DFU over BLE for Simblee
We have around 700 product in the field based on the Simblee BLE module, which was discontinued 1+ year ago. Application was developed using Simblee's proprietary library and the Arduino IDE. We are switching to Laird's BL652 and now using Nordic SDK 15.3.0.
We have our app, based on Nordic SDK 15.3 and S112, developed and working well on our custom board with Laird's BL652. We are adding a new feature that uses the Timeslot API. This API is not available through Simblee's proprietary library, so we are looking for ways of getting all 700 Simblee-based product in the field updated to a new app based on Nordic SDK 10.0 and S110.
I am confident we can develop the app and flash it to Simblee over USB. This video shows how to erase an RFduino (precursor to Simblee) and flash an app based on Nordic SDK.
What's unclear is whether or not it's possible to push an update out to our users via our iOS app and use DFU over BLE to update the Simblee peripherals. This would be ideal as it would not require that our users send their devices back for update.
Simblee uses nRF51822 revision 3 and I think has 128K flash. See attached Simblee data sheet (block diagram on page 6).
Simblee is flashed using the Arduino IDE and a USB shield. If "#include <ota_bootloader.h>" is in app source, a bootloader capable of legacy DFU over BLE is flashed along with the application. See screen capture of nRF Connect showing legacy DFU service, etc. All 700 devices in the field have OTA bootloader flashed.
I am able to build a new version (hex file) of the Simblee app (using Arduino IDE) and use version 0.5.2 of nrfutil to create a zip file:
nrfutil dfu genpkg new_app.zip --application new_app.hex --application-version 0xffff --dev-revision 0xffff --dev-type 0xffff --sd-req 0xfffe
(Interesting that --sd-req is 0xfffe.) Using iOS-Pods-DFU-Library, I can then use the standard procedure to perform DFU over BLE. Here's the code (objective C):
NSURL *bundledFirmwareURL = [[NSBundle mainBundle] URLForResource:@"new_app" withExtension:@"zip"];
DFUFirmware *selectedFirmware = [[DFUFirmware alloc] initWithUrlToZipFile:bundledFirmwareURL];
DFUServiceInitiator *initiator = [[DFUServiceInitiator alloc] initWithQueue:dispatch_get_main_queue()
delegateQueue:dispatch_get_main_queue()
progressQueue:dispatch_get_main_queue()
loggerQueue:dispatch_get_main_queue()];
[initiator withFirmware:selectedFirmware];
initiator.packetReceiptNotificationParameter = 2; // default is 12
initiator.logger = self; // - to get log info
initiator.delegate = self; // - to be informed about current state and errors
initiator.progressDelegate = self; // - to show progress bar
DFUServiceController *controller = [initiator startWithTarget: myPeripheral];
Here's a log of DFU process:
2020-04-21 09:32:46.898944-0600 myapp[6798:4964585] dfuStateDidChangeTo: DFUStateConnecting
2020-04-21 09:32:46.898999-0600 myapp[6798:4964585] self.centralManager.delegate is <myCentralManager: 0x1c01bed80>
2020-04-21 09:32:46.899737-0600 myapp[6798:4964585] logWith: [Callback] Central Manager did update state to: Powered ON
2020-04-21 09:32:46.899757-0600 myapp[6798:4964585] logWith: Connecting to p1...
2020-04-21 09:32:46.899769-0600 myapp[6798:4964585] logWith: centralManager.connect(peripheral, options: nil)
2020-04-21 09:32:46.900128-0600 myapp[6798:4964585] logWith: [Callback] Central Manager did connect peripheral
2020-04-21 09:32:46.900150-0600 myapp[6798:4964585] logWith: Connected to p1
2020-04-21 09:32:46.900161-0600 myapp[6798:4964585] logWith: Discovering services...
