New association request on second Central connection
I'm encountering a strange problem with the nRF52832 when it works as Central with two bonded Peripherals connection.
In particular I'm able to secure the connection with the first Peripherals by calling the pm_handler_secure_on_connection() function as soon as the BLE_GAP_EVT_CONNECTED event is sent by the softdevice.
When I establish the connection with the second one Peripheral (a smartphone) I receive a new association request on the smartphone display, please consider that the device was previously bonded.
If I accept the new pairing with the device (by pressing “OK” on the smartphone display, I use the Just Works method) a new bonding occurs and the connection is secured, after a disconnection I have to pair again.
I use the scan with policy WHITELIST and I call the  sd_ble_gap_connect() function when the NRF_BLE_SCAN_EVT_WHITELIST_ADV_REPORT occurs.
Any idea about the problem?
    Are all devices' bonding information deleted when you start your test, so that you are 100% sure that one device doesn't have old bonding information and the connected device still tries to use some bonding information?
    What are the peripherals in the connection? Are they nRF DKs running your application? Or are both peripherals phones? Does it only happen if the phone is the peripheral? Does it happen if you try to bond with the ble_app_gls example as the peripheral, and the phone as a central using nRF Connect?
    I am afraid you will have to capture a sniffer trace of the packets when you try to connect to the bonded device. You can use the nRF Sniffer.
    Please take one sniffer trace when you delete the bonding information on both devices first, and one where you don't delete the bonding information before you connect.
  • Hi Edvin,
    I perform the following steps during my tests:
    1) turn-on my board (with nRF52832 - Central)
    2) clear the bonding information (by calling the pm_peers_delete() function)
    3) perform a scan with filter policy BLE_GAP_SCAN_FP_ACCEPT_ALL
    4) connect and pair with bonding the two devices (not already bonded with my board) that contains particular UUID into the advertising packet. The first one device is a smartphone and the second one is a PCA10040 board with the ble_app_hrs example of the SDK 16.0.
    5) disconnect the devices after bonding
    6) start a new scan with filter policy  BLE_GAP_SCAN_FP_WHITELIST
    The first connection with the PCA10040 board is established without new association but the second one, with the Android smartphone, requires a new association.
    Thank you for your attention.
     How do you do this? Button press? Disconnect from phone? nRF52 reset? What does the log say?
    The first pairing doesn't require you to click "pair" or enter a passkey, but not the second one, is that what you mean by "association"?
    Did you try to sniff the connection?
    Does this happen on more phones? Have you tried other Android phones? iPhones?
  • Hi Edvin,
    in order to disconnect the devices I turn-off the nRF52832 on the PCA10040 and turn-off the Bluetooth interface of the smartphone. I think that it is not necessary to close all the connections before to change the filter policy of the scan an start the scan again with the BLE_GAP_SCAN_FP_WHITELIST ( point 6) of my test).
    Of course the first pairing (point 4) of my test ) requires the click on the Android pop-up. As soon as I press "OK" on the smartphone display I see the following log messages:
    00> [00:01:13.167,236] <info> app: CENTRAL: Trying to Connect with, peripheral with service ID: 0.
    00>
    00> [00:01:13.167,236] <info> app: CENTRAL EVT: 16.
    00>
    00> [00:01:13.167,236] <debug> peer_manager_handler: Connected, securing connection. conn_handle: 0
    00>
    00> [00:01:13.167,236] <debug> peer_manager_handler: Event PM_EVT_CONN_SEC_PARAMS_REQ
    00>
    00> [00:01:13.167,236] <debug> peer_manager_handler: Security parameter request
    00>
    00> [00:01:13.167,236] <info> app: PM_EVT_CONN_SEC_PARAMS_REQ
    00>
    00>
    00>
    00> [00:01:13.167,236] <debug> peer_manager_handler: Event PM_EVT_CONN_SEC_START
    00>
    00> [00:01:13.167,236] <debug> peer_manager_handler: Connection secu: Bonding
    00>
    00>
    00> [00:01:13.167,236] <info> app: CENTRAL: Connected, handle: 0.
    00>
    00> [00:01:13.167,236] <debug> nrf_ble_gq: Purging request queue with id: 0
    00>
    00> [00:01:13.167,236] <debug> nrf_ble_gq: Registering connection handle: 0x0000
    00>
    00> [00:01:13.167,236] <debug> ble_db_disc: Starting discovery of service with UUID 0xE128 on connection handle 0x0.
    00>
    00> [00:01:13.167,236] <debug> nrf_ble_gq: Adding item to the request queue
    00>
    00> [00:01:13.167,236] <debug> nrf_ble_gq: GATTC Primary Services Discovery Request
    00>
    00> [00:01:13.167,236] <debug> nrf_ble_gq: SD GATT procedure (2) suc[00:01:13.167,236]
    00>
    00> [00:01:13.167,236] <info> app: CENTRAL EVT: 29.
