undefined reference twi error
I hope you can help me. I get an error while compiling. I merge "twi sensor" example from sdk to the "ble app uart" example from sdk. So I customize the sdk_config to enable twi. In addition to that, I add all missing nRF_Drivers to make it work. While compiling, I get the following output:
1> "C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/as" --traditional-format -I../../../config -I../../../../../../components -I../../../../../../components/ble/ble_advertising -I../../../../../../components/ble/ble_dtm -I../../../../../../components/ble/ble_link_ctx_manager -I../../../../../../components/ble/ble_racp -I../../../../../../components/ble/ble_services/ble_ancs_c -I../../../../../../components/ble/ble_services/ble_ans_c -I../../../../../../components/ble/ble_services/ble_bas -I../../../../../../components/ble/ble_services/ble_bas_c -I../../../../../../components/ble/ble_services/ble_cscs -I../../../../../../components/ble/ble_services/ble_cts_c -I../../../../../../components/ble/ble_services/ble_dfu -I../../../../../../components/ble/ble_services/ble_dis -I../../../../../../components/ble/ble_services/ble_gls -I../../../../../../components/ble/ble_services/ble_hids -I../../../../../../components/ble/ble_services/ble_hrs -I../../../../../../components/ble/ble_services/ble_hrs_c -I../../../../../../components/ble/ble_services/ble_hts -I../../../../../../components/ble/ble_services/ble_ias -I../../../../../../components/ble/ble_services/ble_ias_c -I../../../../../../components/ble/ble_services/ble_lbs -I../../../../../../components/ble/ble_services/ble_lbs_c -I../../../../../../components/ble/ble_services/ble_lls -I../../../../../../components/ble/ble_services/ble_nus -I../../../../../../components/ble/ble_services/ble_nus_c -I../../../../../../components/ble/ble_services/ble_rscs -I../../../../../../components/ble/ble_services/ble_rscs_c -I../../../../../../components/ble/ble_services/ble_tps -I../../../../../../components/ble/common -I../../../../../../components/ble/nrf_ble_gatt -I../../../../../../components/ble/nrf_ble_qwr -I../../../../../../components/ble/peer_manager -I../../../../../../components/boards -I../../../../../../components/libraries/atomic -I../../../../../../components/libraries/atomic_fifo -I../../../../../../components/libraries/atomic_flags -I../../../../../../components/libraries/balloc -I../../../../../../components/libraries/bootloader/ble_dfu -I../../../../../../components/libraries/bsp -I../../../../../../components/libraries/button -I../../../../../../components/libraries/cli -I../../../../../../components/libraries/crc16 -I../../../../../../components/libraries/crc32 -I../../../../../../components/libraries/crypto -I../../../../../../components/libraries/csense -I../../../../../../components/libraries/csense_drv -I../../../../../../components/libraries/delay -I../../../../../../components/libraries/ecc -I../../../../../../components/libraries/experimental_section_vars -I../../../../../../components/libraries/experimental_task_manager -I../../../../../../components/libraries/fds -I../../../../../../components/libraries/fifo -I../../../../../../components/libraries/fstorage -I../../../../../../components/libraries/gfx -I../../../../../../components/libraries/gpiote -I../../../../../../components/libraries/hardfault -I../../../../../../components/libraries/hci -I../../../../../../components/libraries/led_softblink -I../../../../../../components/libraries/log -I../../../../../../components/libraries/log/src -I../../../../../../components/libraries/low_power_pwm -I../../../../../../components/libraries/mem_manager -I../../../../../../components/libraries/memobj -I../../../../../../components/libraries/mpu -I../../../../../../components/libraries/mutex -I../../../../../../components/libraries/pwm -I../../../../../../components/libraries/pwr_mgmt -I../../../../../../components/libraries/queue -I../../../../../../components/libraries/ringbuf -I../../../../../../components/libraries/scheduler -I../../../../../../components/libraries/sdcard -I../../../../../../components/libraries/slip -I../../../../../../components/libraries/sortlist -I../../../../../../components/libraries/spi_mngr -I../../../../../../components/libraries/stack_guard -I../../../../../../components/libraries/strerror -I../../../../../../components/libraries/svc -I../../../../../../components/libraries/timer -I../../../../../../components/libraries/twi_mngr -I../../../../../../components/libraries/twi_sensor -I../../../../../../components/libraries/uart -I../../../../../../components/libraries/usbd -I../../../../../../components/libraries/usbd/class/audio -I../../../../../../components/libraries/usbd/class/cdc -I../../../../../../components/libraries/usbd/class/cdc/acm -I../../../../../../components/libraries/usbd/class/hid -I../../../../../../components/libraries/usbd/class/hid/generic -I../../../../../../components/libraries/usbd/class/hid/kbd -I../../../../../../components/libraries/usbd/class/hid/mouse -I../../../../../../components/libraries/usbd/class/msc -I../../../../../../components/libraries/util -I../../../../../../components/nfc/ndef/conn_hand_parser -I../../../../../../components/nfc/ndef/conn_hand_parser/ac_rec_parser -I../../../../../../components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser -I../../../../../../components/nfc/ndef/conn_hand_parser/le_oob_rec_parser -I../../../../../../components/nfc/ndef/connection_handover/ac_rec -I../../../../../../components/nfc/ndef/connection_handover/ble_oob_advdata -I../../../../../../components/nfc/ndef/connection_handover/ble_pair_lib -I../../../../../../components/nfc/ndef/connection_handover/ble_pair_msg -I../../../../../../components/nfc/ndef/connection_handover/common -I../../../../../../components/nfc/ndef/connection_handover/ep_oob_rec -I../../../../../../components/nfc/ndef/connection_handover/hs_rec -I../../../../../../components/nfc/ndef/connection_handover/le_oob_rec -I../../../../../../components/nfc/ndef/generic/message -I../../../../../../components/nfc/ndef/generic/record -I../../../../../../components/nfc/ndef/launchapp -I../../../../../../components/nfc/ndef/parser/message -I../../../../../../components/nfc/ndef/parser/record -I../../../../../../components/nfc/ndef/text -I../../../../../../components/nfc/ndef/uri -I../../../../../../components/nfc/platform -I../../../../../../components/nfc/t2t_lib -I../../../../../../components/nfc/t2t_parser -I../../../../../../components/nfc/t4t_lib -I../../../../../../components/nfc/t4t_parser/apdu -I../../../../../../components/nfc/t4t_parser/cc_file -I../../../../../../components/nfc/t4t_parser/hl_detection_procedure -I../../../../../../components/nfc/t4t_parser/tlv -I../../../../../../components/softdevice/common -I../../../../../../components/softdevice/s140/headers -I../../../../../../components/softdevice/s140/headers/nrf52 -I../../../../../../components/toolchain/cmsis/include -I../../../../../../external/fprintf -I../../../../../../external/segger_rtt -I../../../../../../external/utf_converter -I../../../../../../integration/nrfx -I../../../../../../integration/nrfx/legacy -I../../../../../../modules/nrfx -I../../../../../../modules/nrfx/drivers/include -I../../../../../../modules/nrfx/hal -I../../../../../../modules/nrfx/mdk -I../config -mcpu=cortex-m4 -mlittle-endian -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mthumb "C:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/main.asm" -o "Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o"
1> rm "C:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/main.asm"
1> Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o (28.06.2020 20:58:16) is newer than Output/Debug/Exe/ble_app_uart_pca10100_s140.elf (28.06.2020 20:57:32).
1> Linking ble_app_uart_pca10100_s140.elf
1> "C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld" -X --omagic -eReset_Handler --defsym=__vfprintf=__vfprintf_long --defsym=__vfscanf=__vfscanf_long -EL --gc-sections "-TC:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/ble_app_uart_pca10100_s140.ld" -Map Output/Debug/Exe/ble_app_uart_pca10100_s140.map -u_vectors -o Output/Debug/Exe/ble_app_uart_pca10100_s140.elf --emit-relocs --start-group "@C:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/ble_app_uart_pca10100_s140.ind" --end-group
1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10100_s140 Debug/Obj/nrf_drv_twi.o: in function `nrf_drv_twi_init':
1> C:\Users\hp\Desktop\Firmware Entwicklung\nRF5SDK160098a08e2.zip\integration\nrfx\legacy/nrf_drv_twi.c:186: undefined reference to `nrfx_twi_init'
1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o: in function `nrf_drv_twi_enable':
1> C:\Users\hp\Desktop\Firmware Entwicklung\nRF5SDK160098a08e2.zip\examples\ble_peripheral\ble_app_uart\pca10100\s140\ses/../../../../../../integration/nrfx/legacy/nrf_drv_twi.h:513: undefined reference to `nrfx_twim_enable'
1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o: in function `nrf_drv_twi_tx':
1> C:\Users\hp\Desktop\Firmware Entwicklung\nRF5SDK160098a08e2.zip\examples\ble_peripheral\ble_app_uart\pca10100\s140\ses/../../../../../../integration/nrfx/legacy/nrf_drv_twi.h:544: undefined reference to `nrfx_twim_tx'
Build failed
But I don´t know what I´m making wrong.
