nrf52832 undefined reference to `nrfx_comp_init'
Hello guys,
I'm trying to use the new NRFX library but I've hit the wall with the following error when trying to use the comparator API:
This happens during the link stage. I can see the nrfx_comp.c being compiled, I've set the #define NRFX_COMP_ENABLED 1 in sdk_config.h but the error still persists.
I've included #include "nrfx_comp.h" in my project.
I'm using GCC. Any help is appreciated.
L. B.
  • Did you also added nrfx_comp.c to the project?
    From your SDK folder, add to the project a reference to the following: modules/nrfx/drivers/src/nrfx_comp.c
  • Yes, in my Makefile I've added:
    $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_comp.c \
    in the "SRC_FILES += \" section.
  • I believe my project points to the wrong nrfx_config.h file ... but I cannot understand how does my Makefile do the connection to the correct:
    nRF5_SDK_17.0.0_9d13099/modules/nrfx/templates/nRF52832/nrfx_config.h
  • In the Makefile, `SDK_ROOT` is defined as a relative path
    SDK_ROOT := ../../../../../..
    Can you share your Makefile (Insert->Code) and your folder structure?
  • PROJECT_NAME     := ble_app_uart_pca10040_s132
    TARGETS          := nrf52832_xxaa
    OUTPUT_DIRECTORY := _build
    PROJ_DIR := ../../..
    $(OUTPUT_DIRECTORY)/nrf52832_xxaa.out: \
      LINKER_SCRIPT  := ble_app_uart_gcc_nrf52.ld
    # Source files common to all targets
    SRC_FILES += \
      $(SDK_ROOT)/modules/nrfx/mdk/gcc_startup_nrf52.S \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_backend_rtt.c \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_backend_serial.c \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_default_backends.c \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_frontend.c \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_str_formatter.c \
      $(SDK_ROOT)/components/libraries/button/app_button.c \
      $(SDK_ROOT)/components/libraries/util/app_error.c \
      $(SDK_ROOT)/components/libraries/util/app_error_handler_gcc.c \
      $(SDK_ROOT)/components/libraries/util/app_error_weak.c \
      $(SDK_ROOT)/components/libraries/fifo/app_fifo.c \
      $(SDK_ROOT)/components/libraries/scheduler/app_scheduler.c \
      $(SDK_ROOT)/components/libraries/timer/app_timer2.c \
      $(SDK_ROOT)/components/libraries/uart/app_uart_fifo.c \
      $(SDK_ROOT)/components/libraries/util/app_util_platform.c \
      $(SDK_ROOT)/components/libraries/timer/drv_rtc.c \
      $(SDK_ROOT)/components/libraries/hardfault/hardfault_implementation.c \
      $(SDK_ROOT)/components/libraries/util/nrf_assert.c \
      $(SDK_ROOT)/components/libraries/atomic_fifo/nrf_atfifo.c \
      $(SDK_ROOT)/components/libraries/atomic_flags/nrf_atflags.c \
      $(SDK_ROOT)/components/libraries/atomic/nrf_atomic.c \
      $(SDK_ROOT)/components/libraries/balloc/nrf_balloc.c \
      $(SDK_ROOT)/external/fprintf/nrf_fprintf.c \
      $(SDK_ROOT)/external/fprintf/nrf_fprintf_format.c \
      $(SDK_ROOT)/components/libraries/memobj/nrf_memobj.c \
      $(SDK_ROOT)/components/libraries/pwr_mgmt/nrf_pwr_mgmt.c \
      $(SDK_ROOT)/components/libraries/ringbuf/nrf_ringbuf.c \
      $(SDK_ROOT)/components/libraries/experimental_section_vars/nrf_section_iter.c \
      $(SDK_ROOT)/components/libraries/sortlist/nrf_sortlist.c \
