I am working on nrf52sdk devkit. I am using max30208 temp. sensor. I configured one project twi_sensor and it's working properly. but when I merged this code into ble_app_hts. I am not getting data from TWI comm.
/** @file
* @defgroup ble_sdk_app_hts_main main.c
* @ingroup ble_sdk_app_hts
* @brief Health Thermometer Service Sample Application main file.
* This file contains the source code for a sample application using the Health Thermometer service
* It also includes the sample code for Battery and Device Information services.
* This application uses the @ref srvlib_conn_params module.
#include <stdio.h>
#include <stdint.h>
#include <string.h>
#include "nrf_delay.h"
#include "boards.h"
#include "nordic_common.h"
#include "nrf_drv_twi.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_bas.h"
#include "ble_hts.h"
#include "ble_dis.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "fds.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
//variables define
#include "var_def.h"
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static bool m_hts_meas_ind_conf_pending = false; /**< Flag to keep track of when an indication confirmation is pending. */
static sensorsim_cfg_t m_battery_sim_cfg; /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t m_battery_sim_state; /**< Battery Level sensor simulator state. */
static sensorsim_cfg_t m_temp_celcius_sim_cfg; /**< Temperature simulator configuration. */
static sensorsim_state_t m_temp_celcius_sim_state; /**< Temperature simulator state. */
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
static volatile bool trigger_temp =false;
/* TWI instance ID. */
#define TWI_INSTANCE_ID 0
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
double Temp_sample;
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
{BLE_UUID_HEALTH_THERMOMETER_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
static void advertising_start(bool erase_bonds);
static void temperature_measurement_send(void);
void HTM_application_timers_start(void);
void OT07_write_register(char slave_add, char reg_add, char *bytes, int n){
char data[16];
ret_code_t err_code;
data[0] = reg_add;
for(int i=1;i<=n;i++){
data[i] = bytes[i-1];
err_code = nrf_drv_twi_tx(&m_twi, slave_add, data, n+1, false);
while (m_xfer_done == false);
//NRF_LOG_INFO("wr[%02X %02X]\r\n", data[1], data[2]); //debug
void OT07_read_register( char slave_add,char reg_add, char *bytes, int n){
err_code = nrf_drv_twi_tx(&m_twi, slave_add, ®_add, 1, false);
err_code = nrf_drv_twi_rx(&m_twi, slave_add, bytes, n);
void convert_temperature(char slave_add){ // set convert bit to start conversion
char data[2];
//read ADC_SETUP register 0x14
// OT07_read_register( OT07_ADC_SETUP,data,2);
//nrf_delay_ms(20);
data[0] = data[0]|0xC1;
data[1] = data[1];
//mask convert register value with 0x01 and write back register 0x14
OT07_write_register( slave_add,OT07_ADC_SETUP, data,2);
* @brief Function for handling data from temperature sensor.
* @param[in] temp Temperature in Celsius degrees read from sensor.
__STATIC_INLINE void data_handler(double temp)
NRF_LOG_INFO("Temperature: int %d Celsius degrees.",temp);
* @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
switch (p_event->type)
case NRF_DRV_TWI_EVT_DONE:
if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
data_handler(Temp_sample);
NRF_LOG_INFO("data sent event");
m_xfer_done = true;
* @brief UART initialization.
void twi_init (void)
const nrf_drv_twi_config_t twi_max30208_config = {
.scl = ARDUINO_SCL_PIN,
.sda = ARDUINO_SDA_PIN,
.frequency = NRF_DRV_TWI_FREQ_400K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_twi, &twi_max30208_config, twi_handler, NULL);
nrf_drv_twi_enable(&m_twi);
* @brief Function for reading data from temperature sensor.
void read_sensor_data(char slave_add)
convert_temperature(slave_add);
nrf_delay_ms(20);
char data[2];
uint16_t count = 0;
uint8_t reg[1] = {max30208_read_data};
err_code = nrf_drv_twi_tx(&m_twi, slave_add, reg, 1, false);
err_code = nrf_drv_twi_rx(&m_twi, slave_add, data, 2);
//calculate temperture from data
count = (uint16_t)(data[0]*256 + data[1]);
NRF_LOG_INFO("wr[%02X %02X]\r\n", data[0], data[1]);
NRF_LOG_INFO("Temperature data: count %d ",count);
if (count >= 32768)
{count = 65536 - count;}
Temp_sample = (double)(count * 0.005);
NRF_LOG_INFO("Temperature data: debug %d,%d ",count, Temp_sample);
* @brief Function for setting active mode on MMA7660 accelerometer.
void max30208_setmode(char slave_add)
/* Writing to LM75B_REG_CONF "0" set temperature sensor in NORMAL mode. */
uint8_t reg[2] = {max30208_config, NORMAL_MODE};
err_code = nrf_drv_twi_tx(&m_twi, slave_add, reg, sizeof(reg), false);
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
/**@brief Function for handling Service errors.
