I'm trying to advertise on the coded phy, but SDK 16 seems to have a block in place against doing this when you use S340. I can obviously edit this, but I don't normally edit the SDK without checking first. Does the S340 fully support the coded phy?
static bool config_is_valid(ble_adv_modes_config_t const * const p_config) { if ((p_config->ble_adv_directed_high_duty_enabled == true) && (p_config->ble_adv_extended_enabled == true)) { return false; } #if !defined (S140) else if ( p_config->ble_adv_primary_phy == BLE_GAP_PHY_CODED || p_config->ble_adv_secondary_phy == BLE_GAP_PHY_CODED) { return false; } #endif // !defined (S140) else { return true; } }
As you can see, in ble_advertising.c if you are not specified with S140, it will not init the advertising module with the coded phy.
