ble_app_uart combined with ble_app_hrs: undefined reference
Hey guys,
I'm working with a Laird BL652-DVK (nrF 52832 - chip), Nordic SDK v.14.2.0 and SES (Segger Embedded Studio v.4.30). I am trying to combine the examples ble_app_uart and ble_app_hrs. Both examples are working separatly. But when I build my program, I'm getting "undefined reference errors" and I don't know why, because I changed my paths, config-file and makefile.?
For better understanding: I worked with the program ble_app_uart to send datas and string but that works only for the nordic app (phone and pc), because "pairing not supported". To send and receive datas and strings to a central ble modul (not programmed in C), I want to use the peer manager  for the data communication and use the example ble_app_hrs as reference. Maybe someone has another idea to solve this problem?
Here is my main.c:
 * Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdbool.h>  //peer manager
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_delay.h"  //delay header
//peer manager
#include "app_error.h"
#include "ble.h"
#include "ble_srv_common.h"
#include "fds.h"
#include "peer_manager.h"
#include "ble_conn_state.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_FEATURE_NOT_SUPPORTED       BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2        /**< Reply when unsupported features are requested. */
#define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS      180                                         /**< The advertising timeout (in units of seconds). */
#define APP_ADV_DURATION                18000                                   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
BLE_NUS_DEF(m_nus);        /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
static void advertising_start(bool erase_bonds);
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
///PEER FUNCTIONS
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    ret_code_t err_code;
    switch (p_evt->evt_id)
        case PM_EVT_BONDED_PEER_CONNECTED:
            NRF_LOG_INFO("Connected to a previously bonded device.");
        } break;
        case PM_EVT_CONN_SEC_SUCCEEDED:
            NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
                         ble_conn_state_role(p_evt->conn_handle),
                         p_evt->conn_handle,
                         p_evt->params.conn_sec_succeeded.procedure);
        } break;
        case PM_EVT_CONN_SEC_FAILED:
            /* Often, when securing fails, it shouldn't be restarted, for security reasons.
             * Other times, it can be restarted directly.
             * Sometimes it can be restarted, but only after changing some Security Parameters.
             * Sometimes, it cannot be restarted until the link is disconnected and reconnected.
             * Sometimes it is impossible, to secure the link, or the peer device does not support it.
             * How to handle this error is highly application dependent. */
        } break;
        case PM_EVT_CONN_SEC_CONFIG_REQ:
            // Reject pairing request from an already bonded peer.
            pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
            pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
        } break;
        case PM_EVT_STORAGE_FULL:
            // Run garbage collection on the flash.
            err_code = fds_gc();
            if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
                // Retry.
        } break;
            advertising_start(false);
        } break;
        case PM_EVT_PEER_DATA_UPDATE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
        } break;
        case PM_EVT_PEER_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
        } break;
        case PM_EVT_PEERS_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
        } break;
        case PM_EVT_ERROR_UNEXPECTED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
        } break;
        case PM_EVT_CONN_SEC_START:
        case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
        case PM_EVT_PEER_DELETE_SUCCEEDED:
        case PM_EVT_LOCAL_DB_CACHE_APPLIED:
        case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
            // This can happen when the local DB has changed.
        case PM_EVT_SERVICE_CHANGED_IND_SENT:
        case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
    APP_ERROR_HANDLER(nrf_error);
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_nus    Nordic UART Service structure.
 * @param[in] p_data   Data to be send to UART module.
 * @param[in] length   Length of the data.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length-1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
    uint32_t       err_code;
    ble_nus_init_t nus_init;
    //NUS
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    NRF_LOG_INFO("CONN_PARAMS_ERROR_HANDLER!");    //XXXXXXXXXXXX
    NRF_LOG_INFO("SLEEP_MODE_ENETR!");    //XXXXXXXXXXXX
    // Prepare wakeup buttons.