2020-04-21 09:32:46.900171-0600 myapp[6798:4964585] logWith: peripheral.discoverServices(nil)
2020-04-21 09:32:46.901252-0600 myapp[6798:4964585] logWith: Services discovered
2020-04-21 09:32:46.901281-0600 myapp[6798:4964585] logWith: Starting Legacy DFU...
2020-04-21 09:32:46.901292-0600 myapp[6798:4964585] logWith: Connected to p1
2020-04-21 09:32:46.901303-0600 myapp[6798:4964585] logWith: Services discovered
2020-04-21 09:32:46.901312-0600 myapp[6798:4964585] logWith: Legacy DFU Service found
2020-04-21 09:32:46.901322-0600 myapp[6798:4964585] logWith: Discovering characteristics in DFU Service...
2020-04-21 09:32:46.901332-0600 myapp[6798:4964585] logWith: peripheral.discoverCharacteristics(nil, for: 00001530-1212-EFDE-1523-785FEABCD123)
2020-04-21 09:32:47.146054-0600 myapp[6798:4964585] logWith: DFU characteristics discovered
2020-04-21 09:32:47.146596-0600 myapp[6798:4964585] logWith: Reading DFU Version number...
2020-04-21 09:32:47.146757-0600 myapp[6798:4964585] logWith: peripheral.readValue(00001534-1212-EFDE-1523-785FEABCD123)
2020-04-21 09:32:47.202713-0600 myapp[6798:4964585] logWith: Read Response received from 00001534-1212-EFDE-1523-785FEABCD123, value (0x): 0100
2020-04-21 09:32:47.202883-0600 myapp[6798:4964585] logWith: Version number read: 0.1
2020-04-21 09:32:47.203008-0600 myapp[6798:4964585] dfuStateDidChangeTo: DFUStateStarting
2020-04-21 09:32:47.203542-0600 myapp[6798:4964585] self.centralManager.delegate is <myCentralManager: 0x1c01bed80>
2020-04-21 09:32:47.203698-0600 myapp[6798:4964585] logWith: Enabling notifications for 00001531-1212-EFDE-1523-785FEABCD123...
2020-04-21 09:32:47.203836-0600 myapp[6798:4964585] logWith: peripheral.setNotifyValue(true, for: 00001531-1212-EFDE-1523-785FEABCD123)
2020-04-21 09:32:47.323522-0600 myapp[6798:4964585] logWith: Notifications enabled for 00001531-1212-EFDE-1523-785FEABCD123
2020-04-21 09:32:47.323756-0600 myapp[6798:4964585] logWith: DFU Control Point notifications enabled
2020-04-21 09:32:47.323890-0600 myapp[6798:4964585] logWith: Application with buttonless update found
2020-04-21 09:32:47.324011-0600 myapp[6798:4964585] dfuStateDidChangeTo: DFUStateEnablingDfuMode
2020-04-21 09:32:47.324256-0600 myapp[6798:4964585] self.centralManager.delegate is <myCentralManager: 0x1c01bed80>
2020-04-21 09:32:47.324767-0600 myapp[6798:4964585] logWith: Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123...
2020-04-21 09:32:47.324929-0600 myapp[6798:4964585] logWith: peripheral.writeValue(0x0104, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse)
2020-04-21 09:32:47.381446-0600 myapp[6798:4964585] logWith: Data written to 00001531-1212-EFDE-1523-785FEABCD123
2020-04-21 09:32:47.381623-0600 myapp[6798:4964585] logWith: Jump to bootloader (Op Code = 1, Upload Mode = 4) request sent
2020-04-21 09:32:47.568087-0600 myapp[6798:4964585] logWith: [Callback] Central Manager did disconnect peripheral
2020-04-21 09:32:47.568292-0600 myapp[6798:4964585] logWith: Disconnected by the remote device
2020-04-21 09:32:47.568425-0600 myapp[6798:4964585] logWith: Connecting to p1...
