Breakpoint and reset in SoftDevice addresses 0xA60 and 0xA80
Our application sometimes hits a breakpoint in SoftDevice at either address 0xA60 or (less often) 0xA80.
Based on this post https://devzone.nordicsemi.com/f/nordic-q-a/9622/application-debug-with-softdevice I believe that it might be an assert in SoftDevice to do with the realtime BLE requirements. Is this correct? Is this maybe caused by an ISR taking too long meaning SoftDevice cannot do it's BLE tasks?
Any help would be great, thanks.
  • In the failing cases, maybe the WD is already close to expiring when you get the connection event, and the code responsible for reloading is being delayed enough by that to cause a reset. Have you noticed any impact on failure rate if you increase the timeout and or frequency of the periodic tasks that reload the WD?
  • This was our worry too but, strangely, we can reduce the failure rate but we are struggling to increase the failure rate. We have tested it a few times with the watchdog timeout increased to 10 seconds (from 3 seconds) and the system seems to work without crashing and also doesn't hang anywhere. We have also tried to decrease the watchdog to 1 second but the failure stays the same.
    Is it possible to print the current value of the watchdog timer so that we can see if it is being fed and if it is incrementing in the background as you said it might be.
  • So I've discussed this with a colleague who is experienced with Freertos and he thought the problem could be that the BLE task is not yielding to other thread responsible for feeding the WD. Have you tried to do any profiling to see if there's heavy CPU usage around the time a  connection is established?
  • We have done power profiling and it seems that the CPU usage does not change at the time we see the issue. If it was CPU usage that it would likely happen every time and not just after a prolonged idle period.
    By reducing the watchdog time to about 10ms instead of 3 seconds then we can see the same problem but much quicker. With this quicker watchdog we see that the system can work fine indefinitely, connecting and disconnecting phones; sending commands; etc., but then if we disconnect the phones, leaving the system to idle for about a minute, and afterwards we connect a single phone then the watchdog kicks in and reboots the system.
    This makes it seem like either the watchdog is not being kicked properly or as you previously said it is incrementing in the background building up overtime getting close to the overflow value, then when the system wakes and performs it's actions this CPU usage is long enough that it pushes the watchdog to overflow before it can idle and get kicked.
    We use the nrfx_wdt_channel_feed(m_channel_id); function to kick the watchdog, is this correct?
    Is it possible to print the current watchdog timer value? So that we can see if it does actually increase over time and that it is reloaded correctly.
    Thanks.
  • It's not possible to read the WD counter, unfortunately.  It starts over again when you reload it.
     What's the WDT_CONFIG_BEHAVIOUR configured to in your sdk_config.h file? " Run in SLEEP" would make it count continuously anyway.
    Assume you had to increase the frequency of your reloading task to make 10 ms work?
