FDS garbage collection not clearing dirty records
Hi below is the function i am using to run garbage collection after deleting the data but the result i am getting was the same as before garbage collection.
I mean DIRTY_RECORDS_BEFORE_GC = DIRTY_RECORDS_AFTER_GC.
static void delete_all() {
  NRF_LOG_INFO("deleting all records...");
  ret_code_t rc;
  bool next_record = true;
  while (next_record) {
    fds_record_desc_t record_desc = {0};
    fds_find_token_t ftok = {0};
    if (fds_record_iterate(&record_desc, &ftok) == FDS_SUCCESS) {
      ret_code_t ret = fds_record_delete(&record_desc);
      while (!fds_delete_complete)
      fds_delete_complete = false;
      //NRF_LOG_INFO("Iterate suc..");
      next_record = true;
    } else {
      next_record = false;
  fds_stat_t stat = {0};
  rc = fds_stat(&stat);
  APP_ERROR_CHECK(rc);
  uint16_t no_of_records = stat.valid_records;
  NRF_LOG_INFO("delete all:: %d", no_of_records);
  NRF_LOG_INFO("dirty records %d", stat.dirty_records);
  fds_gc();
  while (!fds_gc_complete);
  fds_gc_complete = false;
    NRF_LOG_INFO("dirty records after gc %d", stat.dirty_records);
Do i need to reinitialize the fds again to get proper dirty records value?
  • Yes exactly the same whatever you mentioned i was doing.
  • Are you able to upload your project so I can try to debug it here?
  • This is the project I am doing so its difficult to disclose in public. If any other source is there to upload my project privately then it is fine for me or else i will re-produce the issue with some code snippet and post it here within some couple of minutes.
     * Copyright (c) 2017 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #include "nordic_common.h"
    #ifdef SOFTDEVICE_PRESENT
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #else
    #include "nrf_drv_clock.h"
    #include "fds.h"
    #include "app_timer.h"
    #include "app_error.h"
    #include "nrf_cli.h"
    #include "fds_example.h"
    #define NRF_LOG_MODULE_NAME app
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_delay.h"
    /* A tag identifying the SoftDevice BLE configuration. */
    #define APP_BLE_CONN_CFG_TAG    1
    bool volatile fds_delete_complete = false;
    static void delete_data(uint16_t file_id, uint16_t record_key);
    /* Array to map FDS return values to strings. */
    char const * fds_err_str[] =
        "FDS_SUCCESS",
        "FDS_ERR_OPERATION_TIMEOUT",
        "FDS_ERR_NOT_INITIALIZED",
        "FDS_ERR_UNALIGNED_ADDR",
        "FDS_ERR_INVALID_ARG",
        "FDS_ERR_NULL_ARG",
        "FDS_ERR_NO_OPEN_RECORDS",
        "FDS_ERR_NO_SPACE_IN_FLASH",
        "FDS_ERR_NO_SPACE_IN_QUEUES",
        "FDS_ERR_RECORD_TOO_LARGE",
        "FDS_ERR_NOT_FOUND",
        "FDS_ERR_NO_PAGES",
        "FDS_ERR_USER_LIMIT_REACHED",
        "FDS_ERR_CRC_CHECK_FAILED",
        "FDS_ERR_BUSY",
        "FDS_ERR_INTERNAL",
    /* Array to map FDS events to strings. */
    static char const * fds_evt_str[] =
        "FDS_EVT_INIT",
        "FDS_EVT_WRITE",
        "FDS_EVT_UPDATE",
        "FDS_EVT_DEL_RECORD",
        "FDS_EVT_DEL_FILE",
        "FDS_EVT_GC",
    /* Dummy configuration data. */
    static configuration_t m_dummy_cfg =
        .config1_on  = false,
        .config2_on  = true,
        .boot_count  = 0x0,
        .device_name = "dummy",
    /* A record containing dummy configuration data. */
    static fds_record_t const m_dummy_record =
        .file_id           = CONFIG_FILE,
        .key               = CONFIG_REC_KEY,
        .data.p_data       = &m_dummy_cfg,
        /* The length of a record is always expressed in 4-byte units (words). */
        .data.length_words = (sizeof(m_dummy_cfg) + 3) / sizeof(uint32_t),
    /* Keep track of the progress of a delete_all operation. */
    static struct
        bool delete_next;   //!< Delete next record.
        bool pending;       //!< Waiting for an fds FDS_EVT_DEL_RECORD event, to delete the next record.
