When we test the BLE conducted power, we find some phenomena, when IC power is setted to 0dBm, the active power loss is similar with passive path loss, it is consistent with the theoretical calculation; But if setting to 4dBm or 8dBm, the active power loss is more than passive path loss. The more detail test report in the attachment. And Base on these test data, when we set the IC power to 4dBm, it seems that the actual output power will chanBLT TX power report1.xlsxge under different load. Could you help to analysis the reason and share some load-pull information to us?
