SDK 12.3.0 - spi slave example not working - Slave does not send back data to Master
it would seem that the Spi Slave example provided with the SDK 12.3.0 does not work correctly for the nRF51DK.
Setup:
Master SPI : STM30G070CB
Slave SPI : nF51DK
SDK : 12.3.0
BaudRate : 62.5 KBits/s
I am using the spi slave example except for the data to transmit back which have been changed :
#define TEST_STRING {'R','o','g','e','r'}
static uint8_t m_tx_buf[5] = TEST_STRING; /**< TX buffer. */
static uint8_t m_rx_buf[5]; /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf); /**< Transfer length. */
So as you can see, the only thing I changed is the message sent back to the master SPI, as well as the buffer of the received message.
The SPI slave can receive the data correctly. I alternate between 'Allo!' and 'Bueno' in an indefinite loop to make sure that the message transition correctly.
However, when the data is received, the slave does not respond back with 'Roger' as it should.
As you can see on the screenshot above, the master SPI is sending either 'Allo!' or 'Bueno' and is expecting 5 characters backs ; the clock is the same length as the first 5 characters, with a clock pause of around 30 usec between the data sent by the master, and the master expecting data back.
When I look at the SPIS document on infocenter, there is no explanation of how the SPIS module works for the nRF51822. The product specification section on the SPI/SPIS is only a paragraph long and if there is any other information regarding the SPIS, it is hidden somewhere I am not aware of.
Since the example provided use easy DMA, I looked through other chips to see if any information was available and saw that the nRF52832 has a lot more explanation (it would seem like nRF52 products are a lot more detailed than nRF51, why is that? Should we use a nRF52 product instead of a nRF51?). In the SPIS section of the nRF52832 , in the slave operation section, I found this information :
If the SPI slave acquires the semaphore, the transaction will be granted. The incoming data on MOSI will be stored in the RXD buffer and the data in the TXD buffer will be clocked out on MISO.
When I look through the example code,  when the buffers are setup with APP_ERROR_CHECK(nrf_drv_spis_buffers_set(&spis, m_tx_buf, m_length, m_rx_buf, m_length)); , if I step into the code :
nrf_drv_spis_buffers_set -> spi_state_change -> spis_state_entry_action_execute
I can see that the SPIS module is taking the semaphore by using NRF_SPIS_TASK_ACQUIRE (nrf_spis_task_trigger(p_spis, NRF_SPIS_TASK_ACQUIRE);). Assuming that the information above about the semaphore is applicable for the nRF51822, the SPIS module should output 'Roger' on the MISO line. But, on a period of 5 seconds, the MISO line is never active once.
So what am I missing here? Is there any other information I should have read that I missed in the product specification because the SPI/SPIS section is pretty barren.
  • So I loaded the Master SPI code on the devkit and I loaded the SPIS code on a custom board that we have (that I know works because I was able to load the BLE_UART examples correctly) just as a sanity check.
    The only modification I made to the code of the master SPI is alternating between "Nordic" and "Shrimp" as a way to make sure that the message is received correctly by the slave.
        bsp_board_leds_init();
        NRF_LOG_INFO("SPI example\r\n");
        nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
        spi_config.ss_pin   = SPI_SS_PIN;
        spi_config.miso_pin = SPI_MISO_PIN;
        spi_config.mosi_pin = SPI_MOSI_PIN;
        spi_config.sck_pin  = SPI_SCK_PIN;
        APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler));
        while (1)
            // Reset rx buffer and transfer done flag
            memset(m_rx_buf, 0, m_length);
            spi_xfer_done = false;
            APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length));
            while (!spi_xfer_done)
                __WFE();
            NRF_LOG_FLUSH();
            bsp_board_led_invert(BSP_BOARD_LED_0);
            if (m_tx_buf[0] == 'N')
                m_tx_buf[0] = 'S';
                m_tx_buf[1] = 'h';
                m_tx_buf[2] = 'r';
                m_tx_buf[3] = 'i';
                m_tx_buf[4] = 'm';
                m_tx_buf[5] = 'p';
                m_tx_buf[6] = 0x00;
                m_tx_buf[0] = 'N';
                m_tx_buf[1] = 'o';
                m_tx_buf[2] = 'r';
                m_tx_buf[3] = 'd';
                m_tx_buf[4] = 'i';
                m_tx_buf[5] = 'c';
                m_tx_buf[6] = 0x00;
            nrf_delay_ms(200);
    And again, the slave is not sending a response on the MISO line.
    In the documentation, it is explicitly said that to only have a one way communication, the buffer needs to be NULL. In the SPI master example, the buffer is not NULL and should clock out data on the MISO line as well.
    So the example is definitely not working as it should and I didn't find any information regarding this issue.
  • As another sanity check, I reversed the role of the custom board and the nRF51 dev kit, and the outcome is still the same. No data on the MISO line.
    Sorry for the delay. Have you had any progress on this in the meantime? I tried to reproduce this on my end by running the SPIS example from SDK 12.3.0 on the nRF51 DK. The only change I made was to change the text string. But as you can see from the screenshot below, it did work for me.
    Are you using the default pin assignments? Maybe you can try swapping MISO and MOSI and see if you get the same result?
    Also, it sounds like you may be looking for the nRF51 Reference Manual. This document is common for the nRF51 series and has a more function description of the peripherals compared to the product specification.
  • I did switch the pins on the custom board but not on the devkit. I was able to get a SPIS response after many power cycles -> erase chip - > reload softdevice hex file -> load IAR project.
    We are having a similar issue that we are currently discussing with Nordic support through emails where at one point, when we try to step into the code with IAR, we will get a RAMCode error pop-up that is fixed the same way as I was able to make this code work by power cycling and erasing the chip many times. We still don't know what is causing this (IAR or the chip or both not playing nice). The RAMCode was seen both on the Nordic DevKit and the custom boards, so I assume that this is the same kind of issue at play here.
    Incidentally, not long after having the issue with the SPIS code not outputting data, the RAMCode error appeared. I cannot say for sure that this is the issue, but at least I was able to make some progress so far.
    I guess this question can be closed, but I don't have any real answers as to why the code is working now and wasn't before.
  • Thanks for the update. I'm not sure how this debugger related issue could be related to the problem with MISO not outputting any data. I would suggest that you try updating the Jlink drivers and the MDK for IAR and see if helps.
    https://www.nordicsemi.com/Software-and-tools/Development-Tools/nRF-MDK
