Coded Phy Settings
Hi Nordic team,
we want to connect 2 nRF52840 based modules with Coded Phy S=8 Mode to make an cable replacement (NUS).
MTU Size is 244 Byte ,to transmit cyclic 200 Byte from A to B abnd B to A.
Normally we work with 2M Phy and 7.5ms connection intervall and it works perfect and also very stable, even with multipoint.
Since the HF rate is lower (125kB instead of 2M) we assume that the connection intervall has to be adjusted.
Is there a recommendation or info manual?
Best regards
Andre
