nrf52840 usb audio class example only works on debug
I'm using nrf52840 with nRF5_SDK_17.0.0_9d13099 and usbd_audio loopback example.
The example works fine with the given hex file
but when i compile it myself, the signal seems to have variable type issue.
but in debugging everthings works fine
I have suspect it's an issue with optimization which mess with the buffer or the signal input, but it seems that removing optimisation option has not resolved the problem.
Maybe someone could share with me their Makefile for the project?
  • You should find makefile in \nRF5_SDK_17.0.0_9d13099\examples\peripheral\usbd_audio\pca10056\blank\armgcc
    The following toolchains/devices have been used for testing and verification:
    - ARM: MDK-ARM version 5.25
    - GCC: GCC ARM Embedded 9.2019q4.major
    - IAR: IAR Workbench 7.80.4
    - SES: SES 4.50
    The issue looks very much like some sort of buffer issue yes, what is the frequency here? Just want to get an idea of the duration.
  • The frequency is 1kHZ.
    I'll try with your exact tools chain.. and will update.
  • I have used
    GCC: GCC ARM Embedded 9 2020-q2-update but this should not make any difference, no?
    below is my Makefile, I'm using MinGW 6.3.0-1
    PROJECT_NAME     := usbd_audio_pca10056
    TARGETS          := nrf52840_xxaa
    OUTPUT_DIRECTORY := _build
    SDK_ROOT := ../../../../../..
    PROJ_DIR := ../../..
    $(OUTPUT_DIRECTORY)/nrf52840_xxaa.out: \
      LINKER_SCRIPT  := usbd_audio_gcc_nrf52.ld
    # Source files common to all targets
    SRC_FILES += \
      $(SDK_ROOT)/modules/nrfx/mdk/gcc_startup_nrf52840.S \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_backend_rtt.c \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_backend_serial.c \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_backend_uart.c \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_default_backends.c \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_frontend.c \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_str_formatter.c \
      $(SDK_ROOT)/components/boards/boards.c \
      $(SDK_ROOT)/components/libraries/button/app_button.c \
      $(SDK_ROOT)/components/libraries/util/app_error.c \
      $(SDK_ROOT)/components/libraries/util/app_error_handler_gcc.c \
      $(SDK_ROOT)/components/libraries/util/app_error_weak.c \
      $(SDK_ROOT)/components/libraries/fifo/app_fifo.c \
      $(SDK_ROOT)/components/libraries/scheduler/app_scheduler.c \
      $(SDK_ROOT)/components/libraries/timer/app_timer2.c \
      $(SDK_ROOT)/components/libraries/uart/app_uart_fifo.c \
      $(SDK_ROOT)/components/libraries/usbd/app_usbd.c \
      $(SDK_ROOT)/components/libraries/usbd/class/audio/app_usbd_audio.c \
      $(SDK_ROOT)/components/libraries/usbd/app_usbd_core.c \
      $(SDK_ROOT)/components/libraries/usbd/app_usbd_string_desc.c \
      $(SDK_ROOT)/components/libraries/util/app_util_platform.c \
      $(SDK_ROOT)/components/libraries/timer/drv_rtc.c \
      $(SDK_ROOT)/components/libraries/hardfault/nrf52/handler/hardfault_handler_gcc.c \
      $(SDK_ROOT)/components/libraries/hardfault/hardfault_implementation.c \
      $(SDK_ROOT)/components/libraries/util/nrf_assert.c \
      $(SDK_ROOT)/components/libraries/atomic_fifo/nrf_atfifo.c \
      $(SDK_ROOT)/components/libraries/atomic/nrf_atomic.c \
      $(SDK_ROOT)/components/libraries/balloc/nrf_balloc.c \
      $(SDK_ROOT)/external/fprintf/nrf_fprintf.c \
      $(SDK_ROOT)/external/fprintf/nrf_fprintf_format.c \
      $(SDK_ROOT)/components/libraries/memobj/nrf_memobj.c \
      $(SDK_ROOT)/components/libraries/ringbuf/nrf_ringbuf.c \
      $(SDK_ROOT)/components/libraries/sortlist/nrf_sortlist.c \
      $(SDK_ROOT)/components/libraries/strerror/nrf_strerror.c \
      $(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_clock.c \
      $(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_power.c \
      $(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_uart.c \
      $(SDK_ROOT)/components/drivers_nrf/nrf_soc_nosd/nrf_nvic.c \
      $(SDK_ROOT)/components/drivers_nrf/nrf_soc_nosd/nrf_soc.c \
      $(SDK_ROOT)/modules/nrfx/soc/nrfx_atomic.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_clock.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_gpiote.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_power.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/prs/nrfx_prs.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_systick.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_uart.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_uarte.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_usbd.c \
      $(SDK_ROOT)/components/libraries/bsp/bsp.c \
      $(PROJ_DIR)/main.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_Syscalls_GCC.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_printf.c \
      $(SDK_ROOT)/modules/nrfx/mdk/system_nrf52840.c \
      $(SDK_ROOT)/external/utf_converter/utf.c \
