CONFIG_PM_SINGLE_IMAGE not working when building mcuboot
I am using NCS 1.3.0.  I try to build mcuboot with CONFIG_PM_SINGLE_IMAGE=y and it looks like partition manager is never run.  I do not get any partitions.yml output in my build folder.
Command line output:
> Executing task in folder pinnacle_firmware: west build -b pinnacle_100_dvk -d /Users/ryan/git/pinnacle100_workspace/pinnacle_firmware/build/mcuboot /Users/ryan/git/pinnacle100_workspace/pinnacle_firmware/../bootloader/mcuboot/boot/zephyr -- -DCONF_FILE="${workspaceFolder}/../modules/zephyr_lib/mcuboot_config/mcuboot-qspi.conf ${workspaceFolder}/../modules/zephyr_lib/mcuboot_config/overlay-disable-hl7800-modem.conf ${workspaceFolder}/../modules/zephyr_lib/mcuboot_config/mcuboot-serial-pinnacle100_dvk.conf ${workspaceFolder}/../modules/zephyr_lib/mcuboot_config/disable-signature-check.conf" <
Including boilerplate (Zephyr base): /Users/ryan/git/pinnacle100_workspace/zephyr/cmake/app/boilerplate.cmake
-- Application: /Users/ryan/git/pinnacle100_workspace/bootloader/mcuboot/boot/zephyr
-- Zephyr version: 2.3.0-rc1 (/Users/ryan/git/pinnacle100_workspace/zephyr)
-- Found Python3: /usr/local/bin/python3.7 (found suitable exact version "3.7.6") found components: Interpreter
-- Board: pinnacle_100_dvk
-- Found west: /usr/local/bin/west (found suitable version "0.7.2", minimum required is "0.7.1")
-- Found dtc: /usr/local/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (/usr/local/Caskroom/gcc-arm-embedded/9-2019-q4-major/gcc-arm-none-eabi-9-2019-q4-major)
-- Found BOARD.dts: /Users/ryan/git/pinnacle100_workspace/zephyr/boards/arm/pinnacle_100_dvk/pinnacle_100_dvk.dts
-- Found devicetree overlay: /Users/ryan/git/pinnacle100_workspace/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: /Users/ryan/git/pinnacle100_workspace/pinnacle_firmware/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /Users/ryan/git/pinnacle100_workspace/pinnacle_firmware/build/mcuboot/zephyr/include/generated/devicetree_unfixed.h
Parsing /Users/ryan/git/pinnacle100_workspace/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration '/Users/ryan/git/pinnacle100_workspace/zephyr/boards/arm/pinnacle_100_dvk/pinnacle_100_dvk_defconfig'
Merged configuration '/Users/ryan/git/pinnacle100_workspace/pinnacle_firmware/../modules/zephyr_lib/mcuboot_config/mcuboot-qspi.conf'
Merged configuration '/Users/ryan/git/pinnacle100_workspace/pinnacle_firmware/../modules/zephyr_lib/mcuboot_config/overlay-disable-hl7800-modem.conf'
Merged configuration '/Users/ryan/git/pinnacle100_workspace/pinnacle_firmware/../modules/zephyr_lib/mcuboot_config/mcuboot-serial-pinnacle100_dvk.conf'
Merged configuration '/Users/ryan/git/pinnacle100_workspace/pinnacle_firmware/../modules/zephyr_lib/mcuboot_config/disable-signature-check.conf'
Configuration saved to '/Users/ryan/git/pinnacle100_workspace/pinnacle_firmware/build/mcuboot/zephyr/.config'
Kconfig header saved to '/Users/ryan/git/pinnacle100_workspace/pinnacle_firmware/build/mcuboot/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: /usr/local/Caskroom/gcc-arm-embedded/9-2019-q4-major/gcc-arm-none-eabi-9-2019-q4-major/bin/arm-none-eabi-gcc
-- Cache files will be written to: /Users/ryan/Library/Caches/zephyr
CMake Warning at /Users/ryan/git/pinnacle100_workspace/nrf/lib/flash_patch/CMakeLists.txt:9 (message):
        --- WARNING: To maintain the integrity of secure boot, ---
        --- enable CONFIG_DISABLE_FLASH_PATCH in production.   ---
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/ryan/git/pinnacle100_workspace/pinnacle_firmware/build/mcuboot
[1/254] Preparing syscall dependency handling
[249/254] Linking C executable zephyr/zephyr_prebuilt.elf
           FLASH:       49880 B        96 KB     50.74%
            SRAM:       30800 B       256 KB     11.75%
        IDT_LIST:         104 B         2 KB      5.08%
[254/254] Linking C executable zephyr/zephyr.elf
generated config file:
# MCUboot-specific configuration options
CONFIG_MCUBOOT=y
CONFIG_PM_PARTITION_SIZE_MCUBOOT=0xc000
CONFIG_PM_PARTITION_SIZE_MCUBOOT_SCRATCH=0x1e000
CONFIG_PM_PARTITION_SIZE_MCUBOOT_PAD=0x200
CONFIG_BOOT_USE_MBEDTLS=y
# MCUBoot settings
CONFIG_BOOT_SIGNATURE_TYPE_RSA=y
CONFIG_BOOT_SIGNATURE_TYPE_RSA_LEN=2048
# CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256 is not set
# CONFIG_BOOT_SIGNATURE_TYPE_ED25519 is not set
CONFIG_MCUBOOT_CLEANUP_ARM_CORE=y
CONFIG_MBEDTLS_CFG_FILE="mcuboot-mbedtls-cfg.h"
# CONFIG_BOOT_HW_KEY is not set
# CONFIG_BOOT_VALIDATE_SLOT0 is not set
# CONFIG_BOOT_UPGRADE_ONLY is not set
CONFIG_BOOT_SWAP_USING_MOVE=y
