undefined reference twi error
I hope you can help me. I get an error while compiling. I merge "twi sensor" example from sdk to the "ble app uart" example from sdk. So I customize the sdk_config to enable twi. In addition to that, I add all missing nRF_Drivers to make it work. While compiling, I get the following output:
1> "C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/as" --traditional-format -I../../../config -I../../../../../../components -I../../../../../../components/ble/ble_advertising -I../../../../../../components/ble/ble_dtm -I../../../../../../components/ble/ble_link_ctx_manager -I../../../../../../components/ble/ble_racp -I../../../../../../components/ble/ble_services/ble_ancs_c -I../../../../../../components/ble/ble_services/ble_ans_c -I../../../../../../components/ble/ble_services/ble_bas -I../../../../../../components/ble/ble_services/ble_bas_c -I../../../../../../components/ble/ble_services/ble_cscs -I../../../../../../components/ble/ble_services/ble_cts_c -I../../../../../../components/ble/ble_services/ble_dfu -I../../../../../../components/ble/ble_services/ble_dis -I../../../../../../components/ble/ble_services/ble_gls -I../../../../../../components/ble/ble_services/ble_hids -I../../../../../../components/ble/ble_services/ble_hrs -I../../../../../../components/ble/ble_services/ble_hrs_c -I../../../../../../components/ble/ble_services/ble_hts -I../../../../../../components/ble/ble_services/ble_ias -I../../../../../../components/ble/ble_services/ble_ias_c -I../../../../../../components/ble/ble_services/ble_lbs -I../../../../../../components/ble/ble_services/ble_lbs_c -I../../../../../../components/ble/ble_services/ble_lls -I../../../../../../components/ble/ble_services/ble_nus -I../../../../../../components/ble/ble_services/ble_nus_c -I../../../../../../components/ble/ble_services/ble_rscs -I../../../../../../components/ble/ble_services/ble_rscs_c -I../../../../../../components/ble/ble_services/ble_tps -I../../../../../../components/ble/common -I../../../../../../components/ble/nrf_ble_gatt -I../../../../../../components/ble/nrf_ble_qwr -I../../../../../../components/ble/peer_manager -I../../../../../../components/boards -I../../../../../../components/libraries/atomic -I../../../../../../components/libraries/atomic_fifo -I../../../../../../components/libraries/atomic_flags -I../../../../../../components/libraries/balloc -I../../../../../../components/libraries/bootloader/ble_dfu -I../../../../../../components/libraries/bsp -I../../../../../../components/libraries/button -I../../../../../../components/libraries/cli -I../../../../../../components/libraries/crc16 -I../../../../../../components/libraries/crc32 -I../../../../../../components/libraries/crypto -I../../../../../../components/libraries/csense -I../../../../../../components/libraries/csense_drv -I../../../../../../components/libraries/delay -I../../../../../../components/libraries/ecc -I../../../../../../components/libraries/experimental_section_vars -I../../../../../../components/libraries/experimental_task_manager -I../../../../../../components/libraries/fds -I../../../../../../components/libraries/fifo -I../../../../../../components/libraries/fstorage -I../../../../../../components/libraries/gfx -I../../../../../../components/libraries/gpiote -I../../../../../../components/libraries/hardfault -I../../../../../../components/libraries/hci -I../../../../../../components/libraries/led_softblink -I../../../../../../components/libraries/log -I../../../../../../components/libraries/log/src -I../../../../../../components/libraries/low_power_pwm -I../../../../../../components/libraries/mem_manager -I../../../../../../components/libraries/memobj -I../../../../../../components/libraries/mpu -I../../../../../../components/libraries/mutex -I../../../../../../components/libraries/pwm -I../../../../../../components/libraries/pwr_mgmt -I../../../../../../components/libraries/queue -I../../../../../../components/libraries/ringbuf -I../../../../../../components/libraries/scheduler -I../../../../../../components/libraries/sdcard -I../../../../../../components/libraries/slip -I../../../../../../components/libraries/sortlist -I../../../../../../components/libraries/spi_mngr -I../../../../../../components/libraries/stack_guard -I../../../../../../components/libraries/strerror -I../../../../../../components/libraries/svc -I../../../../../../components/libraries/timer -I../../../../../../components/libraries/twi_mngr -I../../../../../../components/libraries/twi_sensor -I../../../../../../components/libraries/uart -I../../../../../../components/libraries/usbd -I../../../../../../components/libraries/usbd/class/audio -I../../../../../../components/libraries/usbd/class/cdc -I../../../../../../components/libraries/usbd/class/cdc/acm -I../../../../../../components/libraries/usbd/class/hid -I../../../../../../components/libraries/usbd/class/hid/generic -I../../../../../../components/libraries/usbd/class/hid/kbd -I../../../../../../components/libraries/usbd/class/hid/mouse -I../../../../../../components/libraries/usbd/class/msc -I../../../../../../components/libraries/util -I../../../../../../components/nfc/ndef/conn_hand_parser -I../../../../../../components/nfc/ndef/conn_hand_parser/ac_rec_parser -I../../../../../../components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser -I../../../../../../components/nfc/ndef/conn_hand_parser/le_oob_rec_parser -I../../../../../../components/nfc/ndef/connection_handover/ac_rec -I../../../../../../components/nfc/ndef/connection_handover/ble_oob_advdata -I../../../../../../components/nfc/ndef/connection_handover/ble_pair_lib -I../../../../../../components/nfc/ndef/connection_handover/ble_pair_msg -I../../../../../../components/nfc/ndef/connection_handover/common -I../../../../../../components/nfc/ndef/connection_handover/ep_oob_rec -I../../../../../../components/nfc/ndef/connection_handover/hs_rec -I../../../../../../components/nfc/ndef/connection_handover/le_oob_rec -I../../../../../../components/nfc/ndef/generic/message -I../../../../../../components/nfc/ndef/generic/record -I../../../../../../components/nfc/ndef/launchapp -I../../../../../../components/nfc/ndef/parser/message -I../../../../../../components/nfc/ndef/parser/record -I../../../../../../components/nfc/ndef/text -I../../../../../../components/nfc/ndef/uri -I../../../../../../components/nfc/platform -I../../../../../../components/nfc/t2t_lib -I../../../../../../components/nfc/t2t_parser -I../../../../../../components/nfc/t4t_lib -I../../../../../../components/nfc/t4t_parser/apdu -I../../../../../../components/nfc/t4t_parser/cc_file -I../../../../../../components/nfc/t4t_parser/hl_detection_procedure -I../../../../../../components/nfc/t4t_parser/tlv -I../../../../../../components/softdevice/common -I../../../../../../components/softdevice/s140/headers -I../../../../../../components/softdevice/s140/headers/nrf52 -I../../../../../../components/toolchain/cmsis/include -I../../../../../../external/fprintf -I../../../../../../external/segger_rtt -I../../../../../../external/utf_converter -I../../../../../../integration/nrfx -I../../../../../../integration/nrfx/legacy -I../../../../../../modules/nrfx -I../../../../../../modules/nrfx/drivers/include -I../../../../../../modules/nrfx/hal -I../../../../../../modules/nrfx/mdk -I../config -mcpu=cortex-m4 -mlittle-endian -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mthumb "C:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/main.asm" -o "Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o"
1> rm "C:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/main.asm"
1> Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o (28.06.2020 20:58:16) is newer than Output/Debug/Exe/ble_app_uart_pca10100_s140.elf (28.06.2020 20:57:32).
