Thread Border Router networking fail
Hello Nordic Taam:
I follow the WEB steps below
https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_tz_v4.1.0%2Fthread_ot_performance_measurement.html
Software Development Kit > nRF5 SDK for Thread and Zigbee v4.1.0 > Thread > Thread tools > Thread Border Router
nRF52840 DK Version:nRF5_SDK_for_Thread_and_Zigbee_v4.1.0_32ce5f8\examples\thread\ncp\ftd\uart\hex
Raspberry Pi 3 Version:RaspPi_OT_Border_Router_Demo_v4.1.0-1.alpha
Use nRF52840 DK UART connect Raspberry Pi 3 to get the following information
wpan0 => [
"NCP:State" => "associating"
"Daemon:Enabled" => true
"NCP:Version" => "OPENTHREAD/20191113-00534-gc6a258e3; NRF52840; Apr 5 2020 21:51:18"
"Daemon:Version" => "0.08.00d (; Apr 21 2020 19:11:43)"
"Config:NCP:DriverName" => "spinel"
"NCP:HardwareAddress" => [F4CE363EC3C45B0E]
pi@raspberrypi:~ $ sudo wpanctl status
wpan0 => [
"NCP:State" => "uninitialized"
"NCP:Version" => ""
If I have the wrong steps or have not completed, please give me some pointers, thank you.
Also, can you teach me how to set up the Thread Border Router successfully on Raspberry Pi 3?
Best Regards
Rick.
  • Hi
    OK, I will try this example  "Thread thethings.iO Cloud CoAP Client Example".
    "simulate it" is I want to use this example.
    Pls Could you view the case and reply, Thanks.
     Thread device can't join the Thread network in Thread Google Cloud Platform CoAP Example
    Best Regards,
    Rick.
  • Hi Jørgen
     I try this example  "Thread thethings.iO Cloud CoAP Client Example".
    but it get the error response "HTTP/1.1 400 Bad Request" and {"status":"error","code":400,"message":"Unexpected token '"}
    curl -i -H "Accept: application/json" -H "Content-Type: application/json" -d '{"values":[{"key":"temp","value":"0"},{"key":"counter","value":"0"}]}' -X POST "">api.thethings.io/.../GITM86uZNPu9Ukmja16PM-X-enajMxP01PODgS3tYVI" -k
    following is my thethings.iO information
    Pls kindly help advise how to solve it!
    Best Regards,
    Rick.
  • Hi Jørgen
    I can post commands to thething.io from my PC, Dashboard page can show my send data.
    but CoAP Client can't send to thething.io.
    my version is :
    nRF52840 DK Version:v3.2.0
    nRF5_SDK_for_Thread_and_Zigbee_v3.2.0_9fade31 --> CoAP client node
    Raspberry Pi 3 Version:RaspPi_OT_Border_Router_Demo_v4.1.0-1.alpha --> Border Router
    1. My CoAP client node RTT show " DNS response error 28." and " DNS response error 1".
    2. I only have IPv4, and I ues CLI send "dns resolve ipv4.google.com", it response error"DNS response for ipv4.google.com - Error 28: ResponseTimeout".
    I can ping the PC directly from the border router.
    3. My NAT64 feature can work properly?
    4. Is this description setting from Raspberry Pi or CLI device?
    Best Regards,
    Rick,
  • It looks like you are able to ping Google DNS from the CLI, so that indicates that the connection should be ok.
    Can you try to do the DNS resolve command from the CLI, to check if you are able to get the IP from thethings.IO cloud solution, or if it is somehow blocked? I tested this on my setup right now, and it worked:
    You should also make sure to use the examples from the latest SDK version (v4.1.0), and not the older v3.2.0.
  • Hi Jørgen
    Thanks for your help.
    My nRD52840 DK boards is revision 0.9.0 and 0.9.2. so I use SDK 2.0 and My phone share AP to Raspberry Pi, It can send data to thething.io.
    after SDK 3.1 to 4.2 version is not successfully work.
    I will buy new boards to try the new versions.
    BTW:
    SDK can mixing use?
    ex:
    SDK 2.0 example thething for cloud is the device.
    SDK 3.2 Border Router + RaspPi_OT_Border_Router_Demo_v4.1.0-1.alpha
    or
    SDK 3.2 example thething for cloud is device.
    SDK 2.0 Border Router + RaspPi_OT_Border_Router_Demo_v2.0.0-1.alpha
    Best Regards,
    Rick.
« 4 5 6 7 8 »