# CONFIG_BOOT_BOOTSTRAP is not set
# CONFIG_BOOT_SWAP_SAVE_ENCTLV is not set
# CONFIG_BOOT_ENCRYPT_RSA is not set
# CONFIG_BOOT_ENCRYPT_EC256 is not set
# CONFIG_BOOT_ENCRYPT_X25519 is not set
CONFIG_BOOT_MAX_IMG_SECTORS=256
CONFIG_BOOT_ERASE_PROGRESSIVELY=y
# CONFIG_MEASURED_BOOT is not set
# CONFIG_BOOT_SHARE_DATA is not set
# CONFIG_BOOT_WAIT_FOR_USB_DFU is not set
# CONFIG_ZEPHYR_TRY_MASS_ERASE is not set
# CONFIG_BOOT_USE_BENCH is not set
# CONFIG_MCUBOOT_LOG_LEVEL_OFF is not set
# CONFIG_MCUBOOT_LOG_LEVEL_ERR is not set
# CONFIG_MCUBOOT_LOG_LEVEL_WRN is not set
CONFIG_MCUBOOT_LOG_LEVEL_INF=y
# CONFIG_MCUBOOT_LOG_LEVEL_DBG is not set
CONFIG_MCUBOOT_LOG_LEVEL=3
CONFIG_MCUBOOT_LOG_THREAD_STACK_SIZE=768
CONFIG_MCUBOOT_SERIAL=y
CONFIG_BOOT_SERIAL_UART=y
# CONFIG_BOOT_SERIAL_CDC_ACM is not set
CONFIG_BOOT_MAX_LINE_INPUT_LEN=512
CONFIG_BOOT_SERIAL_DETECT_PORT="GPIO_0"
CONFIG_BOOT_SERIAL_DETECT_PIN=31
CONFIG_BOOT_SERIAL_DETECT_PIN_VAL=0
CONFIG_RECOVERY_UART_DEV_NAME="UART_0"
# end of MCUBoot settings
CONFIG_MCUBOOT_DEVICE_SETTINGS=y
# Zephyr configuration options
CONFIG_MULTITHREADING=y
# CONFIG_LOG_IMMEDIATE is not set
# CONFIG_LOG_PROCESS_THREAD is not set
CONFIG_USB_DEVICE_PRODUCT="MCUBOOT"
CONFIG_UPDATEABLE_IMAGE_NUMBER=1
# Modules
# Nordic nRF Connect
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
CONFIG_LOG_DEFAULT_LEVEL=3
# Bootloader
# CONFIG_BUILD_S1_VARIANT is not set
# CONFIG_SECURE_BOOT is not set
CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x7000
# CONFIG_SECURE_BOOT_CRYPTO is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATE_FW_SIGNATURE=y
# end of Secure Boot firmware validation
# end of Bootloader
# Bluetooth Low Energy
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
# end of Bluetooth Low Energy
# DFU
# CONFIG_DFU_TARGET is not set
# end of DFU
# CONFIG_ESB is not set
# Networking
# Application protocols
# CONFIG_NRF_CLOUD is not set
# CONFIG_DOWNLOAD_CLIENT is not set
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_CLOUD_API is not set
# CONFIG_CLOUD_PERSISTENT_SESSIONS is not set
# Self-Registration (Zi ZHu Ce)
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# end of Application protocols
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# end of NFC
# CONFIG_PROFILER is not set
# SPM
# CONFIG_SPM is not set
# CONFIG_IS_SPM is not set
# end of SPM
# CONFIG_FW_INFO is not set
# CONFIG_PPI_TRACE is not set
# CONFIG_CPU_LOAD is not set
# Nordic MPSL
CONFIG_MPSL_THREAD_COOP_PRIO=8
CONFIG_MPSL_SIGNAL_STACK_SIZE=1024
# CONFIG_MPSL_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_LOG_LEVEL_WRN is not set
CONFIG_MPSL_LOG_LEVEL_INF=y
# CONFIG_MPSL_LOG_LEVEL_DBG is not set
CONFIG_MPSL_LOG_LEVEL=3
# end of Nordic MPSL
# Partition Manager
# Zephyr subsystem configurations
# end of Zephyr subsystem configurations
CONFIG_PM_EXTERNAL_FLASH=y
CONFIG_PM_EXTERNAL_FLASH_DEV_NAME="MX25R64"
CONFIG_PM_EXTERNAL_FLASH_SIZE=0x800000
CONFIG_PM_EXTERNAL_FLASH_BASE=0
# end of Partition Manager
# CONFIG_ZIGBEE is not set
# Libraries
# Binary libraries
# end of Binary libraries
# BSD Library for nrf91
# end of BSD Library for nrf91
# CONFIG_ADP536X is not set
# AT Command driver
# end of AT Command driver
# CONFIG_DISABLE_FLASH_PATCH is not set
# CONFIG_LTE_LINK_CONTROL is not set
# CONFIG_FPROTECT is not set
CONFIG_FPROTECT_BLOCK_SIZE=0x1000
# AT Host Library for nrf91
# CONFIG_AT_HOST_LIBRARY is not set
# end of AT Host Library for nrf91
# CONFIG_DK_LIBRARY is not set
# CONFIG_AT_CMD_PARSER is not set
# CONFIG_MODEM_INFO is not set
# CONFIG_RESET_ON_FATAL_ERROR is not set
# CONFIG_SMS is not set
# CONFIG_SUPL_CLIENT_LIB is not set
# end of Libraries
# Device Drivers
# CONFIG_HW_CC310 is not set
# CONFIG_ETH_RTT is not set
# CONFIG_SENSOR is not set
# GPS Drivers
# CONFIG_GPS_SIM is not set
# end of GPS Drivers
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set
# end of Device Drivers
# External libraries
# end of External libraries
# CONFIG_UNITY is not set
# end of Nordic nRF Connect
CONFIG_COMPONENT_LIB=y
# CONFIG_PIEZO is not set
# CONFIG_VIBEMOTOR is not set
# CONFIG_ACCELEROMETER is not set
# Laird Connectivity Zephyr Components
# CONFIG_LCZ_QRTC is not set
# CONFIG_LCZ_LED is not set
CONFIG_DEFAULT_LED_ON_TIME_FOR_1_SECOND_BLINK=100
CONFIG_DEFAULT_LED_OFF_TIME_FOR_1_SECOND_BLINK=900
# CONFIG_LCZ_DNS is not set
# CONFIG_LCZ_POWER is not set
# end of Laird Connectivity Zephyr Components
# Laird Connectivity Zephyr Utilities
# CONFIG_JSON_LOG_ENABLED is not set
# end of Laird Connectivity Zephyr Utilities
# MCUboot
CONFIG_BOOT_SIGNATURE_KEY_FILE="root-rsa-2048.pem"
