nrfx twis drivers on nrf9160 (Zephyr)
I want to use I2C slave on nrf9160, but there is no I2C slave driver implementation.
So I read that instead of this, I can use nrfx twis drivers on nrf9160.
I followed this thread https://github.com/zephyrproject-rtos/zephyr/issues/21445 to use nrfx twis drivers on zephyr.
prj.conf
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
CONFIG_SERIAL=y
CONFIG_NRFX_TWIS=y
CONFIG_NRFX_TWIS0=y
nrf9160_pca10090ns.overlay
&i2c0 {
	compatible = "nordic,nrf-twis";
	status = "okay";
	sda-pin = < 19 >;
	scl-pin = < 18 >;
When I open the project with these prj.conf and overlay file, I am getting this error:
Loading solution twis_040820.emProject
Executing load commands
cmake -GNinja -DBOARD=nrf9160_pca10090ns -DBOARD_DIR=C:/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=C:/gnuarmemb -BC:/ncs/nrf/samples/jagruti_codes/twis_040820/build_nrf9160_pca10090ns -HC:/ncs/nrf/samples/jagruti_codes/twis_040820 -DDTC_OVERLAY_FILE=C:/ncs/nrf/samples/jagruti_codes/twis_040820/nrf9160_pca10090ns.overlay -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=D:/nRF9160-DK/EmbeddedStudio_ARM_Nordic_v420a_win_x64/arm_segger_embedded_studio_v420a_win_x64_nordic/html/configure_nordic_project_menuconfig.py
-- Using application from 'C:/ncs/nrf/samples/jagruti_codes/twis_040820'
Zephyr version: 2.0.99
-- Selected BOARD nrf9160_pca10090ns
-- Found west: C:/Python37/Scripts/west.exe (found suitable version "0.6.2", minimum required is "0.6.0")
-- Cache files will be written to: C:\Users\b.carre\AppData\Local/.cache/zephyr
-- Loading C:/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns.dts as base
-- Overlaying C:/ncs/zephyr/dts/common/common.dts
-- Overlaying C:/ncs/nrf/samples/jagruti_codes/twis_040820/nrf9160_pca10090ns.overlay
device tree error: 'clock-frequency' appears in /soc/peripheral@40000000/i2c@8000 in nrf9160_pca10090ns.dts.pre.tmp, but is not declared in 'properties:' in C:/ncs/zephyr/dts/bindings\i2c\nordic,nrf-twis.yaml
CMake Error at C:/ncs/zephyr/cmake/dts.cmake:182 (message):
  new extractor failed with return code: 1
  C:/ncs/zephyr/cmake/app/boilerplate.cmake:559 (include)
  CMakeLists.txt:2 (include)
Project load failed
Reported error: solution load command failed (1)
If I remove the compatible = "nordic,nrf-twis"; from overlay file, then there is no error but twis does not work.
Also while adding the IRQ handler,
        IRQ_CONNECT(DT_NORDIC_NRF_I2C_I2C_2_IRQ_0,
                            DT_NORDIC_NRF_I2C_I2C_2_IRQ_0_PRIORITY,
                            nrfx_isr, nrfx_twis_2_irq_handler, 0);
I have these above options available.
But I should use:
IRQ_CONNECT(DT_NORDIC_NRF_TWIS_I2C_0_IRQ_0,
	    DT_NORDIC_NRF_TWIS_I2C_0_IRQ_0_PRIORITY,
	    nrfx_isr, nrfx_twis_0_irq_handler, 0);
But using this, I get the error.
How to solve this problem?
  • nRF9160 supports up to 4x I2C compatible two-wire master/slave with EasyDMA
    Thanks Simon,
    Just to confirm - per quote above you are recommending using one of the unused serial slots as TWIS,  using nrfx, Not Zephyr driver, right?
    Browsing through various posts here on devzone and zephyr communities, what I understand about i2c-slave use on nRF9160:
    a) Until ~3 weeks back Zephyr did Not have support for TWIS/ i2c slave. Though now there's "experimental" i2c slave support added to Zephyr - https://github.com/zephyrproject-rtos/zephyr/issues/27675
    But nRF (including 9160) is explicitly excluded - because how EasyDMA is integral part of i2c operation -
    I think Zephyr driver needs byte-by-byte access to i2c registers.
    b) Per https://github.com/nrfconnect/sdk-zephyr/blob/master/include/drivers/i2c.h#L61 - it reads "The following #defines are used to configure the I2C slave device" - does that mean there's built in support for i2c_slave in current Zephyr for nRF9160? If not, what does this i2c slave device configuration is referring to/ how is it used?
    Will appreciate if you could please comment on what's my best bet for realizing i2c slave on nRF9160? Also is there any example code showing i2c slave in action (nrfx perhaps)? meant for nRF9160 or nRF52.
    Thanks.
    Best,
    SE
  • Hi
    I would suggest using the nrfx drivers, as these are the drivers we are most familiar with. It should be possible to configure any sample project to use TWI(S) as far as I know. Do you have any specific questions on how exactly to do so?
    Simon
  • Thanks Simon,
    Specifically what I'm trying to do - add TWIS to Asset Tracker project.
    When I look at .prj and overlay files for Thingy.91 (in Asset Tracker) - thinking since it uses I2C sensor
    (though operating as TWIM), I'll at least get to see how i2c is configured there.
    But other than CONFIG_*_USE_EXTERNAL=y (vs. CONFIG_ACCEL_USE_SIM=y) I do Not see any
    explicit i2c config (mode, pins etc.) in .prj or overlay files.
    So, my 1st question is -
    a) where am I supposed to make i2c (TWIS in my case)? In order to use nrfx drivers. An example will
        be great.
    b) what is the correct/ recommended way of creating/ modifying project configuration - editing overlay,
        .prj files directly, or from within SES > Configure nRF Connect SDK Project > menuconfig option?
    Best,
    SE
    Please create a new thread. I am receiving notification of this reply every second in my mail box. I received thousands of mail in last 10 minutes. I don't know how to stop it.
  • Hi
    Jagruti: I'm sorry you experienced this notification bonanza yesterday! We're looking into this right now and are working on finding out what exactly has happened here. A suggestion is to disable e-mail notifications from DevZone. This can be done by going to settings in the top right corner and uncheck the "Enable email contact" checkbox.
    SE: Please create a new ticket describing your issue in detail. Feel free to link to this one if you find it relevant.
    Simon
