I am setting up nRF connect SDK into Mac, however I received an error below when setting up a project in SEGGER:
Could you please help me to remove this error?
Thank you,
Thank you,
Can you provide some more information? What version of NCS are you using? Did it work with a previous version of SES? Have you defined the Zephyr path?
Øyvind
Hi
Thank you for your response.
NCS version: 1.1.0
SES version: 4.52
Below is what I did following the instruction of "Getting Started Assistant."
1. Install the toolchain: I installed and verified each item.
2. Clone the nRF connect SDK: I also installed and verified each item.
3. Download SEGGER Embedded Studio: I downloaded it.
4. Set up a project in SEGGER Embedded Studio: I set the path for each item.
However, when I tried to import a project, below error occurred.
In addition, when I tried to import a program to SEGGER, permission error occurred below:
Please advise me.
Thank you,
If using the latest version Catalina, please verify that you have added/allowed your software in the Security & Privacy settings. See this link for more information. Please grant both gnuarmemb and Segger access.
Also, please add full output from SES, change dropdown from tasks to output:
Then copy everything and add here.
Thanks!
Øyvind
