app_uart_get more than 1 byte
I'm using app_uart for communication between different mcu. I can send more than 1 byte like "0x3917015623"  through  changing tx_buffer[0] to tx_buffer[5]. Unfortunately i couldn't recieve the slave devicess message "0x2917013607". I can only get the first byte "0x07". My configuration are the same as uart example. How can i recieve all the message ?. I tried to use serial library but i couldn't initialize. (It gave ERROR 6 NRF_ERROR_NOT_SUPPORTED).
Slave device is sending me a message every second. And i'm calling app_uart_get function every 500 miliseconds.
Here is my uart init;
void uart_error_handle(app_uart_evt_t * p_event)
    if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
    else if (p_event->evt_type == APP_UART_FIFO_ERROR)
void uart_init(void)
    uint32_t err_code;
    const app_uart_comm_params_t comm_params =
            RX_PIN_NUMBER,
            TX_PIN_NUMBER,
            RTS_PIN_NUMBER,
            CTS_PIN_NUMBER,
            UART_HWFC,
            false,
  #if defined (UART_PRESENT)
            NRF_UART_BAUDRATE_115200
  #else
            NRF_UARTE_BAUDRATE_9600
//    const app_uart_buffers_t m_buffers =
//        &rx_buffer_s,
//        sizeof(rx_buffer_s),
//        &tx_buffer_s,
//        sizeof(tx_buffer_s)
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_error_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
//      err_code = app_uart_init(&comm_params, &m_buffers, uart_error_handle, APP_IRQ_PRIORITY_LOW);
//      APP_ERROR_CHECK(err_code);
  • Yes, i can receive the data. But i have another problem with timeslot. I can't transmit data while timeslot enable. For example i added a button, when i pressed button, rs485_send_flag equals the true. Then transmiting will start. When transmitting is done i can catch NRF_SERIAL_EVENT_TX_DONE. But this scenerio happens when i comment the lines 44-53. When i uncomment these lines, i can recieve, but i can not transmit data.
            if(timer_overflow_3 >= 5)
              ++timer_overflow_4;
              timer_overflow_3=0;
              /* 500 ms works*/
              uint32_t err_code;
              ++motor_delay_counter;
              our_sensor_characteristic_update(&m_our_service, &SIGNAL_IN);
              our_trm_error_characteristic_update_2(&m_our_service, &TRM_IN);
              our_rx_characteristic_update(&m_our_service, &rx_data);
              if(rs485_send_flag)
                  ++tx_message[3];
                  err_code = nrf_serial_write(&serial_uart, &tx_message, sizeof(tx_message), NULL, 0);
                  (void)nrf_serial_flush(&serial_uart, 0);
    //          err_code = nrf_serial_write(&serial_uart, &tx_message, sizeof(tx_message), NULL, 0);
    //          ++tx_message[3];
    //          (void)nrf_serial_flush(&serial_uart, 0);
              if((motor_delay_counter > motor_delay) && (motor_stop_flag == false))
                  nrf_gpio_pin_set(MOTOR);
                  motor_delay_counter = 0;
                  // nrf_gpio_pin_set(TX_PIN_NUMBER);
    //  LIGHT STATUS EKLENECEK
            if(timer_overflow_4 >= 2)
              timer_overflow_4 = 0;
              /*1 sec works */
              ret_code_t ret_code;
              uint32_t err_code;
    //          if(!rs485_send_flag)
    //              err_code = request_next_event_earliest(); //timeslota gir
    //              if (err_code != NRF_SUCCESS)
    //                  (void)sd_radio_session_close();
    //                  return err_code;
              delete_record(MOTOR_DELAY_FILE_ID,MOTOR_DELAY_KEY);
              wait_for_fds_ready();
              record_write(MOTOR_DELAY_FILE_ID,MOTOR_DELAY_KEY,&motor_delay);
              //show_stats();
  • Hi Mehmet,
    The attached code runs in main() right? If so, then please attach the entire file. I can see any reason for you not being able to receive or send data via the UART when you're in a Timeslot. You should be able to freely use the UART peripheral, so I think this is unrelated to the Timeslot.