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
# end of MCUboot
# Nordic nrfxlib
# CONFIG_NFC_T2T_NRFXLIB is not set
# CONFIG_NFC_T4T_NRFXLIB is not set
# CONFIG_MPSL is not set
# Crypto libraries for nRF5x SOCs.
# CONFIG_NRF_OBERON is not set
# CONFIG_NRF_CC310_BL is not set
# CONFIG_NRF_CC310_PLATFORM is not set
# end of Crypto libraries for nRF5x SOCs.
# Nordic Security
# CONFIG_NORDIC_SECURITY_BACKEND is not set
# CONFIG_MBEDTLS_ENABLE_HEAP is not set
CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=1500
# end of Nordic Security
# end of Nordic nrfxlib
# Optional modules. Make sure they're installed, via the project manifest.
# CONFIG_CANOPENNODE is not set
# CONFIG_CIVETWEB is not set
CONFIG_HAS_CMSIS_CORE=y
CONFIG_HAS_CMSIS_CORE_M=y
# CONFIG_LIBMETAL is not set
# CONFIG_HAS_SEMTECH_LORAMAC is not set
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
CONFIG_MBEDTLS=y
CONFIG_MBEDTLS_BUILTIN=y
# CONFIG_MBEDTLS_LIBRARY is not set
# CONFIG_MBEDTLS_DEBUG is not set
# CONFIG_MBEDTLS_TEST is not set
CONFIG_APP_LINK_WITH_MBEDTLS=y
# CONFIG_HAS_MEC_HAL is not set
CONFIG_HAS_NORDIC_DRIVERS=y
# Nordic drivers
# CONFIG_NRF_802154_RADIO_DRIVER is not set
# end of Nordic drivers
CONFIG_HAS_NRFX=y
# nrfx drivers
# CONFIG_NRFX_CLOCK is not set
# CONFIG_NRFX_COMP is not set
# CONFIG_NRFX_EGU is not set
# CONFIG_NRFX_EGU0 is not set
# CONFIG_NRFX_EGU1 is not set
# CONFIG_NRFX_EGU2 is not set
# CONFIG_NRFX_EGU3 is not set
# CONFIG_NRFX_EGU4 is not set
# CONFIG_NRFX_EGU5 is not set
# CONFIG_NRFX_GPIOTE is not set
# CONFIG_NRFX_I2S is not set
# CONFIG_NRFX_LPCOMP is not set
# CONFIG_NRFX_NFCT is not set
CONFIG_NRFX_NVMC=y
# CONFIG_NRFX_PDM is not set
# CONFIG_NRFX_POWER is not set
# CONFIG_NRFX_PPI is not set
# CONFIG_NRFX_PWM is not set
# CONFIG_NRFX_PWM0 is not set
# CONFIG_NRFX_PWM1 is not set
# CONFIG_NRFX_PWM2 is not set
# CONFIG_NRFX_PWM3 is not set
# CONFIG_NRFX_QDEC is not set
CONFIG_NRFX_QSPI=y
# CONFIG_NRFX_RNG is not set
# CONFIG_NRFX_RTC is not set
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
# CONFIG_NRFX_RTC2 is not set
# CONFIG_NRFX_SAADC is not set
# CONFIG_NRFX_SPI is not set
# CONFIG_NRFX_SPI0 is not set
# CONFIG_NRFX_SPI1 is not set
# CONFIG_NRFX_SPI2 is not set
# CONFIG_NRFX_SPIM is not set
# CONFIG_NRFX_SPIM0 is not set
# CONFIG_NRFX_SPIM1 is not set
# CONFIG_NRFX_SPIM2 is not set
# CONFIG_NRFX_SPIM3 is not set
# CONFIG_NRFX_SPIS is not set
# CONFIG_NRFX_SPIS0 is not set
# CONFIG_NRFX_SPIS1 is not set
# CONFIG_NRFX_SPIS2 is not set
# CONFIG_NRFX_SYSTICK is not set
# CONFIG_NRFX_TEMP is not set
# CONFIG_NRFX_TIMER is not set
# CONFIG_NRFX_TIMER0 is not set
# CONFIG_NRFX_TIMER1 is not set
# CONFIG_NRFX_TIMER2 is not set
# CONFIG_NRFX_TIMER3 is not set
# CONFIG_NRFX_TIMER4 is not set
# CONFIG_NRFX_TWI is not set
# CONFIG_NRFX_TWI0 is not set
# CONFIG_NRFX_TWI1 is not set
# CONFIG_NRFX_TWIM is not set
# CONFIG_NRFX_TWIM0 is not set
# CONFIG_NRFX_TWIM1 is not set
# CONFIG_NRFX_TWIS is not set
# CONFIG_NRFX_TWIS0 is not set
# CONFIG_NRFX_TWIS1 is not set
# CONFIG_NRFX_UART is not set
# CONFIG_NRFX_UART0 is not set
# CONFIG_NRFX_UARTE is not set
# CONFIG_NRFX_UARTE0 is not set
# CONFIG_NRFX_UARTE1 is not set
# CONFIG_NRFX_USBD is not set
# CONFIG_NRFX_WDT is not set
# CONFIG_NRFX_WDT0 is not set
# CONFIG_NRFX_PRS is not set
# CONFIG_NRFX_PRS_BOX_0 is not set
# CONFIG_NRFX_PRS_BOX_1 is not set
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of nrfx drivers
# CONFIG_OPENAMP is not set
# CONFIG_MIPI_SYST_LIB is not set
CONFIG_TINYCBOR=y
# CONFIG_CBOR_ENCODER_NO_CHECK_USER is not set
CONFIG_CBOR_PARSER_MAX_RECURSIONS=1024
# CONFIG_CBOR_PARSER_NO_STRICT_CHECKS is not set
# CONFIG_CBOR_FLOATING_POINT is not set
# CONFIG_CBOR_HALF_FLOAT_TYPE is not set
CONFIG_CBOR_WITHOUT_OPEN_MEMSTREAM=y
# CONFIG_CBOR_PRETTY_PRINTING is not set
# CONFIG_TINYCRYPT is not set
# end of Modules
# CONFIG_SPI is not set
# CONFIG_TEST_RANDOM_GENERATOR is not set
CONFIG_NET_CONFIG_IEEE802154_DEV_NAME=""
# CONFIG_I2C is not set
# CONFIG_MODEM is not set
CONFIG_GPIO_NRF_P1=y