2020-04-21 09:32:47.568555-0600 myapp[6798:4964585] logWith: centralManager.connect(peripheral, options: nil)
2020-04-21 09:32:47.990087-0600 myapp[6798:4964585] logWith: [Callback] Central Manager did connect peripheral
2020-04-21 09:32:47.990305-0600 myapp[6798:4964585] logWith: Connected to p1
2020-04-21 09:32:47.990439-0600 myapp[6798:4964585] logWith: Discovering services...
2020-04-21 09:32:47.990561-0600 myapp[6798:4964585] logWith: peripheral.discoverServices([00001530-1212-EFDE-1523-785FEABCD123])
2020-04-21 09:32:48.348668-0600 myapp[6798:4964585] logWith: Services discovered
2020-04-21 09:32:48.348880-0600 myapp[6798:4964585] logWith: Legacy DFU Service found
2020-04-21 09:32:48.349146-0600 myapp[6798:4964585] logWith: Discovering characteristics in DFU Service...
2020-04-21 09:32:48.349300-0600 myapp[6798:4964585] logWith: peripheral.discoverCharacteristics(nil, for: 00001530-1212-EFDE-1523-785FEABCD123)
2020-04-21 09:32:48.590536-0600 myapp[6798:4964585] logWith: DFU characteristics discovered
2020-04-21 09:32:48.590722-0600 myapp[6798:4964585] logWith: Reading DFU Version number...
2020-04-21 09:32:48.590997-0600 myapp[6798:4964585] logWith: peripheral.readValue(00001534-1212-EFDE-1523-785FEABCD123)
2020-04-21 09:32:48.648168-0600 myapp[6798:4964585] logWith: Read Response received from 00001534-1212-EFDE-1523-785FEABCD123, value (0x): 0600
2020-04-21 09:32:48.648352-0600 myapp[6798:4964585] logWith: Version number read: 0.6
2020-04-21 09:32:48.648480-0600 myapp[6798:4964585] dfuStateDidChangeTo: DFUStateStarting
2020-04-21 09:32:48.648896-0600 myapp[6798:4964585] self.centralManager.delegate is <myCentralManager: 0x1c01bed80>
2020-04-21 09:32:48.649032-0600 myapp[6798:4964585] logWith: Enabling notifications for 00001531-1212-EFDE-1523-785FEABCD123...
2020-04-21 09:32:48.649222-0600 myapp[6798:4964585] logWith: peripheral.setNotifyValue(true, for: 00001531-1212-EFDE-1523-785FEABCD123)
2020-04-21 09:32:48.769654-0600 myapp[6798:4964585] logWith: Notifications enabled for 00001531-1212-EFDE-1523-785FEABCD123
2020-04-21 09:32:48.769859-0600 myapp[6798:4964585] logWith: DFU Control Point notifications enabled
2020-04-21 09:32:48.770003-0600 myapp[6798:4964585] logWith: Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123...
2020-04-21 09:32:48.770136-0600 myapp[6798:4964585] logWith: peripheral.writeValue(0x0104, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse)
2020-04-21 09:32:48.770262-0600 myapp[6798:4964585] logWith: Writing image sizes (0b, 0b, 34376b) to characteristic 00001532-1212-EFDE-1523-785FEABCD123...
2020-04-21 09:32:48.770387-0600 myapp[6798:4964585] logWith: peripheral.writeValue(0x000000000000000048860000, for: 00001532-1212-EFDE-1523-785FEABCD123, type: .withoutResponse)
2020-04-21 09:32:48.826747-0600 myapp[6798:4964585] logWith: Data written to 00001531-1212-EFDE-1523-785FEABCD123
2020-04-21 09:32:48.826945-0600 myapp[6798:4964585] logWith: Start DFU (Op Code = 1, Upload Mode = 4) request sent
2020-04-21 09:32:50.631436-0600 myapp[6798:4964585] logWith: Notification received from 00001531-1212-EFDE-1523-785FEABCD123, value (0x): 100101
2020-04-21 09:32:50.631663-0600 myapp[6798:4964585] logWith: Response (Op Code = 1, Status = 1) received
2020-04-21 09:32:50.631807-0600 myapp[6798:4964585] logWith: Writing Initialize DFU Parameters...