    I see that you call request_next_event_earliest() when the rs485_send_flag is false. PLease note that you can only call request_next_event_earliest() when you're in a Timeslot as this function writes directly to the RADIO registers.
    //                  return err_code;
    Best regards
    Bjørn
  • I will check the hardware again. For now i can insert my main.c and serial_timeslot.h.
    My main.c file:
    #include "Defination.h"
    static void advertising_start(bool erase_bonds);
    /**@brief Function for assert macro callback.
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    static void time_slot_soc_evt_handler(uint32_t evt_id, void * p_context)
              (evt_id);
    NRF_SDH_SOC_OBSERVER(m_time_slot_soc_observer, 0, time_slot_soc_evt_handler, NULL);
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module.
    static void timers_init(void)
        // Initialize timer module, making it use the scheduler
        ret_code_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising.");
    //            err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING);
            case BLE_ADV_EVT_IDLE:
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    		init.srdata.uuids_complete.p_uuids = m_adv_uuids;
        //init.config.ble_adv_fast_timeout  = APP_ADV_DURATION; //SREKL ADVCERTISING YAPMASINI STYORSAK DEVRE DII BIRAKILMALI
        APP_ERROR_HANDLER(nrf_error);
        uint32_t         err_code;
        //FROM_SERVICE_TUTORIAL: Add code to initialize the services used by the application.
        our_service_init(&m_our_service);
        //our_service_init_2(&m_our_service_2);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module that
     *          are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply
     *       setting the disconnect_on_fail config parameter, but instead we use the event
     *       handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
         if (erase_bonds == true)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    void advertising_stop(void)
        ret_code_t err_code = sd_ble_gap_adv_stop(&m_advertising);
    ret_code_t err_code = NRF_SUCCESS;
                      NRF_LOG_INFO("Disconnected.");
                  case BLE_GAP_EVT_CONNECTED:
                      NRF_LOG_INFO("Connected.");
    //                  err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
                      ble_gap_phys_t const phys =
                          .rx_phys = BLE_GAP_PHY_AUTO,
                          .tx_phys = BLE_GAP_PHY_AUTO,
                  case BLE_GATTC_EVT_TIMEOUT:
                  case BLE_GATTS_EVT_TIMEOUT:
                      // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
        NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, ble_our_service_on_ble_evt, &m_our_service);
        // Call ble_our_service_on_ble_evt() to do housekeeping of ble connections related to our service and characteristics
        NRF_SDH_BLE_OBSERVER(m_ble_observer_2, APP_BLE_OBSERVER_PRIO, ble_evt_handler, &m_our_service);        //ble_eventlerini gzlemliyor
    static void button_handler(uint8_t pin_no, uint8_t button_action)
      //Buttonlarin kac kere basildigini goster
      if(pin_no == BUTTON_ON && button_action == APP_BUTTON_PUSH)
        i++;
        if(i>3){
          i = 0;
          nrf_gpio_pin_set(RTS_PIN_NUMBER);
          rs485_send_flag = true;
        //button_status_check(i,&but_ON);
        button_on_flag = !button_on_flag;
        nrf_gpio_pin_toggle(LED_ON);
      if(pin_no == BUTTON_OFF && button_action == APP_BUTTON_PUSH)
        j++;
        if(j>3){
          j = 0;
    //    button_status_check(j,&but_OFF);
        button_off_flag = !button_off_flag;
