questions for AGPS
Hi
I merged the AGPS to serial_lte_modem slm_at_gps.c but it did not work:
1, if I activate LTE in gps_thread_fn(), it will be failed in supl_session();
00> Established LTE link
00>
00> Starting SUPL session
00> ip 6cb1:61c0:: (c061b16c) port 7276
00>
00> ossinit failed, rc: 8
00>
00> SUPL session internal resources released
00>
00> Done
2, If I activated LTE and attached to network before starting GPS, the gps_data.data_id will never be NRF_GNSS_AGPS_DATA_ID, so the GPS will have no opportunity to download SUPL data from server. why?
  • It looks like you are able to initialize the decoding library now, which is good.
    The error a stack overflow, as is said in the log.
    You could try to figure out what thread overflows by using k_current_get, but my guess is that it is the GPS thread where you are running the SUPL library.
    You could try to increase the stack size of that thread a bit more.
  • Hi Didrik,
    Thanks for your help, now I can connect to the SUPL server and download the data.
    But there is a new problem: it seems the AGPS has not took effect, I tried several times the results were the same. Can you also take a look at below log? Sorry I have not any knowledge of SUPL...
    What is the meaning of log "No location data available"?
    00> [00:00:08.593,597] <inf> lte: +CEREG: 2,"0001","01A2D101",7,0,0,"11100000",~
    00> [00:00:09.005,401] <inf> lte: +CEREG: 1,"0001","01A2D101",7,,,"11100000","1~
    00> [00:00:09.005,432] <inf> lte: Connected to LTE network.
    00>
    00>
    00> ULP encoding length: 38
    00>
    00> Bytes sent: 38
    00>
    00> Bytes received: 34
    00>
    00> ULP ossDecode success, choice 3
    00>
    00> SUPL server responded using version 2.0.4
    00>
    00> SUPL response received
    00>
    00> ULP encoding length: 57
    00>
    00> Bytes sent: 57
    00>
    00> Bytes received: 708
    00>
    00> ULP ossDecode more input 4
    00>
    00> Bytes received: 1416
    00>
    00>
    00> Bytes received: 2124
    00>
    00>
    00> Bytes received: 3065
    00>
    00> ULP ossDecode success, choice 5
    00>
    00> [00:00:09.490,722] <inf> agps: Injected AGPS data, flags: 1, size: 16
    00>
    00> [00:00:09.491,943] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.492,553] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.493,316] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.494,110] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.494,720] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.495,391] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.496,063] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.496,673] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.497,253] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.498,107] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.500,762] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.501,373] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.502,136] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.502,716] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.503,356] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.504,058] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.504,669] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.505,371] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.506,134] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.506,713] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.509,338] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.510,009] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.510,742] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.511,383] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.512,115] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.512,725] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.513,366] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.514,190] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.514,984] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.515,563] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.518,188] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.518,951] <inf> agps: Injected AGPS data, flags: 2, size: 72
    00>
    00> [00:00:09.519,348] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.519,714] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.520,172] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.520,538] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.521,087] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.521,453] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.522,003] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.522,399] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.525,024] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.525,390] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.525,970] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.526,306] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.526,672] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.527,160] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.527,526] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.528,076] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.528,442] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.529,022] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.530,273] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.530,670] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.531,158] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.531,555] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.532,104] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.532,470] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.533,020] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.533,386] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.533,721] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.534,179] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.534,545] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.535,095] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> [00:00:09.538,482] <inf> agps: Injected AGPS data, flags: 3, size: 32
    00>
    00> No integrity data available
    00>
    00> [00:00:09.539,093] <inf> agps: Injected AGPS data, flags: 4, size: 8
    00>
    00> [00:00:09.549,652] <inf> agps: Injected AGPS data, flags: 6, size: 144
    00>
    00> No location data available
    00>
    00> No MCC location info available, MCC: 1
    00>
    00> SUPL POS received
    00>
    00> read again
    00>
    00>
    00> ULP ossDecode success, choice 6
    00>
    00> SUPLEND:
    00>
    00>   Mask: 0
    00>
    00>   Status: 0
    00>
    00> SUPL END received
    00>
    00>
    00> SUPL session finished
    00>
    00> Done
    00>
    00> [00:00:11.405,761] <inf> lte: +CEREG: 0,"0001","01A2D101",7,0,0,"11100000",~
    00> [00:00:12.769,317] <inf> agps: GPS restarted
    00> [00:00:14.769,439] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 7s