# CONFIG_UART_1_NRF_FLOW_CONTROL is not set
CONFIG_BOARD="pinnacle_100_dvk"
CONFIG_SOC="nRF52840_QIAA"
CONFIG_SOC_SERIES="nrf52"
CONFIG_NUM_IRQS=48
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
# CONFIG_WATCHDOG is not set
# CONFIG_UART_NS16550 is not set
CONFIG_GPIO=y
# CONFIG_SYS_POWER_MANAGEMENT is not set
CONFIG_HAS_SYS_POWER_STATE_DEEP_SLEEP_1=y
# CONFIG_DEVICE_POWER_MANAGEMENT is not set
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
# CONFIG_CORTEX_M_SYSTICK is not set
CONFIG_CLOCK_CONTROL=y
CONFIG_NRF_RTC_TIMER=y
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_BUILD_OUTPUT_HEX=y
# CONFIG_FPU is not set
CONFIG_TEXT_SECTION_OFFSET=0
CONFIG_FLASH_SIZE=1024
CONFIG_FLASH_BASE_ADDRESS=0x0
CONFIG_SRAM_SIZE=256
CONFIG_SRAM_BASE_ADDRESS=0x20000000
# CONFIG_GPIO_MCUX is not set
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
CONFIG_HEAP_MEM_POOL_SIZE=0
CONFIG_BOARD_PINNACLE_100_DVK=y
# Board Options
CONFIG_BOARD_ENABLE_DCDC=y
# end of Board Options
# CONFIG_SOC_SERIES_BEETLE is not set
# CONFIG_SOC_SERIES_MPS2 is not set
# CONFIG_SOC_SERIES_MUSCA is not set
# CONFIG_SOC_SERIES_MUSCA_B1 is not set
# CONFIG_SOC_SERIES_SAM3X is not set
# CONFIG_SOC_SERIES_SAM4E is not set
# CONFIG_SOC_SERIES_SAM4S is not set
# CONFIG_SOC_SERIES_SAME70 is not set
# CONFIG_SOC_SERIES_SAMV71 is not set
# CONFIG_SOC_SERIES_SAMD20 is not set
# CONFIG_SOC_SERIES_SAMD21 is not set
# CONFIG_SOC_SERIES_SAMD51 is not set
# CONFIG_SOC_SERIES_SAME51 is not set
# CONFIG_SOC_SERIES_SAME53 is not set
# CONFIG_SOC_SERIES_SAME54 is not set
# CONFIG_SOC_SERIES_SAMR21 is not set
# CONFIG_SOC_SERIES_VALKYRIE is not set
# CONFIG_SOC_SERIES_VIPER is not set
# CONFIG_SOC_SERIES_PSOC62 is not set
# CONFIG_SOC_SERIES_XMC_4XXX is not set
# CONFIG_SOC_SERIES_MEC1501X is not set
# CONFIG_SOC_SERIES_MEC1701X is not set
# CONFIG_SOC_SERIES_NRF51X is not set
CONFIG_SOC_SERIES_NRF52X=y
# CONFIG_SOC_SERIES_NRF53X is not set
# CONFIG_SOC_SERIES_NRF91X is not set
# CONFIG_SOC_SERIES_IMX_6X_M4 is not set
# CONFIG_SOC_SERIES_IMX7_M4 is not set
# CONFIG_SOC_SERIES_IMX_RT is not set
# CONFIG_SOC_SERIES_KINETIS_K2X is not set
# CONFIG_SOC_SERIES_KINETIS_K6X is not set
# CONFIG_SOC_SERIES_KINETIS_K8X is not set
# CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
# CONFIG_SOC_SERIES_KINETIS_KL2X is not set
# CONFIG_SOC_SERIES_KINETIS_KV5X is not set
# CONFIG_SOC_SERIES_KINETIS_KWX is not set
# CONFIG_SOC_SERIES_LPC54XXX is not set
# CONFIG_SOC_SERIES_LPC55XXX is not set
# CONFIG_SOC_QEMU_CORTEX_A53 is not set
# CONFIG_SOC_SERIES_EFM32GG11B is not set
# CONFIG_SOC_SERIES_EFM32HG is not set
# CONFIG_SOC_SERIES_EFM32JG12B is not set
# CONFIG_SOC_SERIES_EFM32PG12B is not set
# CONFIG_SOC_SERIES_EFM32WG is not set
# CONFIG_SOC_SERIES_EFR32BG13P is not set
# CONFIG_SOC_SERIES_EFR32FG1P is not set
# CONFIG_SOC_SERIES_EFR32MG12P is not set
# CONFIG_SOC_SERIES_STM32F0X is not set
# CONFIG_SOC_SERIES_STM32F1X is not set
# CONFIG_SOC_SERIES_STM32F2X is not set
# CONFIG_SOC_SERIES_STM32F3X is not set
# CONFIG_SOC_SERIES_STM32F4X is not set
# CONFIG_SOC_SERIES_STM32F7X is not set
# CONFIG_SOC_SERIES_STM32G0X is not set
# CONFIG_SOC_SERIES_STM32G4X is not set
# CONFIG_SOC_SERIES_STM32H7X is not set
# CONFIG_SOC_SERIES_STM32L0X is not set
# CONFIG_SOC_SERIES_STM32L1X is not set
# CONFIG_SOC_SERIES_STM32L4X is not set
# CONFIG_SOC_SERIES_STM32L5X is not set
# CONFIG_SOC_SERIES_STM32MP1X is not set
# CONFIG_SOC_SERIES_STM32WBX is not set
# CONFIG_SOC_TI_LM3S6965 is not set
# CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
# CONFIG_SOC_SERIES_CC32XX is not set
# CONFIG_SOC_SERIES_MSP432P4XX is not set
# CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
# Hardware Configuration
CONFIG_CPU_HAS_ARM_MPU=y
CONFIG_SOC_FAMILY="nordic_nrf"
CONFIG_SOC_FAMILY_NRF=y
CONFIG_HAS_HW_NRF_ACL=y
CONFIG_HAS_HW_NRF_CC310=y
CONFIG_HAS_HW_NRF_CCM=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_COMP=y
CONFIG_HAS_HW_NRF_ECB=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_EGU1=y
CONFIG_HAS_HW_NRF_EGU2=y
CONFIG_HAS_HW_NRF_EGU3=y
CONFIG_HAS_HW_NRF_EGU4=y