    } m_delete_all;
    /* Flag to check fds initialization. */
    static bool volatile m_fds_initialized;
    static void fds_evt_handler(fds_evt_t const * p_evt)
        NRF_LOG_GREEN("Event: %s received (%s)",
                      fds_evt_str[p_evt->id],
                      fds_err_str[p_evt->result]);
        switch (p_evt->id)
            case FDS_EVT_INIT:
                if (p_evt->result == FDS_SUCCESS)
                    m_fds_initialized = true;
            case FDS_EVT_WRITE:
                    NRF_LOG_INFO("Record ID:\t0x%04x",  p_evt->write.record_id);
                    NRF_LOG_INFO("File ID:\t0x%04x",    p_evt->write.file_id);
                    NRF_LOG_INFO("Record key:\t0x%04x", p_evt->write.record_key);
            } break;
            case FDS_EVT_DEL_RECORD:
                    fds_delete_complete = true;
                    NRF_LOG_INFO("Record ID:\t0x%04x",  p_evt->del.record_id);
                    NRF_LOG_INFO("File ID:\t0x%04x",    p_evt->del.file_id);
                    NRF_LOG_INFO("Record key:\t0x%04x", p_evt->del.record_key);
                m_delete_all.pending = false;
            } break;
    /**@brief   Begin deleting all records, one by one. */
    void delete_all_begin(void)
        m_delete_all.delete_next = true;
    /**@brief   Process a delete all command.
     * Delete records, one by one, until no records are left.
    void delete_all_process(void)
        if (   m_delete_all.delete_next
            & !m_delete_all.pending)
            NRF_LOG_INFO("Deleting next record.");
            m_delete_all.delete_next = record_delete_next();
            if (!m_delete_all.delete_next)
                NRF_LOG_CYAN("No records left to delete.");
    /**@brief   Function for initializing the SoftDevice and enabling the BLE stack. */
        ret_code_t rc;
        uint32_t   ram_start;
        /* Enable the SoftDevice. */
        rc = nrf_sdh_enable_request();
        rc = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start);
        rc = nrf_sdh_ble_enable(&ram_start);
    #else
    static void clock_init(void)
        /* Initialize the clock. */
        ret_code_t rc = nrf_drv_clock_init();
        /* Wait for the clock to be ready. */
        while (!nrf_clock_lf_is_running()) {;}
    /**@brief   Initialize the timer. */
    static void timer_init(void)
    /**@brief   Initialize logging. */
    static void log_init(void)
        ret_code_t rc = NRF_LOG_INIT(NULL);
    /**@brief   Sleep until an event is received. */
    static void power_manage(void)
        (void) sd_app_evt_wait();
    #else
        __WFE();
    /**@brief   Wait for fds to initialize. */
    static void wait_for_fds_ready(void)
        while (!m_fds_initialized)
            power_manage();
    #define FILE_ID         0x0001  /* The ID of the file to write the records into. */
    #define RECORD_KEY_1    0x1111  /* A key for the first record. */
    #define RECORD_KEY_2    0x2222  /* A key for the second record. */
    static uint32_t   const m_deadbeef = 0xDEADBEEF;
    static char       const m_hello[]  = "Hello, world 2!";
    static void write_data();
    //#define FILE_ID     0x1111
    //#define RECORD_KEY  0x2222
    static void read_data();
        ret_code_t rc;
        ble_stack_init();
    #else
        clock_init();
        timer_init();
        log_init();
        cli_init();
        NRF_LOG_INFO("FDS example started.")
        /* Register first to receive an event when initialization is complete. */
        (void) fds_register(fds_evt_handler);
        NRF_LOG_INFO("Initializing fds...");
        rc = fds_init();
        /* Wait for fds to initialize. */
        wait_for_fds_ready();
        NRF_LOG_INFO("Available commands:");
        NRF_LOG_INFO("- print all\t\tprint records");
        NRF_LOG_INFO("- print config\tprint configuration");
        NRF_LOG_INFO("- update\t\tupdate configuration");
        NRF_LOG_INFO("- stat\t\tshow statistics");
        NRF_LOG_INFO("- write\t\twrite a new record");
        NRF_LOG_INFO("- delete\t\tdelete a record");
        NRF_LOG_INFO("- delete_all\tdelete all records");
        NRF_LOG_INFO("- gc\t\trun garbage collection");
        NRF_LOG_INFO("Reading flash usage statistics...");
        NRF_LOG_INFO("Found %d valid records.", stat.valid_records);
        NRF_LOG_INFO("Found %d dirty records (ready to be garbage collected).", stat.dirty_records);
    //    fds_record_desc_t desc = {0};
    //    fds_find_token_t  tok  = {0};
    //    rc = fds_record_find(CONFIG_FILE, CONFIG_REC_KEY, &desc, &tok);
    //    if (rc == FDS_SUCCESS)
    //        /* A config file is in flash. Let's update it. */
    //        fds_flash_record_t config = {0};
    //        /* Open the record and read its contents. */
    //        rc = fds_record_open(&desc, &config);
    //        APP_ERROR_CHECK(rc);
    //        /* Copy the configuration from flash into m_dummy_cfg. */
    //        memcpy(&m_dummy_cfg, config.p_data, sizeof(configuration_t));
    //        NRF_LOG_INFO("Config file found, updating boot count to %d.", m_dummy_cfg.boot_count);
    //        /* Update boot count. */
    //        m_dummy_cfg.boot_count++;
    //        /* Close the record when done reading. */
    //        rc = fds_record_close(&desc);
    //        /* Write the updated record to flash. */
    //        rc = fds_record_update(&desc, &m_dummy_record);
    //    else
    //        /* System config not found; write a new one. */
    //        NRF_LOG_INFO("Writing config file...");
    //        rc = fds_record_write(&desc, &m_dummy_record);
    cli_start();
    uint32_t record_key = 0x0001;
    uint32_t val  = 1000;
    while(record_key < 0x0A)
      write_data(FILE_ID,record_key,val);
      record_key++;
      val++;
    while(record_key < 0x0A){
          read_data(FILE_ID,record_key);
          record_key++;
      delete_data(FILE_ID,record_key);
      record_key++;
        /* Enter main loop. */
        for (;;)
            if (!NRF_LOG_PROCESS())
                power_manage();
            cli_process();
            delete_all_process();
    static void write_data(uint32_t file_id,uint32_t record_key,uint32_t data)
    ret_code_t rc;
    fds_record_t        record;
    // Set up record.