    00> [00:00:14.769,561] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 7s
    00> [00:00:14.806,579] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 7s
    00> [00:00:15.806,671] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 8s
    00> [00:00:16.807,250] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 9s
    00> [00:00:17.806,884] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 10s
    00> [00:00:18.807,067] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 11s
    00> [00:00:19.806,213] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 12s
    00> [00:00:20.806,793] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 13s
    00> [00:00:21.807,373] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 14s
    00> [00:00:22.806,610] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 15s
    00> [00:00:23.807,373] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 16s
    00> [00:00:24.807,098] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 17s
    00> [00:00:25.806,884] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 18s
    00> [00:00:26.807,464] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 19s
    00> [00:00:27.807,067] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 20s
    00> [00:00:28.806,640] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 21s
    00> [00:00:29.807,220] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 22s
    00> [00:00:30.807,006] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 23s
    00> [00:00:31.807,586] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 24s
    00> [00:00:32.807,189] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 25s
    00> [00:00:33.806,762] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 26s
    00> [00:00:34.807,434] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 27s
    00> [00:00:35.807,098] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 28s
    00> [00:00:36.807,647] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 29s
    00> [00:00:37.806,915] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 30s
    00> [00:00:38.806,945] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 31s
    00> [00:00:39.807,739] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 32s
    00> [00:00:40.807,586] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 33s
    00> [00:00:41.807,769] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 34s
    00> [00:00:42.809,112] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 35s
    00> [00:00:43.808,593] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 36s
    00> [00:00:44.809,204] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 37s
    00> [00:00:45.808,837] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 38s
    00> [00:00:46.808,837] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 39s
    00> [00:00:47.809,387] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 40s
    00> [00:00:48.808,807] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 41s
    00> [00:00:49.808,319] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 42s
    00> [00:00:50.808,868] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 43s
    00> [00:00:51.809,417] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 44s
    00> [00:00:52.809,020] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 45s
    00> [00:00:53.808,746] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 46s
    00> [00:00:54.809,417] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 47s
    00> [00:00:55.808,959] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 48s
    00> [00:00:56.809,417] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 49s
    00> [00:00:57.808,959] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 50s
    00> [00:00:58.809,600] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 51s
    00> [00:00:59.809,143] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 52s
    00> [00:01:00.809,570] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 53s
    00> [00:01:01.808,593] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 54s
    00> [00:01:02.809,539] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 55s
    00> [00:01:03.809,143] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 56s
    00> [00:01:04.809,600] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 57s
    00> [00:01:05.808,990] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 58s
    00> [00:01:06.809,387] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 59s
    00> [00:01:07.809,936] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 60s
    00> [00:01:08.809,326] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 61s
    00> [00:01:09.809,204] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 62s
    00> [00:01:10.809,295] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 63s
    00> [00:01:11.809,844] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 64s
    00> [00:01:12.809,326] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 65s
    00> [00:01:13.809,844] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 66s
    00> [00:01:14.809,356] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 67s
    00> [00:01:15.809,906] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 68s
    00> [00:01:16.809,539] <inf> agps: Tracking:1 Using:0 Unhealthy:0, since last fix 69s
    00> [00:01:17.809,539] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 70s
    00> [00:01:18.810,119] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 71s
    00> [00:01:19.810,729] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 72s
    00> [00:01:20.810,272] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 73s
    00> [00:01:21.810,791] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 74s
    00> [00:01:22.810,241] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 75s
    00> [00:01:23.810,760] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 76s
    00> [00:01:24.810,729] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 77s
    00> [00:01:25.811,309] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 78s
    00> [00:01:26.810,729] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 79s
    00> [00:01:27.811,584] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 80s
    00> [00:01:28.810,699] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 81s
    00> [00:01:29.810,821] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 82s
    00> [00:01:30.811,462] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 83s
    00> [00:01:31.810,882] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 84s
    00> [00:01:32.810,943] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 85s
    00> [00:01:33.811,706] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 86s
    00> [00:01:34.811,401] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 87s
    00> [00:01:35.811,584] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 88s
