Example that logs over Segger RTT requiring no configuration changes by me
I'm trying to get debug output to appear in my Segger J-LINK SWO viewer (from an NR52840 SDK board with NRF5 v16) which I understand is a potentially complicated process; I've received nothing in the SWO viewer so far.  Do you have an example which sends debug output to Segger RTT by default, without me screwing anything up, i.e. all I have to do is make flash, just so that I can check that the connection and the Segger tools are good (not that there's much that can go wrong with them)?
FYI, in my sdk_config.h I have NRF_LOG_ENABLED 1,  NRF_LOG_BACKEND_RTT_ENABLED 1, NRF_LOG_BACKEND_UART_ENABLED 0NRF_LOG_DEFERRED 0 and NRF_LOG_DEFAULT_LEVEL 3 and in main.c I start with:
NRF_LOG_INIT(NULL);
NRF_LOG_INFO("Hello world.\n");
In the Segger SWO viewer I've selected nRF52840_xxAA, let it measure the clock, selected channel 0, the green LED near the PCA10056 on the board is flashing regularly and I pressed the reset button on the board. Nada.
Oh, and I also have the defaults for the Segger RTT settings, i.e.:
#define SEGGER_RTT_CONFIG_BUFFER_SIZE_UP 512
#define SEGGER_RTT_CONFIG_MAX_NUM_UP_BUFFERS 2
#define SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN 16
#define SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS 2
#define SEGGER_RTT_CONFIG_DEFAULT_MODE 0
Rob
  • Hmmm.  Haven't been able to do it again though.  Any hints on reliability?  I've tried reducing the speed from 4000 kHz to 1000 kHz but that doesn't seem to have helped.
  • It seems to work only the first time after JLink connects.  If I do a reset (pressing 'r' in JLink commander, or pressing the reset button on the board) nothing more comes out; I have to restart JLink commander and then does stuffs appear in the RTT viewer once more.
    Any clues as to why that might be?
  • No, even that's not consistent, it just seems to be unreliable.
  • I have seen some issues with the RTT viewer, but the RTT itself has been reliable in my experience (I'm usually viewing the logs in the SES IDE). I noticed now from your logs that you are using a beta release for the J-link, maybe that's the problem. Could you try to update it?
    Simple Blinky example with RTT logging:
    blinky_pca10056.hex
    I found this old thread I had on SWO: https://devzone.nordicsemi.com/f/nordic-q-a/31263/itm_sendchar-with-pca10056-nrf52840. As you can see, it will still require some configuration to get working plus we do not have a logger backend for it.
  • There seem to be two distinct behaviours.  I've switched to the release version of the JLink tools (6.64B) and I find that sometimes I get absolutely nothing at all from the target, no matter how many times I power it down, restart JLink, restart jlinkrttclient etc.  Other times it bursts into life and stays working for a while and in that situation I see lost characters, sometimes all of them past a certain point in execution, sometimes just a few.
    I changed main() to just do this:
        NRF_LOG_INIT(NULL);
        NRF_LOG_RAW_INFO("\nStarting up...\n");
        NRF_LOG_RAW_INFO("Printing a hex count 256 times in a loop...\n");
        for (size_t count = 0; count < 256; count++) {
            NRF_LOG_RAW_INFO("%02x", count);
        NRF_LOG_RAW_INFO("\nDone.\n");
        while (1) {};
    ...and sometimes it just stops in the middle, which you can see in the second case here:
    Starting up...
    000102030405060708090A0B0C0D0E0F101112131415161718191A1B1C1D1E1F202122232425262728292A2B2C2D2E2F303132333435363738393A3B3C3D3E3F404142434445464748494A4B4C4D4E4F505152535455565758595A5B5C5D5E5F606162636465666768696A6B6C6D6E6F707172737475767778797A7B7C7D7E7F808182838485868788898A8B8C8D8E8F909192939495969798999A9B9C9D9E9FA0A1A2A3A4A5A6A7A8A9AAABACADAEAFB0B1B2B3B4B5B6B7B8B9BABBBCBDBEBFC0C1C2C3C4C5C6C7C8C9CACBCCCDCECFD0D1D2D3D4D5D6D7D8D9DADBDCDDDEDFE0E1E2E3E4E5E6E7E8E9EAEBECEDEEEFF0F1F2F3F4F5F6F7F8F9FAFBFCFDFEFF
    Done.
    Starting up...
    Starting up...
    Done.
    Other times it loses characters, which if you look carefully you can see in the output here where it loses four prints, eight characters on the 6th iteration (I've inserted spaces so that you can see the gap):
    Starting up...
    Printing a hex count 256 * 10 times in a loop...
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
    Done.
    In these cases the viewer is still running, if I press the reset button on the target and it's in a "working" phase it reads the new output, it seem that the target either stopped or lost all further characters or lost some characters.  I had assumed that with NRF_LOG_DEFERRED 0 the NRF_LOG_RAW_INFO() call should act just like a printf() and block until all characters are sent, so there shouldn't be a timing/buffering issue.
    Maybe I should go try that SWO, see if it is more reliable...?  Are there any other reliability things you might suggest?  I'm using a 15 cm long USB cable and I've tried this on all the USB ports on my (Dell) laptop.
