low current value in sleep_mode_enter ()
I am using
  • Custom Board(nRF52840)
  • SDK 15.3.0
  • Keil IDE
  • The soft device is S140
  • JLinkRTTViewer for debug
My board has two leds and two buttons for door open / close.
When entering the System Off mode using the sleep_mode_enter () function, the current consumption varies between 11uA and 34uA.
I know that current consumption is less than 1uA when in System Off mode.
Please advise.
Alex
    // Initialize.
	gpio_led_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    conn_params_init();
	sleep_mode_enter();
  • You may check out:
    https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/optimizing-power-on-nrf52-designs
    I suspect floating input pin; for instance you have configured a pin as input, however the pin is not connected to a defined level (e.g. low or high).
  • Hi Kenneth,
    Thank you for your kind reply.
    1. By enabling and populating the DC/DC converter
         #define POWER_ENABLED 1
         #define POWER_CONFIG_DEFAULT_DCDCEN 1
        err_code = sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
        Is it correct ?
    2. by enabling/populating the 32kHz LFCLK crystal
        I use BLE and the Advertising Interval is 1 second.
       Can I use the 32KHz LFCLK Crystal even in this case?
       How can I set if it is available?
    3. I suspect floating input pin
       I attach a function that initializes gpio and led.
       Each input pin has a hardware pull-up
       Alex
    void gpio_led_init(void)
       ret_code_t err_code;
        nrf_drv_gpiote_in_config_t gyro_int_config = NRFX_GPIOTE_RAW_CONFIG_IN_SENSE_HITOLO(false);
        gyro_int_config.pull = NRF_GPIO_PIN_NOPULL;			//200208 NRF_GPIO_PIN_PULLUP;
        err_code = nrf_drv_gpiote_in_init(PWR_CHK_DOOR_CLOSE, &gyro_int_config, door_close_handler);
        nrf_drv_gpiote_in_event_enable(PWR_CHK_DOOR_CLOSE, true);
    	nrf_drv_gpiote_in_config_t power_chk_int_config = NRFX_GPIOTE_RAW_CONFIG_IN_SENSE_HITOLO(false);
        power_chk_int_config.pull = NRF_GPIO_PIN_NOPULL;
        err_code = nrf_drv_gpiote_in_init(DOOR_OPEN, &power_chk_int_config, POWER_CHK_INT_handler);
        nrf_drv_gpiote_in_event_enable(DOOR_OPEN, true);
    	nrf_gpio_cfg_output(RED_LED);					// led port를 output으로 설정
    	nrf_gpio_cfg_output(BLUE_LED);
    	nrf_gpio_pin_set(RED_LED);
    	nrf_gpio_pin_set(BLUE_LED);
    	nrf_gpio_cfg_input(DOOR_OPEN, NRF_GPIO_PIN_NOPULL);
    	nrf_gpio_cfg_input(PWR_CHK_DOOR_CLOSE, NRF_GPIO_PIN_NOPULL);
  • HI,
    I am using s112 for 52810.
    I attached a hexa file.
    I always appreciate your kind response.
    Alex
    nrf52810_xxaa.hex
  • Hi, the code is resetting. It starts the LFXO which takes 250ms, and during this time it's in idle mode consuming about 2uA. Then something happens and it resets. It never reaches the SYSTEMOFF line. So the current bursts you are seeing is the chip resetting.
  • Hi Stian,
    Thank you for your quick and friendly reply.
    I agree with you too.
    But looking at the source code I can't figure out where this happens.
    I zip the program and attach it.
    I think it has entered SystemOff mode as the current draw drops to 0.6 ~ 0.7uA.
    Alex
    sokey - 52810.zip
  • Hello, you need to debug the application. Start the debugger and check the return values for all functions. Set breakpoints in main to see how far it goes before it resets.
    The cause of the reset is due to missing timers_init ().
    Added timers_init (), so conn_params_init () run successfully.
    The way to wakeup from systemoff is " devzone.nordicsemi.com/.../173257 " referenced.
    Current consumption ranges from 0.1uA to 0.2uA in SystemOff mode.
    Alex