2020-04-21 09:32:50.631932-0600 myapp[6798:4964585] logWith: Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123...
2020-04-21 09:32:50.632057-0600 myapp[6798:4964585] logWith: peripheral.writeValue(0x0200, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse)
2020-04-21 09:32:50.632179-0600 myapp[6798:4964585] logWith: Writing to characteristic 00001532-1212-EFDE-1523-785FEABCD123...
2020-04-21 09:32:50.632310-0600 myapp[6798:4964585] logWith: peripheral.writeValue(0xffffffffffff00000100feff0cc0, for: 00001532-1212-EFDE-1523-785FEABCD123, type: .withoutResponse)
2020-04-21 09:32:50.632433-0600 myapp[6798:4964585] logWith: Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123...
2020-04-21 09:32:50.632555-0600 myapp[6798:4964585] logWith: peripheral.writeValue(0x0201, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse)
2020-04-21 09:32:50.686862-0600 myapp[6798:4964585] logWith: Data written to 00001531-1212-EFDE-1523-785FEABCD123
2020-04-21 09:32:50.746196-0600 myapp[6798:4964585] logWith: Data written to 00001531-1212-EFDE-1523-785FEABCD123
2020-04-21 09:32:50.748853-0600 myapp[6798:4964585] logWith: Notification received from 00001531-1212-EFDE-1523-785FEABCD123, value (0x): 100201
2020-04-21 09:32:50.749026-0600 myapp[6798:4964585] logWith: Response (Op Code = 2, Status = 1) received
2020-04-21 09:32:50.749217-0600 myapp[6798:4964585] logWith: Initialize DFU Parameters completed
2020-04-21 09:32:50.750442-0600 myapp[6798:4964585] dfuStateDidChangeTo: DFUStateUploading
2020-04-21 09:32:50.750809-0600 myapp[6798:4964585] self.centralManager.delegate is <myCentralManager: 0x1c01bed80>
2020-04-21 09:32:50.750953-0600 myapp[6798:4964585] logWith: Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123...
2020-04-21 09:32:50.751086-0600 myapp[6798:4964585] logWith: peripheral.writeValue(0x080200, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse)
2020-04-21 09:32:50.808035-0600 myapp[6798:4964585] logWith: Data written to 00001531-1212-EFDE-1523-785FEABCD123
2020-04-21 09:32:50.808253-0600 myapp[6798:4964585] logWith: Packet Receipt Notif Req (Op Code = 8, Value = 2) request sent
2020-04-21 09:32:50.808391-0600 myapp[6798:4964585] logWith: Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123...
2020-04-21 09:32:50.808670-0600 myapp[6798:4964585] logWith: peripheral.writeValue(0x03, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse)
2020-04-21 09:32:50.867842-0600 myapp[6798:4964585] logWith: Data written to 00001531-1212-EFDE-1523-785FEABCD123
2020-04-21 09:32:50.868020-0600 myapp[6798:4964585] logWith: Uploading firmware...
2020-04-21 09:32:50.868156-0600 myapp[6798:4964585] logWith: Sending firmware to DFU Packet characteristic...
