NRF52840 long range test
Hey guys, I've been trying to do a range test with 2x PCA10056 dev kits. I believe I've set everything up correctly and cannot achieve more than 300-400 meters before the connection drops out (300m after it had rained a lot and 400m on a clear blue sky day). I've also tried tested in different locations in case background noise was an issue but I cannot get close the 1300m that Nordic achieved.
Changes I've made to the hrs client/servers demos:
- Enable the coded PHY. Which appears to be working because the dongle I have cant see the advert from the peripheral but the central connects and notifications are sent and received.
- Increase transmit power to 8dbm (in scanning, advertising and connection).
Peripheral:
ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, m_tx_output_power);
Central:
err_code = nrf_ble_scan_start(&m_scan);
err_code = bsp_indication_set(BSP_INDICATE_SCANNING);
err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_SCAN_INIT, 0, m_tx_output_power);
On both peripheral and central:
static int m_tx_output_power = 8;
ble_gap_phys_t phys_settings =
.tx_phys = BLE_GAP_PHY_CODED,
.rx_phys = BLE_GAP_PHY_CODED,
case BLE_GAP_EVT_CONNECTED:
    err_code = sd_ble_gap_phy_update(p_gap_evt->conn_handle, &phys_settings);
    err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_CONN, m_conn_handle, m_tx_output_power);
- reduce NRF_SDH_BLE_GATT_MAX_MTU_SIZE to 23.
I've also tried attaching a external antenna to the coax connector with quoted gain of 6dbi and it made no difference to the range nor rssi reported when advertising. It appears as thought it is still using the onboard antenna.
What am I doing wrong??? Is there anything else I need to change in order to get more range? I'm looking to achieve a connection range of 500m while raining.
I'm using the nRF5SDK160098a08e2 SDK and S140 softdeivce included in the SDK. Attached is my source:
ble_src.zip