    record.file_id           = file_id;
    record.key               = record_key;
    record.data.p_data       = &data;
    /* The following calculation takes into account any eventual remainder of the division. */
    record.data.length_words = 1/*(sizeof(data) + 3) / 4*/;
    rc = fds_record_write(&record_desc, &record);
        NRF_LOG_INFO("data success %d",record_key);
        while (!NRF_LOG_PROCESS());
        cli_process();
        // Handle error.
    else{
    NRF_LOG_INFO("error writing");
    static void read_data(uint32_t file_id,uint32_t record_key)
    ret_code_t rc;
    fds_flash_record_t  flash_record;
      /* It is required to zero the token before first use. */
    memset(&ftok, 0x00, sizeof(fds_find_token_t));
    /* Loop until all records with the given key and file ID have been found. */
    if (fds_record_find(file_id, record_key, &record_desc, &ftok) == FDS_SUCCESS)
         //NRF_LOG_INFO("record_found");
        if (fds_record_open(&record_desc, &flash_record) != FDS_SUCCESS)
            NRF_LOG_INFO("opening_error");
            /* Handle error. */
    //    char data[16];
    //    memcpy(&data,flash_record.p_data,sizeof(data));
    //    for(int i=0;i<sizeof(data);i++)
    //      NRF_LOG_INFO("%c",data[i]);
        uint32_t recorded_data = 0;
        memcpy(&recorded_data,flash_record.p_data,sizeof(recorded_data));
        NRF_LOG_INFO("recorded_data : %d",recorded_data);
        cli_process();
        /* Access the record through the flash_record structure. */
        /* Close the record when done. */
        if (fds_record_close(&record_desc) != FDS_SUCCESS)
            NRF_LOG_INFO("error closing the file");
            /* Handle error. */
    else{
    NRF_LOG_INFO("no data ");
    static void delete_data(uint16_t file_id, uint16_t record_key) {
      NRF_LOG_INFO("deleting records...");
      ret_code_t rc;
      int err = fds_record_find(file_id, record_key, &record_desc, &ftok);
      if (err == FDS_SUCCESS) {
        while (!fds_delete_complete);
        if (ret == FDS_SUCCESS) {
          NRF_LOG_INFO("delete suc..");
        fds_gc();
    I attached Modified flash_fds example from SDK 15.3.0 to reproduce the issue. But one thing i am not able to understand was if i send 'stat' command via putty-Terminal then it gives dirty records as '0'. How come?
  • Thanks, but you're calling fds_stat() immediately after calling fds_gc() so the garbage collection does not get time any to complete.
    Code using fds_gc_complete flag:
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #else
    #include "fds.h"
    bool volatile fds_gc_complete = false;
        "FDS_SUCCESS",
        "FDS_ERR_NULL_ARG",
        "FDS_ERR_NO_PAGES",
        "FDS_ERR_BUSY",
        "FDS_ERR_INTERNAL",
        "FDS_EVT_INIT",
        "FDS_EVT_WRITE",
        "FDS_EVT_UPDATE",
        "FDS_EVT_DEL_FILE",
        "FDS_EVT_GC",
        .config2_on  = true,
        .boot_count  = 0x0,
    static struct
    } m_delete_all;
        switch (p_evt->id)
            case FDS_EVT_INIT:
            case FDS_EVT_WRITE:
            } break;
            } break;
            case FDS_EVT_GC:
                if (p_evt->result == NRF_SUCCESS)
                    fds_gc_complete = true;
            } break;
        ret_code_t rc;
        uint32_t   ram_start;
    #else
    #else
        __WFE();
            power_manage();
        ret_code_t rc;
        ble_stack_init();
    #else
        clock_init();
        timer_init();
        log_init();
        cli_init();
        rc = fds_init();
    //    else
    cli_start();
      record_key++;
      val++;
          record_key++;
      record_key++;
        for (;;)
                power_manage();
            cli_process();
    ret_code_t rc;
    // Set up record.
        cli_process();
        // Handle error.
    else{
    ret_code_t rc;
            /* Handle error. */
    //    char data[16];
        cli_process();
            /* Handle error. */
    else{
      ret_code_t rc;
        fds_gc();
