.1.0. I followed the instructions in the nrfConnect tool including
updating to the latest version of the compiler.
I get the following in the output window in SES. I get a similar error when I try to load in the ble_gateway project
Loading solution aws_fota.emProject
Executing load commands
cmake -GNinja -DBOARD=nrf9160_pca10090ns -DBOARD_DIR=C:/Projects/PCDWorks/nRF9160/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=C:/gnuarmemb -BC:/Projects/PCDWorks/nRF9160/ncs/nrf/samples/nrf9160/aws_fota/build_nrf9160_pca10090ns -HC:/Projects/PCDWorks/nRF9160/ncs/nrf/samples/nrf9160/aws_fota -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:/Program Files/SEGGER/arm_segger_embedded_studio_v430c_win_x64_nordic/html/configure_nordic_project_menuconfig.py
-- Using application from 'C:/Projects/PCDWorks/nRF9160/ncs/nrf/samples/nrf9160/aws_fota'
Zephyr version: 1.14.99
-- Selected BOARD nrf9160_pca10090ns
-- Found west: C:/Python37/Scripts/west.exe (found suitable version "0.5.8", minimum required is "0.5.6")
validation.invalid
 --- All found errors ---
["Key 'repo-path' was not defined. Path: '/projects/0'", "Key 'repo-path' was not defined. Path: '/projects/3'", "Key 'repo-path' was not defined. Path: '/projects/4'", "Key 'repo-path' was not defined. Path: '/projects/5'", "Key 'repo-path' was not defined. Path: '/projects/6'", "Key 'repo-path' was not defined. Path: '/projects/12'"]
  File "C:\Projects\PCDWorks\nRF9160\ncs\.west\west\src\west\manifest.py", line 153, in __init__
    schema_files=[_SCHEMA_PATH[key]]
  File "c:\python37\lib\site-packages\pykwalify\core.py", line 167, in validate
    error_msg=u'.\n - '.join(self.validation_errors)))
pykwalify.errors.SchemaError: <SchemaError: error code 2: Schema validation failed:
 - Key 'repo-path' was not defined. Path: '/projects/0'.
 - Key 'repo-path' was not defined. Path: '/projects/3'.
 - Key 'repo-path' was not defined. Path: '/projects/4'.
 - Key 'repo-path' was not defined. Path: '/projects/5'.
 - Key 'repo-path' was not defined. Path: '/projects/6'.
 - Key 'repo-path' was not defined. Path: '/projects/12'.: Path: '/'>
During handling of the above exception, another exception occurred:
  File "c:\python37\lib\runpy.py", line 193, in _run_module_as_main
    "__main__", mod_spec)
  File "c:\python37\lib\runpy.py", line 85, in _run_code
    exec(code, run_globals)
  File "C:\Python37\Scripts\west.exe\__main__.py", line 9, in <module>
  File "c:\python37\lib\site-packages\west\_bootstrap\main.py", line 499, in main
    wrap(wrap_argv)
  File "c:\python37\lib\site-packages\west\_bootstrap\main.py", line 485, in wrap
    west.main.main(argv)
  File "C:\Projects\PCDWorks\nRF9160\ncs\.west\west\src\west\main.py", line 569, in main
    extensions = get_extension_commands()
  File "C:\Projects\PCDWorks\nRF9160\ncs\.west\west\src\west\main.py", line 531, in get_extension_commands
    extensions = extension_commands()
  File "C:\Projects\PCDWorks\nRF9160\ncs\.west\west\src\west\commands\command.py", line 181, in extension_commands
    manifest = Manifest.from_file()
  File "C:\Projects\PCDWorks\nRF9160\ncs\.west\west\src\west\manifest.py", line 91, in from_file
    return Manifest(source_file=source_file, sections=sections)
  File "C:\Projects\PCDWorks\nRF9160\ncs\.west\west\src\west\manifest.py", line 156, in __init__
    self._malformed(e, key)
  File "C:\Projects\PCDWorks\nRF9160\ncs\.west\west\src\west\manifest.py", line 226, in _malformed
    complaint))
west.manifest.MalformedManifest: Malformed manifest file C:\Projects\PCDWorks\nRF9160\ncs\nrf\west.yml (schema: C:\Projects\PCDWorks\nRF9160\ncs\.west\west\src\west\manifest-schema.yml):
CMake Error at C:/Projects/PCDWorks/nRF9160/ncs/zephyr/cmake/zephyr_module.cmake:45 (message):
    File "C:/Projects/PCDWorks/nRF9160/ncs/zephyr/scripts/zephyr_module.py", line 168, in <module>
      main()
    File "C:/Projects/PCDWorks/nRF9160/ncs/zephyr/scripts/zephyr_module.py", line 142, in main
      returncode=p.returncode)
  subprocess.CalledProcessError: Command '['C:/Python37/Scripts/west.exe',
  'list', '--format={posixpath}']' returned non-zero exit status 1.