1> Linking ble_app_uart_pca10100_s140.elf
1> "C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld" -X --omagic -eReset_Handler --defsym=__vfprintf=__vfprintf_long --defsym=__vfscanf=__vfscanf_long -EL --gc-sections "-TC:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/ble_app_uart_pca10100_s140.ld" -Map Output/Debug/Exe/ble_app_uart_pca10100_s140.map -u_vectors -o Output/Debug/Exe/ble_app_uart_pca10100_s140.elf --emit-relocs --start-group "@C:/Users/hp/Desktop/Firmware Entwicklung/nRF5SDK160098a08e2.zip/examples/ble_peripheral/ble_app_uart/pca10100/s140/ses/Output/ble_app_uart_pca10100_s140 Debug/Obj/ble_app_uart_pca10100_s140.ind" --end-group
1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10100_s140 Debug/Obj/nrf_drv_twi.o: in function `nrf_drv_twi_init':
1> C:\Users\hp\Desktop\Firmware Entwicklung\nRF5SDK160098a08e2.zip\integration\nrfx\legacy/nrf_drv_twi.c:186: undefined reference to `nrfx_twi_init'
1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o: in function `nrf_drv_twi_enable':
1> C:\Users\hp\Desktop\Firmware Entwicklung\nRF5SDK160098a08e2.zip\examples\ble_peripheral\ble_app_uart\pca10100\s140\ses/../../../../../../integration/nrfx/legacy/nrf_drv_twi.h:513: undefined reference to `nrfx_twim_enable'
1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.50/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10100_s140 Debug/Obj/main.o: in function `nrf_drv_twi_tx':
1> C:\Users\hp\Desktop\Firmware Entwicklung\nRF5SDK160098a08e2.zip\examples\ble_peripheral\ble_app_uart\pca10100\s140\ses/../../../../../../integration/nrfx/legacy/nrf_drv_twi.h:544: undefined reference to `nrfx_twim_tx'
Build failed
But I don´t know what I´m making wrong.
Could you help me with that?
Thanks in advance
  • Hi Karl,
    Good. When debug is defined you may proceed with debugging the code as you did earlier - enter debug mode, and see which function that leads to the APP_ERROR_FAULT_HANDLER function that you ended up in earlier. The difference now will be that the specific reason for ending up in the fault handler will be visible, so for instance it will say NRFX_ERROR_INTERNAL if an unexpected transition occurred on the bus during the transmission, for example. This will make it much easier to pinpoint the source of the error.
    I need a little bit more help with that. I debugged again and I saw the following information:
    I can see that the app_error_handler is called, and which parameters (err_code, line_number, file_name) are used for the call. But furthermore I can´t see a reason for my fault. Could you please tell me how to going on here? :-)
    There should not be a problem with this if you have changed the project configuration to match the nRF52833 DK instead of the nRF52840 DK.
    Which changes did you make in this regards to the project I provided you earlier?
    1.: Set Preprocessor definitions as shown in Screenshotn above - just change to the correct board and chip.
    2.: Adjust the RAM and Flash sizes in Linker Options
    The values for this I copied from an solution from this post:
    https://devzone.nordicsemi.com/f/nordic-q-a/56802/change-softdevice-nrf52833
    In general I use this values for making a project working for nrf52833, because in SDK there are many projects not available for PCA10100.
    I suppose it could be. Did you get the address header file from the manufacturer directly, or did you transcribe / implement it yourself? I am just asking to make sure.
    I use the standard I2C adress from manufacturer for this sensor. There is a Pin, which can be used for configuring the I2C address - setting high for 0x69, low for 0x68. I use the 0x68. This is also the address which is found by "TWI Scanner Example".
    Thanks in advance for your help!
    Regards
    Simon
  • Hello Simon,
    Sorry for my late reply.
    From this, it seems that your debug terminal is empty. Are you using UART or RTT backend for your logger?
    If you are using UART logging, then you will need to make sure that NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED is set to 1 in your sdk_config file, and then you will need to take a look in your serial monitor to see the exact error.
    If you are using RTT logging, then you will need to make sure that NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED is set to 0, to see the error in the debug terminal.
    Good - then it seems there is nothing wrong with the hardware setup and addressing, at least.
    So, I think we will need to dive into the error that is generated as mentioned above.
    Looking forward to resolving this issue together!
    Karl
  • Hi Karl,
    Thanks for Reply. I can now read the correct sensor data!!! :-)
    ______________________________________________
    Now, I am able to see error Messages in the debug terminal! I got the following error:
    <info> app_timer: RTC: initialized.
