I've a problem with a PPK board.
When the current go over 10mA the value reported is wrong, in my case should be 15mA and PPK measure 80mA and more. Instead, in the range of microamperes the value is correct.
Tried with a differrent PPK board and it is working correctly.
The PPK is used to measure an exetrnal DUT with regulated voltage from the board, software used is nRFConnect 3.3.0 and Power Profiler application 2.3.1.
What can I do, if possible, to fix this problem? Or the board is irreparably damaged?
Many thanks in advance.
Valerio
