Example that logs over Segger RTT requiring no configuration changes by me
I'm trying to get debug output to appear in my Segger J-LINK SWO viewer (from an NR52840 SDK board with NRF5 v16) which I understand is a potentially complicated process; I've received nothing in the SWO viewer so far.  Do you have an example which sends debug output to Segger RTT by default, without me screwing anything up, i.e. all I have to do is make flash, just so that I can check that the connection and the Segger tools are good (not that there's much that can go wrong with them)?
FYI, in my sdk_config.h I have NRF_LOG_ENABLED 1,  NRF_LOG_BACKEND_RTT_ENABLED 1, NRF_LOG_BACKEND_UART_ENABLED 0, NRF_LOG_DEFERRED 0 and NRF_LOG_DEFAULT_LEVEL 3 and in main.c I start with:
NRF_LOG_INIT(NULL);
NRF_LOG_INFO("Hello world.\n");
In the Segger SWO viewer I've selected nRF52840_xxAA, let it measure the clock, selected channel 0, the green LED near the PCA10056 on the board is flashing regularly and I pressed the reset button on the board. Nada.
Oh, and I also have the defaults for the Segger RTT settings, i.e.:
#define SEGGER_RTT_CONFIG_BUFFER_SIZE_UP 512
#define SEGGER_RTT_CONFIG_MAX_NUM_UP_BUFFERS 2
#define SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN 16
#define SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS 2
#define SEGGER_RTT_CONFIG_DEFAULT_MODE 0
Rob
  • Hi Rob,
    RTT is printed out on the SWDIO line instead of SWO. Could you try the RTTViewer instead and see if it works?
    Thre are several examples which have RTT logging enabled by default. ble_app_uart is one of them (located in \nRF5_SDK_16.0.0_98a08e2\examples\ble_peripheral\ble_app_uart\pca10056\s140). Note: remember to load the Softdevice since it's a BLE app: make flash_softdevice && make flash
    Vidar
    Edit: RTTViewer is not available for Linux MacOS if I recall correctly. So if you are not working in Windows, try to first connect the debugger with Jlink commander (JLinkExe) first, then run the RTTClient executable from another terminal window.
  • Ah, apologies, I thought RTT was the same thing as SWO.  Do you have SDO out also, nice and standard...?
    Anyway, RTT shows the same thing: all seems to start up OK but no sign of any of my debug.
    I tried that example you pointed to, which built and downloaded fine, but I still don't see anything in the RTT viewer.  RTT viewer connects (see output below) and the green LED on the board flashes more rapidly but no text ever appears in the terminal window.  What else might I be doing wrong?
    LOG: Connecting to J-Link via USB...
    LOG: Device "NRF52840_XXAA" selected.
    LOG: InitTarget() start
    LOG: InitTarget() end
    LOG: Found SW-DP with ID 0x2BA01477
    LOG: DPIDR: 0x2BA01477
    LOG: Scanning AP map to find all available APs
    LOG: AP[2]: Stopped AP scan as end of AP map has been reached
    LOG: AP[0]: AHB-AP (IDR: 0x24770011)
    LOG: AP[1]: JTAG-AP (IDR: 0x02880000)
    LOG: Iterating through AP map to find AHB-AP to use
    LOG: AP[0]: Core found
    LOG: AP[0]: AHB-AP ROM base: 0xE00FF000
    LOG: CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
    LOG: Found Cortex-M4 r0p1, Little endian.
    LOG: FPUnit: 6 code (BP) slots and 2 literal slots
    LOG: CoreSight components:
    LOG: ROMTbl[0] @ E00FF000
    LOG: ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
    LOG: ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
    LOG: ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
    LOG: ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
    LOG: ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
    LOG: ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
    LOG: RTT Viewer connected.
  • I've generally had more success with the RTTClient. Could you try that as well? I have included some screenshots below to show how I tested it here. We do not have any examples for SWO that I'm aware of. I'm actually not sure if this output is even available on the Jlink lite we have on our DKs. I will find out if you are interested.
    RTT viewer:
    RTT Client:
  • Yes, I would be interested in SWO I think, seems simpler for me.
    I did have auto-detect on in the RTT Viewer.  Just did what you suggested and started JLink in one DOS box:
    Connecting to target via SWD
    AP[0]: Core found
    Cortex-M4 identified.
    J-Link>g
    WARNING: T-bit of XPSR is 0 but should be 1. Changed to 1.
    J-Link>r
    Reset delay: 0 ms
    Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit.
    Reset: Halt core after reset via DEMCR.VC_CORERESET.
    Reset: Reset device via AIRCR.SYSRESETREQ.
    J-Link>
    ...but when I start jlinkrttclient in another window it looks the same as yours except no debug is printed below it:
    C:\Program Files (x86)\SEGGER\JLink_V641a>jlinkrttclient
    ###RTT Client: ************************************************************
    ###RTT Client: *               SEGGER Microcontroller GmbH                *
    ###RTT Client: *   Solutions for real time microcontroller applications   *
    ###RTT Client: *                                                          *
    ###RTT Client: *       (c) 2012 - 2016  SEGGER Microcontroller GmbH       *
    ###RTT Client: *                                                          *
    ###RTT Client: *     www.segger.com     Support: [email protected]       *
    ###RTT Client: *                                                          *
    ###RTT Client: *                                                          *
    ###RTT Client: * SEGGER J-Link RTT Client   Compiled Nov 27 2018 14:10:37 *
    ###RTT Client: *                                                          *
    ###RTT Client: -----------------------------------------------
    ###RTT Client: Connecting to J-Link RTT Server via localhost:19021  Connected.
    SEGGER J-Link V6.41a (beta) - Real time terminal output
    J-Link OB-SAM3U128-V2-NordicSemi compiled Jan 21 2020 17:30:48 V1.0, SN=683253856
    Process: JLink.exe
    This is with the ble_peripheral build still on the NRF52840 DK board.  What am I doing wrong?
  • Ooo!  Belay that, I just built and download my own build to my board and J-Link RTT client suddenly burst into life:
    <info> app: Hello world.
    <info> app: CELLULAR_PORT_TEST: tick time now is 0.
    <info> app: CELLULAR_PORT_TEST: creating a mutex...
    <info> app:                     returned error code 0, handle 0x20000978.
    <info> app: CELLULAR_PORT_TEST: creating a queue...
    <info> app:                     returned error code 0, handle 0x200009c0.
    <info> app: CELLULAR_PORT_TEST: creating a test task with stack 2048 byte(s) and priority 12, passing it the pointer 0x20000220 containing
    Obviously I'm doing something right, just need to figure out the sequence.  Thanks for your help, if you have anything on using SWO then do let me know.
