BLE scanning on AC mains powered unit with dimming
I have an application that requires mains power for lighting with a BLE receiver that is permanently advertising and scanning and I need to be able to dim the lights.  My circuit uses zero-crossing and a triac to control the mains.  I'm using a Fanstel BT832 module which is just the NRF52832 chip.
My code is currently based on the ble_app_interactive from the ble_central_and_peripheral examples in nRF5_SDK_16.
I've built a prototype unit that works in every respect except the dimming. The dimming is fine if I turn off advertising and scanning, but flickers when these are running. I've tried using only GPIOTE to achieve the dimming (which flickered). I then found some example code that used PPI, with 2 timer instances monitoring phase shift and pulse length, and tried this. Again the dimming works perfectly until I start the scanning or advertising.
I’ve tried the code on the NRF52-dk, which gives the same results, but have also tried the code on a Decawave DWM1001 which uses the NRF52832 and this seems to work without any flickering.  I cannot see any reason for this.
I thought the lack of a crystal on the Fanstel chip may have been to blame, as the Decawave module has a crystal, but the NRF52-dk has a crystal and this still sees the flicker.
Can anyone help with how to overcome this?
const nrf_drv_timer_t phaseshift_timer  = NRF_DRV_TIMER_INSTANCE(1);
const nrf_drv_timer_t pulselength_timer = NRF_DRV_TIMER_INSTANCE(2);
static nrf_ppi_channel_t                m_zerocrossing_channel;
void zerocrossing_event_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action) {}
void trigger_event_handler(nrf_timer_event_t event_type, void* p_context){}
/** @brief Function for timer initialization, which will be started by zero-crossing using PPI.
static void high_resolution_timer_init(void)
    uint32_t err_code = NRF_SUCCESS;
    nrf_drv_timer_config_t timer_config = NRF_DRV_TIMER_DEFAULT_CONFIG;
    timer_config.frequency = NRF_TIMER_FREQ_1MHz;
    timer_config.bit_width = NRF_TIMER_BIT_WIDTH_16;
//    timer_config.interrupt_priority = NRF_APP_PRIORITY_LOW;
    timer_config.interrupt_priority = APP_IRQ_PRIORITY_LOW;
    timer_config.mode = NRF_TIMER_MODE_TIMER;
    timer_config.p_context = NULL;
    err_code = nrf_drv_timer_init(&phaseshift_timer, &timer_config, trigger_event_handler);
    // 10000 cycles at 1Mhz makes 0.01 sec - the duration of one half wave at 50Hz mains AC frequency
    nrf_drv_timer_extended_compare(&phaseshift_timer, NRF_TIMER_CC_CHANNEL0, 0x2710, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
    err_code = nrf_drv_timer_init(&pulselength_timer, &timer_config, trigger_event_handler);
    // the length of the triac firing pulse is 0.001 sec
    nrf_drv_timer_extended_compare(&pulselength_timer, NRF_TIMER_CC_CHANNEL0, 0x03E8, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
/** @brief Function for initializing the PPI peripheral.
#define SAJ_PIN_IN    16
#define SAJ_PIN_OUT   20
static void peripheral_init(void)
    nrf_ppi_channel_t ppi_channel2;
    nrf_ppi_channel_t ppi_channel3;
    nrf_ppi_channel_t ppi_channel4;
    nrf_ppi_channel_t ppi_channel5;
    nrf_ppi_channel_t ppi_channel6;
    uint32_t zerocrossing_addr;
    uint32_t load_addr;
    // init the phase-shift and pulse-length timer
    high_resolution_timer_init();
    if (!nrf_drv_gpiote_is_init())
        if(err_code != NRF_SUCCESS)
            return;
    // create the zero-crossing event
    nrf_drv_gpiote_in_config_t zero_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);
    zero_config.pull = NRF_GPIO_PIN_PULLUP;
    err_code = nrf_drv_gpiote_in_init(SAJ_PIN_IN, &zero_config, zerocrossing_event_handler);
    zerocrossing_addr = nrf_drv_gpiote_in_event_addr_get(SAJ_PIN_IN);
    nrf_drv_gpiote_in_event_enable(SAJ_PIN_IN, true);
    // assign zero-crossing event to start of phase-shift timer
    // start timer on zero-crossing event
    err_code = nrf_drv_ppi_channel_alloc(&m_zerocrossing_channel);
    err_code = nrf_drv_ppi_channel_assign(m_zerocrossing_channel,
                                          zerocrossing_addr,
                                          nrf_drv_timer_task_address_get(&phaseshift_timer, NRF_TIMER_TASK_START));