        nrf_gpio_pin_toggle(LED_OFF);
      if(pin_no == BUTTON_LAMBA && button_action == APP_BUTTON_PUSH)
        k++;
        if(k>3){
          k = 0;
    //    button_status_check(k,&but_LAMB);
          button_lamba_flag = !button_lamba_flag;
          nrf_gpio_pin_toggle(LED_LAMBA);
      if(pin_no == BUTTON_MOTOR && button_action == APP_BUTTON_PUSH)
        l++;
        if(l>3){
          l = 0;
    //    button_status_check(l,&but_MOT);
          button_motor_flag = !button_motor_flag;
          nrf_gpio_pin_toggle(LED_MOTOR);
    static void app_buttons_init(void)
      static app_button_cfg_t buttons_cfg[4] = {
        {BUTTON_ON, APP_BUTTON_ACTIVE_LOW, NRF_GPIO_PIN_PULLUP, button_handler},
        {BUTTON_OFF, APP_BUTTON_ACTIVE_LOW, NRF_GPIO_PIN_PULLUP, button_handler},
        {BUTTON_LAMBA, APP_BUTTON_ACTIVE_LOW, NRF_GPIO_PIN_PULLUP, button_handler},
        {BUTTON_MOTOR, APP_BUTTON_ACTIVE_LOW, NRF_GPIO_PIN_PULLUP, button_handler}
      err_code = app_button_init(buttons_cfg,4,5);
      err_code = app_button_enable();
    static void log_init(void)
            nrf_pwr_mgmt_run();
    //2 msn de buraya gelecek
    void timer_event_handler(nrf_timer_event_t event_type, void * p_context)
        ++timer_overflow;
        nrf_gpio_pin_clear(PD_OUT);     //active high
        nrf_delay_us(25);
        nrf_gpio_pin_set(PD_OUT);
        nrf_delay_us(15);
        SIGNAL_IN = saadc_measure_SENSOR();    //Sensor measurement
        TRM_IN = saadc_measure_TRM();   //sensor error measurement
    /*-------------------------lm sonucu karar verme koulu-------------------------*/
        if(SIGNAL_IN > 790)               //2.78 V stndeyse engel yok demektir.
            if(accuracy_counter == 0)
    //                nrf_gpio_pin_set(MOTOR);
              motor_stop_flag = false;
              --accuracy_counter;
          else if(SIGNAL_IN < 767)        //2.70 V altndaysa engel var demektir.
            ++accuracy_counter;
            if(accuracy_counter > receiver_sample_counter)
              accuracy_counter = receiver_sample_counter;
    //          nrf_gpio_pin_clear(TX_PIN_NUMBER); //LED i yak
              nrf_gpio_pin_clear(MOTOR);         //MOTOR'u durdur
              motor_stop_flag = true;
    /*-----------------------------TRANSMITTER ERROR DETECT-------------------------------*/
         if((TRM_IN < 75)||(TRM_IN > 750))               //0.26 V den kk, 2.63 V dan bykse hata var.
            ++transmitter_detect_counter;
            if(transmitter_detect_counter > transmitter_error_sample_counter)
              transmitter_detect_counter = transmitter_error_sample_counter;
              trm_error_flag = true;
              nrf_gpio_pin_clear(RX_PIN_NUMBER);
           else                                           // normal alma kosulu ise
              if(transmitter_detect_counter > 0)
                --transmitter_detect_counter;
              if(transmitter_detect_counter ==0)
                  trm_error_flag = false;
                  nrf_gpio_pin_set(RX_PIN_NUMBER);
    static void timer_internal_init(void)
        // Configure the timer to use the default configuration set in sdk_config.h
        //Initializing the Timer driver
        err_code = nrf_drv_timer_init(&timer0, &timer_cfg, timer_event_handler);
        /*Configure the timer to generate the COMPARE event after 200*1000UL ticks and enable the shortcut that triggers the CLEAR task on every COMPARE event.
            This will */
        nrf_drv_timer_extended_compare(&timer0, NRF_TIMER_CC_CHANNEL0, nrf_drv_timer_ms_to_ticks(&timer0, 2), NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true); // Set last argument to false for Task 3
        nrf_drv_timer_enable(&timer0);  // Turning on the Timer.
