app_uart_get more than 1 byte
I'm using app_uart for communication between different mcu. I can send more than 1 byte like "0x3917015623"  through  changing tx_buffer[0] to tx_buffer[5]. Unfortunately i couldn't recieve the slave devicess message "0x2917013607". I can only get the first byte "0x07". My configuration are the same as uart example. How can i recieve all the message ?. I tried to use serial library but i couldn't initialize. (It gave ERROR 6 NRF_ERROR_NOT_SUPPORTED).
Slave device is sending me a message every second. And i'm calling app_uart_get function every 500 miliseconds.
Here is my uart init;
void uart_error_handle(app_uart_evt_t * p_event)
    if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
    else if (p_event->evt_type == APP_UART_FIFO_ERROR)
void uart_init(void)
    uint32_t err_code;
    const app_uart_comm_params_t comm_params =
            RX_PIN_NUMBER,
            TX_PIN_NUMBER,
            RTS_PIN_NUMBER,
            CTS_PIN_NUMBER,
            UART_HWFC,
            false,
  #if defined (UART_PRESENT)
            NRF_UART_BAUDRATE_115200
  #else
            NRF_UARTE_BAUDRATE_9600
//    const app_uart_buffers_t m_buffers =
//        &rx_buffer_s,
//        sizeof(rx_buffer_s),
//        &tx_buffer_s,
//        sizeof(tx_buffer_s)
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_error_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
//      err_code = app_uart_init(&comm_params, &m_buffers, uart_error_handle, APP_IRQ_PRIORITY_LOW);
//      APP_ERROR_CHECK(err_code);
  • Hi Caner,
    Caner Celiktas said:
    • If i powered up nrf board first, pic board secondly, data transfer is OK.
    • If i powered up pic board first, nrf board secondly, data is slipping.
    When you say data slipping, then its the nRF not receiving the correct data sent from the PIC? Or nRF to PIC?
    If i do data transfer one after another in 500 ms(by pressing key quickly or by software) data is slipping again.
     Is this in both directions, PIC to nRF or nRF to PIC?