      $(SDK_ROOT)/components/libraries/strerror/nrf_strerror.c \
      $(SDK_ROOT)/components/libraries/uart/retarget.c \
      $(SDK_ROOT)/modules/nrfx/mdk/system_nrf52.c \
      $(SDK_ROOT)/components/boards/boards.c \
      $(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_clock.c \
      $(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_uart.c \
      $(SDK_ROOT)/modules/nrfx/soc/nrfx_atomic.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_clock.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_gpiote.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/prs/nrfx_prs.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_uart.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_uarte.c \
      $(SDK_ROOT)/components/libraries/bsp/bsp.c \
      $(SDK_ROOT)/components/libraries/bsp/bsp_btn_ble.c \
      $(PROJ_DIR)/main.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_Syscalls_GCC.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_printf.c \
      $(SDK_ROOT)/components/ble/common/ble_advdata.c \
      $(SDK_ROOT)/components/ble/ble_advertising/ble_advertising.c \
      $(SDK_ROOT)/components/ble/common/ble_conn_params.c \
      $(SDK_ROOT)/components/ble/common/ble_conn_state.c \
      $(SDK_ROOT)/components/ble/ble_link_ctx_manager/ble_link_ctx_manager.c \
      $(SDK_ROOT)/components/ble/common/ble_srv_common.c \
      $(SDK_ROOT)/components/ble/nrf_ble_gatt/nrf_ble_gatt.c \
      $(SDK_ROOT)/components/ble/nrf_ble_qwr/nrf_ble_qwr.c \
      $(SDK_ROOT)/external/utf_converter/utf.c \
      $(SDK_ROOT)/components/ble/ble_services/ble_nus/ble_nus.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh_ble.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh_soc.c \
      ../../../user_uart.c \
      ../../../user_bluetooth.c \
      ../../../user_pwm.c \
      ../../../user_touch.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_pwm.c \
    # Include folders common to all targets
    INC_FOLDERS += \
      $(SDK_ROOT)/components/nfc/ndef/generic/message \
      $(SDK_ROOT)/components/nfc/t2t_lib \
      $(SDK_ROOT)/components/nfc/t4t_parser/hl_detection_procedure \
      $(SDK_ROOT)/components/ble/ble_services/ble_ancs_c \
      $(SDK_ROOT)/components/ble/ble_services/ble_ias_c \
      $(SDK_ROOT)/components/libraries/pwm \
      $(SDK_ROOT)/components/softdevice/s132/headers/nrf52 \
      $(SDK_ROOT)/components/libraries/usbd/class/cdc/acm \
      $(SDK_ROOT)/components/libraries/usbd/class/hid/generic \
      $(SDK_ROOT)/components/libraries/usbd/class/msc \
      $(SDK_ROOT)/components/libraries/usbd/class/hid \
      $(SDK_ROOT)/modules/nrfx/hal \
      $(SDK_ROOT)/components/nfc/ndef/conn_hand_parser/le_oob_rec_parser \
      $(SDK_ROOT)/components/libraries/log \
      $(SDK_ROOT)/components/ble/ble_services/ble_gls \
      $(SDK_ROOT)/components/libraries/fstorage \
      $(SDK_ROOT)/components/nfc/ndef/text \
      $(SDK_ROOT)/components/libraries/mutex \
      $(SDK_ROOT)/components/libraries/gfx \
      $(SDK_ROOT)/components/libraries/bootloader/ble_dfu \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/common \
      $(SDK_ROOT)/components/libraries/fifo \
      $(SDK_ROOT)/components/boards \
      $(SDK_ROOT)/components/nfc/ndef/generic/record \
