Raised a ticket for driver QSPI configuration.
 I had raised ticket "https://devzone.nordicsemi.com/f/nordic-q-a/63754/nordic-sdk-qspi-driver-call".
Wanted help for using qspi driver with non blocking mode. I have modified code on driver with semaphore with call back event registered in qspi_init. After 2 hours of logging , system gets reset even when watch dog timer is completely disabled,
Here, is the code i have modified
static nrfx_err_t qspi_task_perform(nrf_qspi_task_t task)
// Wait for peripheral
if (m_cb.interrupt_driven)
return NRFX_ERROR_BUSY;
nrf_qspi_event_clear(NRF_QSPI, NRF_QSPI_EVENT_READY);
if (m_cb.handler)
m_cb.interrupt_driven = true;
nrf_qspi_int_enable(NRF_QSPI, NRF_QSPI_INT_READY_MASK);
ISR_flag =0;
nrf_qspi_task_trigger(NRF_QSPI, task);
if (m_cb.handler == NULL)
while (!nrf_qspi_event_check(NRF_QSPI, NRF_QSPI_EVENT_READY))
//while(!ISR_flag);
adi_osal_SemPend(qspi_task_evt_sem, ADI_OSAL_TIMEOUT_FOREVER); // pending semaphore in qspi_task_perform where read/write is called.
return NRFX_SUCCESS;
void nrfx_qspi_irq_handler(void)
// Catch Event ready interrupts
if (nrf_qspi_event_check(NRF_QSPI, NRF_QSPI_EVENT_READY))
m_cb.interrupt_driven = false;
ISR_flag = 1;
adi_osal_SemPost(qspi_task_evt_sem); // posting semaphore when handler is called.
m_cb.handler(NRFX_QSPI_EVENT_DONE, m_cb.p_context);
ADI_OSAL_SEM_HANDLE   qspi_task_evt_sem; // declaration of variable
adi_osal_SemCreate(&qspi_task_evt_sem, 0);// semaphore create in file system init and is done once
Please help . It logs for 2 hours then i see reset getting happened. Are there mixture of blocking calls inside nrfx_qspi.c I have attached full code.
#include <nrfx.h>
#include "adi_osal.h"
extern ADI_OSAL_SEM_HANDLE   qspi_task_evt_sem;
#if NRFX_CHECK(NRFX_QSPI_ENABLED)
#include <nrfx_qspi.h>
volatile uint8_t ISR_flag  =0;
 * @brief Command byte used to read status register.
#define QSPI_STD_CMD_RDSR 0x05
 * @brief Byte used to mask status register and retrieve the write-in-progess bit.
#define QSPI_MEM_STATUSREG_WIP_Pos 0x01
 * @brief Default time used in timeout function.
#define QSPI_DEF_WAIT_TIME_US 10
 * @brief Default number of tries in timeout function.
#define QSPI_DEF_WAIT_ATTEMPTS 100
  * @brief Control block - driver instance local data.
typedef struct
    nrfx_qspi_handler_t handler;          /**< Handler. */
    nrfx_drv_state_t    state;            /**< Driver state. */
    volatile bool       interrupt_driven; /**< Information if the current operation is performed and is interrupt-driven. */
    void *              p_context;        /**< Driver context used in interrupt. */
} qspi_control_block_t;
static qspi_control_block_t m_cb;
    if (m_cb.handler)
  ISR_flag =0;
    //while(!ISR_flag);
static bool qspi_pins_configure(nrf_qspi_pins_t const * p_config)
    // Check if the user set meaningful values to struct fields. If not, return false.
    if ((p_config->sck_pin == NRF_QSPI_PIN_NOT_CONNECTED) ||
        (p_config->csn_pin == NRF_QSPI_PIN_NOT_CONNECTED) ||
        (p_config->io0_pin == NRF_QSPI_PIN_NOT_CONNECTED) ||
        (p_config->io1_pin == NRF_QSPI_PIN_NOT_CONNECTED))
        return false;
    nrf_qspi_pins_set(NRF_QSPI, p_config);
    return true;
nrfx_err_t nrfx_qspi_init(nrfx_qspi_config_t const * p_config,
                          nrfx_qspi_handler_t        handler,
                          void *                     p_context)
    NRFX_ASSERT(p_config);
    if (m_cb.state != NRFX_DRV_STATE_UNINITIALIZED)
        return NRFX_ERROR_INVALID_STATE;
    if (!qspi_pins_configure(&p_config->pins))
        return NRFX_ERROR_INVALID_PARAM;
    nrf_qspi_xip_offset_set(NRF_QSPI, p_config->xip_offset);
    nrf_qspi_ifconfig0_set(NRF_QSPI, &p_config->prot_if);
    nrf_qspi_ifconfig1_set(NRF_QSPI, &p_config->phy_if);
    m_cb.handler = handler;
    m_cb.p_context = p_context;
    /* QSPI interrupt is disabled because the device should be enabled in polling mode (wait for activate
       task event ready)*/
    nrf_qspi_int_disable(NRF_QSPI, NRF_QSPI_INT_READY_MASK);
    if (handler)
        NRFX_IRQ_PRIORITY_SET(QSPI_IRQn, p_config->irq_priority);
        NRFX_IRQ_ENABLE(QSPI_IRQn);
    m_cb.state = NRFX_DRV_STATE_INITIALIZED;
    nrf_qspi_enable(NRF_QSPI);
    nrf_qspi_task_trigger(NRF_QSPI, NRF_QSPI_TASK_ACTIVATE);
    // Waiting for the peripheral to activate
    bool result;
    NRFX_WAIT_FOR(nrf_qspi_event_check(NRF_QSPI, NRF_QSPI_EVENT_READY),
                  QSPI_DEF_WAIT_ATTEMPTS,
                  QSPI_DEF_WAIT_TIME_US,
                  result);
    if (!result)
        return NRFX_ERROR_TIMEOUT;
nrfx_err_t nrfx_qspi_cinstr_xfer(nrf_qspi_cinstr_conf_t const * p_config,
                                 void const *                   p_tx_buffer,
                                 void *                         p_rx_buffer)
    NRFX_ASSERT(m_cb.state != NRFX_DRV_STATE_UNINITIALIZED);
    /* In some cases, only opcode should be sent. To prevent execution, set function code is
     * surrounded by an if.