    uint32_t err_code;
    NRF_LOG_INFO("ON_ADV_EVT!");    //XXXXXXXXXXXX
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("BLE_ADV_EVT_FAST!");    //XXXXXXXXXXXX
        case BLE_ADV_EVT_IDLE:
            NRF_LOG_INFO("BLE_ADV_EVT_IDLE!");    //XXXXXXXXXXXX
            sleep_mode_enter();
            NRF_LOG_INFO("Default!");    //XXXXXXXXXXXX
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
#ifndef S140
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
#if !defined (S112)
         case BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST:
            ble_gap_data_length_params_t dl_params;
            // Clearing the struct will effectivly set members to @ref BLE_GAP_DATA_LENGTH_AUTO
            memset(&dl_params, 0, sizeof(ble_gap_data_length_params_t));
            err_code = sd_ble_gap_data_length_update(p_ble_evt->evt.gap_evt.conn_handle, &dl_params, NULL);
        } break;
#endif //!defined (S112)
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
        case BLE_EVT_USER_MEM_REQUEST:
            NRF_LOG_INFO("BLE_EVT_USER_MEM_REQUEST.");
            err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
            NRF_LOG_INFO("err_code: ");
        case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
            NRF_LOG_INFO("BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST.");
            ble_gatts_evt_rw_authorize_request_t  req;
            ble_gatts_rw_authorize_reply_params_t auth_reply;
            req = p_ble_evt->evt.gatts_evt.params.authorize_request;
            NRF_LOG_INFO("req: ");
            if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                    (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                    (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                    if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                        auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                        NRF_LOG_INFO("auth_reply.type: ");
                        auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                    auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                    NRF_LOG_INFO("APP_FEATURE_NOT_SUPPORTED: ");
                    err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
                                                               &auth_reply);
                    NRF_LOG_INFO("Err_code: ");
        } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
            // No implementation needed.
//dispatch BLE events to the peer manager
//this must be called before any event handler uses this module
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
    ble_conn_state_on_ble_evt(p_ble_evt);
    ble_conn_params_on_ble_evt(p_ble_evt);
    pm_on_ble_evt(p_ble_evt);
    ble_nus_on_ble_evt(&m_nus, p_ble_evt);
    ble_advertising_on_ble_evt(p_ble_evt);
    bsp_btn_ble_on_ble_evt(p_ble_evt);
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    uint32_t ram_start = 0;
    // Enable BLE stack.
    NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, ble_evt_handler, NULL);     //BLE event interrupt
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, 64);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
                do
                    err_code = ble_nus_string_send(&m_nus, data_array, &length);
                    if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) )
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    //init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.advdata.flags                = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    //init.config.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
/**@brief Function for placing the application in low power state while waiting for events.
static void power_manage(void)
    uint32_t err_code = sd_app_evt_wait();
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Application main function.
    uint32_t err_code;
    bool     erase_bonds;
    // Initialize.
    err_code = app_timer_init();
    uart_init();
    log_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    peer_manager_init();
    printf("\r\nUART Start!\r\n");
    NRF_LOG_INFO("UART Start!");
    NRF_LOG_INFO("BLE advertising done!");
    static uint8_t DecArrWHO[] = {56};
    uint16_t length = sizeof(DecArrWHO);
    // Enter main loop.
    for (;;)
        ble_nus_string_send(&m_nus, DecArrWHO, &length);
        nrf_delay_ms(500);        //delay fuer Anzeige in Termite, fuer Debugging nicht benoetigt
Here is my config_sdk.c:
sdk_config.h
And here is my makefile:
PROJECT_NAME     := ble_app_uart_pca10040_s132
TARGETS          := nrf52832_xxaa
OUTPUT_DIRECTORY := _build
SDK_ROOT := ../../../../../..
PROJ_DIR := ../../..
