Cannot get BLE advertising packet while scanning with beaconing_nrf52840
I am new to the Nordic environment and am trying to set up a beacon to scan and advertise using BLE.
I used the beaconing example (https://github.com/NordicSemiconductor/nRF5-SDK-for-Mesh/tree/master/examples/beaconing).
The issue I am facing is that I cannot get advertising results in any meaningful way.
I have attached my entire main.c file, but I think only these parts are relevant:
static void scan_event(scan_evt_t const * p_scan_evt)
//this is never called.
   __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, " Scanning! \n");
static void scan_init(void)
nrf_ble_scan_init_t init;
init.connect_if_match = false;
init.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
 char data[BLE_GAP_SCAN_BUFFER_MAX];
ble_data_t buffer =
  .p_data = data,
  .len = NRF_BLE_SCAN_BUFFER
 ble_data_t scan_buff;
  ble_gap_conn_params_t conn_param=
  .min_conn_interval = BLE_GAP_CP_MIN_CONN_INTVL_MIN,         /**< Minimum Connection Interval in 1.25 ms units, see @ref BLE_GAP_CP_LIMITS.*/
  .max_conn_interval = BLE_GAP_CP_MIN_CONN_INTVL_MAX,         /**< Maximum Connection Interval in 1.25 ms units, see @ref BLE_GAP_CP_LIMITS.*/
  .slave_latency = BLE_GAP_CP_SLAVE_LATENCY_MAX,            /**< Slave Latency in number of connection events, see @ref BLE_GAP_CP_LIMITS.*/
  .conn_sup_timeout = BLE_GAP_CP_CONN_SUP_TIMEOUT_NONE         /**< Connection Supervision Timeout in 10 ms units, see @ref BLE_GAP_CP_LIMITS.*/
 ble_gap_scan_params_t scan_param =
    .extended = 0,
    .report_incomplete_evts = 0,
    .active = 1,
    .filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
    .scan_phys = BLE_GAP_PHY_1MBPS,
    .interval = BLE_GAP_CP_MIN_CONN_INTVL_MAX,
    .window = BLE_GAP_SCAN_WINDOW_MIN,
    .timeout = BLE_GAP_EVT_TIMEOUT,
//    .channel_mask = {0x0, 0x0, 0x0, 0x0, 0x0}
  scan_ctx.connect_if_match = false;
  scan_ctx.conn_params = conn_param;
  scan_ctx.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
  scan_ctx.scan_params = scan_param;
  scan_ctx.evt_handler = scan_event;
  scan_ctx.scan_buffer = buffer;
    nrf_ble_scan_filters_disable(&scan_ctx);
    nrf_ble_scan_init(&scan_ctx, &init, scan_event);
   bool isit = is_whitelist_used(&scan_ctx);
   __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Whitelist is used? %d\n", isit);
static void start(void)
     ret_code_t a = nrf_ble_scan_start(&scan_ctx);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Nrf Mesh ret_code: %d \n", a);
After a lot of digging I discovered that the code I am interested in is in the file "nrf_ble_scan.c" in the function nrf_ble_scan_on_ble_evt, but once again this function is never called. As far as I understand this should work, but I am not able to get any results.
/* Copyright (c) 2010 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
 * list of conditions and the following disclaimer.