  C:/Projects/PCDWorks/nRF9160/ncs/zephyr/cmake/app/boilerplate.cmake:249 (include)
  CMakeLists.txt:10 (include)
Project load failed
Reported error: solution load command failed (1)
  • Here is additional information. The following is the output from the command line from attempting to update the project using west
    Microsoft Windows [Version 10.0.17763.973]
    (c) 2018 Microsoft Corporation. All rights reserved.
    C:\Projects\PCDWorks\nRF9160\ncs\nrf>git fetch origin
    C:\Projects\PCDWorks\nRF9160\ncs\nrf>git checkout v1.1.0
    HEAD is now at d3130d77 manifest: Use v1.1.0 release tags
    M       samples/nrf9160/aws_fota/CMakeLists.txt
    M       subsys/net/lib/aws_fota/src/aws_fota.c
    C:\Projects\PCDWorks\nRF9160\ncs\nrf>west update
    validation.invalid
        wrap(wrap_argv)
        complaint))
  • Also if I try to use west in a new folder parallel to my existing working folder I get the following:
    Receiving objects: 100% (23039/23039), 9.03 MiB | 3.58 MiB/s, done.
    Resolving deltas: 100% (15895/15895), done.
    From github.com/.../fw-nrfconnect-nrf
     * tag               v1.1.0      -> FETCH_HEAD
     * [new branch]      master      -> origin/master
     * [new branch]      v1.0-branch -> origin/v1.0-branch
     * [new branch]      v1.1-branch -> origin/v1.1-branch
     * [new tag]         v0.1.0      -> v0.1.0
     * [new tag]         v0.1.0-rc1  -> v0.1.0-rc1
     * [new tag]         v0.3.0      -> v0.3.0
     * [new tag]         v0.3.0-rc1  -> v0.3.0-rc1
     * [new tag]         v0.3.0-rc2  -> v0.3.0-rc2
     * [new tag]         v0.4.0      -> v0.4.0
     * [new tag]         v0.4.0-rc1  -> v0.4.0-rc1
     * [new tag]         v0.4.0-rc2  -> v0.4.0-rc2
     * [new tag]         v1.0.0      -> v1.0.0
     * [new tag]         v1.0.0-rc1  -> v1.0.0-rc1
     * [new tag]         v1.0.0-rc2  -> v1.0.0-rc2
     * [new tag]         v1.0.0-rc3  -> v1.0.0-rc3
     * [new tag]         v1.0.0-rc4  -> v1.0.0-rc4
     * [new tag]         v1.1.0      -> v1.1.0
     * [new tag]         v1.1.0-rc1  -> v1.1.0-rc1
     * [new tag]         v1.1.0-rc2  -> v1.1.0-rc2
     * [new tag]         v1.1.0-rc3  -> v1.1.0-rc3
    8c94096fa7cfca9970b531e30dcf7b116c78782b refs/tags/v1.1.0
    Checking out files: 100% (1238/1238), done.
    Note: checking out 'v1.1.0'.