$(OUTPUT_DIRECTORY)/nrf52832_xxaa.out: \
  LINKER_SCRIPT  := ble_app_uart_gcc_nrf52.ld
# Source files common to all targets
SRC_FILES += \
  $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_backend_rtt.c \
  $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_backend_serial.c \
  $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_backend_uart.c \
  $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_default_backends.c \
  $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_frontend.c \
  $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_str_formatter.c \
  $(SDK_ROOT)/components/libraries/button/app_button.c \
  $(SDK_ROOT)/components/libraries/util/app_error.c \
  $(SDK_ROOT)/components/libraries/util/app_error_weak.c \
  $(SDK_ROOT)/components/libraries/fifo/app_fifo.c \
  $(SDK_ROOT)/components/libraries/scheduler/app_scheduler.c \
  $(SDK_ROOT)/components/libraries/timer/app_timer.c \
  $(SDK_ROOT)/components/libraries/uart/app_uart_fifo.c \
  $(SDK_ROOT)/components/libraries/util/app_util_platform.c \
  $(SDK_ROOT)/components/libraries/crc16/crc16.c \
  $(SDK_ROOT)/components/libraries/fds/fds.c \
  $(SDK_ROOT)/components/libraries/hardfault/hardfault_implementation.c \
  $(SDK_ROOT)/components/libraries/util/nrf_assert.c \
  $(SDK_ROOT)/components/libraries/atomic_fifo/nrf_atfifo.c \
  $(SDK_ROOT)/components/libraries/balloc/nrf_balloc.c \
  $(SDK_ROOT)/external/fprintf/nrf_fprintf.c \
  $(SDK_ROOT)/external/fprintf/nrf_fprintf_format.c \
  $(SDK_ROOT)/components/libraries/fstorage/nrf_fstorage.c \
  $(SDK_ROOT)/components/libraries/fstorage/nrf_fstorage_sd.c \
  $(SDK_ROOT)/components/libraries/experimental_memobj/nrf_memobj.c \
  $(SDK_ROOT)/components/libraries/pwr_mgmt/nrf_pwr_mgmt.c \
  $(SDK_ROOT)/components/libraries/experimental_section_vars/nrf_section_iter.c \
  $(SDK_ROOT)/components/libraries/strerror/nrf_strerror.c \
  $(SDK_ROOT)/components/libraries/uart/retarget.c \
  $(SDK_ROOT)/components/libraries/util/sdk_mapped_flags.c \
  $(SDK_ROOT)/components/boards/boards.c \
  $(SDK_ROOT)/components/drivers_nrf/clock/nrf_drv_clock.c \
  $(SDK_ROOT)/components/drivers_nrf/common/nrf_drv_common.c \
  $(SDK_ROOT)/components/drivers_nrf/gpiote/nrf_drv_gpiote.c \
  $(SDK_ROOT)/components/drivers_nrf/uart/nrf_drv_uart.c \
  $(SDK_ROOT)/components/libraries/bsp/bsp.c \
  $(SDK_ROOT)/components/libraries/bsp/bsp_btn_ble.c \
  $(SDK_ROOT)/components/libraries/bsp/bsp_nfc.c \
  $(PROJ_DIR)/main.c \
  $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT.c \
  $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_Syscalls_GCC.c \
  $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_printf.c \
  $(SDK_ROOT)/components/ble/common/ble_advdata.c \
  $(SDK_ROOT)/components/ble/ble_advertising/ble_advertising.c \
  $(SDK_ROOT)/components/ble/common/ble_conn_params.c \
  $(SDK_ROOT)/components/ble/common/ble_conn_state.c \
  $(SDK_ROOT)/components/ble/common/ble_srv_common.c \
  $(SDK_ROOT)/components/ble/peer_manager/gatt_cache_manager.c \
  $(SDK_ROOT)/components/ble/peer_manager/gatts_cache_manager.c \
  $(SDK_ROOT)/components/ble/peer_manager/id_manager.c \
  $(SDK_ROOT)/components/ble/nrf_ble_gatt/nrf_ble_gatt.c \