    00>
    00> [00:01:13.167,236] <debug> nrf_ble_gq: Processing the request queue...
    00>
    00> [00:01:13.167,236] <debug> ble_db_disc: Found service UUID 0xE128.
    00>
    00>
    00> [00:01:13.167,236] <debug> nrf_ble_gq: GATTC Characteristic Discovery Request
    00>
    00> [00:01:13.167,236] <debug> nrf_ble_gq: SD GATT procedure (3) succeeded on connection handle: 0.
    00>
    00> [00:01:13.167,236] <info> app: CENTRAL EVT: 48.
    00>
    00> [00:01:13.167,236] <info> app: CENTRAL EVT: 18.
    00>
    00> [00:01:13.167,236] <info> app: BLE_GAP_EVT_CONN_PARAM_UPDATE
    00>
    00>
    00>
    00>
    00>
    00> [00:01:13.167,236] <info> app: CENTRAL EVT: 50.
    00>
    00>
    00>
    00> [00:01:13.167,236] <debug> nrf_ble_gq: GATTC Characteristic Descriptor Request
    00>
    00> [00:01:13.167,236] <debug> nrf_ble_gq: SD GATT procedure (4) succeeded on connection handle: 0.
    00>
    00>
    00>
    00>
    00>
    00> [00:01:13.167,236] <debug> ble_db_disc: Discovery of service with UUID 0xE128 completed with success on connection handle 0x0.
    00>
    00> [00:01:13.167,236] <debug> ble_db_disc: Starting discovery of service with UUID 0x180D on connection handle 0x0.
    00>
    00>
    00>
    00> ceeded on connection handle: 0.
    00>
    00>
    00>
    00> [00:01:13.167,236] <debug> nrf_ble_gq: GATTC Write Request
    00>
    00> [00:01:13.167,236] <debug> nrf_ble_gq: SD GATT procedure (1) succeeded on connection handle: 0.
    00>
    00> [00:01:13.916,381] <info> app: BLE_GAP_EVT_CONN_PARAM_UPDATE
    00>
    00> [00:01:14.318,786] <debug> peer_manager_handler: Event PM_EVT_CONN_SEC_SUCCEEDED
    00>
    00> [00:01:14.318,786] <info> peer_manager_handler: Connection secured: role: Central, conn_handle: 0, procedure: Bonding
    00>
    00> [00:01:14.318,908] <info> app: PM_EVT_CONN_SEC_SUCCEEDED
    00>
    00> [00:01:14.392,456] <debug> peer_manager_handler: Event PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
    00>
    00> [00:01:14.392,456] <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Bonding data, action: Update
    00>
    00> [00:01:14.392,883] <info> app: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
    00>
    00> [00:01:14.395,263] <debug> peer_manager_handler: Event PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
    00>
    00> [00:01:14.395,263] <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update
    00>
    00> [00:01:14.395,507] <info> app: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
    00>
    00>
    00>
    00> [00:01:14.400,939] <debug> peer_manager_handler: Event PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
    00>
    00>
    00> [00:01:14.401,184] <info> app: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
    00>
    00>
    00>
    00> [00:01:14.863,952] <debug> nrf_ble_gq: Processing the request queue...
    00>
    00> [00:01:14.864,013] <debug> ble_hrs_c: Received HVX on link 0x0, not associated to this instance. Ignore.
    00>
    00> [00:01:14.864,013] <info> app: CENTRAL EVT: 57.
    00>
    00> [00:01:15.629,028] <info> app: CENTRAL EVT: 31.
    00>
    00> [00:01:15.629,028] <info> app: BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST
    00>
    00>
    00>
    00> [00:01:15.681,396] <info> app: CENTRAL EVT: 18.
    00>
    00> [00:01:15.681,396] <info> app: BLE_GAP_EVT_CONN_PARAM_UPDATE
    00>
    00>
    00>
    00> [00:01:18.289,184] <info> app: CENTRAL EVT: 17.
    00>
    00> [00:01:18.289,184] <info> app: CENTRAL: Disconnected, handle: 0, reason: 0x16
    00>
    00>
    After the disconnection I connect the PCA10040 board and than the previusly bonded smartphone (the same of the above trave).
    The problem is that I see a new pair request on the smartphone display after the new connection.
    If I click "Ok" again on the smartphone display I see the same log above posted, if I click "No" I see the pairing error.
  • Can you try to disconnect from the phone, instead of resetting the nRF52, please?
    For the future: When you want to attach logs or snippets, please use the insert->code function.