    You are in 'detached HEAD' state. You can look around, make experimental
    changes and commit them, and you can discard any commits you make in this
    state without impacting any branches by performing another checkout.
    If you want to create a new branch to retain commits you create, you may
    do so (now or later) by using -b with the checkout command again. Example:
      git checkout -b <new-branch-name>
    cloning github.com/.../west at revision master
    [92m=== Cloning west repository from https://github.com/zephyrproject-rtos/west, rev. master into C:\Projects\PCDWorks\nrf9160_110\ncs\.west\west
    [0mInitialized empty Git repository in C:/Projects/PCDWorks/nrf9160_110/ncs/.west/west/.git/
    remote: Enumerating objects: 3276, done.
    Receiving objects:  99% (3244/3276)d 0 (delta 0), pack-reused 3276R
    Receiving objects: 100% (3276/3276), 932.94 KiB | 3.75 MiB/s, done.
    Resolving deltas: 100% (1945/1945), done.
    From https://github.com/zephyrproject-rtos/west
     * branch            master       -> FETCH_HEAD
     * [new branch]      v0.6-branch  -> origin/v0.6-branch
     * [new tag]         v0.2.0       -> v0.2.0
     * [new tag]         v0.2.0rc1    -> v0.2.0rc1
     * [new tag]         v0.2.0rc2    -> v0.2.0rc2
     * [new tag]         v0.2.0rc3    -> v0.2.0rc3
     * [new tag]         v0.3.0rc1    -> v0.3.0rc1
     * [new tag]         v0.4.0rc1    -> v0.4.0rc1
     * [new tag]         v0.5.0       -> v0.5.0
     * [new tag]         v0.5.1       -> v0.5.1
     * [new tag]         v0.5.2       -> v0.5.2
     * [new tag]         v0.5.3       -> v0.5.3
     * [new tag]         v0.5.4       -> v0.5.4
     * [new tag]         v0.5.5       -> v0.5.5
     * [new tag]         v0.5.6       -> v0.5.6
     * [new tag]         v0.5.7       -> v0.5.7
     * [new tag]         v0.5.8       -> v0.5.8
     * [new tag]         v0.6.0       -> v0.6.0
     * [new tag]         v0.6.0rc1    -> v0.6.0rc1
     * [new tag]         v0.6.0rc2    -> v0.6.0rc2
     * [new tag]         v0.6.0rc3    -> v0.6.0rc3
     * [new tag]         v0.6.1       -> v0.6.1
     * [new tag]         v0.6.2       -> v0.6.2
     * [new tag]         v0.6.3       -> v0.6.3
     * [new tag]         v0.6.99.dev3 -> v0.6.99.dev3
     * [new tag]         v0.6.99.dev4 -> v0.6.99.dev4
    2101a7af38bedf2a3ea2c6cb1f70834b7151a9fb refs/remotes/origin/master
    Already on 'master'
    Branch 'master' set up to track remote branch 'master' from 'origin'.
    Error: no west.main in C:\Projects\PCDWorks\nrf9160_110\ncs\.west\west
    C:\Projects\PCDWorks\nrf9160_110\ncs>west update
    Error: "C:\Projects\PCDWorks\nrf9160_110\ncs" is not in a west installation.
    Things to try:
     - Set ZEPHYR_BASE to a zephyr repository path in a west installation.
     - Run "west init" to set up an installation here.
     - Run "west init -h" for additional information.
    C:\Projects\PCDWorks\nrf9160_110\ncs>west init
    Initializing in C:\Projects\PCDWorks\nrf9160_110\ncs
    [92m=== Cloning manifest repository from https://github.com/zephyrproject-rtos/zephyr, rev. master into C:\Projects\PCDWorks\nrf9160_110\ncs\.west\tmp
    [0mInitialized empty Git repository in C:/Projects/PCDWorks/nrf9160_110/ncs/.west/tmp/.git/
    remote: Enumerating objects: 18, done.
    remote: Counting objects: 100% (18/18), done.
    remote: Compressing objects: 100% (18/18), done.
    remote: Total 410928 (delta 5), reused 1 (delta 0), pack-reused 410910
    Receiving objects: 100% (410928/410928), 291.95 MiB | 2.99 MiB/s, done.