CONFIG_HAS_HW_NRF_EGU5=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIO1=y
CONFIG_HAS_HW_NRF_GPIOTE=y
CONFIG_HAS_HW_NRF_I2S=y
CONFIG_HAS_HW_NRF_LPCOMP=y
CONFIG_HAS_HW_NRF_MWU=y
CONFIG_HAS_HW_NRF_NFCT=y
CONFIG_HAS_HW_NRF_NVMC_PE=y
CONFIG_HAS_HW_NRF_PDM=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_PPI=y
CONFIG_HAS_HW_NRF_PWM0=y
CONFIG_HAS_HW_NRF_PWM1=y
CONFIG_HAS_HW_NRF_PWM2=y
CONFIG_HAS_HW_NRF_PWM3=y
CONFIG_HAS_HW_NRF_QDEC=y
CONFIG_HAS_HW_NRF_QSPI=y
CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
CONFIG_HAS_HW_NRF_RNG=y
CONFIG_HAS_HW_NRF_RTC0=y
CONFIG_HAS_HW_NRF_RTC1=y
CONFIG_HAS_HW_NRF_RTC2=y
CONFIG_HAS_HW_NRF_SAADC=y
CONFIG_HAS_HW_NRF_SPI0=y
CONFIG_HAS_HW_NRF_SPI1=y
CONFIG_HAS_HW_NRF_SPI2=y
CONFIG_HAS_HW_NRF_SPIM0=y
CONFIG_HAS_HW_NRF_SPIM1=y
CONFIG_HAS_HW_NRF_SPIM2=y
CONFIG_HAS_HW_NRF_SPIM3=y
CONFIG_HAS_HW_NRF_SPIS0=y
CONFIG_HAS_HW_NRF_SPIS1=y
CONFIG_HAS_HW_NRF_SPIS2=y
CONFIG_HAS_HW_NRF_SWI0=y
CONFIG_HAS_HW_NRF_SWI1=y
CONFIG_HAS_HW_NRF_SWI2=y
CONFIG_HAS_HW_NRF_SWI3=y
CONFIG_HAS_HW_NRF_SWI4=y
CONFIG_HAS_HW_NRF_SWI5=y
CONFIG_HAS_HW_NRF_TEMP=y
CONFIG_HAS_HW_NRF_TIMER0=y
CONFIG_HAS_HW_NRF_TIMER1=y
CONFIG_HAS_HW_NRF_TIMER2=y
CONFIG_HAS_HW_NRF_TIMER3=y
CONFIG_HAS_HW_NRF_TIMER4=y
CONFIG_HAS_HW_NRF_TWI0=y
CONFIG_HAS_HW_NRF_TWI1=y
CONFIG_HAS_HW_NRF_TWIM0=y
CONFIG_HAS_HW_NRF_TWIM1=y
CONFIG_HAS_HW_NRF_TWIS0=y
CONFIG_HAS_HW_NRF_TWIS1=y
CONFIG_HAS_HW_NRF_UART0=y
CONFIG_HAS_HW_NRF_UARTE0=y
CONFIG_HAS_HW_NRF_UARTE1=y
CONFIG_HAS_HW_NRF_USBD=y
CONFIG_HAS_HW_NRF_WDT=y
CONFIG_SOC_NRF52840=y
# CONFIG_SOC_NRF52810_QFAA is not set
# CONFIG_SOC_NRF52811_QFAA is not set
# CONFIG_SOC_NRF52820_QDAA is not set
# CONFIG_SOC_NRF52832_CIAA is not set
# CONFIG_SOC_NRF52832_QFAA is not set
# CONFIG_SOC_NRF52832_QFAB is not set
# CONFIG_SOC_NRF52833_QIAA is not set
CONFIG_SOC_NRF52840_QIAA=y
CONFIG_SOC_DCDC_NRF52X=y
# CONFIG_NFCT_PINS_AS_GPIOS is not set
CONFIG_GPIO_AS_PINRESET=y
CONFIG_NRF_ENABLE_ICACHE=y
# CONFIG_SOC_LOG_LEVEL_OFF is not set
# CONFIG_SOC_LOG_LEVEL_ERR is not set
# CONFIG_SOC_LOG_LEVEL_WRN is not set
CONFIG_SOC_LOG_LEVEL_INF=y
# CONFIG_SOC_LOG_LEVEL_DBG is not set
CONFIG_SOC_LOG_LEVEL=3
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
CONFIG_SOC_COMPATIBLE_NRF52X=y
# ARM Options
CONFIG_ARCH="arm"
CONFIG_CPU_CORTEX=y
CONFIG_CPU_CORTEX_M=y
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
CONFIG_PLATFORM_SPECIFIC_INIT=y
CONFIG_FAULT_DUMP=2
CONFIG_CPU_CORTEX_M4=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV7_M_ARMV8_M_FP=y
CONFIG_XIP=y
# ARM Cortex-M0/M0+/M3/M4/M7/M23/M33 options
CONFIG_GEN_ISR_TABLES=y
# CONFIG_ZERO_LATENCY_IRQS is not set
# end of ARM Cortex-M0/M0+/M3/M4/M7/M23/M33 options
CONFIG_ARM_MPU=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
# CONFIG_MPU_STACK_GUARD is not set
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
CONFIG_GEN_IRQ_VECTOR_TABLE=y
CONFIG_MAIN_STACK_SIZE=10240
CONFIG_IDLE_STACK_SIZE=320
CONFIG_ISR_STACK_SIZE=2048
CONFIG_TEST_EXTRA_STACKSIZE=0
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_ARCH_LOG_LEVEL_OFF is not set
# CONFIG_ARCH_LOG_LEVEL_ERR is not set
# CONFIG_ARCH_LOG_LEVEL_WRN is not set
CONFIG_ARCH_LOG_LEVEL_INF=y
# CONFIG_ARCH_LOG_LEVEL_DBG is not set
CONFIG_ARCH_LOG_LEVEL=3
# CONFIG_MPU_LOG_LEVEL_OFF is not set
# CONFIG_MPU_LOG_LEVEL_ERR is not set
# CONFIG_MPU_LOG_LEVEL_WRN is not set
CONFIG_MPU_LOG_LEVEL_INF=y
# CONFIG_MPU_LOG_LEVEL_DBG is not set
CONFIG_MPU_LOG_LEVEL=3
# CONFIG_HW_STACK_PROTECTION is not set
# CONFIG_USERSPACE is not set
CONFIG_PRIVILEGED_STACK_SIZE=1024
CONFIG_KOBJECT_TEXT_AREA=256
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# Interrupt Configuration
# CONFIG_DYNAMIC_INTERRUPTS is not set
CONFIG_GEN_SW_ISR_TABLE=y
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=0
CONFIG_GEN_IRQ_START_VECTOR=0
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_CPU_HAS_FPU=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MEMORY_PROTECTION=y
CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y
