questions for AGPS
Hi
I merged the AGPS to serial_lte_modem slm_at_gps.c but it did not work:
1, if I activate LTE in gps_thread_fn(), it will be failed in supl_session();
00> Established LTE link
00>
00> Starting SUPL session
00> ip 6cb1:61c0:: (c061b16c) port 7276
00>
00> ossinit failed, rc: 8
00>
00> SUPL session internal resources released
00>
00> Done
2, If I activated LTE and attached to network before starting GPS, the gps_data.data_id will never be NRF_GNSS_AGPS_DATA_ID, so the GPS will have no opportunity to download SUPL data from server. why?
    Sorry to push you, our project is waiting for this agps feature, can anybody provide the support of how to integrate the SUPL client library to serial_lte_modem sample?
  • If you are using Segger Embedded Studio, did you remember to re-open the project after making the changes to the prj.conf file?
    Looking at the GPS sample, it uses a stack of 4KB and heap of 2KB, so I don't know why your configuration did not work.
    I will ask our developers if they have other suggestions for you.
    We built the project by gcc on linux server.
    Looking forward to your update, thank you
  • The answer I got was this:
    This code does not use the zephyr kernel memory allocation code (k_malloc), it uses the libc vanilla malloc implementation. So this heap has to be tuned with either CONFIG_MINIMAL_LIBC_MALLOC_ARENA_SIZE or CONFIG_NEWLIB_LIBC_ALIGNED_HEAP_SIZE kconfig parameter, depending on which libc version is used.
    However, before you start playing around with those options, I want you to try something else:
    The GPS sample is using the Newlib libc, instead of Zephyr's standard minimal libc. However, the serial_lte_modem sample does not. Could you try to enable the Newlib libc?
    You can do that by adding CONFIG_NEWLIB_LIBC=y to your prj.conf file
  • Hi
    Still failed, the system will crash, here is the error log after enabled the Newlib libc
    And the result will be same with or without option "CONFIG_NEWLIB_LIBC_ALIGNED_HEAP_SIZE=4096"
    [00:00:17.443,603] <inf> lte: +CEREG: 2,"0001","01A2D101",7,0,0,"11100000",~
    [00:00:17.874,969] <inf> lte: +CEREG: 1,"0001","01A2D101",7,,,"00001111","1~
    [00:00:17.875,000] <inf> lte: Connected to LTE network.
    ULP encoding length: 38
    [00:00:18.049,774] <err> os: r0/a1:  0x00000002  r1/a2:  0x20023788  r2/a3:  0xf0f0f0f0
    [00:00:18.049,774] <err> os: r3/a4:  0x2002fe58 r12/ip:  0x00000000 r14/lr:  0x00043dcf
    [00:00:18.049,774] <err> os:  xpsr:  0x41000000
    [00:00:18.049,774] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000
    [00:00:18.049,804] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
    [00:00:18.049,804] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
    [00:00:18.049,835] <err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000
    [00:00:18.049,835] <err> os: fpscr:  0x20024acc
    [00:00:18.049,835] <err> os: Faulting instruction address (r15/pc): 0x00037bd6
    [00:00:18.049,835] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
    [00:00:18.049,835] <err> os: Current thread: 0x20023788 (unknown)
    [00:00:18.538,238] <err> fatal_error: Resetting system
    *** Booting Zephyr OS build v2.1.99-ncs1  ***