    static void gpio_init(void)
      nrf_gpio_cfg_output(TX_PIN_NUMBER);
      nrf_gpio_cfg_output(RX_PIN_NUMBER);
      nrf_gpio_cfg_output(RTS_PIN_NUMBER);
      nrf_gpio_cfg_output(RELAY_2);
      nrf_gpio_cfg_output(RELAY_1);
      nrf_gpio_cfg_output(MOTOR);
      nrf_gpio_cfg_output(PD_OUT);
      nrf_gpio_cfg_output(LED_OFF);
      nrf_gpio_cfg_output(LED_ON);
      nrf_gpio_cfg_output(LED_LAMBA);
      nrf_gpio_cfg_output(LED_MOTOR);
      nrf_gpio_cfg_input(BUTTON_MOTOR,NRF_GPIO_PIN_PULLUP);
      nrf_gpio_cfg_input(BUTTON_ON,NRF_GPIO_PIN_PULLUP);
      nrf_gpio_cfg_input(BUTTON_OFF,NRF_GPIO_PIN_PULLUP);
      nrf_gpio_cfg_input(BUTTON_LAMBA,NRF_GPIO_PIN_PULLUP);
      nrf_gpio_pin_clear(LED_ON);  //aktif low
      nrf_gpio_pin_set(LED_OFF);   //aktif low
      nrf_gpio_pin_set(LED_LAMBA); //aktif low
      nrf_gpio_pin_set(LED_MOTOR); //aktif low
      nrf_gpio_pin_clear(RELAY_1);
      nrf_gpio_pin_set(RELAY_2);
      nrf_gpio_pin_clear(RTS_PIN_NUMBER);   //clear 0 volt receiver
    void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event) {
    	// Do nothing, as we use blocking mode
    int saadc_init()
      nrf_saadc_channel_config_t config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN3);
      nrf_saadc_channel_config_t config_2 = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1);
      int ret = nrf_drv_saadc_init(NULL, saadc_event_handler);
      if(ret) return ret;
      ret = nrf_drv_saadc_channel_init(3,&config);
      ret = nrf_drv_saadc_channel_init(1,&config_2);
      return ret;
    int saadc_measure_SENSOR()
      nrf_drv_saadc_sample_convert(3,&SIGNAL_IN);
      if(SIGNAL_IN < 0)
        SIGNAL_IN = 0;
      return SIGNAL_IN;
    int saadc_measure_TRM()
      nrf_drv_saadc_sample_convert(1, &TRM_IN);
      if(TRM_IN < 0)
        TRM_IN = 0;
      return  TRM_IN;
    static void fds_evt_handler(fds_evt_t const * p_evt)
    //    NRF_LOG_INFO("Event: %s received (%s)",
    //                  fds_evt_str[p_evt->id],
    //                  fds_err_str[p_evt->result]);
        switch (p_evt->id)
            case FDS_EVT_INIT:
                if (p_evt->result == FDS_SUCCESS)
                    m_fds_initialized = true;
            case FDS_EVT_WRITE:
    //                NRF_LOG_INFO("Record ID:\t0x%04x",  p_evt->write.record_id);
    //                NRF_LOG_INFO("File ID:\t0x%04x",    p_evt->write.file_id);
    //                NRF_LOG_INFO("Record key:\t0x%04x", p_evt->write.record_key);
            } break;
            case FDS_EVT_DEL_RECORD:
    //                NRF_LOG_INFO("Record ID:\t0x%04x",  p_evt->del.record_id);
    //                NRF_LOG_INFO("File ID:\t0x%04x",    p_evt->del.file_id);
    //                NRF_LOG_INFO("Record key:\t0x%04x", p_evt->del.record_key);
                m_delete_all.pending = false;
            } break;
    /**@brief   Sleep until an event is received. */
    static void power_manage(void)
    #ifdef SOFTDEVICE_PRESENT
        (void) sd_app_evt_wait();
    #else
        __WFE();
    /**@brief   Wait for fds to initialize. */
    static void wait_for_fds_ready(void)
        while (!m_fds_initialized)
            power_manage();
    /**@brief Function for application main entry.
        ret_code_t rc;
        ret_code_t ret;
        bool erase_bonds;
        // Initialize.
                log_init();
        power_management_init();
        saadc_init();
        timers_init();
        timer_internal_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        ret = nrf_serial_init(&serial_uart, &m_uart0_drv_config, &serial_config); //UART ile NRF_LOG Mod�lleri ayn� anda kullan�lam�yor. NRF_LOG mod�l� devred��� b�rak�ld�.