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
static void service_error_handler(uint32_t nrf_error)
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
bool is_indication_enabled;
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
case PM_EVT_CONN_SEC_SUCCEEDED:
// Send a single temperature measurement if indication is enabled.
// NOTE: For this to work, make sure ble_hts_on_ble_evt() is called before
// pm_evt_handler() in ble_evt_dispatch().
err_code = ble_hts_is_indication_enabled(&m_hts, &is_indication_enabled);
if (is_indication_enabled)
//temperature_measurement_send();
HTM_application_timers_start();
advertising_start(false);
/**@brief Function for performing a battery measurement, and update the Battery Level characteristic in the Battery Service.
static void battery_level_update(void)
uint8_t battery_level;
battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
if ((err_code != NRF_SUCCESS) &&
(err_code != NRF_ERROR_INVALID_STATE) &&
(err_code != NRF_ERROR_BUSY) &&
(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer timeout.
* @details This function will be called each time the battery level measurement timer expires.
* @param[in] p_context Pointer used for passing some arbitrary information (context) from the
* app_start_timer() call to the timeout handler.
void battery_level_meas_timeout_handler(void * p_context)
UNUSED_PARAMETER(p_context);
battery_level_update();
void htm_timeout_handler(void * p_context)
/**@brief Function for populating simulated health thermometer measurement.
static void hts_sim_measurement(ble_hts_meas_t * p_meas)
static ble_date_time_t time_stamp = { 2012, 12, 5, 11, 50, 0 };
uint32_t celciusX100;
p_meas->temp_in_fahr_units = false;
p_meas->time_stamp_present = true;
p_meas->temp_type_present = (TEMP_TYPE_AS_CHARACTERISTIC ? false : true);
celciusX100 = sensorsim_measure(&m_temp_celcius_sim_state, &m_temp_celcius_sim_cfg);
p_meas->temp_in_celcius.exponent = -2;
p_meas->temp_in_celcius.mantissa = celciusX100;
p_meas->temp_in_fahr.exponent = -2;
p_meas->temp_in_fahr.mantissa = (32 * 100) + ((celciusX100 * 9) / 5);
p_meas->time_stamp = time_stamp;
p_meas->temp_type = BLE_HTS_TEMP_TYPE_FINGER;
// update simulated time stamp
time_stamp.seconds += 27;
if (time_stamp.seconds > 59)
time_stamp.seconds -= 60;
time_stamp.minutes++;
if (time_stamp.minutes > 59)
time_stamp.minutes = 0;
/**@brief Function for the Timer initialization.
* @details Initializes the timer module. This creates and starts application timers.
void timers_init(void)
// Initialize timer module.
err_code = app_timer_init();
// Create timers.
err_code = app_timer_create(&m_battery_timer_id,
APP_TIMER_MODE_REPEATED,
battery_level_meas_timeout_handler);
err_code = app_timer_create(&m_htm_timer_id,
htm_timeout_handler);
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_THERMOMETER);
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
/**@brief Function for simulating and sending one Temperature Measurement.
ble_hts_meas_t simulated_meas;
if (!m_hts_meas_ind_conf_pending)
hts_sim_measurement(&simulated_meas);
err_code = ble_hts_measurement_send(&m_hts, &simulated_meas);
switch (err_code)
case NRF_SUCCESS:
// Measurement was successfully sent, wait for confirmation.
m_hts_meas_ind_conf_pending = true;
case NRF_ERROR_INVALID_STATE:
// Ignore error.
/**@brief Function for handling the Health Thermometer Service events.
* @details This function will be called for all Health Thermometer Service events which are passed
* to the application.
* @param[in] p_hts Health Thermometer Service structure.
* @param[in] p_evt Event received from the Health Thermometer Service.
static void on_hts_evt(ble_hts_t * p_hts, ble_hts_evt_t * p_evt)
switch (p_evt->evt_type)
case BLE_HTS_EVT_INDICATION_ENABLED:
// Indication has been enabled, send a single temperature measurement
// temperature_measurement_send();
case BLE_HTS_EVT_INDICATION_CONFIRMED:
// No implementation needed.