  $(SDK_ROOT)/components/ble/nrf_ble_qwr/nrf_ble_qwr.c \
  $(SDK_ROOT)/components/ble/peer_manager/peer_data_storage.c \
  $(SDK_ROOT)/components/ble/peer_manager/peer_database.c \
  $(SDK_ROOT)/components/ble/peer_manager/peer_id.c \
  $(SDK_ROOT)/components/ble/peer_manager/peer_manager.c \
  $(SDK_ROOT)/components/ble/peer_manager/pm_buffer.c \
  $(SDK_ROOT)/components/ble/peer_manager/pm_mutex.c \
  $(SDK_ROOT)/components/ble/peer_manager/security_dispatcher.c \
  $(SDK_ROOT)/components/ble/peer_manager/security_manager.c \
  $(SDK_ROOT)/components/toolchain/gcc/gcc_startup_nrf52.S \
  $(SDK_ROOT)/components/toolchain/system_nrf52.c \
  $(SDK_ROOT)/components/ble/ble_services/ble_bas/ble_bas.c \
  $(SDK_ROOT)/components/ble/ble_services/ble_dis/ble_dis.c \
  $(SDK_ROOT)/components/ble/ble_services/ble_hrs/ble_hrs.c \
  $(SDK_ROOT)/components/ble/ble_services/ble_nus/ble_nus.c \
  $(SDK_ROOT)/components/softdevice/common/nrf_sdh.c \
  $(SDK_ROOT)/components/softdevice/common/nrf_sdh_ble.c \
  $(SDK_ROOT)/components/softdevice/common/nrf_sdh_soc.c \
# Include folders common to all targets
INC_FOLDERS += \
  $(SDK_ROOT)/components/drivers_nrf/comp \
  $(SDK_ROOT)/components/drivers_nrf/twi_master \
  $(SDK_ROOT)/components/ble/ble_services/ble_ancs_c \
  $(SDK_ROOT)/components/ble/ble_services/ble_ias_c \
  $(SDK_ROOT)/components/libraries/pwm \
  $(SDK_ROOT)/components/softdevice/s132/headers/nrf52 \
  $(SDK_ROOT)/components/libraries/usbd/class/cdc/acm \
  $(SDK_ROOT)/components/libraries/usbd/class/hid/generic \
  $(SDK_ROOT)/components/libraries/usbd/class/msc \
  $(SDK_ROOT)/components/libraries/usbd/class/hid \
  $(SDK_ROOT)/components/libraries/experimental_log \
  $(SDK_ROOT)/components/ble/ble_services/ble_gls \
  $(SDK_ROOT)/components/libraries/fstorage \
  $(SDK_ROOT)/components/drivers_nrf/i2s \
  $(SDK_ROOT)/components/libraries/mutex \
  $(SDK_ROOT)/components/libraries/gpiote \
  $(SDK_ROOT)/components/libraries/experimental_log/src \
  $(SDK_ROOT)/components/drivers_nrf/gpiote \
  $(SDK_ROOT)/components/libraries/fifo \
  $(SDK_ROOT)/components/boards \
  $(SDK_ROOT)/components/libraries/experimental_memobj \
  $(SDK_ROOT)/components/drivers_nrf/common \
  $(SDK_ROOT)/components/ble/ble_advertising \
  $(SDK_ROOT)/components/ble/ble_services/ble_bas_c \
  $(SDK_ROOT)/components/ble/ble_services/ble_hrs_c \
  $(SDK_ROOT)/components/libraries/queue \
  $(SDK_ROOT)/components/libraries/pwr_mgmt \
  $(SDK_ROOT)/components/ble/ble_dtm \
  $(SDK_ROOT)/components/toolchain/cmsis/include \
  $(SDK_ROOT)/components/ble/ble_services/ble_rscs_c \
  $(SDK_ROOT)/components/drivers_nrf/uart \
  $(SDK_ROOT)/components/ble/common \
  $(SDK_ROOT)/components/ble/ble_services/ble_lls \
  $(SDK_ROOT)/components/drivers_nrf/wdt \
  $(SDK_ROOT)/components/libraries/bsp \
  $(SDK_ROOT)/components/ble/ble_services/ble_bas \
  $(SDK_ROOT)/components/libraries/experimental_section_vars \
  $(SDK_ROOT)/components/softdevice/s132/headers \
  $(SDK_ROOT)/components/ble/ble_services/ble_ans_c \
  $(SDK_ROOT)/components/libraries/slip \
  $(SDK_ROOT)/components/libraries/mem_manager \
  $(SDK_ROOT)/external/segger_rtt \