    00> [00:01:36.811,309] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 89s
    00> [00:01:37.810,943] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 90s
    00> [00:01:38.811,645] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 91s
    00> [00:01:39.811,157] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 92s
    00> [00:01:40.811,157] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 93s
    00> [00:01:41.811,859] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 94s
    00> [00:01:42.811,614] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 95s
    00> [00:01:43.811,065] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 96s
    00> [00:01:44.811,767] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 97s
    00> [00:01:45.811,157] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 98s
    00> [00:01:46.811,828] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 99s
    00> [00:01:47.810,668] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 100s
    00> [00:01:48.811,370] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 101s
    00> [00:01:49.812,103] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 102s
    00> [00:01:50.811,737] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 103s
    00> [00:01:51.811,401] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 104s
    00> [00:01:52.811,981] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 105s
    00> [00:01:53.811,370] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 106s
    00> [00:01:54.811,462] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 107s
    00> [00:01:55.812,225] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 108s
    00> [00:01:56.811,553] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 109s
    00> [00:01:57.812,133] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 110s
    00> [00:01:58.811,401] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 111s
    00> [00:01:59.811,492] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 112s
    00> [00:02:00.812,164] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 113s
    00> [00:02:01.811,553] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 114s
    00> [00:02:02.811,035] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 115s
    00> [00:02:03.812,377] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 116s
    00> [00:02:04.812,072] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 117s
    00> [00:02:05.812,286] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 118s
    00> [00:02:06.811,981] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 119s
    00> [00:02:07.811,645] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 120s
    00> [00:02:08.812,408] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 121s
    00> [00:02:09.812,011] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 122s
    00> [00:02:10.811,676] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 123s
    00> [00:02:11.812,561] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 124s
    00> [00:02:12.812,286] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 125s
    00> [00:02:13.812,438] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 126s
    00> [00:02:14.812,469] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 127s
    00> [00:02:15.811,828] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 128s
    00> [00:02:16.812,530] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 129s
    00> [00:02:17.812,042] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 130s
    00> [00:02:18.812,805] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 131s
    00> [00:02:19.812,286] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 132s
    00> [00:02:20.812,530] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 133s
    00> [00:02:21.811,981] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 134s
    00> [00:02:22.812,683] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 135s
    00> [00:02:23.812,042] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 136s
    00> [00:02:24.812,774] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 137s
    00> [00:02:25.812,561] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 138s
    00> [00:02:26.812,927] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 139s
    00> [00:02:27.812,255] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 140s
    00> [00:02:28.812,774] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 141s
    00> [00:02:29.812,225] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 142s
    00> [00:02:30.812,835] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 143s
    00> [00:02:31.812,164] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 144s
    00> [00:02:32.813,110] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 145s
    00> [00:02:33.812,896] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 146s
    00> [00:02:34.812,927] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 147s
    00> [00:02:35.812,957] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 148s
    00> [00:02:36.812,927] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 149s
    00> [00:02:37.813,018] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 150s
    00> [00:02:38.813,079] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 151s
    00> [00:02:39.812,500] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 152s
    00> [00:02:40.812,377] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 153s
    00> [00:02:41.812,927] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 154s
    00> [00:02:42.812,438] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 155s
    00> [00:02:43.813,262] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 156s
    00> [00:02:44.813,110] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 157s
    00> [00:02:45.813,110] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 158s
    00> [00:02:46.813,201] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 159s
    00> [00:02:47.813,232] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 160s
    00> [00:02:48.813,262] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 161s
    00> [00:02:49.813,201] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 162s
    00> [00:02:50.812,774] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 163s
    00> [00:02:51.812,561] <inf> agps: Tracking:2 Using:0 Unhealthy:0, since last fix 164s
    00> [00:02:52.813,720] <inf> agps: Tracking:3 Using:0 Unhealthy:0, since last fix 165s
    00> [00:02:53.813,385] <inf> agps: Tracking:3 Using:0 Unhealthy:0, since last fix 166s
    00> [00:02:54.814,697] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 167s
    00> [00:02:55.814,178] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 168s
    00> [00:02:56.814,178] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 169s
    00> [00:02:57.813,934] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 170s
