nrfx twis drivers on nrf9160 (Zephyr)
I want to use I2C slave on nrf9160, but there is no I2C slave driver implementation.
So I read that instead of this, I can use nrfx twis drivers on nrf9160.
I followed this thread https://github.com/zephyrproject-rtos/zephyr/issues/21445 to use nrfx twis drivers on zephyr.
prj.conf
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
CONFIG_SERIAL=y
CONFIG_NRFX_TWIS=y
CONFIG_NRFX_TWIS0=y
nrf9160_pca10090ns.overlay
&i2c0 {
	compatible = "nordic,nrf-twis";
	status = "okay";
	sda-pin = < 19 >;
	scl-pin = < 18 >;
When I open the project with these prj.conf and overlay file, I am getting this error:
Loading solution twis_040820.emProject
Executing load commands
cmake -GNinja -DBOARD=nrf9160_pca10090ns -DBOARD_DIR=C:/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=C:/gnuarmemb -BC:/ncs/nrf/samples/jagruti_codes/twis_040820/build_nrf9160_pca10090ns -HC:/ncs/nrf/samples/jagruti_codes/twis_040820 -DDTC_OVERLAY_FILE=C:/ncs/nrf/samples/jagruti_codes/twis_040820/nrf9160_pca10090ns.overlay -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=D:/nRF9160-DK/EmbeddedStudio_ARM_Nordic_v420a_win_x64/arm_segger_embedded_studio_v420a_win_x64_nordic/html/configure_nordic_project_menuconfig.py
-- Using application from 'C:/ncs/nrf/samples/jagruti_codes/twis_040820'
Zephyr version: 2.0.99
-- Selected BOARD nrf9160_pca10090ns
-- Found west: C:/Python37/Scripts/west.exe (found suitable version "0.6.2", minimum required is "0.6.0")
-- Cache files will be written to: C:\Users\b.carre\AppData\Local/.cache/zephyr
-- Loading C:/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns.dts as base
-- Overlaying C:/ncs/zephyr/dts/common/common.dts
-- Overlaying C:/ncs/nrf/samples/jagruti_codes/twis_040820/nrf9160_pca10090ns.overlay
device tree error: 'clock-frequency' appears in /soc/peripheral@40000000/i2c@8000 in nrf9160_pca10090ns.dts.pre.tmp, but is not declared in 'properties:' in C:/ncs/zephyr/dts/bindings\i2c\nordic,nrf-twis.yaml
CMake Error at C:/ncs/zephyr/cmake/dts.cmake:182 (message):
  new extractor failed with return code: 1
  C:/ncs/zephyr/cmake/app/boilerplate.cmake:559 (include)
  CMakeLists.txt:2 (include)
Project load failed
Reported error: solution load command failed (1)
If I remove the compatible = "nordic,nrf-twis"; from overlay file, then there is no error but twis does not work.
Also while adding the IRQ handler,
        IRQ_CONNECT(DT_NORDIC_NRF_I2C_I2C_2_IRQ_0,
                            DT_NORDIC_NRF_I2C_I2C_2_IRQ_0_PRIORITY,
                            nrfx_isr, nrfx_twis_2_irq_handler, 0);
I have these above options available.
But I should use:
IRQ_CONNECT(DT_NORDIC_NRF_TWIS_I2C_0_IRQ_0,
	    DT_NORDIC_NRF_TWIS_I2C_0_IRQ_0_PRIORITY,
	    nrfx_isr, nrfx_twis_0_irq_handler, 0);
But using this, I get the error.
How to solve this problem?
    I was able to solve the above problem. I updated ncs tag to v1.2.0 and there was no compilation error.
    But still TWIS is not working as expected.
    nRF9160DK TWIS is interfaced to SAM's TWIM. At the same, SAM is interfaced to the sensor. SAM uses same TWIM instance but the different addresses for nRF9160DK and sensor.
    When I connect SAM and nRF9160DK TWI pins, the communication between SAM and sensor is also stopped.
    I don't understand what is the problem.
    Because same setup works with nRF52840DK. When I use nRF52840DK as TWIS instead of nRF9160DK, everything works properly.
    I just want the same functionality on nRF9160DK, but nothing works.
    How should I proceed?
  • Hi
    Glad you were able to solve the initial issue. What kind of error are you seeing now then? Could it be that the I2C 0 instance is already used by the SPI or some other part of your application? The SPI and TWI can not use the same instance, as they share certain resources and therefore can not be used at the same time.
    Simon
    No I am using separate instances for SPI and I2C (SPI3 and I2C2).
    Now I have decided to use I2C master, so I can use zephyr drivers for that.
    Thank you for your help.
  • Hi Simon,
    I have same use case as Jagruti - need to interface nRF9160 (running Asset Tracker app)
    interfaced from/ managed by an external I2C master. So the two questions I have are:
    1) Will Asset tracker application allow TWIS operation with getting into conflict with other
        system resources that Asset tracker allocate by default?
    2) Will 9160 respond to asynchronous queries from external/ other master in multi-master
        environment?  If so, then I don't necessarily need TWIS on 9160/ Asset tracker side.
    Please advise. Thanks.
    Best,
    SE
  • Hi
    The nRF9160 should be able to be interfaced by an external I2C master as the nRF9160 supports up to 4x I2C compatible two-wire master/slave with EasyDMA, and the asset tracker application does not use all of these instances by default.
    Simon