    Resolving deltas: 100% (307876/307876), done.
    From https://github.com/zephyrproject-rtos/zephyr
     * [new branch]      add_rgb565_font        -> origin/add_rgb565_font
     * [new branch]      arm                    -> origin/arm
     * [new branch]      backport-17058-to-v1.14-branch -> origin/backport-17058-to-v1.14-branch
     * [new branch]      backport-17066-to-v1.14-branch -> origin/backport-17066-to-v1.14-branch
     * [new branch]      backport-17067-to-v1.14-branch -> origin/backport-17067-to-v1.14-branch
     * [new branch]      backport-17141-to-v1.14-branch -> origin/backport-17141-to-v1.14-branch
     * [new branch]      backport-17159-to-v1.14-branch -> origin/backport-17159-to-v1.14-branch
     * [new branch]      backport-17227-to-v1.14-branch -> origin/backport-17227-to-v1.14-branch
     * [new branch]      backport-17263-to-v1.14-branch -> origin/backport-17263-to-v1.14-branch
     * [new branch]      backport-17474-to-v1.14-branch -> origin/backport-17474-to-v1.14-branch
     * [new branch]      backport-17847-to-v1.14-branch -> origin/backport-17847-to-v1.14-branch
     * [new branch]      backport-18040-to-v1.14-branch -> origin/backport-18040-to-v1.14-branch
     * [new branch]      backport-18744-to-v1.14-branch -> origin/backport-18744-to-v1.14-branch
     * [new branch]      backport-19020-to-v1.14-branch -> origin/backport-19020-to-v1.14-branch
     * [new branch]      backport-19166-to-v2.0-branch -> origin/backport-19166-to-v2.0-branch
     * [new branch]      backport-19185-to-v2.0-branch -> origin/backport-19185-to-v2.0-branch
     * [new branch]      backport-19194-to-v2.0-branch -> origin/backport-19194-to-v2.0-branch
     * [new branch]      backport-19211-to-v2.0-branch -> origin/backport-19211-to-v2.0-branch
     * [new branch]      backport-19266-to-v2.0-branch -> origin/backport-19266-to-v2.0-branch
     * [new branch]      backport-19268-to-v2.0-branch -> origin/backport-19268-to-v2.0-branch
     * [new branch]      backport-19533-to-v1.14-branch -> origin/backport-19533-to-v1.14-branch
     * [new branch]      backport-19580-to-v2.0-branch -> origin/backport-19580-to-v2.0-branch
     * [new branch]      backport-19789-to-v2.0-branch -> origin/backport-19789-to-v2.0-branch
     * [new branch]      backport-19792-to-v2.0-branch -> origin/backport-19792-to-v2.0-branch
     * [new branch]      backport-19819-to-v2.0-branch -> origin/backport-19819-to-v2.0-branch
     * [new branch]      backport-19920-to-v2.0-branch -> origin/backport-19920-to-v2.0-branch
     * [new branch]      backport-20354-to-v2.0-branch -> origin/backport-20354-to-v2.0-branch
     * [new branch]      bugfix/log_strdup_gatt -> origin/bugfix/log_strdup_gatt
     * [new branch]      topic-ble-llcp         -> origin/topic-ble-llcp
     * [new branch]      topic-gpio             -> origin/topic-gpio
     * [new branch]      topic-sensors          -> origin/topic-sensors
     * [new branch]      v1.10-branch           -> origin/v1.10-branch
     * [new branch]      v1.11-branch           -> origin/v1.11-branch
     * [new branch]      v1.12-branch           -> origin/v1.12-branch
     * [new branch]      v1.13-branch           -> origin/v1.13-branch
     * [new branch]      v1.14-branch           -> origin/v1.14-branch
     * [new branch]      v1.5-branch            -> origin/v1.5-branch
