undefined reference twi error
I hope you can help me. I get an error while compiling. I merge "twi sensor" example from sdk to the "ble app uart" example from sdk. So I customize the sdk_config to enable twi. In addition to that, I add all missing nRF_Drivers to make it work. While compiling, I get the following output:
1> "C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/as" --traditional-format -I../../../config -I../../../../../../components -I../../../../../../components/ble/ble_advertising -I../../../../../../components/ble/ble_dtm -I../../../../../../components/ble/ble_link_ctx_manager -I../../../../../../components/ble/ble_racp -I../../../../../../components/ble/ble_services/ble_ancs_c -I../../../../../../components/ble/ble_services/ble_ans_c -I../../../../../../components/ble/ble_services/ble_bas -I../../../../../../components/ble/ble_services/ble_bas_c -I../../../../../../components/ble/ble_services/ble_cscs -I../../../../../../components/ble/ble_services/ble_cts_c -I../../../../../../components/ble/ble_services/ble_dfu -I../../../../../../components/ble/ble_services/ble_dis -I../../../../../../components/ble/ble_services/ble_gls -I../../../../../../components/ble/ble_services/ble_hids -I../../../../../../components/ble/ble_services/ble_hrs -I../../../../../../components/ble/ble_services/ble_hrs_c -I../../../../../../components/ble/ble_services/ble_hts -I../../../../../../components/ble/ble_services/ble_ias -I../../../../../../components/ble/ble_services/ble_ias_c -I../../../../../../components/ble/ble_services/ble_lbs -I../../../../../../components/ble/ble_services/ble_lbs_c -I../../../../../../components/ble/ble_services/ble_lls -I../../../../../../components/ble/ble_services/ble_nus -I../../../../../../components/ble/ble_services/ble_nus_c -I../../../../../../components/ble/ble_services/ble_rscs -I../../../../../../components/ble/ble_services/ble_rscs_c -I../../../../../../components/ble/ble_services/ble_tps -I../../../../../../components/ble/common -I../../../../../../components/ble/nrf_ble_gatt -I../../../../../../components/ble/nrf_ble_qwr -I../../../../../../components/ble/peer_manager -I../../../../../../components/boards -I../../../../../../components/libraries/atomic -I../../../../../../components/libraries/atomic_fifo -I../../../../../../components/libraries/atomic_flags -I../../../../../../components/libraries/balloc -I../../../../../../components/libraries/bootloader/ble_dfu -I../../../../../../components/libraries/bsp -I../../../../../../components/libraries/button -I../../../../../../components/libraries/cli -I../../../../../../components/libraries/crc16 -I../../../../../../components/libraries/crc32 -I../../../../../../components/libraries/crypto -I../../../../../../components/libraries/csense -I../../../../../../components/libraries/csense_drv -I../../../../../../components/libraries/delay -I../../../../../../components/libraries/ecc -I../../../../../../components/libraries/experimental_section_vars -I../../../../../../components/libraries/experimental_task_manager -I../../../../../../components/libraries/fds -I../../../../../../components/libraries/fifo -I../../../../../../components/libraries/fstorage -I../../../../../../components/libraries/gfx -I../../../../../../components/libraries/gpiote -I../../../../../../components/libraries/hardfault -I../../../../../../components/libraries/hci -I../../../../../../components/libraries/led_softblink -I../../../../../../components/libraries/log -I../../../../../../components/libraries/log/src -I../../../../../../components/libraries/low_power_pwm -I../../../../../../components/libraries/mem_manager -I../../../../../../components/libraries/memobj -I../../../../../../components/libraries/mpu -I../../../../../../components/libraries/mutex -I../../../../../../components/libraries/pwm -I../../../../../../components/libraries/pwr_mgmt -I../../../../../../components/libraries/queue -I../../../../../../components/libraries/ringbuf -I../../../../../../components/libraries/scheduler -I../../../../../../components/libraries/sdcard -I../../../../../../components/libraries/slip -I../../../../../../components/libraries/sortlist -I../../../../../../components/libraries/spi_mngr -I../../../../../../components/libraries/stack_guard -I../../../../../../components/libraries/strerror -I../../../../../../components/libraries/svc -I../../../../../../components/libraries/timer -I../../../../../../components/libraries/twi_mngr -I../../../../../../components/libraries/twi_sensor -I../../../../../../components/libraries/uart -I../../../../../../components/libraries/usbd -I../../../../../../components/libraries/usbd/class/audio -I../../../../../../components/libraries/usbd/class/cdc -I../../../../../../components/libraries/usbd/class/cdc/acm -I../../../../../../components/libraries/usbd/class/hid -I../../../../../../components/libraries/usbd/class/hid/generic -I../../../../../../components/libraries/usbd/class/hid/kbd -I../../../../../../components/libraries/usbd/class/hid/mouse -I../../../../../../components/libraries/usbd/class/msc -I../../../../../../components/libraries/util -I../../../../../../components/nfc/ndef/conn_hand_parser -I../../../../../../components/nfc/ndef/conn_hand_parser/ac_rec_parser -I../../../../../../components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser -I../../../../../../components/nfc/ndef/conn_hand_parser/le_oob_rec_parser -I../../../../../../components/nfc/ndef/connection_handover/ac_rec -I../../../../../../components/nfc/ndef/connection_handover/ble_oob_advdata -I../../../../../../components/nfc/ndef/connection_handover/ble_pair_lib -I../../../../../../components/nfc/ndef/connection_handover/ble_pair_msg -I../../../../../../components/nfc/ndef/connection_handover/common -I../../../../../../components/nfc/ndef/connection_handover/ep_oob_rec -I../../../../../../components/nfc/ndef/connection_handover/hs_rec -I../../../../../../components/nfc/ndef/connection_handover/le_oob_rec -I../../../../../../components/nfc/ndef/generic/message -I../../../../../../components/nfc/ndef/generic/record -I../../../../../../components/nfc/ndef/launchapp -I../../../../../../components/nfc/ndef/parser/message -I../../../../../../components/nfc/ndef/parser/record -I../../../../../../components/nfc/ndef/text -I../../../../../../components/nfc/ndef/uri -I../../../../../../components/nfc/platform -I../../../../../../components/nfc/t2t_lib -I../../../../../../components/nfc/t2t_parser -I../../../../../../components/nfc/t4t_lib -I../../../../../../components/nfc/t4t_parser/apdu -I../../../../../../components/nfc/t4t_parser/cc_file -I../../../../../../components/nfc/t4t_parser/hl_detection_procedure -I../../../../../../components/nfc/t4t_parser/tlv -I../../../../../../components/softdevice/common -I../../../../../../components/softdevice/s140/headers -I../../../../../../components/softdevice/s140/headers/nrf52 -I../../../../../../components/toolchain/cmsis/include -I../../../../../../external/fprintf -I../../../../../../external/segger_rtt -I../../../../../../external/utf_converter -I../../../../../../integration/nrfx -I../../../../../../integration/nrfx/legacy -I../../../../../../modules/nrfx -I../../../../../../modules/nrfx/drivers/include -I../../../../../../modules/nrfx/hal -I../../../../../../modules/nrfx/mdk -I../config -mcpu=cortex-m4 -mlittle-endian -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mthumb "C:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/main.asm" -o "Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o"
1> rm "C:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/main.asm"
1> Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o (28.06.2020 20:58:16) is newer than Output/Debug/Exe/ble_app_uart_pca10100_s140.elf (28.06.2020 20:57:32).
1> Linking ble_app_uart_pca10100_s140.elf
1> "C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld" -X --omagic -eReset_Handler --defsym=__vfprintf=__vfprintf_long --defsym=__vfscanf=__vfscanf_long -EL --gc-sections "-TC:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/ble_app_uart_pca10100_s140.ld" -Map Output/Debug/Exe/ble_app_uart_pca10100_s140.map -u_vectors -o Output/Debug/Exe/ble_app_uart_pca10100_s140.elf --emit-relocs --start-group "@C:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/ble_app_uart_pca10100_s140.ind" --end-group
1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10100_s140 Debug/Obj/nrf_drv_twi.o: in function `nrf_drv_twi_init':
1> C:\Users\hp\Desktop\Firmware Entwicklung\nRF5SDK160098a08e2.zip\integration\nrfx\legacy/nrf_drv_twi.c:186: undefined reference to `nrfx_twi_init'
1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o: in function `nrf_drv_twi_enable':
1> C:\Users\hp\Desktop\Firmware Entwicklung\nRF5SDK160098a08e2.zip\examples\ble_peripheral\ble_app_uart\pca10100\s140\ses/../../../../../../integration/nrfx/legacy/nrf_drv_twi.h:513: undefined reference to `nrfx_twim_enable'
1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o: in function `nrf_drv_twi_tx':
1> C:\Users\hp\Desktop\Firmware Entwicklung\nRF5SDK160098a08e2.zip\examples\ble_peripheral\ble_app_uart\pca10100\s140\ses/../../../../../../integration/nrfx/legacy/nrf_drv_twi.h:544: undefined reference to `nrfx_twim_tx'
Build failed
But I don´t know what I´m making wrong.
Could you help me with that?
Thanks in advance
  • Hello Simon,
    simon1516 said:
    thank you for your reply :-)
    No problem at all, I am happy to help! :)
    simon1516 said:
    Done. I can reach the sensor with the example.
    Great, then we know the connection is working, and that the sensor is replying as expected.
    simon1516 said:
    I have analyzed this many times now - And what I can see is: It seems that the register I read increment every "read process". So I can read the correct value exactly every 64 times.Every 64 times, because the register map (user bank 0 has 64 registers; https://invensense.tdk.com/wp-content/uploads/2016/06/DS-000189-ICM-20948-v1.3.pdf chapter 7.1).