      $(SDK_ROOT)/components/nfc/t4t_parser/cc_file \
      $(SDK_ROOT)/components/ble/ble_advertising \
      $(SDK_ROOT)/external/utf_converter \
      $(SDK_ROOT)/components/ble/ble_services/ble_bas_c \
      $(SDK_ROOT)/modules/nrfx/drivers/include \
      $(SDK_ROOT)/components/libraries/experimental_task_manager \
      $(SDK_ROOT)/components/ble/ble_services/ble_hrs_c \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/le_oob_rec \
      $(SDK_ROOT)/components/libraries/queue \
      $(SDK_ROOT)/components/libraries/pwr_mgmt \
      $(SDK_ROOT)/components/ble/ble_dtm \
      $(SDK_ROOT)/components/toolchain/cmsis/include \
      $(SDK_ROOT)/components/ble/ble_services/ble_rscs_c \
      $(SDK_ROOT)/components/ble/common \
      $(SDK_ROOT)/components/ble/ble_services/ble_lls \
      $(SDK_ROOT)/components/nfc/platform \
      $(SDK_ROOT)/components/libraries/bsp \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/ac_rec \
      $(SDK_ROOT)/components/ble/ble_services/ble_bas \
      $(SDK_ROOT)/components/libraries/mpu \
      $(SDK_ROOT)/components/libraries/experimental_section_vars \
      $(SDK_ROOT)/components/softdevice/s132/headers \
      $(SDK_ROOT)/components/ble/ble_services/ble_ans_c \
      $(SDK_ROOT)/components/libraries/slip \
      $(SDK_ROOT)/components/libraries/delay \
      $(SDK_ROOT)/components/libraries/csense_drv \
      $(SDK_ROOT)/components/libraries/memobj \
      $(SDK_ROOT)/components/ble/ble_services/ble_nus_c \
      $(SDK_ROOT)/components/softdevice/common \
      $(SDK_ROOT)/components/ble/ble_services/ble_ias \
      $(SDK_ROOT)/components/libraries/usbd/class/hid/mouse \
      $(SDK_ROOT)/components/libraries/low_power_pwm \
      $(SDK_ROOT)/components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser \
      $(SDK_ROOT)/components/ble/ble_services/ble_dfu \
      $(SDK_ROOT)/external/fprintf \
      $(SDK_ROOT)/components/libraries/svc \
      $(SDK_ROOT)/components/libraries/atomic \
      $(SDK_ROOT)/components \
      $(SDK_ROOT)/components/libraries/scheduler \
      $(SDK_ROOT)/components/libraries/cli \
      $(SDK_ROOT)/components/ble/ble_services/ble_lbs \
      $(SDK_ROOT)/components/ble/ble_services/ble_hts \
      $(SDK_ROOT)/components/ble/ble_services/ble_cts_c \
      $(SDK_ROOT)/components/libraries/crc16 \
      $(SDK_ROOT)/components/nfc/t4t_parser/apdu \
      $(SDK_ROOT)/components/libraries/util \
      $(SDK_ROOT)/components/libraries/usbd/class/cdc \
      $(SDK_ROOT)/components/libraries/csense \
      $(SDK_ROOT)/components/libraries/balloc \
      $(SDK_ROOT)/components/libraries/ecc \
      $(SDK_ROOT)/components/libraries/hardfault \
      $(SDK_ROOT)/components/ble/ble_services/ble_cscs \
      $(SDK_ROOT)/components/libraries/uart \
      $(SDK_ROOT)/components/libraries/hci \
      $(SDK_ROOT)/components/libraries/usbd/class/hid/kbd \
      $(SDK_ROOT)/components/libraries/timer \
      $(SDK_ROOT)/integration/nrfx \
      $(SDK_ROOT)/components/nfc/t4t_parser/tlv \
      $(SDK_ROOT)/components/libraries/sortlist \
      $(SDK_ROOT)/components/libraries/spi_mngr \
      $(SDK_ROOT)/components/libraries/led_softblink \
      $(SDK_ROOT)/components/nfc/ndef/conn_hand_parser \
      $(SDK_ROOT)/components/libraries/sdcard \
      $(SDK_ROOT)/components/nfc/ndef/parser/record \
