I just entered a Case to Nordic with this same question but do not expect to get a response over the weekend so I am posting here. I made the assumption that the Nordic Cases and the Developer Zone are not related. If this is considered a double-post I apologize.
I used the RF6350_radio_configuration_example as a starting point for our TWI interface. The goal is for the nRF51822 to act a a Master and send commands to a Slave to read/write the Slave's RAM/EEPROM.
I am using the nRF51822 EK with our TWI Slave attached and uVision 4 and the TWI transmission are unsuccessful. When a command is issured there are two negative SDA pulses followed by continuous SCL pulses. (36 usec period = 27.8KHz). The Slave requires clock freuencies of 10KHz-100KHz. When the code reaches “if (timeout == 0)” in the twi_master_write() while loop timeout always equals 0 which may be why the transmissioin fails. Of course this may not be the only problem.
I am still plugging away on this but time is short so any suggestions will be appreciated.