    Could you confirm for me what frequency you are using for your TWIM? - Judging by your main.c you shared some time ago, what is the value of your NRFX_TWIM_DEFAULT_CONFIG define in the sdk_config?
    simon1516 said:
    The code is really simple:
    1. chose the correct register (write)
    2. read one byte from the sensor (read)
    I am not sure I have understood you correctly, but you do nothing with your initial nrfx_twim_xfer_desc_t test struct here - you are not transferring it. with the code you share here.
    You will need to call nrfx_twim_xfer; the NRFX_TWIM_XFER_DESC_TX only creates a TX description structure.
    Especially, please see Section 6.3: Single-Byte Read Sequence in the datasheet you linked.
    Usually, you can think of even addresses as write-to addresses, and odd addresses as read-from addresses. wince the LSB of the 8-bit address determines the R/W bit.
    What does your log output when you run your program, btw?
    I highly recommend reading a this summary of the TWI protocol, to gain a better understanding of how the protocol is built.
    Looking forward to resolving this issue together!
    Karl
  • Hi Karl,
    I hope you are fine.
    It was configured to 400k. I changed this to 100k but it doesn´t take affect. The result was the same.
    The problem is, if I add the line "err_code = nrfx_twim_xfer(&m_twim, &test, NULL);" directly behind the TX description structure the application aborts. In debug terminal I get the following messages:
    Yes, I tried to follow the insctructions from the manual:
    But in general: My understandness is, that if I call "nrfx_twim_xfer" after a "NRFX_TWIM_XFER_DESC_TX" then this "write procedure" works automatically (Start Signal, I2C Adress etc), isn´t that right?
    In addition to that, I attached my actual source code. I have just copied you example from above. The only change is, adding my sensor (ICM20948) to it instead of LM75b.
    ble_app_uart_with_twim v0.2.zip
    Thanks for help!
    Simon
  • Hello Simon,
    I am fine, and I hope you are too. Thank you for asking!
    From the datasheet it seems 400k is the appropriate frequency, so please revert to 400k.
    You will need to call _xfer if you intend to do the write. The debug terminal in the included picture is empty.
    Could you make sure that you have DEBUG defined in your preprocessor settings? The included picture illustrates how you could go about doing this.
    This will allow you to see the specific error that triggered APP_ERROR_CHECK.
    Please make sure DEBUG is defined as shown, and then add _xfer again, and see what error is being generated.
    I am not sure I have understood what you mean here correctly, but if you are asking if the XFER_DESC_TX readies a single TWIM_TX with the information you provide it ( address, p_data, and length ) then yes, that is the case.
    Thank you. I think we will be able to get to the bottom of it when we see what error is being generated by the _XFER function. If not, I will take a look at the project and see if I am able to replicate this behavior on my end.
    Karl
  • Hi Karl,
    I added "DEBUG" in first line because it wasn´t there. Unfortunaly, I didn´t get messages in the debug terminal. If I press "build an debug" I went to the same error, but without any help in the debug window...
    Could there be a problem, using nrf52833 instead of nrf52840?
    I set active build confifuration to "debug" instead of "release", but this doesn´t take affect. Is there something other I could try?
    Could there be a problem with my TWIM address? ICM20948 has 0x69 by default. So I assume that the TWIM functions RX and TX automatically set the LSB for Read/Write. Is that correct?
    Kind regards
    Simon
  • Hello Simon,
    Good. When debug is defined you may proceed with debugging the code as you did earlier - enter debug mode, and see which function that leads to the APP_ERROR_FAULT_HANDLER function that you ended up in earlier. The difference now will be that the specific reason for ending up in the fault handler will be visible, so for instance it will say NRFX_ERROR_INTERNAL if an unexpected transition occurred on the bus during the transmission, for example. This will make it much easier to pinpoint the source of the error.
    There will however be nothing in the debug terminal still - this is because the "Debug terminal" in Segger Embedded Studios really is an RTT terminal for the JLink to output logs. If your application does not use the RTT backend for its logging module, then nothing will show up in the debug terminal.
    There should not be a problem with this if you have changed the project configuration to match the nRF52833 DK instead of the nRF52840 DK.
    Which changes did you make in this regards to the project I provided you earlier?
    Since you defined DEBUG in the "common" configuration, it will be present for both DEBUG and RELEASE mode, so that should be all right.
    I suppose it could be. Did you get the address header file from the manufacturer directly, or did you transcribe / implement it yourself? I am just asking to make sure.
    You are correct that the TWIM _DESC_TX and _DESC_RX macros sets the R/W bit for you. In this sense, you could read TX as "write" and RX as "read".
    Karl