# Floating Point Options
# end of Floating Point Options
# General Kernel Options
# CONFIG_KERNEL_LOG_LEVEL_OFF is not set
# CONFIG_KERNEL_LOG_LEVEL_ERR is not set
# CONFIG_KERNEL_LOG_LEVEL_WRN is not set
CONFIG_KERNEL_LOG_LEVEL_INF=y
# CONFIG_KERNEL_LOG_LEVEL_DBG is not set
CONFIG_KERNEL_LOG_LEVEL=3
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=0
CONFIG_NUM_METAIRQ_PRIORITIES=0
# CONFIG_SCHED_DEADLINE is not set
# CONFIG_SCHED_CPU_MASK is not set
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
CONFIG_ERRNO=y
CONFIG_SCHED_DUMB=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_DUMB=y
# Kernel Debugging and Metrics
# CONFIG_INIT_STACKS is not set
# CONFIG_KERNEL_DEBUG is not set
CONFIG_BOOT_BANNER=y
CONFIG_BOOT_DELAY=0
# CONFIG_EXECUTION_BENCHMARKING is not set
# CONFIG_THREAD_MONITOR is not set
# CONFIG_THREAD_NAME is not set
# end of Kernel Debugging and Metrics
# Work Queue Options
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
# end of Work Queue Options
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_SIZE=0
CONFIG_TIMESLICE_PRIORITY=0
# CONFIG_POLL is not set
# end of Timer API Options
# Other Kernel Object Options
CONFIG_NUM_MBOX_ASYNC_MSGS=10
CONFIG_NUM_PIPE_ASYNC_MSGS=10
CONFIG_MEM_POOL_HEAP_BACKEND=y
# end of Other Kernel Object Options
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
CONFIG_SWAP_NONATOMIC=y
CONFIG_SYS_CLOCK_EXISTS=y
# CONFIG_LEGACY_TIMEOUT_API is not set
CONFIG_TIMEOUT_64BIT=y
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Security Options
# end of Security Options
# SMP Options
CONFIG_MP_NUM_CPUS=1
# end of SMP Options
CONFIG_TICKLESS_IDLE=y
CONFIG_TICKLESS_IDLE_THRESH=3
CONFIG_TICKLESS_KERNEL=y
# end of General Kernel Options
CONFIG_HAS_DTS=y
CONFIG_HAS_DTS_GPIO=y
# Device Drivers
# CONFIG_IEEE802154 is not set
CONFIG_CONSOLE=y
CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
CONFIG_CONSOLE_HAS_DRIVER=y
# CONFIG_UART_CONSOLE is not set
# CONFIG_USB_UART_CONSOLE is not set
# CONFIG_RAM_CONSOLE is not set
CONFIG_RTT_CONSOLE=y
CONFIG_RTT_TX_RETRY_CNT=2
CONFIG_RTT_TX_RETRY_DELAY_MS=2
# CONFIG_RTT_TX_RETRY_IN_INTERRUPT is not set
# CONFIG_IPM_CONSOLE_SENDER is not set
# CONFIG_IPM_CONSOLE_RECEIVER is not set
# CONFIG_UART_PIPE is not set
# CONFIG_UART_MCUMGR is not set
# CONFIG_SEMIHOST_CONSOLE is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
CONFIG_UART_CONSOLE_LOG_LEVEL_INF=y
# CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
CONFIG_UART_CONSOLE_LOG_LEVEL=3
# CONFIG_GSM_MUX is not set
CONFIG_UART_MUX_RX_STACK_SIZE=512
CONFIG_UART_MUX_RX_PRIORITY=7
# CONFIG_UART_MUX_LOG_LEVEL_OFF is not set
# CONFIG_UART_MUX_LOG_LEVEL_ERR is not set
# CONFIG_UART_MUX_LOG_LEVEL_WRN is not set
CONFIG_UART_MUX_LOG_LEVEL_INF=y
# CONFIG_UART_MUX_LOG_LEVEL_DBG is not set
CONFIG_UART_MUX_LOG_LEVEL=3
CONFIG_HAS_SEGGER_RTT=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
# CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
# CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
CONFIG_SEGGER_RTT_MODE=0
# CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
# CONFIG_NET_LOOPBACK is not set
CONFIG_SERIAL=y
# Capabilities
CONFIG_SERIAL_HAS_DRIVER=y
CONFIG_SERIAL_SUPPORT_ASYNC=y
CONFIG_SERIAL_SUPPORT_INTERRUPT=y
# CONFIG_UART_ASYNC_API is not set
# CONFIG_UART_LINE_CTRL is not set
# CONFIG_UART_DRV_CMD is not set
# Serial Drivers
# CONFIG_UART_NSIM is not set
CONFIG_UART_NRFX=y
CONFIG_UART_0_NRF_UART=y
CONFIG_UART_0_INTERRUPT_DRIVEN=y
# CONFIG_UART_0_NRF_PARITY_BIT is not set
# CONFIG_UART_0_NRF_FLOW_CONTROL is not set
CONFIG_UART_1_NRF_UARTE=y
CONFIG_UART_1_INTERRUPT_DRIVEN=y
# CONFIG_UART_1_NRF_PARITY_BIT is not set
CONFIG_UART_1_NRF_TX_BUFFER_SIZE=32
CONFIG_NRF_UART_PERIPHERAL=y
CONFIG_NRF_UARTE_PERIPHERAL=y
# CONFIG_UART_ALTERA_JTAG is not set
# CONFIG_UART_PL011 is not set
# CONFIG_UART_RTT is not set
# Interrupt Controllers
# CONFIG_SWERV_PIC is not set
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
# end of Interrupt Controllers
# Timer Drivers
CONFIG_SYSTEM_CLOCK_DISABLE=y
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