        APP_ERROR_CHECK(ret);
        gpio_init();
        timeslot_sd_init();
        app_buttons_init();
        // Start execution.
        advertising_start(erase_bonds);
         /* Register first to receive an event when initialization is complete. */
        (void) fds_register(fds_evt_handler);
        rc = fds_init();
        APP_ERROR_CHECK(rc);
      /* Wait for fds to initialize. */
         motor_delay = record_read(MOTOR_DELAY_FILE_ID,MOTOR_DELAY_KEY);
         NRF_LOG_INFO("FDS_REGISTER complete.");
    //     delete_all_process();
    //     wait_for_fds_ready();
        // Enter main loop.
        for (;;)
            idle_state_handle();
            if(timer_overflow >=5)
              timer_overflow=0;
              ++timer_overflow_2;
             /*10_ms operations*/
            if(timer_overflow_2 >=10)
              ++timer_overflow_3;
              timer_overflow_2=0;
             /*100_ms operations*/
              if(button_motor_flag == true)
                nrf_gpio_pin_set(RELAY_1);
              if(button_lamba_flag == true)
                nrf_gpio_pin_clear(RELAY_2);
              ++timer_overflow_4;
              timer_overflow_3=0;
              /* 500 ms works*/
              uint32_t err_code;
              if(rs485_send_flag)
                  ++tx_message[3];
    //          ++tx_message[3];
              /*1 sec works */
              uint32_t err_code;
                      return err_code;
              //show_stats();
    My serial_timeslot.h
    #include <stdint.h>
    #include <stdbool.h>
    #include "nrf.h"
    #include "app_error.h"
    #include "nrf_gpio.h"
    #include "nrf_sdh.h"
    #include "boards.h"
    #include "nrf_serial.h"
    #include "nrf_drv_uart.h"
    uint8_t tx_message[] = {0x29,0x17,0x01,0x52,0x6D};
    uint8_t temp_ni;      // The index for the temporary receive buffer
    uint8_t rs485_ni;
    uint8_t cs, state=0, len;
    uint8_t to, source;
    uint8_t rx_message_temp[128];
    uint8_t rx_message[128]; //receive buffer
    uint8_t data_length[128];
    bool rs485_send_flag = false;
    static void serial_rx_cb(struct nrf_serial_s *p_serial, nrf_serial_event_t event);
    NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uart0_drv_config,
                          RX_PIN_NUMBER, TX_PIN_NUMBER,
                          RTS_PIN_NUMBER, CTS_PIN_NUMBER,
                          NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED,
                          NRF_UART_BAUDRATE_9600,
                          UART_DEFAULT_CONFIG_IRQ_PRIORITY);
    #define SERIAL_FIFO_TX_SIZE 32
    #define SERIAL_FIFO_RX_SIZE 32
    NRF_SERIAL_QUEUES_DEF(serial_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
    #define SERIAL_BUFF_TX_SIZE 5
    #define SERIAL_BUFF_RX_SIZE 5   //Buffer size alınan mesaj boyutundan küçük veya eşit olmalı
    NRF_SERIAL_BUFFERS_DEF(serial_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
    NRF_SERIAL_CONFIG_DEF(serial_config, NRF_SERIAL_MODE_IRQ,
                          &serial_queues, &serial_buffs, &serial_rx_cb, NULL);
    NRF_SERIAL_UART_DEF(serial_uart, 0);
    #define RS485_ID    0x17
    // Purpose:    Add a byte of data to the temporary receive buffer
    // Inputs:     The byte of data
    void rs485_add_to_temp(uint8_t b) {
       // Store the byte
       rx_message[temp_ni] = b;
       // Make the index cyclic
       if(++temp_ni >= 256)
          temp_ni = 0;
    static void serial_rx_cb(struct nrf_serial_s *p_serial, nrf_serial_event_t event) {
        if (event == NRF_SERIAL_EVENT_RX_DATA) {
            uint8_t * buf = p_serial->p_ctx->p_config->p_buffers->p_rxb;
    /*----------------------------BUFFER SIZE = MESSAGE SIZE----------------------------------------------------------*/
            NRF_LOG_INFO("Recieved 1.BYTE : %d  2.BYTE : %d  3.BYTE : %d  4.BYTE : %d  5.BYTE : %d \n",
            buf[0],buf[1],buf[2],buf[3],buf[4]);
    //        NRF_LOG_INFO("Recieved 6.BYTE : %d  7.BYTE : %d  8.BYTE : %d  9.BYTE : %d  10.BYTE : %d \n",
    //        buf[5],buf[6],buf[7],buf[8],buf[9]);
    /*------------------BUFFER SIZE = 1 BYTE-----------------------------------------------------------------------------------*/
    //Islemci transmitter degistiginde almıyor. almasi icin reset atilmasi gerekiyor.