     * [new branch]      v1.6-branch            -> origin/v1.6-branch
     * [new branch]      v1.7-branch            -> origin/v1.7-branch
     * [new branch]      v1.8-branch            -> origin/v1.8-branch
     * [new branch]      v1.9-branch            -> origin/v1.9-branch
     * [new branch]      v2.0-branch            -> origin/v2.0-branch
     * [new branch]      v2.1-branch            -> origin/v2.1-branch
     * [new tag]         v1.10.0                -> v1.10.0
     * [new tag]         v1.10.0-rc1            -> v1.10.0-rc1
     * [new tag]         v1.10.0-rc2            -> v1.10.0-rc2
     * [new tag]         v1.10.0-rc3            -> v1.10.0-rc3
     * [new tag]         v1.11.0                -> v1.11.0
     * [new tag]         v1.11.0-rc1            -> v1.11.0-rc1
     * [new tag]         v1.11.0-rc2            -> v1.11.0-rc2
     * [new tag]         v1.11.0-rc3            -> v1.11.0-rc3
     * [new tag]         v1.12.0                -> v1.12.0
     * [new tag]         v1.12.0-rc1            -> v1.12.0-rc1
     * [new tag]         v1.12.0-rc2            -> v1.12.0-rc2
     * [new tag]         v1.12.0-rc3            -> v1.12.0-rc3
     * [new tag]         v1.13.0                -> v1.13.0
     * [new tag]         v1.13.0-rc1            -> v1.13.0-rc1
     * [new tag]         v1.13.0-rc2            -> v1.13.0-rc2
     * [new tag]         v1.13.0-rc3            -> v1.13.0-rc3
     * [new tag]         v1.14.0                -> v1.14.0
     * [new tag]         v1.14.0-rc1            -> v1.14.0-rc1
     * [new tag]         v1.14.0-rc2            -> v1.14.0-rc2
     * [new tag]         v1.14.0-rc3            -> v1.14.0-rc3
     * [new tag]         v1.14.1                -> v1.14.1
     * [new tag]         v1.14.1-rc1            -> v1.14.1-rc1
     * [new tag]         v1.14.1-rc2            -> v1.14.1-rc2
     * [new tag]         v1.14.1-rc3            -> v1.14.1-rc3
     * [new tag]         v1.2.0                 -> v1.2.0
     * [new tag]         v1.2.0-rc1             -> v1.2.0-rc1
     * [new tag]         v1.2.0-rc2             -> v1.2.0-rc2
     * [new tag]         v1.3.0                 -> v1.3.0
     * [new tag]         v1.3.0-rc1             -> v1.3.0-rc1
     * [new tag]         v1.3.0-rc2             -> v1.3.0-rc2
     * [new tag]         v1.4.0                 -> v1.4.0
     * [new tag]         v1.4.0-rc1             -> v1.4.0-rc1
     * [new tag]         v1.4.0-rc2             -> v1.4.0-rc2
     * [new tag]         v1.4.0-rc3             -> v1.4.0-rc3
     * [new tag]         v1.5.0                 -> v1.5.0
     * [new tag]         v1.5.0-rc0             -> v1.5.0-rc0
     * [new tag]         v1.5.0-rc1             -> v1.5.0-rc1
     * [new tag]         v1.5.0-rc2             -> v1.5.0-rc2
     * [new tag]         v1.5.0-rc3             -> v1.5.0-rc3
     * [new tag]         v1.5.0-rc4             -> v1.5.0-rc4
     * [new tag]         v1.6.0                 -> v1.6.0
     * [new tag]         v1.6.0-rc1             -> v1.6.0-rc1
     * [new tag]         v1.6.0-rc2             -> v1.6.0-rc2
     * [new tag]         v1.6.0-rc3             -> v1.6.0-rc3
     * [new tag]         v1.6.0-rc4             -> v1.6.0-rc4
     * [new tag]         v1.6.1                 -> v1.6.1
     * [new tag]         v1.6.1-rc              -> v1.6.1-rc