      $(SDK_ROOT)/modules/nrfx/mdk \
      $(SDK_ROOT)/components/ble/ble_link_ctx_manager \
      $(SDK_ROOT)/components/ble/ble_services/ble_nus \
      $(SDK_ROOT)/components/libraries/twi_mngr \
      $(SDK_ROOT)/components/ble/ble_services/ble_hids \
      $(SDK_ROOT)/components/libraries/strerror \
      $(SDK_ROOT)/components/libraries/crc32 \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/ble_oob_advdata \
      $(SDK_ROOT)/components/nfc/t2t_parser \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/ble_pair_msg \
      $(SDK_ROOT)/components/libraries/usbd/class/audio \
      $(SDK_ROOT)/components/nfc/t4t_lib \
      $(SDK_ROOT)/components/ble/peer_manager \
      $(SDK_ROOT)/components/libraries/mem_manager \
      $(SDK_ROOT)/components/libraries/ringbuf \
      $(SDK_ROOT)/components/ble/ble_services/ble_tps \
      $(SDK_ROOT)/components/nfc/ndef/parser/message \
      $(SDK_ROOT)/components/ble/ble_services/ble_dis \
      $(SDK_ROOT)/components/nfc/ndef/uri \
      $(SDK_ROOT)/components/ble/nrf_ble_gatt \
      $(SDK_ROOT)/components/ble/nrf_ble_qwr \
      $(SDK_ROOT)/components/libraries/gpiote \
      $(SDK_ROOT)/components/libraries/button \
      $(SDK_ROOT)/modules/nrfx \
      $(SDK_ROOT)/components/libraries/twi_sensor \
      $(SDK_ROOT)/integration/nrfx/legacy \
      $(SDK_ROOT)/components/libraries/usbd \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/ep_oob_rec \
      $(SDK_ROOT)/external/segger_rtt \
      $(SDK_ROOT)/components/libraries/atomic_fifo \
      $(SDK_ROOT)/components/ble/ble_services/ble_lbs_c \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/ble_pair_lib \
      $(SDK_ROOT)/components/libraries/crypto \
      $(SDK_ROOT)/components/ble/ble_racp \
      $(SDK_ROOT)/components/libraries/fds \
      $(SDK_ROOT)/components/nfc/ndef/launchapp \
      $(SDK_ROOT)/components/libraries/atomic_flags \
      $(SDK_ROOT)/components/ble/ble_services/ble_hrs \
      $(SDK_ROOT)/components/ble/ble_services/ble_rscs \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/hs_rec \
      $(SDK_ROOT)/components/nfc/ndef/conn_hand_parser/ac_rec_parser \
      $(SDK_ROOT)/components/libraries/stack_guard \
      $(SDK_ROOT)/components/libraries/log/src \
      ../config \
    # Libraries common to all targets
    LIB_FILES += \
    # Optimization flags
    OPT = -O3 -g3
    # Uncomment the line below to enable link time optimization
    #OPT += -flto
    # C flags common to all targets
    CFLAGS += $(OPT)
    CFLAGS += -DAPP_TIMER_V2
    CFLAGS += -DAPP_TIMER_V2_RTC1_ENABLED
    CFLAGS += -DBOARD_PCA10040
    CFLAGS += -DCONFIG_GPIO_AS_PINRESET
    CFLAGS += -DFLOAT_ABI_HARD
    CFLAGS += -DNRF52
    CFLAGS += -DNRF52832_XXAA
    CFLAGS += -DNRF52_PAN_74
    CFLAGS += -DNRF_SD_BLE_API_VERSION=7
    CFLAGS += -DS132
    CFLAGS += -DSOFTDEVICE_PRESENT
    CFLAGS += -mcpu=cortex-m4
    CFLAGS += -mthumb -mabi=aapcs
    CFLAGS += -Wall -Werror
    CFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    # keep every function in a separate section, this allows linker to discard unused ones
    CFLAGS += -ffunction-sections -fdata-sections -fno-strict-aliasing
    CFLAGS += -fno-builtin -fshort-enums
    # C++ flags common to all targets
    CXXFLAGS += $(OPT)
    # Assembler flags common to all targets