    if (p_tx_buffer)
        nrf_qspi_cinstrdata_set(NRF_QSPI, p_config->length, p_tx_buffer);
    /* modify begin by Leo, 2020-06-28,not need to disable interrupt if no use it*/
    if(m_cb.handler)
    /* modify end by Leo, 2020-06-28 */
    nrf_qspi_cinstr_transfer_start(NRF_QSPI, p_config);
    bool result;
                  result);
    if (!result)
        // This timeout should never occur when WIPWAIT is not active, since in this
        // case the QSPI peripheral should send the command immediately, without any
        // waiting for previous write to complete.
        NRFX_ASSERT(p_config->wipwait);
    /* modify begin by Leo, 2020-06-28 not need to disable interrupt if no use it*/
    if(m_cb.handler)
    if (p_rx_buffer)
        nrf_qspi_cinstrdata_get(NRF_QSPI, p_config->length, p_rx_buffer);
nrfx_err_t nrfx_qspi_cinstr_quick_send(uint8_t               opcode,
                                       nrf_qspi_cinstr_len_t length,
                                       void const *          p_tx_buffer)
    nrf_qspi_cinstr_conf_t config = NRFX_QSPI_DEFAULT_CINSTR(opcode, length);
    return nrfx_qspi_cinstr_xfer(&config, p_tx_buffer, NULL);
nrfx_err_t nrfx_qspi_mem_busy_check(void)
    nrfx_err_t ret_code;
    uint8_t status_value = 0;
    nrf_qspi_cinstr_conf_t const config =
        NRFX_QSPI_DEFAULT_CINSTR(QSPI_STD_CMD_RDSR,
                                 NRF_QSPI_CINSTR_LEN_2B);
    ret_code = nrfx_qspi_cinstr_xfer(&config, &status_value, &status_value);
    if (ret_code != NRFX_SUCCESS)
        return ret_code;
    if ((status_value & QSPI_MEM_STATUSREG_WIP_Pos) != 0x00)
void nrfx_qspi_uninit(void)
    nrf_qspi_task_trigger(NRF_QSPI, NRF_QSPI_TASK_DEACTIVATE);
    // Workaround for nRF52840 anomaly 122: Current consumption is too high.
    *(volatile uint32_t *)0x40029054ul = 1ul;
    nrf_qspi_disable(NRF_QSPI);
    NRFX_IRQ_DISABLE(QSPI_IRQn);
    m_cb.state = NRFX_DRV_STATE_UNINITIALIZED;
nrfx_err_t nrfx_qspi_write(void const * p_tx_buffer,
                           size_t       tx_buffer_length,
                           uint32_t     dst_address)
    NRFX_ASSERT(p_tx_buffer != NULL);
    if (!nrfx_is_in_ram(p_tx_buffer))
        return NRFX_ERROR_INVALID_ADDR;
    nrf_qspi_write_buffer_set(NRF_QSPI, p_tx_buffer, tx_buffer_length, dst_address);
    return qspi_task_perform(NRF_QSPI_TASK_WRITESTART);
nrfx_err_t nrfx_qspi_read(void *   p_rx_buffer,
                          size_t   rx_buffer_length,
                          uint32_t src_address)
    NRFX_ASSERT(p_rx_buffer != NULL);
    if (!nrfx_is_in_ram(p_rx_buffer))
    nrf_qspi_read_buffer_set(NRF_QSPI, p_rx_buffer, rx_buffer_length, src_address);
    return qspi_task_perform(NRF_QSPI_TASK_READSTART);
nrfx_err_t nrfx_qspi_erase(nrf_qspi_erase_len_t length,
                           uint32_t             start_address)
    nrf_qspi_erase_ptr_set(NRF_QSPI, start_address, length);
    return qspi_task_perform(NRF_QSPI_TASK_ERASESTART);
nrfx_err_t nrfx_qspi_chip_erase(void)
    return nrfx_qspi_erase(NRF_QSPI_ERASE_LEN_ALL, 0);
        ISR_flag = 1;