     * [new tag]         v1.6.99                -> v1.6.99
     * [new tag]         v1.7.0                 -> v1.7.0
     * [new tag]         v1.7.0-rc1             -> v1.7.0-rc1
     * [new tag]         v1.7.0-rc2             -> v1.7.0-rc2
     * [new tag]         v1.7.0-rc3             -> v1.7.0-rc3
     * [new tag]         v1.7.0-rc4             -> v1.7.0-rc4
     * [new tag]         v1.7.1                 -> v1.7.1
     * [new tag]         v1.7.1-rc              -> v1.7.1-rc
     * [new tag]         v1.7.99                -> v1.7.99
     * [new tag]         v1.8.0                 -> v1.8.0
     * [new tag]         v1.8.0-rc1             -> v1.8.0-rc1
     * [new tag]         v1.8.0-rc2             -> v1.8.0-rc2
     * [new tag]         v1.8.0-rc3             -> v1.8.0-rc3
     * [new tag]         v1.8.0-rc4             -> v1.8.0-rc4
     * [new tag]         v1.8.99                -> v1.8.99
     * [new tag]         v1.9.0                 -> v1.9.0
     * [new tag]         v1.9.0-rc1             -> v1.9.0-rc1
     * [new tag]         v1.9.0-rc2             -> v1.9.0-rc2
     * [new tag]         v1.9.0-rc3             -> v1.9.0-rc3
     * [new tag]         v1.9.0-rc4             -> v1.9.0-rc4
     * [new tag]         v1.9.1                 -> v1.9.1
     * [new tag]         v1.9.2                 -> v1.9.2
     * [new tag]         v2.0.0                 -> v2.0.0
     * [new tag]         v2.0.0-rc1             -> v2.0.0-rc1
     * [new tag]         v2.0.0-rc2             -> v2.0.0-rc2
     * [new tag]         v2.0.0-rc3             -> v2.0.0-rc3
     * [new tag]         v2.1.0                 -> v2.1.0
     * [new tag]         v2.1.0-rc1             -> v2.1.0-rc1
     * [new tag]         v2.1.0-rc2             -> v2.1.0-rc2
     * [new tag]         v2.1.0-rc3             -> v2.1.0-rc3
     * [new tag]         zephyr-v1.0.0          -> zephyr-v1.0.0
     * [new tag]         zephyr-v1.1.0          -> zephyr-v1.1.0
     * [new tag]         zephyr-v1.10.0         -> zephyr-v1.10.0
     * [new tag]         zephyr-v1.11.0         -> zephyr-v1.11.0
     * [new tag]         zephyr-v1.12.0         -> zephyr-v1.12.0
     * [new tag]         zephyr-v1.13.0         -> zephyr-v1.13.0
     * [new tag]         zephyr-v1.14.0         -> zephyr-v1.14.0
     * [new tag]         zephyr-v1.14.1         -> zephyr-v1.14.1
     * [new tag]         zephyr-v1.2.0          -> zephyr-v1.2.0
     * [new tag]         zephyr-v1.3.0          -> zephyr-v1.3.0
     * [new tag]         zephyr-v1.4.0          -> zephyr-v1.4.0
     * [new tag]         zephyr-v1.5.0          -> zephyr-v1.5.0
     * [new tag]         zephyr-v1.6.0          -> zephyr-v1.6.0
     * [new tag]         zephyr-v1.6.1          -> zephyr-v1.6.1
     * [new tag]         zephyr-v1.7.0          -> zephyr-v1.7.0
     * [new tag]         zephyr-v1.7.1          -> zephyr-v1.7.1
     * [new tag]         zephyr-v1.8.0          -> zephyr-v1.8.0
     * [new tag]         zephyr-v1.9.0          -> zephyr-v1.9.0
     * [new tag]         zephyr-v1.9.1          -> zephyr-v1.9.1
     * [new tag]         zephyr-v1.9.2          -> zephyr-v1.9.2
     * [new tag]         zephyr-v2.0.0          -> zephyr-v2.0.0
     * [new tag]         zephyr-v2.1.0          -> zephyr-v2.1.0
    05f0d85b6a93ff1471e2fd9133a940a50cc11666 refs/remotes/origin/master
    Checking out files: 100% (10837/10837), done.