    ASMFLAGS += -g3
    ASMFLAGS += -mcpu=cortex-m4
    ASMFLAGS += -mthumb -mabi=aapcs
    ASMFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    ASMFLAGS += -DAPP_TIMER_V2
    ASMFLAGS += -DAPP_TIMER_V2_RTC1_ENABLED
    ASMFLAGS += -DBOARD_PCA10040
    ASMFLAGS += -DCONFIG_GPIO_AS_PINRESET
    ASMFLAGS += -DFLOAT_ABI_HARD
    ASMFLAGS += -DNRF52
    ASMFLAGS += -DNRF52832_XXAA
    ASMFLAGS += -DNRF52_PAN_74
    ASMFLAGS += -DNRF_SD_BLE_API_VERSION=7
    ASMFLAGS += -DS132
    ASMFLAGS += -DSOFTDEVICE_PRESENT
    # Linker flags
    LDFLAGS += $(OPT)
    LDFLAGS += -mthumb -mabi=aapcs -L$(SDK_ROOT)/modules/nrfx/mdk -T$(LINKER_SCRIPT)
    LDFLAGS += -mcpu=cortex-m4
    LDFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    # let linker dump unused sections
    LDFLAGS += -Wl,--gc-sections
    # use newlib in nano version
    LDFLAGS += --specs=nano.specs
    nrf52832_xxaa: CFLAGS += -D__HEAP_SIZE=8192
    nrf52832_xxaa: CFLAGS += -D__STACK_SIZE=8192
    nrf52832_xxaa: ASMFLAGS += -D__HEAP_SIZE=8192
    nrf52832_xxaa: ASMFLAGS += -D__STACK_SIZE=8192
    # Add standard libraries at the very end of the linker input, after all objects
    # that may need symbols provided by these libraries.
    LIB_FILES += -lc -lnosys -lm
    .PHONY: default help
    # Default target - first one defined
    default: nrf52832_xxaa
    # Print all targets that can be built
    help:
    	@echo following targets are available:
    	@echo		nrf52832_xxaa
    	@echo		flash_softdevice
    	@echo		sdk_config - starting external tool for editing sdk_config.h
    	@echo		flash      - flashing binary
    TEMPLATE_PATH := $(SDK_ROOT)/components/toolchain/gcc
    include $(TEMPLATE_PATH)/Makefile.common
    $(foreach target, $(TARGETS), $(call define_target, $(target)))
    .PHONY: flash flash_softdevice erase
    flash: nrf52832_xxaa
    	@echo Flashing: $(OUTPUT_BINARY_DIRECTORY)/$<.hex
    	/openocd_2/bin/openocd -f interface/stlink-v2.cfg  -f target/nrf52.cfg -c "init" -c "reset halt" -c "program ./_build/nrf52832_xxaa.hex verify reset exit"
    flash_softdevice:
    	/openocd_2/bin/openocd -f interface/stlink-v2.cfg -f target/nrf52.cfg -c "init" -c "reset halt" -c "flash probe 0" -c "nrf5 mass_erase" -c "program ../../../s132_nrf52_7.0.1_softdevice.hex verify reset exit" -c"exit"
    reset:
    	/openocd_2/bin/openocd -f interface/stlink-v2.cfg  -f target/nrf52.cfg -c "init" -c "reset run" -c "exit"
    # Flash the program
    #flash: default
    #	@echo Flashing: $(OUTPUT_DIRECTORY)/nrf52832_xxaa.hex
    #	nrfjprog -f nrf52 --program $(OUTPUT_DIRECTORY)/nrf52832_xxaa.hex --sectorerase
    #	nrfjprog -f nrf52 --reset
    # Flash softdevice
    #flash_softdevice:
    #	@echo Flashing: s132_nrf52_7.0.1_softdevice.hex
    #	nrfjprog -f nrf52 --program $(SDK_ROOT)/components/softdevice/s132/hex/s132_nrf52_7.0.1_softdevice.hex --sectorerase
    erase:
    	nrfjprog -f nrf52 --eraseall
    SDK_CONFIG_FILE := ../config/sdk_config.h
    CMSIS_CONFIG_TOOL := $(SDK_ROOT)/external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar
    sdk_config:
    	java -jar $(CMSIS_CONFIG_TOOL) $(SDK_CONFIG_FILE)
    And my dir structure:
    my project is in /nRF5_SDK_17.0.0_9d13099/examples/ble_peripheral/my_blue_project
    and I have a main.c in /my_blue_project directory.