    // create the load control task
    nrf_drv_gpiote_out_config_t load_config = GPIOTE_CONFIG_OUT_TASK_TOGGLE(true);
    load_config.init_state = NRF_GPIOTE_INITIAL_VALUE_LOW;
    err_code = nrf_drv_gpiote_out_init(SAJ_PIN_OUT, &load_config);
    load_addr = nrf_drv_gpiote_out_task_addr_get(SAJ_PIN_OUT);
    nrf_drv_gpiote_out_task_enable(SAJ_PIN_OUT);
    // assign the end of the phase-shift timer to the load control task
    // toggle load control if timer overruns
    err_code = nrf_drv_ppi_channel_alloc(&ppi_channel2);
    err_code = nrf_drv_ppi_channel_assign(ppi_channel2,
                                          nrf_drv_timer_event_address_get(&phaseshift_timer, NRF_TIMER_EVENT_COMPARE0),
                                          load_addr);
    // assign the end of the phase-shift timer to the start of the pulse-length timer
    // start pulse_length timer with the end of the phase-shift timer
    err_code = nrf_drv_ppi_channel_alloc(&ppi_channel3);
    err_code = nrf_drv_ppi_channel_assign(ppi_channel3,
                                          nrf_drv_timer_task_address_get(&pulselength_timer, NRF_TIMER_TASK_START));
    // assign the end of the phase-shift timer to stop the phase-shift timer
    // end of phase-shift timer stops itself
    err_code = nrf_drv_ppi_channel_alloc(&ppi_channel4);
    err_code = nrf_drv_ppi_channel_assign(ppi_channel4,
                                          nrf_drv_timer_task_address_get(&phaseshift_timer, NRF_TIMER_TASK_STOP));
    // assign end of pulse-length timer to the load control task
    // toggle load control with the end of pulse-length timer
    err_code = nrf_drv_ppi_channel_alloc(&ppi_channel5);
    err_code = nrf_drv_ppi_channel_assign(ppi_channel5,
                                          nrf_drv_timer_event_address_get(&pulselength_timer, NRF_TIMER_EVENT_COMPARE0),
                                          load_addr);
    // assign end of pulse-length timer to stop itself
    // end of pulse-length timer stops itself
    err_code = nrf_drv_ppi_channel_alloc(&ppi_channel6);
    err_code = nrf_drv_ppi_channel_assign(ppi_channel6,
                                          nrf_drv_timer_task_address_get(&pulselength_timer, NRF_TIMER_TASK_STOP));
    err_code = nrf_drv_ppi_channel_enable(ppi_channel2);
    err_code = nrf_drv_ppi_channel_enable(ppi_channel3);
    err_code = nrf_drv_ppi_channel_enable(ppi_channel4);
    err_code = nrf_drv_ppi_channel_enable(ppi_channel5);
    err_code = nrf_drv_ppi_channel_enable(ppi_channel6);
void set_brightness(uint16_t brightness)
    if(brightness > 0) {
        NRF_LOG_RAW_INFO("Setting brightness %u\r\n", brightness);
        // enable zero-crossing event
        err_code = nrf_drv_ppi_channel_enable(m_zerocrossing_channel);
        uint16_t counter;
        counter = 10000 - 100*brightness;
        // the min ticks is 4 - represents full cycle load
        nrf_drv_timer_extended_compare(&phaseshift_timer, NRF_TIMER_CC_CHANNEL0, counter+4, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
        // disable zero-crossing event
        err_code = nrf_drv_ppi_channel_disable(m_zerocrossing_channel);
    log_init();
//    timer_init();
    ble_m_init();
    peer_manager_init();
//    nfc_pairing_init(); // SAJ: not using NFC pairing
    NRF_LOG_RAW_INFO("App started.\r\n");
    scan_start();
    adv_start();
    peripheral_init();
    set_brightness(25);
    for (;;)
        idle_state_handler();
// <h> Clock - SoftDevice clock configuration
// ***** SAJ DIMMING: IMPORTANT!!! ***** amendments made to this are to allow the code to run on the Fanstel chip
// as the code that ran OK on the dev kit would not run on the Fanstel without these changes
// <o> NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
// <0=> NRF_CLOCK_LF_SRC_RC
// <1=> NRF_CLOCK_LF_SRC_XTAL
// <2=> NRF_CLOCK_LF_SRC_SYNTH
#ifndef NRF_SDH_CLOCK_LF_SRC
#define NRF_SDH_CLOCK_LF_SRC 0 // SAJ: was 1
// <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
#ifndef NRF_SDH_CLOCK_LF_RC_CTIV
#define NRF_SDH_CLOCK_LF_RC_CTIV 16 // SAJ: was 0
// <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
// <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
// <i>  if the temperature has not changed.
#ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
#define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2 // SAJ: was 0
// <o> NRF_SDH_CLOCK_LF_ACCURACY  - External clock accuracy used in the LL to compute timing.
// <0=> NRF_CLOCK_LF_ACCURACY_250_PPM
// <1=> NRF_CLOCK_LF_ACCURACY_500_PPM
// <2=> NRF_CLOCK_LF_ACCURACY_150_PPM
// <3=> NRF_CLOCK_LF_ACCURACY_100_PPM
// <4=> NRF_CLOCK_LF_ACCURACY_75_PPM
// <5=> NRF_CLOCK_LF_ACCURACY_50_PPM
// <6=> NRF_CLOCK_LF_ACCURACY_30_PPM
// <7=> NRF_CLOCK_LF_ACCURACY_20_PPM
// <8=> NRF_CLOCK_LF_ACCURACY_10_PPM
// <9=> NRF_CLOCK_LF_ACCURACY_5_PPM
// <10=> NRF_CLOCK_LF_ACCURACY_2_PPM
// <11=> NRF_CLOCK_LF_ACCURACY_1_PPM
#ifndef NRF_SDH_CLOCK_LF_ACCURACY
#define NRF_SDH_CLOCK_LF_ACCURACY 1 // SAJ: was 7
// </h>
  • Have tried another Decawave DWM1001 and the flicker DOES exist on this as well.
  • So there are 4 scenarios that are likely:
    1. If you're using TIMER0, it is required by the SoftDevice, use TIMER1 instead.
    2. A SoftDevice timing event has execution priority and delays your application from starting or updating the timer in such a way that your signal output is out of phase with the AC signal.
    3. In case you're using a PWM like signal, the PWM signal has been inverted due to a SoftDevice timing event preempting during a PWM update procedure.
    4. Clock jitter/glitch as the HFXO is turned on/off to service RADIO events. If this is the case the solution would be to keep the HFXO always on.
    I suggest you scope your signal output (to the opto-triac), check voltage levels, and compare the AC phase.
  • Thanks for your suggestions.
    Re point 1 - I'm using TIMER1 and TIMER2 (not TIMER0).
    Re point 2 - I guess this is the problem, but don't know how to get around it.  I can't see a way of changing the priorities as the interrupt priority for the SD is reserved.
    Re point 3 - I'm not currently using PWM, but am now looking at this to see if I can use this instead of a timer.
    Re point 4 - I've set the clock to NRF_CLOCK_LF_SRC_RC rather than XTAL as the Fanstel chip does not have a crystal.
    I don't have an oscilloscope so can't follow your suggestion.
    1. Ok, good.
    2. You can request what is called a Timeslot, where for a given time, you are guaranteed not to get preempted by the SoftDevice. See:
      Timeslot API timing
      Radio Timeslot API usage scenarios
      Radio Timeslot API processor usage patterns
      sd_radio_session_open
      sd_radio_request
    3. If you can use the PWM peripheral I'd recommend it as it cannot be inverted, and its operation is a lot closer to real-time than a TIMER based PWM. With the PWM peripheral you can update the duty-cycle whenever you want to and the changes won't take effect until the next period. This means that you can, for instance, tie the zero-crossing event to automatically start a new PWM sequence, ensuring phase stability over time, without being dependent on CPU availability. This can ofc be done with the TIMER based PWM as well, but the update procedure will have to be done in a Timeslot.
    4. The module does have a 32MHz crystal, as it is mandatory for RF communications, only the 32.768KHz crystal is optional. The peripheral system of the MCU runs on a 16MHz clock, derived from HFCLK clock controller, who, during radio event, uses the HFXO as its source.
    5. At some point, you really should verify your control signals and triac outputs.