# end of Timer Drivers
# CONFIG_ENTROPY_GENERATOR is not set
# CONFIG_GPIO_LOG_LEVEL_OFF is not set
# CONFIG_GPIO_LOG_LEVEL_ERR is not set
# CONFIG_GPIO_LOG_LEVEL_WRN is not set
CONFIG_GPIO_LOG_LEVEL_INF=y
# CONFIG_GPIO_LOG_LEVEL_DBG is not set
CONFIG_GPIO_LOG_LEVEL=3
# CONFIG_GPIO_SHELL is not set
# CONFIG_GPIO_DW is not set
CONFIG_GPIO_NRFX=y
CONFIG_GPIO_NRF_INIT_PRIORITY=40
CONFIG_GPIO_NRF_P0=y
# CONFIG_GPIO_INTEL_APL is not set
# CONFIG_SHARED_IRQ is not set
# CONFIG_I2S is not set
# CONFIG_PWM is not set
# CONFIG_PINMUX is not set
# CONFIG_ADC is not set
# CONFIG_DAC is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF=y
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
CONFIG_CLOCK_CONTROL_NRF=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM=y
# CONFIG_PTP_CLOCK is not set
# CONFIG_IPM is not set
CONFIG_FLASH_HAS_DRIVER_ENABLED=y
CONFIG_FLASH_HAS_PAGE_LAYOUT=y
CONFIG_FLASH=y
# CONFIG_FLASH_LOG_LEVEL_OFF is not set
# CONFIG_FLASH_LOG_LEVEL_ERR is not set
# CONFIG_FLASH_LOG_LEVEL_WRN is not set
CONFIG_FLASH_LOG_LEVEL_INF=y
# CONFIG_FLASH_LOG_LEVEL_DBG is not set
CONFIG_FLASH_LOG_LEVEL=3
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_SOC_FLASH_NRF=y
# CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
# CONFIG_SOC_FLASH_NRF_UICR is not set
# CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
# CONFIG_FLASH_SIMULATOR is not set
CONFIG_NORDIC_QSPI_NOR=y
CONFIG_NORDIC_QSPI_NOR_QE_BIT=6
CONFIG_NORDIC_QSPI_NOR_INIT_PRIORITY=80
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_NORDIC_QSPI_NOR_FLASH_ALLOW_STACK_USAGE_FOR_DATA_IN_FLASH=y
# CONFIG_COUNTER is not set
# CONFIG_DMA is not set
# CONFIG_USB is not set
# CONFIG_CRYPTO is not set
# CONFIG_DISPLAY is not set
# CONFIG_LED_STRIP is not set
# CONFIG_WIFI is not set
# CONFIG_LED is not set
# CONFIG_CAN is not set
# CONFIG_AUDIO is not set
# CONFIG_NEURAL_NET_ACCEL is not set
# CONFIG_HWINFO is not set
# CONFIG_ESPI is not set
# CONFIG_PS2 is not set
# CONFIG_KSCAN is not set
# CONFIG_VIDEO is not set
# CONFIG_EEPROM is not set
# CONFIG_PECI is not set
# CONFIG_PECI_INTERRUPT_DRIVEN is not set
# C Library
CONFIG_MINIMAL_LIBC=y
# CONFIG_NEWLIB_LIBC is not set
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_MINIMAL_LIBC_MALLOC=y
CONFIG_MINIMAL_LIBC_MALLOC_ARENA_SIZE=0
CONFIG_MINIMAL_LIBC_CALLOC=y
CONFIG_MINIMAL_LIBC_REALLOCARRAY=y
# CONFIG_MINIMAL_LIBC_LL_PRINTF is not set
CONFIG_STDOUT_CONSOLE=y
# end of C Library
# Additional libraries
# CONFIG_FNMATCH is not set
# CONFIG_LVGL is not set
# OS Support Library
# CONFIG_JSON_LIBRARY is not set
# CONFIG_RING_BUFFER is not set
CONFIG_BASE64=y
# CONFIG_SYS_HEAP_VALIDATE is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# end of OS Support Library
CONFIG_POSIX_MAX_FDS=4
# CONFIG_POSIX_API is not set
# CONFIG_PTHREAD_IPC is not set
# CONFIG_POSIX_CLOCK is not set
CONFIG_MAX_TIMER_COUNT=5
# CONFIG_POSIX_MQUEUE is not set
# CONFIG_EVENTFD is not set
# CONFIG_UPDATEHUB is not set
# CONFIG_UPDATEHUB_LOG_LEVEL_OFF is not set
# CONFIG_UPDATEHUB_LOG_LEVEL_ERR is not set
# CONFIG_UPDATEHUB_LOG_LEVEL_WRN is not set
CONFIG_UPDATEHUB_LOG_LEVEL_INF=y
# CONFIG_UPDATEHUB_LOG_LEVEL_DBG is not set
CONFIG_UPDATEHUB_LOG_LEVEL=3
# CONFIG_OPENAMP_RSC_TABLE is not set
# end of Additional libraries
# CONFIG_BT is not set
# CONFIG_CONSOLE_SUBSYS is not set
# CONFIG_CPLUSPLUS is not set
# System Monitoring Options
# CONFIG_BOOT_TIME_MEASUREMENT is not set
# CONFIG_STATS is not set
# end of System Monitoring Options
# Debugging Options
CONFIG_DEBUG=y
# CONFIG_STACK_USAGE is not set
# CONFIG_STACK_SENTINEL is not set
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
# CONFIG_ASSERT is not set
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
# CONFIG_ASSERT_NO_COND_INFO is not set
# CONFIG_ASSERT_NO_MSG_INFO is not set
# CONFIG_OBJECT_TRACING is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_INFO is not set
# CONFIG_OPENOCD_SUPPORT is not set
# end of Debugging Options
# CONFIG_THREAD_ANALYZER is not set
# CONFIG_DISK_ACCESS is not set
# File Systems
# CONFIG_FILE_SYSTEM is not set
# CONFIG_FCB is not set
# CONFIG_NVS is not set
# end of File Systems
CONFIG_LOG=y