2020-04-21 09:32:50.868323-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 0
2020-04-21 09:32:51.348064-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 1
2020-04-21 09:32:51.887798-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 2
2020-04-21 09:32:52.367730-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 3
2020-04-21 09:32:52.907785-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 4
2020-04-21 09:32:53.478040-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 5
2020-04-21 09:32:54.018251-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 6
2020-04-21 09:32:54.557918-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 7
2020-04-21 09:32:55.068485-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 8
2020-04-21 09:32:55.637790-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 9
2020-04-21 09:32:56.117765-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 10
2020-04-21 09:32:56.657789-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 11
2020-04-21 09:32:57.227668-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 12
2020-04-21 09:32:57.707820-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 13
2020-04-21 09:32:58.337878-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 14
2020-04-21 09:32:58.817613-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 15
2020-04-21 09:33:42.047232-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 96
2020-04-21 09:33:42.526689-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 97
2020-04-21 09:33:43.096535-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 98
2020-04-21 09:33:43.576753-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 99
2020-04-21 09:33:44.115962-0600 myapp[6798:4964585] dfuProgressDidChangeFor: 100
2020-04-21 09:33:44.177036-0600 myapp[6798:4964585] logWith: Notification received from 00001531-1212-EFDE-1523-785FEABCD123, value (0x): 100301
2020-04-21 09:33:44.177245-0600 myapp[6798:4964585] logWith: Response (Op Code = 3, Status = 1) received
2020-04-21 09:33:44.177383-0600 myapp[6798:4964585] logWith: Upload completed in 53.31 seconds
2020-04-21 09:33:44.177659-0600 myapp[6798:4964585] dfuStateDidChangeTo: DFUStateValidating
2020-04-21 09:33:44.177920-0600 myapp[6798:4964585] self.centralManager.delegate is <myCentralManager: 0x1c01bed80>
2020-04-21 09:33:44.178052-0600 myapp[6798:4964585] logWith: Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123...
2020-04-21 09:33:44.178299-0600 myapp[6798:4964585] logWith: peripheral.writeValue(0x04, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse)
2020-04-21 09:33:44.235144-0600 myapp[6798:4964585] logWith: Data written to 00001531-1212-EFDE-1523-785FEABCD123
2020-04-21 09:33:44.235320-0600 myapp[6798:4964585] logWith: Validate Firmware (Op Code = 4) request sent
2020-04-21 09:33:44.266531-0600 myapp[6798:4964585] logWith: Notification received from 00001531-1212-EFDE-1523-785FEABCD123, value (0x): 100401
2020-04-21 09:33:44.266707-0600 myapp[6798:4964585] logWith: Response (Op Code = 4, Status = 1) received
2020-04-21 09:33:44.266840-0600 myapp[6798:4964585] dfuStateDidChangeTo: DFUStateDisconnecting
2020-04-21 09:33:44.267228-0600 myapp[6798:4964585] self.centralManager.delegate is <myCentralManager: 0x1c01bed80>
2020-04-21 09:33:44.267456-0600 myapp[6798:4964585] logWith: Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123...
2020-04-21 09:33:44.267631-0600 myapp[6798:4964585] logWith: peripheral.writeValue(0x05, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse)
2020-04-21 09:33:44.325032-0600 myapp[6798:4964585] logWith: Data written to 00001531-1212-EFDE-1523-785FEABCD123
2020-04-21 09:33:44.325210-0600 myapp[6798:4964585] logWith: Activate and Reset (Op Code = 5) request sent
2020-04-21 09:33:44.512551-0600 myapp[6798:4964585] logWith: [Callback] Central Manager did disconnect peripheral
2020-04-21 09:33:44.512743-0600 myapp[6798:4964585] logWith: Disconnected by the remote device
2020-04-21 09:33:44.512872-0600 myapp[6798:4964585] dfuStateDidChangeTo: DFUStateCompleted
2020-04-21 09:33:44.513096-0600 myapp[6798:4964585] self.centralManager.delegate is <myCentralManager: 0x1c01bed80>
We don't know how Simblee's library was developed, if with the Nordic SDK of the time, which SoftDevice and version was used, if at all. All we know is all Simblee devices in the field have the legacy DFU service installed. Is there a way we can learn more, like which SD is used? If we knew that a SD was used and the version, we could develop our new Nordic SDK-based app for Simblee so that DFU over BLE would work? Perhaps the only DFU over BLE option available is to update all of bootloader, SD and app. Given Simblee is only 128K, not sure if this is possible.
