nrf_drv and nrfx drivers
nRF5_SDK_16.0.0_98a08e2\examples\peripheral\uart. In the SDK 16 ,UART example,why the legacy driver nrf_drv_uart.c is used instead of the sdk recommended nrfx_uart.c.
Secondly, which takes priority in selecting drivers sdk_config.h or the source file and the includes.
    This is correct, the example uses the legacy drivers - however you can find the similar or same functionality in the nrfx_uarte driver when implementing it yourself, it is described in the nrfx_uarte API reference.
    If you are starting development yourself, I recommend using the nrfx driver directly, to be compatible with future releases that does not include the nrf_drv.
    The legacy files take priority, as can be read about in this ticket if their *_ENABLEs are defined - i.e it is not enough to just set the enables to 0, you must uncomment/remove them from your SDK config to avoid this. This behavior is known to cause some confusion, and our SDK team has been made aware of the issue.
    Karl