# CONFIG_LOG_MINIMAL is not set
# CONFIG_LOG_RUNTIME_FILTERING is not set
CONFIG_LOG_OVERRIDE_LEVEL=0
CONFIG_LOG_MAX_LEVEL=4
# CONFIG_LOG_MIPI_SYST_ENABLE is not set
# Prepend log message with function name
# CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
# end of Prepend log message with function name
CONFIG_LOG_PRINTK=y
CONFIG_LOG_PRINTK_MAX_STRING_LENGTH=128
# CONFIG_LOG_ENABLE_FANCY_OUTPUT_FORMATTING is not set
CONFIG_LOG_MODE_OVERFLOW=y
# CONFIG_LOG_MODE_NO_OVERFLOW is not set
# CONFIG_LOG_BLOCK_IN_THREAD is not set
CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
CONFIG_LOG_BUFFER_SIZE=1024
CONFIG_LOG_DETECT_MISSED_STRDUP=y
CONFIG_LOG_STRDUP_MAX_STRING=32
CONFIG_LOG_STRDUP_BUF_COUNT=4
# CONFIG_LOG_STRDUP_POOL_PROFILING is not set
CONFIG_LOG_DOMAIN_ID=0
# CONFIG_LOG_FRONTEND is not set
CONFIG_LOG_BACKEND_RTT=y
# CONFIG_LOG_BACKEND_RTT_MODE_DROP is not set
CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=y
CONFIG_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE=16
CONFIG_LOG_BACKEND_RTT_RETRY_CNT=4
CONFIG_LOG_BACKEND_RTT_RETRY_DELAY_MS=5
CONFIG_LOG_BACKEND_RTT_BUFFER=0
CONFIG_LOG_BACKEND_RTT_FORCE_PRINTK=y
# CONFIG_LOG_BACKEND_RB is not set
CONFIG_LOG_BACKEND_SHOW_COLOR=y
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
# Management
# CONFIG_MCUMGR_SMP_BT is not set
# CONFIG_MCUMGR_SMP_SHELL is not set
# CONFIG_MCUMGR_SMP_UART is not set
# CONFIG_MCUMGR is not set
# CONFIG_MCUMGR_SMP_UDP is not set
# end of Management
# Networking
# CONFIG_NET_BUF is not set
# CONFIG_NETWORKING is not set
# end of Networking
# CONFIG_SHELL is not set
# CONFIG_IMG_MANAGER is not set
# Random subsystem
# end of Random subsystem
# Storage
CONFIG_FLASH_MAP=y
# CONFIG_FLASH_MAP_CUSTOM is not set
# CONFIG_STREAM_FLASH is not set
# end of Storage
# CONFIG_SETTINGS is not set
# Testing
# CONFIG_ZTEST is not set
# CONFIG_ZTEST_MOCKING is not set
# CONFIG_TEST is not set
# CONFIG_TEST_SHELL is not set
# CONFIG_TEST_USERSPACE is not set
CONFIG_TEST_ARM_CORTEX_M=y
# end of Testing
# CONFIG_TRACING is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# CONFIG_JWT is not set
# Controller Area Network (CAN) bus subsystem
# CONFIG_ISOTP is not set
# end of Controller Area Network (CAN) bus subsystem
CONFIG_TOOLCHAIN_GNUARMEMB=y
# Build and Link Features
# Linker Options
# CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
CONFIG_LINKER_ORPHAN_SECTION_WARN=y
# CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
# CONFIG_CODE_DATA_RELOCATION is not set
CONFIG_HAS_FLASH_LOAD_OFFSET=y
CONFIG_USE_DT_CODE_PARTITION=y
CONFIG_FLASH_LOAD_OFFSET=0x0
CONFIG_FLASH_LOAD_SIZE=0x18000
# CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
# CONFIG_CUSTOM_RODATA_LD is not set
# CONFIG_CUSTOM_RWDATA_LD is not set
# CONFIG_CUSTOM_SECTIONS_LD is not set
CONFIG_KERNEL_ENTRY="__start"
CONFIG_LINKER_SORT_BY_ALIGNMENT=y
# end of Linker Options
# Compiler Options
# CONFIG_NATIVE_APPLICATION is not set
CONFIG_SIZE_OPTIMIZATIONS=y
# CONFIG_SPEED_OPTIMIZATIONS is not set
# CONFIG_DEBUG_OPTIMIZATIONS is not set
# CONFIG_NO_OPTIMIZATIONS is not set
CONFIG_COMPILER_OPT=""
# end of Compiler Options
# CONFIG_ASSERT_ON_ERRORS is not set
# CONFIG_NO_RUNTIME_CHECKS is not set
CONFIG_RUNTIME_ERROR_CHECKS=y
# Build Options
CONFIG_KERNEL_BIN_NAME="zephyr"
CONFIG_OUTPUT_STAT=y
CONFIG_OUTPUT_DISASSEMBLY=y
# CONFIG_OUTPUT_DISASSEMBLE_ALL is not set
CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
CONFIG_BUILD_OUTPUT_BIN=y
# CONFIG_BUILD_OUTPUT_EXE is not set
# CONFIG_BUILD_OUTPUT_S19 is not set
# CONFIG_BUILD_NO_GAP_FILL is not set
# CONFIG_BUILD_OUTPUT_STRIPPED is not set
# CONFIG_APPLICATION_DEFINED_SYSCALL is not set
# CONFIG_MAKEFILE_EXPORTS is not set
# CONFIG_LEGACY_DEVICETREE_MACROS is not set
# end of Build Options
# end of Build and Link Features
# Boot Options
# CONFIG_IS_BOOTLOADER is not set
# CONFIG_BOOTLOADER_MCUBOOT is not set
CONFIG_REBOOT=y
# CONFIG_MISRA_SANE is not set
# end of Boot Options
# Compatibility
CONFIG_COMPAT_INCLUDES=y
# end of Compatibility