    //        cs ^= (uint8_t)buf[0];
    //        switch(state) {
    //          case 0: //Gönderen ID sini al
    //            //temp_ni = rs485_ni;
    //            source = buf[0];
    //            cs = buf[0];
    //            rs485_add_to_temp(source);
    //            NRF_LOG_INFO("Master ID OK.");
    //            //++state;
    //            break;
    //          case 1://Alıcı adresini al
    //            to =buf[0];
    //            rs485_add_to_temp(to);
    //            NRF_LOG_INFO("Slave address OK.");
    //            break;
    //          case 2: //Uzunluk
    //            len = buf[0];
    //            rs485_add_to_temp(len);
    //            NRF_LOG_INFO("Length OK.");
    //            break;
    //          case 255: //Checksum kontrolu
    //            //rs485_ni=temp_ni;
    //            state=0;
    //            rs485_add_to_temp(buf[0]);
    //            NRF_LOG_INFO("Checksum OK.");
    //            temp_ni=0;
    //            NRF_LOG_INFO("Recieved 1.BYTE : %d  2.BYTE : %d  3.BYTE : %d  4.BYTE : %d  5.BYTE : %d  6.BYTE : %d  \n",
    //                          rx_message[0],rx_message[1],rx_message[2],rx_message[3],rx_message[4],rx_message[5]);
    //            NRF_LOG_INFO("Checksum : %d  \n", rx_message[6]);
    //            memset(&rx_message, 0, sizeof(rx_message));
    //            return;
    //          default:
    //            --len;
    //            break;
    //        if ((state>=3) && (!len))
    //            state=255;
    //            NRF_LOG_INFO("Message OK.");
    //        else
    //            ++state;
    //          nrf_gpio_pin_set(RTS_PIN_NUMBER);
        else if(event == NRF_SERIAL_EVENT_DRV_ERR)
    //          ret_code_t ret;
    //          ret = nrf_serial_uninit(&serial_uart);
    //          APP_ERROR_CHECK(ret);
    //          //nrf_delay_ms(10);
    //          ret = nrf_serial_init(&serial_uart, &m_uart0_drv_config, &serial_config);
    //          NRF_LOG_INFO("Serial Module initialized again.");
        else if(event == NRF_SERIAL_EVENT_TX_DONE)
              NRF_LOG_INFO("Sending message : %d \n" ,tx_message[3]);
    uint8_t rx_data, rx_data1, rx_data2;
    int8_t tx_data=0x66;
    /**Timeslot API için sabitler
    static nrf_radio_request_t  m_timeslot_request;
    static uint32_t             m_slot_length;
    static nrf_radio_signal_callback_return_param_t signal_callback_return_param;
    /**Bir sonraki timeslot eventini earliest modda çağır
    uint32_t request_next_event_earliest(void)
        m_slot_length                                  = 20000;
        m_timeslot_request.request_type                = NRF_RADIO_REQ_TYPE_EARLIEST;
        m_timeslot_request.params.earliest.hfclk       = NRF_RADIO_HFCLK_CFG_NO_GUARANTEE;
        m_timeslot_request.params.earliest.priority    = NRF_RADIO_PRIORITY_NORMAL;
        m_timeslot_request.params.earliest.length_us   = m_slot_length;
        m_timeslot_request.params.earliest.timeout_us  = 1000000;
        return sd_radio_request(&m_timeslot_request);
    /**@brief Configure next timeslot event in earliest configuration
    void configure_next_event_earliest(void)
    /**@brief Configure next timeslot event in normal configuration
    void configure_next_event_normal(void)
        m_slot_length                                 = 100000;
        m_timeslot_request.request_type               = NRF_RADIO_REQ_TYPE_NORMAL;
        m_timeslot_request.params.normal.hfclk        = NRF_RADIO_HFCLK_CFG_NO_GUARANTEE;
        m_timeslot_request.params.normal.priority     = NRF_RADIO_PRIORITY_HIGH;