Could you help me with that?
Thanks in advance
  • Hi Karl,
    thanks for your help. Your example is working fine now. I decided to work with your example, because I just had to include my specifif sensor part - not really complicated. For the moment there aren´t special questions from working with twim and I have a project which is compiling without any errors or warnings.
    Thanks a lot!
    regards
    Simon
  • Hello Simon,
    I am happy to hear that the example I provided is working fine for you now, and that you found it useful.
    Please do not hesitate to open a new ticket if you should encounter any issues or questions in the future.
    Karl
  • Hi Karl,
    unfortunaly, I´m getting a error while trying to make my sensor work with TWIM. Maybe you could help me. I think I can reach the sensor correctly, because if I change the sensor I2C adress the application doesn´t work - so I think I2C connection works fine and the sensor is reachable.
    I´m not sure, how to work with this TWIM functions. I looked at your example, but I have one or two questions:
    1.: I wrote a function ICM20948_set_mode:
    void ICM20948_set_mode(void)
        ret_code_t err_code;
        /* Sensor en */
        uint8_t reg[2] = {0x06, 0x01};
        nrfx_twim_xfer_desc_t normal_mode_config = NRFX_TWIM_XFER_DESC_TX(ICM20948_ADDR, reg, sizeof(reg));
        err_code = nrfx_twim_xfer(&m_twim, &normal_mode_config, NULL);
        while (m_xfer_done == false);
            /*Select User Bank 0 */
        reg[0] = 0x7F;
        reg[1] = 0x00;
        m_xfer_done = false;
        nrfx_twim_xfer_desc_t sensor_on = NRFX_TWIM_XFER_DESC_TX(ICM20948_ADDR, reg, sizeof(reg));
        err_code = nrfx_twim_xfer(&m_twim, &normal_mode_config, NULL);    APP_ERROR_CHECK(err_code);
    I´m not sure, when to use "m_xfer_done = false;" In the first lines it is included, in the second lines not. I copied this from your example. It is my aim, to write to two registers:
    - Enable Sensor
    - Selecting the correct User Bank / Registertable
    2.: I wrote a function "read_sensor_data":
    static void read_sensor_data()
        ret_code_t err_code1;
        /* register 0 */
        uint8_t reg1 = 0x00;
        nrfx_twim_xfer_desc_t normal_mode_config = NRFX_TWIM_XFER_DESC_TX(ICM20948_ADDR, &reg1, 1);
        nrfx_twim_xfer_desc_t lm75b_reading = NRFX_TWIM_XFER_DESC_RX(ICM20948_ADDR, &m_sample, 1);
        /* Read 1 byte from the specified address  */
        ret_code_t err_code = nrfx_twim_xfer(&m_twim, &lm75b_reading, NULL);
    So I first write the correct register - the register I want to read from (0).
    Then I read 1 byte of this register.
    The register 0 is a "test-register" from the sensor (ICM20948), and the standard value stored in this register is "0xEA". So i should read this value.
    But if I watch the value from "m_sample", there I can see different values in it...I update this variable twice a second...sometimes I can see the correct value "0xEA". But not always.  Something I´m making wrong...
    In general, for I2C communiction I need to write to a register, before I can read it. Is that correct?
    I also attached my main.c, if you need this for analyzing.