  $(SDK_ROOT)/components/libraries/usbd/class/cdc \
  $(SDK_ROOT)/components/drivers_nrf/hal \
  $(SDK_ROOT)/components/ble/ble_services/ble_nus_c \
  $(SDK_ROOT)/components/drivers_nrf/rtc \
  $(SDK_ROOT)/components/softdevice/common \
  $(SDK_ROOT)/components/ble/ble_services/ble_ias \
  $(SDK_ROOT)/components/libraries/usbd/class/hid/mouse \
  $(SDK_ROOT)/components/libraries/ecc \
  $(SDK_ROOT)/components/drivers_nrf/ppi \
  $(SDK_ROOT)/components/ble/ble_services/ble_dfu \
  $(SDK_ROOT)/external/fprintf \
  $(SDK_ROOT)/components/drivers_nrf/twis_slave \
  $(SDK_ROOT)/components/libraries/atomic \
  $(SDK_ROOT)/components \
  $(SDK_ROOT)/components/libraries/scheduler \
  $(SDK_ROOT)/components/libraries/cli \
  $(SDK_ROOT)/components/ble/ble_services/ble_lbs \
  $(SDK_ROOT)/components/ble/ble_services/ble_hts \
  $(SDK_ROOT)/components/drivers_nrf/delay \
  $(SDK_ROOT)/components/libraries/crc16 \
  $(SDK_ROOT)/components/drivers_nrf/timer \
  $(SDK_ROOT)/components/libraries/util \
  $(SDK_ROOT)/components/drivers_nrf/pwm \
  ../config \
  $(SDK_ROOT)/components/libraries/csense_drv \
  $(SDK_ROOT)/components/libraries/csense \
  $(SDK_ROOT)/components/libraries/balloc \
  $(SDK_ROOT)/components/libraries/low_power_pwm \
  $(SDK_ROOT)/components/libraries/hardfault \
  $(SDK_ROOT)/components/ble/ble_services/ble_cscs \
  $(SDK_ROOT)/components/libraries/uart \
  $(SDK_ROOT)/components/libraries/hci \
  $(SDK_ROOT)/components/libraries/usbd/class/hid/kbd \
  $(SDK_ROOT)/components/drivers_nrf/spi_slave \
  $(SDK_ROOT)/components/drivers_nrf/lpcomp \
  $(SDK_ROOT)/components/libraries/timer \
  $(SDK_ROOT)/components/drivers_nrf/rng \
  $(SDK_ROOT)/components/drivers_nrf/power \
  $(SDK_ROOT)/components/libraries/usbd/config \
  $(SDK_ROOT)/components/toolchain \
  $(SDK_ROOT)/components/libraries/led_softblink \
  $(SDK_ROOT)/components/drivers_nrf/qdec \
  $(SDK_ROOT)/components/ble/ble_services/ble_cts_c \
  $(SDK_ROOT)/components/drivers_nrf/spi_master \
  $(SDK_ROOT)/components/ble/ble_services/ble_nus \
  $(SDK_ROOT)/components/libraries/twi_mngr \
  $(SDK_ROOT)/components/ble/ble_services/ble_hids \
  $(SDK_ROOT)/components/libraries/strerror \
  $(SDK_ROOT)/components/drivers_nrf/pdm \
  $(SDK_ROOT)/components/libraries/crc32 \
  $(SDK_ROOT)/components/libraries/usbd/class/audio \
  $(SDK_ROOT)/components/ble/peer_manager \
  $(SDK_ROOT)/components/drivers_nrf/swi \
  $(SDK_ROOT)/components/ble/ble_services/ble_tps \
  $(SDK_ROOT)/components/ble/ble_services/ble_dis \
  $(SDK_ROOT)/components/device \
  $(SDK_ROOT)/components/ble/nrf_ble_gatt \
  $(SDK_ROOT)/components/ble/nrf_ble_qwr \
  $(SDK_ROOT)/components/libraries/button \
  $(SDK_ROOT)/components/libraries/usbd \
  $(SDK_ROOT)/components/drivers_nrf/saadc \
  $(SDK_ROOT)/components/libraries/atomic_fifo \
  $(SDK_ROOT)/components/ble/ble_services/ble_lbs_c \
  $(SDK_ROOT)/components/ble/ble_racp \
  $(SDK_ROOT)/components/toolchain/gcc \
  $(SDK_ROOT)/components/libraries/fds \
  $(SDK_ROOT)/components/libraries/twi \
  $(SDK_ROOT)/components/drivers_nrf/clock \
  $(SDK_ROOT)/components/ble/ble_services/ble_rscs \
  $(SDK_ROOT)/components/drivers_nrf/usbd \