Any guidance would be greatly appreciated.
Many thanks,
Tim
Simblee RFD77101 Datasheet v2.2.pdf
  • Hi Edvin. I tried connecting to Simblee via nRF51 DK and it appears that it's readback protected. This is not surprising.
    So will turn my attention to building an nRF51 DFU/BLE bootloader and see if the Simblee DFU bootloader will accept it.
    I don't suppose it's possible to look inside the Simblee DFU bootloader hex file to see which SD is required? I've attached the hex.
    Tim
    ota_bootloader_dual_bank.hex
  • The bootloader is usually placed in the top of the flash. This is done to minimize the restriction of the application size.
    The bootloader does not contain the softdevice. Check out the memory layout for the bootloader:
    https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v12.3.0/lib_bootloader.html?cp=7_5_8_3_5_0_1#lib_bootloader_memory
  • Thanks Edvin. Yes, I realize the SD is separate from the BL and app. I wondered, though, if the SD required by the BL might be somehow specified in the BL itself. Please pardon my inexperience.
    Can the location of the application in flash offer a clue of the required SD? The start address of the app allows enough room for the MBR and SD. Each SD version has a particular size.
    Thank you,
    Tim
  • No worries, Tim. It may say something about the version in the BL hex file, but as soon as they change just a tiny thing in the bootloader project, it may change the location of many (!) things in the .hex file. In this case, you are looking at a binary blob that you would have to reverse engineer in some way. Besides, I believe that the softdevice version is stored in the bootloader settings, and not in the bootloader itself. And since the requirement for the dfu image is 0xfffd, I doubt it will say.
    Unfortunately, the flash start is quite generic. It is rounded up to the next page. So this would indicate that the softdevice ends between 0x1E000 and 0x1EFFF.
    Looking at the latest softdevice for nRF51, S130 from SDK12.3.0, the applications from this version starts at 0x1B000, so I am not sure this is actually a hint. Please also note that the start address of an application transferred over DFU doesn't really matter. The bootloader will place it after the softdevice. They may have known this, and just set a "random" address.
    I am not sure why you would need to know what softdevice version they use? Can you remind me? You don't need this in order to transfer the new bootloader (if possible).
  • Thank you Edvin. All understandable, and I’m learning a lot from you.
    I agree the best approach is to replace the Simblee bootloader (via DFU over BLE) with one I develop thereby giving us full control over the DFU process from that point on. However, I speculate that the Simblee bootloader does not allow update of the bootloader itself. If this turns out to be the case, then it seems to me our only option to update the application on the 700 Simblees in the field would be to first discover the SoftDevice and version required by the currently installed Simblee bootloader and develop our new nRF51822 app accordingly, then push it out to our users via a new version of our iOS app that uses DFU over BLE to update the application. Am I understanding this correctly?
    The next step is to build a DFU/BLE bootloader for nRF51822 and see if the currently installed Simblee bootloader will accept it. This is what I’m working on now.
    I am also going to try and reach the developer of Simblee and also the company that acquired the product (AMS) to see if, given they discontinued the Simblee product line, they might provide developers that used Simblee access to information that would be helpful.
    All along I’ve been assuming that if I’m unable to update the application on Simblee, either by updating the bootloader, SoftDevice and application, or just the application, that we would be able to have our 700 customers return their devices and we could erase the flash and install our own bootloader, application (and appropriate SoftDevice) via an nRF51 DK. Unfortunately, the Simblee flash process via the Arduino IDE uses Serial IO on GPIO 0/1 whereas SWD (required by nRF51 DK) is supported on two different Simblee pins and our board layout does not provide access to SWDCLK. So we can’t even update the application by recalling product.
    Will see where this all leads. Enjoying the learning along the way.
    Many thanks,
    Tim
