NRF9160 AWS FOTA over HTTPS
I have been reviewing this merge: https://github.com/NordicPlayground/fw-nrfconnect-nrf/pull/1982 and it appears that there is capability in the fota example to enable https/tls download for the aws fota example. It appears that DOWNLOAD_CLIENT_TLS needs to be set in the config, but when I set it in the KConfig it failed to build. I am using CLI, not Segger.
My guess is that I am setting this in the wrong place but my attempt at backtracking this is failing a bit. Was hoping that someone could chime in with where I need to enable the TLS.
  • I am planning on using S3 as the bin source, so the sample cert that was setup should suffice (from what I can tell).
  • I have successfully used the AWS FOTA example over http, but https is required for the project.
Apologies for the noob questions, just trying to sort this out.