  $(SDK_ROOT)/components/ble/ble_services/ble_hrs \
# Libraries common to all targets
LIB_FILES += \
# Optimization flags
OPT = -O3 -g3
# Uncomment the line below to enable link time optimization
#OPT += -flto
# C flags common to all targets
CFLAGS += $(OPT)
CFLAGS += -DBOARD_PCA10040
CFLAGS += -DCONFIG_GPIO_AS_PINRESET
CFLAGS += -DFLOAT_ABI_HARD
CFLAGS += -DNRF52
CFLAGS += -DNRF52832_XXAA
CFLAGS += -DNRF52_PAN_74
CFLAGS += -DNRF_SD_BLE_API_VERSION=5
CFLAGS += -DS132
CFLAGS += -DSOFTDEVICE_PRESENT
CFLAGS += -DSWI_DISABLE0
CFLAGS += -mcpu=cortex-m4
CFLAGS += -mthumb -mabi=aapcs
CFLAGS +=  -Wall -Werror
CFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
# keep every function in a separate section, this allows linker to discard unused ones
CFLAGS += -ffunction-sections -fdata-sections -fno-strict-aliasing
CFLAGS += -fno-builtin -fshort-enums
# C++ flags common to all targets
CXXFLAGS += $(OPT)
# Assembler flags common to all targets
ASMFLAGS += -g3
ASMFLAGS += -mcpu=cortex-m4
ASMFLAGS += -mthumb -mabi=aapcs
ASMFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
ASMFLAGS += -DBOARD_PCA10040
ASMFLAGS += -DCONFIG_GPIO_AS_PINRESET
ASMFLAGS += -DFLOAT_ABI_HARD
ASMFLAGS += -DNRF52
ASMFLAGS += -DNRF52832_XXAA
ASMFLAGS += -DNRF52_PAN_74
ASMFLAGS += -DNRF_SD_BLE_API_VERSION=5
ASMFLAGS += -DS132
ASMFLAGS += -DSOFTDEVICE_PRESENT
ASMFLAGS += -DSWI_DISABLE0
# Linker flags
LDFLAGS += $(OPT)
LDFLAGS += -mthumb -mabi=aapcs -L $(TEMPLATE_PATH) -T$(LINKER_SCRIPT)
LDFLAGS += -mcpu=cortex-m4
LDFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
# let linker dump unused sections
LDFLAGS += -Wl,--gc-sections
# use newlib in nano version
LDFLAGS += --specs=nano.specs
# Add standard libraries at the very end of the linker input, after all objects
# that may need symbols provided by these libraries.
LIB_FILES += -lc -lnosys -lm
.PHONY: default help
# Default target - first one defined
default: nrf52832_xxaa
# Print all targets that can be built
help:
	@echo following targets are available:
	@echo		nrf52832_xxaa
	@echo		flash_softdevice
	@echo		sdk_config - starting external tool for editing sdk_config.h
	@echo		flash      - flashing binary
TEMPLATE_PATH := $(SDK_ROOT)/components/toolchain/gcc
include $(TEMPLATE_PATH)/Makefile.common
$(foreach target, $(TARGETS), $(call define_target, $(target)))
.PHONY: flash flash_softdevice erase
# Flash the program
flash: $(OUTPUT_DIRECTORY)/nrf52832_xxaa.hex
	@echo Flashing: $<
	nrfjprog -f nrf52 --program $< --sectorerase
	nrfjprog -f nrf52 --reset
# Flash softdevice
flash_softdevice:
	@echo Flashing: s132_nrf52_5.0.0_softdevice.hex
	nrfjprog -f nrf52 --program $(SDK_ROOT)/components/softdevice/s132/hex/s132_nrf52_5.0.0_softdevice.hex --sectorerase
erase:
	nrfjprog -f nrf52 --eraseall
SDK_CONFIG_FILE := ../config/sdk_config.h
CMSIS_CONFIG_TOOL := $(SDK_ROOT)/external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar
sdk_config:
	java -jar $(CMSIS_CONFIG_TOOL) $(SDK_CONFIG_FILE)
With main.c posted above I'm getting this errors:
Building ‘ble_app_uart_pca10040_s132’ from solution ‘ble_app_uart_pca10040_s132’ in configuration ‘Debug’
  Compiling ‘main.c’
  Linking ble_app_uart_pca10040_s132.elf
