Hello
I am using nRF5 SDK ver.16 to try to create a BLE HID touchscreen device.
I referenced ble_hids_mouse example and changed HID report map.
On Windows 10, it works pretty good with single-touch. However multi-touch don't work.
I was assuming the "Contact count maximum" is cause of the problem.
I followed the guide and set this feature value (Contact count maximum) is 10. But have changed nothing.
- How do confirm that the feature value was updated?
- Have any other reason?
This is HID report descriptor:
static uint8_t rep_map_data[] = { /*--------------------------------------------------------------------------*/\ /* INPUT REPORT ID Touch */\ /*--------------------------------------------------------------------------*/\ 0x05, 0x0D, // USAGE_PAGE(Digitizers) 0x09, 0x04, // USAGE (Touch Screen) 0xA1, 0x01, // COLLECTION(Application) 0x85, 0x01, // REPORT_ID /* Touch one */ 0x09, 0x22, // USAGE (Finger) 0xA1, 0x02, // COLLECTION (Logical) 0x09, 0x42, // USAGE (Tip Switch) 0x15, 0x00, // LOGICAL_MINIMUM (0) 0x25, 0x01, // LOGICAL_MAXIMUM (1) 0x75, 0x01, // REPORT_SIZE (1) 0x95, 0x01, // REPORT_COUNT(1) 0x81, 0x02, // INPUT (Data,Var,Abs) 0x95, 0x07, // REPORT_COUNT (7) 0x81, 0x03, // INPUT (Cnst,Ary,Abs) 0x09, 0x51, // USAGE (Contact Identifier) 0x75, 0x08, // REPORT_SIZE (8) 0x95, 0x01, // REPORT_COUNT (1) 0x81, 0x02, // INPUT (Data,Var,Abs) 0x05, 0x01, // USAGE_PAGE (Generic Desktop) 0x09, 0x30, // Usage (X) 0x09, 0x31, // Usage (Y) 0x16, 0x00, 0x00, // Logical Minimum (0) 0x26, 0x10, 0x27, // Logical Maximum (10000) 0x36, 0x00, 0x00, // Physical Minimum (0) 0x46, 0x10, 0x27, // Physical Maximum (10000) 0x65, 0x11, // Unit (Centimeter, SI-Linear) 0x75, 0x10, // Report Size (16), 0x95, 0x02, // Report Count (2), 0x81, 0x02, // Input (Data,Var,Abs) 0xC0, // END_COLLECTION /* Touch two */ 0x09, 0x22, // USAGE (Finger) 0xA1, 0x02, // COLLECTION (Logical) 0x09, 0x42, // USAGE (Tip Switch) 0x15, 0x00, // LOGICAL_MINIMUM (0) 0x25, 0x01, // LOGICAL_MAXIMUM (1) 0x75, 0x01, // REPORT_SIZE (1) 0x95, 0x01, // REPORT_COUNT(1) 0x81, 0x02, // INPUT (Data,Var,Abs) 0x95, 0x07, // REPORT_COUNT (7) 0x81, 0x03, // INPUT (Cnst,Ary,Abs) 0x09, 0x51, // USAGE (Contact Identifier) 0x75, 0x08, // REPORT_SIZE (8) 0x95, 0x01, // REPORT_COUNT (1) 0x81, 0x02, // INPUT (Data,Var,Abs) 0x05, 0x01, // USAGE_PAGE (Generic Desktop) 0x09, 0x30, // Usage (X) 0x09, 0x31, // Usage (Y) 0x16, 0x00, 0x00, // Logical Minimum (0) 0x26, 0x10, 0x27, // Logical Maximum (10000) 0x36, 0x00, 0x00, // Physical Minimum (0) 0x46, 0x10, 0x27, // Physical Maximum (10000) 0x65, 0x11, // Unit (Centimeter, SI-Linear) 0x75, 0x10, // Report Size (16), 0x95, 0x02, // Report Count (2), 0x81, 0x02, // Input (Data,Var,Abs) 0xC0, // END_COLLECTION /* Scan time */ 0x55, 0x0C, // UNIT_EXPONENT (-4) 0x66, 0x01, 0x10, // UNIT (Seconds) 0x35, 0x00, // PHYSICAL_MINIMUM (0) 0x47, 0xff, 0xff, 0x00, 0x00, // PHYSICAL_MAXIMUM (65535) 0x15, 0x00, // LOGICAL_MINIMUM (0) 0x27, 0xff, 0xff, 0x00, 0x00, // LOGICAL_MAXIMUM (65535) 0x75, 0x10, // REPORT_SIZE (16) 0x95, 0x01, // REPORT_COUNT (1) 0x09, 0x56, // USAGE (Scan Time) 0x81, 0x02, // INPUT (Data,Var,Abs) /* Contact count */ 0x09, 0x54, // USAGE (Contact count) 0x15, 0x00, // LOGICAL_MINIMUM (0) 0x25, 0x0A, // LOGICAL_MAXIMUM (10) 0x75, 0x08, // REPORT_SIZE (8) 0x95, 0x01, // REPORT_COUNT(1) 0x81, 0x02, // INPUT (Data,Var,Abs) /*--------------------------------------------------------------------------*/\ /* FEATURE REPORT ID Max Contact */\ /*--------------------------------------------------------------------------*/\ 0x85, 0x03, // REPORT_ID 0x09, 0x55, // USAGE(Contact Count Maximum) 0x25, 0x0A, // LOGICAL_MAXIMUM (10) 0x95, 0x01, // REPORT_COUNT(1) 0x75, 0x08, // REPORT_SIZE (8) 0xB1, 0x02, // FEATURE (Data,Var,Abs) /*--------------------------------------------------------------------------*/\ /* FEATURE REPORT ID Microsoft signature */\ /*--------------------------------------------------------------------------*/\ 0x85, 0x44, // REPORT_ID 0x06, 0x00, 0xff, // USAGE_PAGE (Vendor Defined) 0x09, 0xC5, // USAGE (Vendor Usage 0xC5) 0x15, 0x00, // LOGICAL_MINIMUM (0) 0x26, 0xff, 0x00, // LOGICAL_MAXIMUM (0xff) 0x75, 0x08, // REPORT_SIZE (8) 0x96, 0x00, 0x01, // REPORT_COUNT (0x100 (256)) 0xb1, 0x02, // FEATURE (Data,Var,Abs) 0xC0 // END_COLLECTION };
Thank you