* @details Initialize the Health Thermometer, Battery and Device Information services.
ble_hts_init_t hts_init;
ble_bas_init_t bas_init;
ble_dis_init_t dis_init;
ble_dis_sys_id_t sys_id;
// Initialize Health Thermometer Service
memset(&hts_init, 0, sizeof(hts_init));
hts_init.evt_handler = on_hts_evt;
hts_init.p_gatt_queue = &m_ble_gatt_queue;
hts_init.error_handler = service_error_handler;
hts_init.temp_type_as_characteristic = TEMP_TYPE_AS_CHARACTERISTIC;
hts_init.temp_type = BLE_HTS_TEMP_TYPE_BODY;
// Here the sec level for the Health Thermometer Service can be changed/increased.
hts_init.ht_meas_cccd_wr_sec = SEC_JUST_WORKS;
hts_init.ht_type_rd_sec = SEC_OPEN;
err_code = ble_hts_init(&m_hts, &hts_init);
// Initialize Battery Service.
memset(&bas_init, 0, sizeof(bas_init));
// Here the sec level for the Battery Service can be changed/increased.
bas_init.bl_rd_sec = SEC_OPEN;
bas_init.bl_cccd_wr_sec = SEC_OPEN;
bas_init.bl_report_rd_sec = SEC_OPEN;
bas_init.evt_handler = NULL;
bas_init.support_notification = true;
bas_init.p_report_ref = NULL;
bas_init.initial_batt_level = 100;
err_code = ble_bas_init(&m_bas, &bas_init);
// Initialize Device Information Service.
memset(&dis_init, 0, sizeof(dis_init));
ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, MANUFACTURER_NAME);
ble_srv_ascii_to_utf8(&dis_init.model_num_str, MODEL_NUM);
sys_id.manufacturer_id = MANUFACTURER_ID;
sys_id.organizationally_unique_id = ORG_UNIQUE_ID;
dis_init.p_sys_id = &sys_id;
dis_init.dis_char_rd_sec = SEC_OPEN;
err_code = ble_dis_init(&dis_init);
/**@brief Function for initializing the sensor simulators.
static void sensor_simulator_init(void)
m_battery_sim_cfg.min = MIN_BATTERY_LEVEL;
m_battery_sim_cfg.max = MAX_BATTERY_LEVEL;
m_battery_sim_cfg.incr = BATTERY_LEVEL_INCREMENT;
m_battery_sim_cfg.start_at_max = true;
sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
// Temperature is in celcius (it is multiplied by 100 to avoid floating point arithmetic).
m_temp_celcius_sim_cfg.min = MIN_CELCIUS_DEGREES;
m_temp_celcius_sim_cfg.max = MAX_CELCIUS_DEGRESS;
m_temp_celcius_sim_cfg.incr = CELCIUS_DEGREES_INCREMENT;
m_temp_celcius_sim_cfg.start_at_max = false;
sensorsim_init(&m_temp_celcius_sim_state, &m_temp_celcius_sim_cfg);
/**@brief Function for starting application timers.
static void application_timers_start(void)
// Start application timers.
err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
err_code = app_timer_start(m_htm_timer_id, HTM_temp_timer, NULL);
/**@brief Function for handling the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module which
* are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply
* setting the disconnect_on_fail config parameter, but instead we use the event
* handler mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
/**@brief Function for handling a Connection Parameters error.
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising.");
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
uint32_t err_code = NRF_SUCCESS;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected.");
NRF_LOG_INFO("Disconnected.");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
uint32_t ram_start = 0;
// Enable BLE stack.
* @param[in] event Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
case BSP_EVENT_WHITELIST_OFF:
case BSP_EVENT_KEY_0:
if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
trigger_temp=true;
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
* @details Encodes the required advertising data and passes it to the stack.
* Also builds a structure to be passed to the stack when starting advertising.
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
nrf_pwr_mgmt_run();
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
/**@brief Function for application main entry.
bool erase_bonds;
log_init();
NRF_LOG_INFO("\r\nTWI sensor example started.");
NRF_LOG_FLUSH();
twi_init();
max30208_setmode(max30208_slave_add);
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
advertising_init();
services_init();
sensor_simulator_init();
conn_params_init();
peer_manager_init();
// Start execution.
NRF_LOG_INFO("Health Thermometer example started.");
advertising_start(erase_bonds);
while (true)
if(trigger_temp)
nrf_delay_ms(500);
read_sensor_data(max30208_slave_add);
NRF_LOG_FLUSH();
trigger_temp=false;
idle_state_handle();