#include <stdio.h>
#include "nrf_delay.h"
#include "nrf_gpio.h"
#include "ble.h"
#include "boards.h"
#include "simple_hal.h"
#include "nrf_mesh.h"
#include "log.h"
#include "advertiser.h"
#include "mesh_app_utils.h"
#include "mesh_stack.h"
#include "ble_softdevice_support.h"
#include "mesh_provisionee.h"
#include "nrf_mesh_config_examples.h"
#include "app_timer.h"
#include "example_common.h"
#include "nrf_mesh_configure.h"
#include "ad_type_filter.h"
#include "nrf_ble_scan.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
//#include "ble_conn_params.h"
//#include "ble_db_discovery.h"
//#include "ble_hrs.h"
//#include "ble_hrs_c.h"
#include "ble_conn_state.h"
#include "sdk_errors.h"
#include "nrf_sdh_ble.h"
#if defined(NRF51) && defined(NRF_MESH_STACK_DEPTH)
#include "stack_depth.h"
 * Definitions
#define ADVERTISER_BUFFER_SIZE  (64)
#define APP_BLE_CONN_CFG_TAG            1                                               /**< Tag that identifies the SoftDevice BLE configuration. */
 * Forward declaration of static functions
 * Static variables
/** Single advertiser instance. May periodically transmit one packet at a time. */
static advertiser_t m_advertiser;
static uint8_t      m_adv_buffer[ADVERTISER_BUFFER_SIZE];
static bool         m_device_provisioned;
static nrf_ble_scan_t scan_ctx;
static void rx_cb(const nrf_mesh_adv_packet_rx_data_t * p_rx_data)
    LEDS_OFF(BSP_LED_0_MASK);  /* @c LED_RGB_RED_MASK on pca10031 */
    char msg[128];
    (void) sprintf(msg, "RX [@%u]: RSSI: %3d ADV TYPE: %x ADDR: [%02x:%02x:%02x:%02x:%02x:%02x]",
                   p_rx_data->p_metadata->params.scanner.timestamp,
                   p_rx_data->p_metadata->params.scanner.rssi,
                   p_rx_data->adv_type,
                   p_rx_data->p_metadata->params.scanner.adv_addr.addr[0],
                   p_rx_data->p_metadata->params.scanner.adv_addr.addr[1],
                   p_rx_data->p_metadata->params.scanner.adv_addr.addr[2],
                   p_rx_data->p_metadata->params.scanner.adv_addr.addr[3],
                   p_rx_data->p_metadata->params.scanner.adv_addr.addr[4],
                   p_rx_data->p_metadata->params.scanner.adv_addr.addr[5]);
    __LOG_XB(LOG_SRC_APP, LOG_LEVEL_INFO, msg, p_rx_data->p_payload, p_rx_data->length);
    LEDS_ON(BSP_LED_0_MASK);  /* @c LED_RGB_RED_MASK on pca10031 */
static void adv_init(void)
    advertiser_instance_init(&m_advertiser, NULL, m_adv_buffer, ADVERTISER_BUFFER_SIZE);
static void adv_start(void)
    /* Let scanner accept Complete Local Name AD Type. */
    bearer_adtype_add(BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME);
    advertiser_enable(&m_advertiser);
    /* advertising data set  */
    static const uint8_t adv_data[] =
//        0x11, /* AD data length (including type, but not itself) */
//        BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME, /* AD data type (Complete local name) */
//        'N',  /* AD data payload (Name of device) */
//        'o',
//        'r',
//        'd',
//        'i',
//        'c',
//        'S',
//        'e',
//        'm',
//        'i',
//        'M',
//        'e',
//        's',
//        'h'
        0x1F, /* AD data length (including type, but not itself) */
        BLE_GAP_AD_TYPE_MANUFACTURER_SPECIFIC_DATA, /* AD data type (Complete local name) */
        0xF0,  /* AD data payload (Name of device) */
        0xFF,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0,
        0xF0
    /* Allocate packet */
    adv_packet_t * p_packet = advertiser_packet_alloc(&m_advertiser, sizeof(adv_data));
    if (p_packet)
        /* Construct packet contents */
        memcpy(p_packet->packet.payload, adv_data, sizeof(adv_data));
        /* Repeat forever */
        p_packet->config.repeats = ADVERTISER_REPEAT_INFINITE;
        advertiser_packet_send(&m_advertiser, p_packet);
static void node_reset(void)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset  -----\n");
    hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
    /* This function may return if there are ongoing flash operations. */
    mesh_stack_device_reset();
static void config_server_evt_cb(const config_server_evt_t * p_evt)
    if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
        node_reset();
static void device_identification_start_cb(uint8_t attention_duration_s)
    hal_led_mask_set(LEDS_MASK, false);
    hal_led_blink_ms(BSP_LED_2_MASK  | BSP_LED_3_MASK,