    00> [00:02:58.813,690] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 171s
    00> [00:02:59.814,270] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 172s
    00> [00:03:00.814,361] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 173s
    00> [00:03:01.814,086] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 174s
    00> [00:03:02.814,117] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 175s
    00> [00:03:03.814,575] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 176s
    00> [00:03:04.814,208] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 177s
    00> [00:03:05.813,629] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 178s
    00> [00:03:06.814,361] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 179s
    00> [00:03:07.814,086] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 180s
    00> [00:03:08.814,025] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 181s
    00> [00:03:09.813,995] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 182s
    00> [00:03:10.813,995] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 183s
    00> [00:03:11.813,934] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 184s
    00> [00:03:12.814,758] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 185s
    00> [00:03:13.815,307] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 186s
    00> [00:03:14.814,636] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 187s
    00> [00:03:15.814,697] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 188s
    00> [00:03:16.814,849] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 189s
    00> [00:03:17.814,910] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 190s
    00> [00:03:18.814,758] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 191s
    00> [00:03:19.814,819] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 192s
    00> [00:03:20.815,551] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 193s
    00> [00:03:21.814,819] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 194s
    00> [00:03:22.814,941] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 195s
    00> [00:03:23.815,002] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 196s
    00> [00:03:24.814,849] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 197s
    00> [00:03:25.814,575] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 198s
    00> [00:03:26.814,941] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 199s
    00> [00:03:27.815,460] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 200s
    00> [00:03:28.816,009] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 201s
    00> [00:03:29.814,636] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 202s
    00> [00:03:30.814,422] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 203s
    00> [00:03:31.815,032] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 204s
    00> [00:03:32.815,551] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 205s
    00> [00:03:33.814,514] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 206s
    00> [00:03:34.815,246] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 207s
    00> [00:03:35.815,277] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 208s
    00> [00:03:36.815,002] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 209s
    00> [00:03:37.815,155] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 210s
    00> [00:03:38.815,063] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 211s
    00> [00:03:39.815,521] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 212s
    00> [00:03:40.815,216] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 213s
    00> [00:03:41.815,124] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 214s
    00> [00:03:42.814,971] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 215s
    00> [00:03:43.815,338] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 216s
    00> [00:03:44.815,795] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 217s
    00> [00:03:45.815,490] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 218s
    00> [00:03:46.816,009] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 219s
    00> [00:03:47.814,910] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 220s
    00> [00:03:48.815,460] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 221s
    00> [00:03:49.815,093] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 222s
    00> [00:03:50.815,490] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 223s
    00> [00:03:51.816,101] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 224s
    00> [00:03:52.815,704] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 225s
    00> [00:03:53.816,375] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 226s
    00> [00:03:54.815,216] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 227s
    00> [00:03:55.815,734] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 228s
    00> [00:03:56.815,612] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 229s
    00> [00:03:57.815,643] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 230s
    00> [00:03:58.815,368] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 231s
    00> [00:03:59.815,673] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 232s
    00> [00:04:00.816,192] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 233s
    00> [00:04:01.816,741] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 234s
    00> [00:04:02.815,368] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 235s
    00> [00:04:03.815,155] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 236s
    00> [00:04:04.815,917] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 237s
    00> [00:04:05.815,979] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 238s
    00> [00:04:06.816,467] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 239s
    00> [00:04:07.815,856] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 240s
    00> [00:04:08.815,551] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 241s
    00> [00:04:09.816,406] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 242s
    00> [00:04:10.815,979] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 243s
    00> [00:04:11.816,589] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 244s
    00> [00:04:12.816,711] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 245s
    00> [00:04:13.815,399] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 246s
    00> [00:04:14.816,192] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 247s
    00> [00:04:15.816,040] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 248s
    00> [00:04:16.816,101] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 249s
    00> [00:04:17.816,101] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 250s
    00> [00:04:18.816,131] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 251s
    00> [00:04:19.816,253] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 252s