    # Include folders common to all targets
    INC_FOLDERS += \
      $(SDK_ROOT)/components \
      $(SDK_ROOT)/modules/nrfx/mdk \
      $(SDK_ROOT)/components/libraries/scheduler \
      $(PROJ_DIR) \
      $(SDK_ROOT)/components/libraries/timer \
      $(SDK_ROOT)/components/libraries/fifo \
      $(SDK_ROOT)/components/boards \
      $(SDK_ROOT)/components/libraries/strerror \
      $(SDK_ROOT)/components/toolchain/cmsis/include \
      $(SDK_ROOT)/components/libraries/util \
      $(SDK_ROOT)/components/libraries/bsp \
      ../config \
      $(SDK_ROOT)/components/libraries/usbd/class/audio \
      $(SDK_ROOT)/components/libraries/balloc \
      $(SDK_ROOT)/components/libraries/ringbuf \
      $(SDK_ROOT)/components/libraries/hardfault/nrf52 \
      $(SDK_ROOT)/modules/nrfx/hal \
      $(SDK_ROOT)/components/libraries/hardfault \
      $(SDK_ROOT)/components/libraries/uart \
      $(SDK_ROOT)/components/libraries/log \
      $(SDK_ROOT)/components/libraries/button \
      $(SDK_ROOT)/modules/nrfx \
      $(SDK_ROOT)/components/libraries/experimental_section_vars \
      $(SDK_ROOT)/integration/nrfx/legacy \
      $(SDK_ROOT)/components/libraries/usbd \
      $(SDK_ROOT)/components/libraries/delay \
      $(SDK_ROOT)/external/segger_rtt \
      $(SDK_ROOT)/components/libraries/atomic_fifo \
      $(SDK_ROOT)/components/drivers_nrf/nrf_soc_nosd \
      $(SDK_ROOT)/components/libraries/atomic \
      $(SDK_ROOT)/components/libraries/sortlist \
      $(SDK_ROOT)/components/libraries/memobj \
      $(SDK_ROOT)/integration/nrfx \
      $(SDK_ROOT)/external/utf_converter \
      $(SDK_ROOT)/modules/nrfx/drivers/include \
      $(SDK_ROOT)/external/fprintf \
      $(SDK_ROOT)/components/libraries/log/src \
    # Libraries common to all targets
    LIB_FILES += \
    # Optimization flags
    #OPT = -O3 -g3
    # Uncomment the line below to enable link time optimization
    #OPT += -flto
    # C flags common to all targets
    CFLAGS += $(OPT)
    CFLAGS += -DAPP_TIMER_V2
    CFLAGS += -DAPP_TIMER_V2_RTC1_ENABLED
    CFLAGS += -DBOARD_PCA10056
    CFLAGS += -DCONFIG_GPIO_AS_PINRESET
    CFLAGS += -DFLOAT_ABI_HARD
    CFLAGS += -DNRF52840_XXAA
    CFLAGS += -mcpu=cortex-m4
    CFLAGS += -mthumb -mabi=aapcs
    CFLAGS += -Wall -Werror
    CFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    # keep every function in a separate section, this allows linker to discard unused ones
    CFLAGS += -ffunction-sections -fdata-sections -fno-strict-aliasing
    CFLAGS += -fno-builtin -fshort-enums
    # C++ flags common to all targets
    CXXFLAGS += $(OPT)
    # Assembler flags common to all targets
    ASMFLAGS += -g3
    ASMFLAGS += -mcpu=cortex-m4
    ASMFLAGS += -mthumb -mabi=aapcs
    ASMFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    ASMFLAGS += -DAPP_TIMER_V2
    ASMFLAGS += -DAPP_TIMER_V2_RTC1_ENABLED
    ASMFLAGS += -DBOARD_PCA10056
    ASMFLAGS += -DCONFIG_GPIO_AS_PINRESET
    ASMFLAGS += -DFLOAT_ABI_HARD
    ASMFLAGS += -DNRF52840_XXAA
    # Linker flags
    LDFLAGS += $(OPT)
    LDFLAGS += -mthumb -mabi=aapcs -L$(SDK_ROOT)/modules/nrfx/mdk -T$(LINKER_SCRIPT)
    LDFLAGS += -mcpu=cortex-m4
    LDFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    # let linker dump unused sections
    LDFLAGS += -Wl,--gc-sections
    # use newlib in nano version
    LDFLAGS += --specs=nano.specs
    nrf52840_xxaa: CFLAGS += -D__HEAP_SIZE=8192
    nrf52840_xxaa: CFLAGS += -D__STACK_SIZE=8192
    nrf52840_xxaa: ASMFLAGS += -D__HEAP_SIZE=8192
    nrf52840_xxaa: ASMFLAGS += -D__STACK_SIZE=8192
    # Add standard libraries at the very end of the linker input, after all objects
    # that may need symbols provided by these libraries.
    LIB_FILES += -lc -lnosys -lm
    .PHONY: default help
    # Default target - first one defined
    default: nrf52840_xxaa
    # Print all targets that can be built
    help:
    	@echo following targets are available:
    	@echo		nrf52840_xxaa
    	@echo		sdk_config - starting external tool for editing sdk_config.h
    	@echo		flash      - flashing binary
    TEMPLATE_PATH := $(SDK_ROOT)/components/toolchain/gcc
    include $(TEMPLATE_PATH)/Makefile.common
    $(foreach target, $(TARGETS), $(call define_target, $(target)))
    .PHONY: flash erase
    # Flash the program
    flash: default
    	@echo Flashing: $(OUTPUT_DIRECTORY)/nrf52840_xxaa.hex
    	nrfjprog -f nrf52 --program $(OUTPUT_DIRECTORY)/nrf52840_xxaa.hex --sectorerase
    	nrfjprog -f nrf52 --reset
    erase:
    	nrfjprog -f nrf52 --eraseall
    SDK_CONFIG_FILE := ../config/sdk_config.h
    CMSIS_CONFIG_TOOL := $(SDK_ROOT)/external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar
    sdk_config:
    	java -jar $(CMSIS_CONFIG_TOOL) $(SDK_CONFIG_FILE)
  • If the code that used to generate the given hex file -which works flawlessly- is the same as the given code.
    The only differences should be in either the Makefile or the toolchain