    <error> app: ERROR 17 [NRF_ERROR_BUSY] at C:\Users\hp\Desktop\Firmware Entwicklung\nRF5SDK160098a08e2.zip\examples\ble_peripheral\ble_app_uart_with_twim v0.2\main.c:820
    PC at: 0x00031395
    <error> app: End of error report
    Line 820 in main.c Shows the following:
       err_code = nrfx_twim_xfer(&m_twim, &lm75b_reading, NULL);
    I didn´t understand this error completely, but I found an old thread, where the same error was issued by a timing/timout reason (https://devzone.nordicsemi.com/f/nordic-q-a/28483/twi---nrf_error_busy-with-nrf52832-and-s132)
    Because of this, I added "nrf_delay_ms(50);" before every "err_code = nrfx_twim_xfer". An volia´it work´s. I can write to a Register and read Registers :-)
    So far so good. But it doesn´t surprised, there are two other questions I would like to ask you.
    1.: The general communication to the sensor works now. But after about three minutes, the application stopps with working. No sensor data is sended by the nRF52833. I send a single Byte to uart every 50ms. After three minutes, no more data is sent to uart terminal. Do I have a Chance, to enclouse this error?
    2.: A few weeks ago, I deleted every nrf_delay_ms() function from my Code. The reasen: If I powered the board by a LiPo battery, the application didn´t work. Powering by USB works fine. I don´t know why, but deleting all nrf_delay_ms() functions from code fixed this behavior. Now I need this functions again - so what can I do here?
    Thank you Karl for great support!
    EDIT: To Point 1 - I started a debug session again. After about three minutes the application stopps. In debug terminal I can see a report "Logs dropped" many times.
    Do you know, why this is Happening?
    Kind regards
    Simon
  • Hello Simon,
    No problem at all, I am happy to hear that you now are able to read the correct sensor data! :)
    Great! This makes debugging a lot easier, when you get the error pinpointed.
    Now that you know which function that returned the error, and what error is generated then you can take a look in the API Reference for the function to find out what caused it.
    For your example, it is the nrfx_twim_xfer function returned with NRF_ERROR_BUSY. Looking at the API Reference, we see that this error is returned when "The driver is not ready for a new transfer.", so indeed there seems to be a timing issue. Perhaps a new transfer is being queued at line 820 before the previous one is finished.
    I am glad to hear that you were able to read and write the registers now!
    However, I think we should be able to reduce that delay quite a bit - 50 ms is a lot of time to waste every time you are making a single byte transfer over TWIM.
    Firstly, perhaps you could try to reduce the necessary delay - or add another condition that would ensure that the previous transfer is finished?
    For example, the flag you are currently clearing in the event handler, perhaps that instead should start a timer that expires after a certain time, which allows the next transfer to proceed?
    This will free up the CPU to do other tasks ( or sleep ) for the transfer wait period.
    Where does the application stop after three minutes, is it a particular place in the code?
    Or, is it another error being generated?
    The logs dropped means the logger modules buffer is full. Are you using deferred logging? And if so, when are you processing these logs? If not, what is the size of your loggers buffer?
    What do you mean when you say "didnt work"?
    Please see my above recommendation to avoid the nrf_delay call. In general, adding NOP cycles ( like nrf_delay ) is not a good practice to meet timing requirements. A much better solution would be a standalone timer, or basing it on some other event entirely.
    Thank you for the kind words, I am happy to help!
    Karl
  • Hi Karl,
    Could you guide me how to use such a timer? I defined "#define TWIM_transmission_time APP_TIMER_TICKS(10) " to get a timer with 10ms delay time. So now, I would like to use this timer in my "twim_handler". Nothing should happen, if the timer isn´t expired. The timer should restart, if it is expired and an twim event was done. Could you give me a small Syntax for this?
    I have already included "app_timer.h", so I think it would make sense to use this.
    Could you tell me, how to get this Information?
    Here I think I have to debug again (because debugging is working now :-) ). I will try this and give you a short Feedback the next days!
    Thanks in advance
    Simon
