nrf52810 not responding to SDK simple examples
Greetings Nordicsemi
Have an issue on the BLE651 (453-0005C), in bulit with nrf58210, have bought a 2 sample pieces on a stockist market,
Starting there were a few errors in the SDK, which have to be adjusted, have look up in this Devzone, not sure whether it was the right solution too
1) nrf_erratas.h (include the lib path to DeviceFamilyPack)
devzone.nordicsemi.com/.../rte-device-nrf52832_xxaa-system_nrf52-c-29-error-5-cannot-open-source-input-file-nrf_erratas-h-no-such-file-or-directory
2) insufficient RAM for Flash Algorithms, (have adjusted the to 0x2000)
devzone.nordicsemi.com/.../nordic-q-a/4098/insufficient-ram-for-flash-algorithm
Here's are the solutions that Larid provided me so far, and yet the nrf58210, is still responding, yet not to what the SDK implies
1) Understanding BLE, normal OS bluetooth utility on computers are not able to detect the app bluetooth signals, have adopted nrf Connect Application via smartphone, yet it was not detected via scan
2) nRF5_SDK\components\softdevice\common\nrf_sdh.c
Oscillator
3) Have adjusted the program to test single i/o testing, the module did not respond to the function? or isit flash into the module?
Examples Used : https://drive.google.com/file/d/11_M5TIvS7WRko8TuW0wSTjScP-OPQYIi/view
nRF5SDK14101dda907\examples\dtm\direct_test_mode\pca10040e
SDK used:  nRF5SDK14101 dda907
Platform used : Keil V5
Flash Progammer : ST - LINKER
Warmly
el
  • Purely usingly Nordic SDK examples to do the detection to check the module bought?
  • But you flashed the S112 softdevice, then?
    I don't know if the unmodified examples from the SDK will work. That depends on the pinout on your board. Check out the pca10040.h file in the SDK (or the equivalent file that is used in your project).
    I am not familiar with Laird's evaluation boards. I suggest you contact them and check if they have any known issues or userguides.
    BR,
    Edvin
  • Yes have flash S112 device, and used the Nordic SDK, whereas the links send, therefore maybe could you have any simple example to share just to verify the modules bought are good? BLE651, nRF52810
    Have not used Laird DK, this is to development quick models of the BLE transmission
  • I do not have a Laird DK, so I can not guarantee that any project that I compile works.
    1. It looks like, from your "connections made" layout, that you are not using an LFXTAL. Please set this in your sdk_config.h file for your project:
    #define NRF_SDH_CLOCK_LF_SRC 0
    #define NRF_SDH_CLOCK_LF_RC_CTIV 16
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    #define NRF_SDH_CLOCK_LF_ACCURACY 1
    After you have done this, please let me know what project you are testing on, and tell me the path to that sdk_config.h file.
    2: How do you flash the application and the softdevice? Can you show me some screenshots?
    3: Have you tried to debug? Is the main() function reached?
  • Greetings Edvin
    Sorry for being lengthy
    On side too have no Laird SDK, which is not needed for this development  yet, cause have only downloaded the examples from Nordic SDK web site,
    for pointer 1, yes have done both with the prescribe with or without XTAL and change the clock settings, is in the video links, please refer to them again in the above, as right have tested adjusted the parameters, they are still responding the same as previous describe
    pointer 2, this links shows, how it was flash, before and after editied the parameters/ add the XTAL is the same
    pointer 3,
    Yes, have used 3 exmaples
    1)... \nRF5SDK14101dda907\examples\ble_peripheral\ble_app_uart\pca10040e\s112\arm5_no_packs\ble_app_uart_pca10040e_s112
    this example, using the Laird BLE smartphone app should be able to pick up the adverister, however is not in the
    2)C:\Users\ephraem\Downloads\DeviceDownload(3)_14.1_\nRF5SDK14101dda907\examples\dtm\direct_test_mode\pca10040e\blank\arm5_no_packs\direct_test_mode_pca10040e
    this example, is the one that keeps the led on, which suggest that module is not yet configured?
    3) is a modifed example from (2)direct_test_mode_pca10040e, have change it to the below image, toggle led on tx, rx pin 18, 19 to normal output generation, it seems not responding to the commands, instead only original direct_test_mode_pca10040e example have the led to light on, which even when and FTDI (USB - UART/TTL) device to the tx,rx pins, and connected comupter via a virtual terminal, there is no transmission
    have debug using toggle led, yet the functions are not responding
    the path is on the screen on top