                     LED_BLINK_ATTENTION_INTERVAL_MS,
                     LED_BLINK_ATTENTION_COUNT(attention_duration_s));
static void provisioning_aborted_cb(void)
    hal_led_blink_stop();
static void unicast_address_print(void)
    dsm_local_unicast_address_t node_address;
    dsm_local_unicast_addresses_get(&node_address);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
ble_data_t buffer =
  .p_data = data,
    .extended = 0,
    .active = 1,
static void provisioning_complete_cb(void)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
    unicast_address_print();
    hal_led_mask_set(LEDS_MASK, LED_MASK_STATE_OFF);
    hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
static void mesh_init(void)
    mesh_stack_init_params_t init_params =
        .core.irq_priority = NRF_MESH_IRQ_PRIORITY_LOWEST,
        .core.lfclksrc     = DEV_BOARD_LF_CLK_CFG,
        .models.config_server_cb = config_server_evt_cb
    uint32_t status = mesh_stack_init(&init_params, &m_device_provisioned);
    switch (status)
        case NRF_ERROR_INVALID_DATA:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Data in the persistent memory was corrupted. Device starts as unprovisioned.\n");
			__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Reset device before start provisioning.\n");
        case NRF_SUCCESS:
            ERROR_CHECK(status);
    /* Start listening for incoming packets */
//    nrf_mesh_rx_cb_set(rx_cb);
//ble_gap_conn_params_t conn_param=
//  .min_conn_interval = BLE_GAP_CP_MIN_CONN_INTVL_MIN,         /**< Minimum Connection Interval in 1.25 ms units, see @ref BLE_GAP_CP_LIMITS.*/
//  .max_conn_interval = BLE_GAP_CP_MIN_CONN_INTVL_MAX,         /**< Maximum Connection Interval in 1.25 ms units, see @ref BLE_GAP_CP_LIMITS.*/
//  .slave_latency = BLE_GAP_CP_SLAVE_LATENCY_MAX,            /**< Slave Latency in number of connection events, see @ref BLE_GAP_CP_LIMITS.*/
//  .conn_sup_timeout = BLE_GAP_CP_CONN_SUP_TIMEOUT_NONE         /**< Connection Supervision Timeout in 10 ms units, see @ref BLE_GAP_CP_LIMITS.*/
// ble_gap_scan_params_t scan_param =
//    .extended = 1,
//    .report_incomplete_evts = 1,
//    .active = 1,
//    .filter_policy = 2,
//    .scan_phys = BLE_GAP_PHY_AUTO,
//    .interval = BLE_GAP_CP_MIN_CONN_INTVL_MAX,
//    .window = BLE_GAP_SCAN_WINDOW_MIN,
//    .timeout = BLE_GAP_EVT_TIMEOUT,
// char data[31];
//ble_data_t buffer =
//  .p_data = data,
//  .len = NRF_BLE_SCAN_BUFFER
// ble_data_t scan_buff;
//nrf_ble_scan_init_t init =
//  .p_scan_param = &scan_param,
//  .connect_if_match = false,
//  .p_conn_param = NULL,
//  .conn_cfg_tag = 0x00
//nrf_ble_scan_t scan_ctx =
//  .conn_params = conn_param,
//  .conn_cfg_tag = 0x00,
//  .scan_params = scan_param,
//  .evt_handler = scan_event,
//  .scan_buffer = buffer
static void initialize(void)
    stack_depth_paint_stack();
    ERROR_CHECK(app_timer_init());
    hal_leds_init();
    __LOG_INIT(LOG_SRC_APP, LOG_LEVEL_INFO, log_callback_rtt);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Bluetooth Mesh Beacon Example -----\n");
    ble_stack_init();
    mesh_init();
     /* Initialize the advertiser */
    adv_init();
    /* Initialize the scanner */
    scan_init();
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initialization complete!\n");
    if (!m_device_provisioned)
        static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
        mesh_provisionee_start_params_t prov_start_params =
            .p_static_data    = static_auth_data,
            .prov_complete_cb = provisioning_complete_cb,
            .prov_device_identification_start_cb = device_identification_start_cb,
            .prov_device_identification_stop_cb = NULL,
            .prov_abort_cb = provisioning_aborted_cb,
            .p_device_uri = EX_URI_BEACON
        ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
    /* Start advertising own beacon */
    /* Note: If application wants to start beacons at later time, adv_start() API must be called
     * from the same IRQ priority context same as that of the Mesh Stack. */
//    adv_start();
    mesh_app_uuid_print(nrf_mesh_configure_device_uuid_get());
    ERROR_CHECK(mesh_stack_start());
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Bluetooth Mesh Beacon example started!\n");
    hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
    initialize();
    start();
    for (;;)
        (void)sd_app_evt_wait();