    00> [00:04:20.816,925] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 253s
    00> [00:04:21.815,612] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 254s
    00> [00:04:22.816,192] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 255s
    00> [00:04:23.816,345] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 256s
    00> [00:04:24.816,406] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 257s
    00> [00:04:25.816,497] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 258s
    00> [00:04:26.816,314] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 259s
    00> [00:04:27.816,314] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 260s
    00> [00:04:28.817,108] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 261s
    00> [00:04:29.816,406] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 262s
    00> [00:04:30.816,528] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 263s
    00> [00:04:31.816,314] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 264s
    00> [00:04:32.816,375] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 265s
    00> [00:04:33.816,894] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 266s
    00> [00:04:34.816,497] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 267s
    00> [00:04:35.816,162] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 268s
    00> [00:04:36.816,711] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 269s
    00> [00:04:37.816,558] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 270s
    00> [00:04:38.816,711] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 271s
    00> [00:04:39.816,558] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 272s
    00> [00:04:40.816,009] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 273s
    00> [00:04:41.816,589] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 274s
    00> [00:04:42.817,077] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 275s
    00> [00:04:43.816,864] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 276s
    00> [00:04:44.816,894] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 277s
    00> [00:04:45.816,650] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 278s
    00> [00:04:46.817,504] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 279s
    00> [00:04:47.817,535] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 280s
    00> [00:04:48.817,626] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 281s
    00> [00:04:49.816,802] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 282s
    00> [00:04:50.817,352] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 283s
    00> [00:04:51.816,986] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 284s
    00> [00:04:52.816,741] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 285s
    00> [00:04:53.816,314] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 286s
    00> [00:04:54.817,077] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 287s
    00> [00:04:55.817,169] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 288s
    00> [00:04:56.816,833] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 289s
    00> [00:04:57.816,650] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 290s
    00> [00:04:58.817,047] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 291s
    00> [00:04:59.817,199] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 292s
    00> [00:05:00.816,925] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 293s
    00> [00:05:01.817,108] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 294s
    00> [00:05:02.816,558] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 295s
    00> [00:05:03.817,779] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 296s
    00> [00:05:04.817,321] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 297s
    00> [00:05:05.817,169] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 298s
    00> [00:05:06.817,047] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 299s
    00> [00:05:07.817,352] <inf> agps: Tracking:3 Using:3 Unhealthy:0, since last fix 300s
  • Great to hear you got it working!
    May I ask what stack size you ended up with?
    The "No location data available" means just that: the SUPL server does not have any location data to provide you. Instead, the library will fall back on its own table.
    Google's SUPL server is keeping a database over cell tower positions, but this database is not complete. So the "No location data available" is expected and happens all the time.
    When that happens, the library will fall back to assuming you are at the geographical center of the country you are in. How much this helps depends on the size of your country, and where in the country you are.
    The stack size remained as 4KB, added "CONFIG_NEWLIB_LIBC=y" and
    "CONFIG_NEWLIB_LIBC_ALIGNED_HEAP_SIZE=16384"
    Can you provide some SUPL server which supported chinese NB-IoT in China area for verification?
    I have tried the server "221.176.0.55" with China Mobile NB-IoT but no luck, Could you help check below error log and point out how to get it work?
    00> [00:00:42.133,605] <inf> lte: +CEREG: 1,"5B82","01966A1C",9,,,"00100001","0~
    00> [00:00:42.133,605] <inf> lte: Connected to LTE network.
    00> ip ddb0:37:: (3700b0dd) port 7275
    00> Connected to SUPL server "221.176.0.55:7275"
    00> Bytes sent: 38
    00> ULP ossDecode fail 5
    00> SUPL error: 1
    00> ULP encoding length: 18
    00> Bytes sent: 18
    00> [00:00:42.500,152] <err> agps: SUPL session failed: -1
    00> Done
    00> [00:00:42.819,000] <inf> lte: +CEREG: 0,"5B82","01966A1C",9,0,0,"11100000",~
    00> [00:00:43.192,077] <inf> agps: GPS restarted
    00> [00:00:45.192,199] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 20s
    00> [00:00:45.192,321] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 20s
    00> [00:00:45.217,224] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 20s
    00> [00:00:46.217,254] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 21s
    00> [00:00:47.217,773] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 22s
    00> [00:00:48.216,857] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 23s
    00> [00:00:49.217,376] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 24s
    00> [00:00:50.217,346] <inf> agps: Tracking:0 Using:0 Unhealthy:0, since last fix 25s
  • Hi, I am not aware of any SUPL servers that are supported in China, but I am looking into it.
    The error you get is DATA_ERROR, which means that the data you receive from the server is not formatted correctly.
    I have seen that error with another Chinese customer that tried to use the same server, but I was not able to identify the problem at the time.
    One of my colleagues says that China Telecom has a server that can be used if you are using China Telecom, but we have not been able to find the IP address of that server. Is it the 221.176.0.55 server you are using?
    I will look more into it tomorrow.