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrfx_twim.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "TRAINIO"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    // TWIM SENSOR EXAMPLE MERGE START
    #define TWIM_INSTANCE_ID                1
    /* TWI ICM20948 Adresse. */
    #define ICM20948_ADDR    0x69
    /* ICM20948 Register * s. datasheet*/
    #define USER_BANK        0x7F
    #define ACCEL_X_H        0x2D
    #define ACCEL_X_L        0x2E
    #define b_Battery_Pin 33
    static volatile bool m_xfer_done = false;
    static const nrfx_twim_t m_twim = NRFX_TWIM_INSTANCE(TWIM_INSTANCE_ID);
    /* Buffer for samples read from sensor. */
    static uint8_t m_sample;
    // ICM20948 Daten
    uint8_t ACCEL_X_High = 0x2D;
    uint8_t ACCEL_X_Low;
    // TWIM SENSOR EXAMPLE MERGE STOP
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= 10))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
        /* Sensor en */
        reg[0] = 0x7F;
        reg[1] = 0x00;
     * @brief Function for handling data from temperature sensor.
     * @param[in] temp          Temperature in Celsius degrees read from sensor.
    __STATIC_INLINE void data_handler(uint8_t temp)
        NRF_LOG_INFO("%d", temp);
     * @brief TWI events handler.
    void twim_handler(nrfx_twim_evt_t const * p_event, void * p_context)
        switch (p_event->type)
            case NRFX_TWIM_EVT_DONE:
                if (p_event->xfer_desc.type == NRFX_TWIM_XFER_RX)
                    data_handler(m_sample);
                m_xfer_done = true;
     * @brief UART initialization.
    void twim_init (void)
        nrfx_twim_config_t twim_lm75b_config = NRFX_TWIM_DEFAULT_CONFIG;
        twim_lm75b_config.scl = 13;
        twim_lm75b_config.sda = 16;
        err_code = nrfx_twim_init(&m_twim, &twim_lm75b_config, twim_handler, NULL);
        nrfx_twim_enable(&m_twim);
     * @brief Function for reading data from temperature sensor.
        /* register 0 */
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        twim_init();
        ICM20948_set_mode();
        // Start execution.
        advertising_start();
    while (true)
            do
                __WFE();
            }while (m_xfer_done == false);
            read_sensor_data();
    Thanks in advance!
    Simon
  • Hello Simon,
    I am terribly sorry for the long delay in answering - I have been out of office for some time now, and this ticket had the "verified answer" status, which made it slip through the cracks.
    Do you still require help with this issue?
    This is not a definitive way to confirm whether your TWI communication is succeeding or not.
    If you take a look at the TWI Scanner example you can see how you may detect the device's address, and thus ensure you are reaching the sensor correctly. I.e if you flash your device with the unmodified example, it should detect your sensor and write its device address to the log.
    m_xfer_done should be set true during the callback for the NRFX_TWIM_EVT_DONE event. This will ensure that the previous write / read has finished before proceeding to the next. If I remember correctly the initial value of this is false, but it would indeed be better practice to set it to false before any TWI operation is initiated.
    It seems weird that you can only see the correct value "sometimes" - what are you seeing when the value is incorrect? Is there any errors generated when this happens?
    Yes, in TWI communication the master must initiate the read, by writing to the slave that it would like to read out the contents of a specific register.
    Again, my apologies for the late reply.
    Looking forward to resolving this issue together!
    Karl
  • Hi Karl, thank you for your reply :-)
    No problem, and yes, I would need a little bit help.
    Done. I can reach the sensor with the example.
    I have analyzed this many times now - And what I can see is: It seems that the register I read increment every "read process". So I can read the correct value exactly every 64 times.Every 64 times, because the register map (user bank 0 has 64 registers; https://invensense.tdk.com/wp-content/uploads/2016/06/DS-000189-ICM-20948-v1.3.pdf chapter 7.1). And also the other values are repeating every 64 times...I would like to show you my actual function for reading from the sensor - no worry, just a few lines of code :-)
    The code is really simple:
    1. chose the correct register (write)
    2. read one byte from the sensor (read)
            /* register "0" chose */
        uint8_t reg5 = {0x00};
        nrfx_twim_xfer_desc_t test = NRFX_TWIM_XFER_DESC_TX(ICM20948_ADDR, &reg5, sizeof(reg5));
        nrfx_twim_xfer_desc_t lm75b_reading = NRFX_TWIM_XFER_DESC_RX(ICM20948_ADDR, &m_sample, sizeof(m_sample));
        /* Read */
    I think in this code is the fault, but I don´t know what I´m doing wrong. My aim is it, to read the same register every time.
    It would be great, if you can help me with that.
    Kind regards
    Simon
