I need help with converting any example from Keil to SES
I've been trying for days to convert any example from Keil to SES, I have road probably every question here on the dev zone but I am unable to fix this, I ever specially install windows on my mac to try if there it would work.
So, I have done everything from official nordic documents, I've been through several problems which I happily solve, but that I'm not able to.
I get those errors:
unplaced section: .log_dynamic_data_app [nrf_log_frontend.o], size=12, align=4
undefined symbol: __SRAM_segment_end__
undefined symbol: __start_log_const_data
undefined symbol: __start_log_dynamic_data
undefined symbol: __stop_log_const_data
I'm working on latest SEGGER, I have tried latest SDK, also 14.2 . The same errors.
Thanks for reply
  • I did that:
    1. in Eclipse, Project -> Build configurations -> set active -> 1 Debug
    than Project -> Build All
    and I have outcome:
    Build Finished. 0 errors, 2 warnings. (took 3s.169ms)
    2.  in Eclipse, Project -> Build configurations -> set active -> 2 Release
    and I have outcome:
    Build Finished. 0 errors, 0 warnings. (took 81ms)
    Firstly I merged BlueIOThingy.hex file from Debug folder (in BlueIOThingy example project) it it of course do not worked.
    Now I merged BlueIOThingy.hex file from Realese folder (in BlueIOThingy example project) and still I am not able to see it advertise but I see a change, On dev Board: LED2, LED3, LED4 is on and LED1 is blinking very very quickly. I do not know if it means something, but this is the difference from now and before.
    Is the debug need to be run with JLINK option in Eclipse ->Preferences->Run/Debug->JLINK ? Because if Yes maybe that is the problem? Cause it is not there, I don't know why.
  • To run from Eclipse debugger, first select the project BlueIOThingy.  Then select from the menu "Run/Debug Configurations...".  You'll see a popup.  From the left you see a list of selections.  look for JLink.  Create a new configuration.    You see
    Browse and select your BlueIOThingy.elf you want to use. Then select Debugger tab
    Set NRF52832_XXAA in the device name box.  Then click debug.  It will flash and start debugging mode.
    The BlueIOThingy firmware is made for this board.
    It's available at https://www.crowdsupply.com/i-syst/blyst-nano
    To use it on a different board. You need to modify the code for your own board.  The current board uses the BME680 and the ICM-20948 sensors.
  • I got this from debug session:
    assertion "s" failed: file "/Users/jacobbudny/Desktop/DEVELOPMENT/external/Invn/Devices/Drivers/Icm20948/Icm20948Serif.h", line 78, function: inv_icm20948_serif_read_reg
    Okay so maybe I did not understand from the begining..
    To be fully cleared:
    What I have:
    nrf52 DK this one: https://www.nordicsemi.com/Software-and-Tools/Development-Kits/nRF52-DK
    MPU9250 this one: https://www.sparkfun.com/products/13762
    What I want:
    I want to connect MPU9250 (GND,VDD,SCL,SDA) (or another 9axis sensor, I can also get another sensor if its necessary, if with ICM-20948 its simpler or better that's not problem for me.) to nrf52 DK and get raw data from MPU9250 (accx,accy etc.(9 of those)) over bluetooth to computer/phone/tablet and receive them in real time. And I've been fighting with it for a month now.
    Where should I start? Or If its even possible?
    As you said in your first answer:
    "Example source code using MPU-9250 and stream data to Thing App.
    https://github.com/IOsonata/IOsonata/tree/master/ARM/Nordic/exemples/BlueIOThingy "
    I was convinced that its possible? But now I am not exactly sure ;/ Where should I start then?
    Thanks anyway for your help, you've been so helpful, can't thank you enough...
  • The driver is available for both.  All you need to do is to use the correct driver with the correct interface.  Which means to configure I2C driver with your pin map.  Then pass it to the MPU-9250 driver.  it is at line 602 of BlueIOThingy.cpp.  The default is SPI interface.  Pass your I2C interface to it. The I2C configuration is at line 250-274
    Change line 602 from
        if (MPU9250Init(&g_Spi, &g_Timer) == true)
    to
        if (MPU9250Init(&g_I2c, &g_Timer) == true)
    and in board.h change pin map for the MPU9250 interrupt pin of your board.  The code related to the MPU is in BlueIOMPU9250.cpp
    The firmware auto detect the MPU-9250 or the ICM-20948.
    At the same time you can change the I/O map for the LED to your board as well.
  • Okay I changed the lines,
    But I do not see any I2C/TWI pins here to set up to nordic dv board:
    //#define NORDIC_DK // For Nordic DevKit
    #ifdef NORDIC_DK
    #define UART_TX_PIN 9//7
    #define UART_RX_PIN 11//8
    #define UART_RTS_PIN 8//11
    #define UART_CTS_PIN 10//12
    #define SPI_DEVNO            2
    #define SPI_MISO_PORT        0
    #define SPI_MISO_PIN         13
    #define SPI_MISO_PINOP       1
    #define SPI_MOSI_PORT        0
    #define SPI_MOSI_PIN         12
    #define SPI_MOSI_PINOP       1
    #define SPI_SCK_PORT         0
    #define SPI_SCK_PIN          11
    #define SPI_SCK_PINOP        1
    #define SPI_BME280_CS_PORT         0
    #define SPI_BME280_CS_PIN          26
    #define SPI_BME280_CS_PINOP        1
    #else
    I only see SPI pins here. I can't figure it out what pins is for SCL/SDA, Or maybe I should redefined them?
    Also in lines 250-274 in BlueIOThingy.cpp there is nothing about mpu9250, only for air/humidity sensors  and their connection.
    I searched more about mou9250 in code, but I am able to figure out what else to change to get the raw data from it over ble.
    Also, I still did not managed to get nordic dev kit to advertise with this example, maybe there is more to change ?