    Already on 'master'
    Receiving objects: 100% (3276/3276), 935.02 KiB | 5.67 MiB/s, done.
    Already on 'master'
    I had those error messages like you.
    In the beginning, it is the python version. It seems you already fixed that.
    You could refer to this tutorial to update the NCS version.
    The error while initiating a new ncs folder:
     I would suggest that create a new folder named ncs and Initialize west with the revision of the nRF Connect SDK that you want to check out. Please see Getting the nRF Connect SDK code
    Fullscreen
    1
    2
    3
    pip3 install west
    west init -m https://github.com/NordicPlayground/fw-nrfconnect-nrf --mr v1.1.0
    west update
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    -Amanda H.
  • I am following the steps you have provided
    1) Create a new folder named ncs
    2) pip3 install west
    C:\Projects\PCDWorks\nrf9160_110\ncs>pip3 install west
    Requirement already satisfied: west in c:\python37\lib\site-packages (0.5.8)
    Requirement already satisfied: colorama in c:\python37\lib\site-packages (from west) (0.4.1)
    Requirement already satisfied: PyYAML in c:\python37\lib\site-packages (from west) (4.2b4)
    Requirement already satisfied: pykwalify in c:\python37\lib\site-packages (from west) (1.7.0)
    Requirement already satisfied: configobj in c:\python37\lib\site-packages (from west) (5.0.6)
    Requirement already satisfied: python-dateutil>=2.4.2 in c:\python37\lib\site-packages (from pykwalify->west) (2.8.0)
    Requirement already satisfied: docopt>=0.6.2 in c:\python37\lib\site-packages (from pykwalify->west) (0.6.2)
    Requirement already satisfied: six in c:\python37\lib\site-packages (from configobj->west) (1.12.0)
    WARNING: You are using pip version 19.2.1, however version 20.0.1 is available.
    You should consider upgrading via the 'python -m pip install --upgrade pip' command.
    3) west init -m github.com/.../fw-nrfconnect-nrf --mr v1.1.0
    This gives errors that you see at the end
    C:\Projects\PCDWorks\nrf9160_110\ncs>west init -m github.com/.../fw-nrfconnect-nrf --mr v1.1.0
    [92m=== Cloning manifest repository from https://github.com/NordicPlayground/fw-nrfconnect-nrf, rev. v1.1.0 into C:\Projects\PCDWorks\nrf9160_110\ncs\.west\tmp
    remote: Enumerating objects: 35, done.
    remote: Counting objects: 100% (35/35), done.
    remote: Compressing objects: 100% (34/34), done.
    remote: Total 23083 (delta 9), reused 3 (delta 0), pack-reused 23048
    Receiving objects: 100% (23083/23083), 9.05 MiB | 4.85 MiB/s, done.
    Resolving deltas: 100% (15920/15920), done.
    From https://github.com/NordicPlayground/fw-nrfconnect-nrf
    remote: Total 3276 (delta 0), reused 0 (delta 0), pack-reused 3276
    Receiving objects: 100% (3276/3276), 935.02 KiB | 4.12 MiB/s, done.
    Already on 'master'
  • Also note the following link where I reported a similar error when trying to load in a project:
    devzone.nordicsemi.com/.../compile-error-for-nrf9160-lte_ble_gateway-project
    The only difference is that I updated the SDK from v1.0.0 to v1.1.0
    I was instructed to build at the command using the following command which did actually build:
    west build -b nrf9160_pca10090ns -d build -p
    but I get the following error when I use this command
    C:\Projects\PCDWorks\nRF9160\ncs\nrf\samples\nrf9160\aws_fota>west build -b nrf9160_pca10090ns -d build -p
    validation.invalid
        wrap(wrap_argv)
        complaint))
1 2 3 4 5 »