        m_timeslot_request.params.normal.distance_us  = 50000;
        m_timeslot_request.params.normal.length_us    = m_slot_length;
    /**@brief Timeslot signal handler
    void nrf_evt_signal_handler(uint32_t evt_id)
        uint32_t err_code;
        switch (evt_id)
            case NRF_EVT_RADIO_SIGNAL_CALLBACK_INVALID_RETURN:
                //No implementation needed
            case NRF_EVT_RADIO_SESSION_IDLE:
            case NRF_EVT_RADIO_SESSION_CLOSED:
                //No implementation needed, session ended
            case NRF_EVT_RADIO_BLOCKED:
                //Fall through
            case NRF_EVT_RADIO_CANCELED:
    /**@brief Timeslot event handler
    nrf_radio_signal_callback_return_param_t * radio_callback(uint8_t signal_type)
        switch(signal_type)
            case NRF_RADIO_CALLBACK_SIGNAL_TYPE_START:
                //Start of the timeslot - set up timer interrupt
                signal_callback_return_param.params.request.p_next = NULL;
                signal_callback_return_param.callback_action = NRF_RADIO_SIGNAL_CALLBACK_ACTION_NONE;
                NRF_TIMER0->INTENSET = TIMER_INTENSET_COMPARE0_Msk;
                NRF_TIMER0->CC[0] = m_slot_length - 1000;
                NVIC_EnableIRQ(TIMER0_IRQn);
            uint32_t err_code;
            err_code = nrf_serial_read(&serial_uart, &rx_message_temp, sizeof(rx_message_temp), NULL, 0);
            //NRF_LOG_INFO("Recieved error : %d \n",err_code);
            /*Bu if koşulu ile yeni bir chaz bağlandığında uart yeniden başlatılıyor *
            if(err_code == 13)
              ret_code_t ret;
              //nrf_delay_ms(10);
            case NRF_RADIO_CALLBACK_SIGNAL_TYPE_RADIO:
            case NRF_RADIO_CALLBACK_SIGNAL_TYPE_TIMER0:
                //Timer interrupt - do graceful shutdown - schedule next timeslot
                configure_next_event_normal();
                signal_callback_return_param.params.request.p_next = &m_timeslot_request;
                signal_callback_return_param.callback_action = NRF_RADIO_SIGNAL_CALLBACK_ACTION_REQUEST_AND_END;
            case NRF_RADIO_CALLBACK_SIGNAL_TYPE_EXTEND_SUCCEEDED:
            case NRF_RADIO_CALLBACK_SIGNAL_TYPE_EXTEND_FAILED:
                //Try scheduling a new timeslot
                configure_next_event_earliest();
        return (&signal_callback_return_param);
    //NRF_SDH_SOC_OBSERVER(m_signal_evt_observer, 0, nrf_evt_signal_handler, NULL);
    /**@brief Function for initializing the timeslot API.
    uint32_t timeslot_sd_init(void)
        uint32_t err_code;
        err_code = sd_radio_session_open(radio_callback);
            return err_code;
    //        return err_code;
        return NRF_SUCCESS;
  • HI Mehmet,
    Apologies for the very long wait.
    Have you made any progress on this issue?
    Best regards
    Bjørn
  • Hi Bjorn,
    Because of pandemic situation, i will not be on work until August. Yes, i have some progress. Firstly, i remove timeslot and change some components(pull up resistors and termination resistors) on pcb. I let the event handlers do all data transfer. It works fine at some situation.
    • If i powered up nrf board first, pic board secondly, data transfer is OK.
    • If i powered up pic board first, nrf board secondly, data is slipping.
    • If i do data transfer one after another in 500 ms(by pressing key quickly or by software) data is slipping again.
    For now, It works but unreliable. I need to find a exact solution for this issue. I am sorry but i can not give more details because of i am not office and i will not be able in office until August.
    Best regards
    Caner