    Output/ble_app_uart_pca10040_s132 Debug/Obj/peer_manager.o: in function `ble_evt_handler':
    undefined reference to `im_ble_evt_handler'
    M:\Programme\C\nRF5_SDK_14.2.0_17b948a\components\ble\peer_manager/peer_manager.c:294: undefined reference to `sm_ble_evt_handler'
    M:\Programme\C\nRF5_SDK_14.2.0_17b948a\components\ble\peer_manager/peer_manager.c:295: undefined reference to `gcm_ble_evt_handler'
    Output/ble_app_uart_pca10040_s132 Debug/Obj/peer_manager.o: in function `pm_init':
    undefined reference to `pds_init'
    M:\Programme\C\nRF5_SDK_14.2.0_17b948a\components\ble\peer_manager/peer_manager.c:321: undefined reference to `pdb_init'
    M:\Programme\C\nRF5_SDK_14.2.0_17b948a\components\ble\peer_manager/peer_manager.c:327: undefined reference to `sm_init'
    M:\Programme\C\nRF5_SDK_14.2.0_17b948a\components\ble\peer_manager/peer_manager.c:333: undefined reference to `smd_init'
    M:\Programme\C\nRF5_SDK_14.2.0_17b948a\components\ble\peer_manager/peer_manager.c:339: undefined reference to `gcm_init'
    M:\Programme\C\nRF5_SDK_14.2.0_17b948a\components\ble\peer_manager/peer_manager.c:345: undefined reference to `gscm_init'
    M:\Programme\C\nRF5_SDK_14.2.0_17b948a\components\ble\peer_manager/peer_manager.c:351: undefined reference to `im_init'
    Output/ble_app_uart_pca10040_s132 Debug/Obj/peer_manager.o: in function `pm_sec_params_set':
    undefined reference to `sm_sec_params_set'
    Output/ble_app_uart_pca10040_s132 Debug/Obj/peer_manager.o: in function `pm_conn_sec_config_reply':
    undefined reference to `sm_conn_sec_config_reply'
    Output/ble_app_uart_pca10040_s132 Debug/Obj/peer_manager.o: in function `pm_peer_delete':
    undefined reference to `im_peer_free'
    Output/ble_app_uart_pca10040_s132 Debug/Obj/peer_manager.o: in function `pm_peers_delete':
    undefined reference to `pdb_next_peer_id_get'
    M:\Programme\C\nRF5_SDK_14.2.0_17b948a\components\ble\peer_manager/peer_manager.c:820: undefined reference to `pdb_next_peer_id_get'
Build failed
If I activate my dispatch_function in main.c (commented out at the moment):
I'm getting this error:
  Compiling ‘main.c’
    implicit declaration of function 'ble_conn_state_on_ble_evt'; did you mean 'ble_conn_state_conn_idx'? [-Wimplicit-function-declaration]
    implicit declaration of function 'ble_conn_params_on_ble_evt'; did you mean 'ble_conn_params_init'? [-Wimplicit-function-declaration]
    implicit declaration of function 'pm_on_ble_evt'; did you mean 'on_adv_evt'? [-Wimplicit-function-declaration]
    passing argument 1 of 'ble_nus_on_ble_evt' from incompatible pointer type [-Wincompatible-pointer-types]
    main.c
    expected 'const ble_evt_t *' {aka 'const struct <anonymous> *'} but argument is of type 'ble_nus_t *' {aka 'struct ble_nus_s *'}
    implicit declaration of function 'on_ble_evt'; did you mean 'on_adv_evt'? [-Wimplicit-function-declaration]
    too few arguments to function 'ble_advertising_on_ble_evt'
    main.c
    declared here
    implicit declaration of function 'bsp_btn_ble_on_ble_evt'; did you mean 'nrf_ble_qwr_on_ble_evt'? [-Wimplicit-function-declaration]
Build failed
I hope someone can help me.
Thanks in advance
Christoph
