I have an ongoing issue with using the Keil compiler and the supplied examples.
There has been some email correspondence which is detailed below:-
Hi David,
I have done what they have suggested (I think) and still get a compiler error.
Here is a screen shot of the packs installed:-
I open the following project:-
If I remove 8.3.1 family pack, I get a message saying the pack is not installed and it is then installed automatically.
I then try and compile the project and get the following error:-
I could try and locate the library, but when I tried this in the past it sometimes brings up more errors.
Best Regards
Paul
Hi Paul
Please see below from Nordic,
Hi David,
I have managed to find the email chain that has the work around to the issue that you are seeing:
install the latest mdk 8.30.2. Then try to rename \modules\nrfx\mdk\compiler_abstraction.h to compiler_abstraction_copy.h, then it should compile.
FYI: It should be possible to manually download 8.27.0 as described here:
https://devzone.nordicsemi.com/f/nordic-q-a/55378/mdk-uvision-sdk-16-0-keil-family-pack-installation/224413#224413
But using the latest mdk (currently: 8.30.2) is in general recommended (for latest errata workaround etc.)
I have asked the support manager to give me an update on where we are with a fix to this issue, rather than just a work around. I hope that I will be able to get back to you on this early next week.
Claire
