pstorage didn't load correct data
Hi everybody,
I test the pstorage library. But it didn't work. I print the result with uart, as the image shows. But as you see, It has some problem. And I have no idea why.
image description
I show the code In the following. I hope somebody can help me find which step went wrong.
By the way, I used the softdevice s110 v7.1.
Many thanks!
main function:
    uint8_t data[4]={1,2,3,4};
	uint8_t getdata[8];
	storage_init();
	clear_data();
	store_data(0,data,4,0);
	printf("store\r\n ");
	printf("%d ",data[0]);
	printf("%d ",data[1]);
	printf("%d ",data[2]);
	printf("%d \r\n",data[3]);
	load_data(0,getdata,4,0);
	printf("load \r\n ");
	printf("%d ",getdata[0]);
	printf("%d ",getdata[1]);
	printf("%d ",getdata[2]);
	printf("%d \r\n",getdata[3]);
function I used:
static void example_cb_handler(pstorage_handle_t  * handle,
                           uint8_t              op_code,
                           uint32_t             result,
                           uint8_t            * p_data,
                           uint32_t             data_len)
switch(op_code)
   case PSTORAGE_LOAD_OP_CODE:
       if (result == NRF_SUCCESS)
           printf("OP successful\r\n");
           printf("OP failed.\r\n");
       // Source memory can now be reused or freed.
static pstorage_handle_t base_handle;
static void storage_init(void)
     uint32_t retval;
	retval = pstorage_init();
	if(retval == NRF_SUCCESS)
			printf("Module initialization successful\r\n");
		 printf("Initialization failed, take corrective action.\r\n");
	pstorage_module_param_t param;
	param.block_size  = 16;
	param.block_count = 32;
	param.cb          = example_cb_handler;
	retval = pstorage_register(&param, &base_handle);
	if (retval == NRF_SUCCESS)
			printf("Registration successful%d    %d.\r\n",base_handle.module_id,base_handle.block_id);
			printf("Registration failed.\r\n");
    static void load_data(pstorage_size_t block_num,
										uint8_t * dest_data,
										pstorage_size_t size,
										pstorage_size_t offset)
pstorage_handle_t block_handle;
uint32_t          retval;
retval = pstorage_block_identifier_get(&base_handle, block_num, &block_handle);
		printf("get block ID success.ID: %d\r\n",block_handle.block_id);
		printf("get block failed.\r\n");
// Request to read 4 bytes from block at an offset of 12 bytes.
retval = pstorage_load(dest_data, &block_handle, size, offset);
		printf("load success.\r\n");
		printf("load failed.\r\n");
    static void store_data(pstorage_size_t block_num,
										 uint8_t * source_data,
uint32_t          retval;
// Request to write 8 bytes to block at an offset of 20 bytes.
retval = pstorage_store(&block_handle, source_data, size, offset);
		printf("store success.\r\n");
		printf("store failed.\r\n");
    static void clear_data(void){
uint32_t          retval;
// Request clearing of all blocks in the module. 32 blocks each with 16 bytes in size.
retval = pstorage_clear(&base_handle, 16 * 32);
		printf("clear success.\r\n");
		printf("clear failed.\r\n");
