app_error_fault_handler / SDK V17.0.0 / SD S140 v6.1.1 / nRF52833 Custom board / id = 0x00000001 / PC=0x00014AA6 / nRFConnect for Desktop v3.4.2 / Secured Bootloader (semi-custom) / DFU OTA failed
I understand I shouldn't use S140 v6.1.1 with SDK v17.0.0, but we want to try to keep using v6.1.1 as it's been well tested. Since the ATT_MTU example works with this setup, we have a high hope it will work for DFU OTA as well.
The reason for the move to SDK v17.0.0 because of the new project iteration uses nRF52833.
It is a Bootloader OTA application, taken from the Bootloader component (SDK library), with a thin layer of our wrapper.
It advertises, it connects, but then when I started the DFU OTA transfer using nRF Connect for Desktop v3.4.2, it failed (hard faulted on embedded side).
Here is the error (the last part):
2020-08-04T20:38:29.543Z DEBUG      297 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:2 payload_length:0 data_integrity:0 err_code:0x0
2020-08-04T20:38:29.543Z DEBUG  time:2020-08-04T20:38:29.545Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 count:1
2020-08-04T20:38:29.544Z DEBUG      298 ->  [00 9c 00 00 01 01 00 0f 00 00 00 01 00 01 03 ] type:     VENDOR_SPECIFIC reliable:yes seq#:7 ack#:2 payload_length:f data_integrity:1 header_checksum:2b err_code:0x0
2020-08-04T20:38:29.578Z DEBUG   295/ 0 <-  [N/A] type:                 ACK reliable: no seq#:0 ack#:0 payload_length:0 data_integrity:0 err_code:0x0
2020-08-04T20:38:29.578Z DEBUG   296/ 0 <-  [01 9c 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:2 ack#:0 payload_length:6 data_integrity:1 header_checksum:d0 err_code:0x0
2020-08-04T20:38:29.578Z DEBUG      299 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:3 payload_length:0 data_integrity:0 err_code:0x0
2020-08-04T20:38:29.611Z DEBUG   297/ 0 <-  [02 38 00 00 00 00 00 00 00 0f 00 01 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:3 ack#:0 payload_length:10 data_integrity:1 header_checksum:2e err_code:0x0
2020-08-04T20:38:29.611Z DEBUG      300 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:4 payload_length:0 data_integrity:0 err_code:0x0
2020-08-04T20:38:29.612Z DEBUG GATTC_EVT_WRITE_RSP time:2020-08-04T20:38:29.612Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:15 writeOp:1 offset:0 len:0
2020-08-04T20:38:29.612Z INFO Attribute value changed, handle: 0x0F, value (0x): 03
2020-08-04T20:38:29.644Z DEBUG   298/ 0 <-  [02 39 00 00 00 00 00 00 00 0f 00 01 0b 00 60 03 01 8d 00 00 00 1f 9f e7 a6 ] type:     VENDOR_SPECIFIC reliable:yes seq#:4 ack#:0 payload_length:19 data_integrity:1 header_checksum:9d err_code:0x0
2020-08-04T20:38:29.644Z DEBUG      301 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:5 payload_length:0 data_integrity:0 err_code:0x0
2020-08-04T20:38:29.645Z DEBUG GATTC_EVT_HVX time:2020-08-04T20:38:29.645Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:15 type:1 len:11
2020-08-04T20:38:29.645Z INFO Attribute value changed, handle: 0x0F, value (0x): 60-03-01-8D-00-00-00-1F-9F-E7-A6
2020-08-04T20:38:29.650Z DEBUG      302 ->  [00 9c 00 00 01 01 00 0f 00 00 00 01 00 01 04 ] type:     VENDOR_SPECIFIC reliable:yes seq#:0 ack#:5 payload_length:f data_integrity:1 header_checksum:1a err_code:0x0
2020-08-04T20:38:29.683Z DEBUG   299/ 0 <-  [N/A] type:                 ACK reliable: no seq#:0 ack#:1 payload_length:0 data_integrity:0 err_code:0x0
2020-08-04T20:38:29.683Z DEBUG   300/ 0 <-  [01 9c 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:5 ack#:1 payload_length:6 data_integrity:1 header_checksum:c5 err_code:0x0
2020-08-04T20:38:29.683Z DEBUG      303 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:6 payload_length:0 data_integrity:0 err_code:0x0
2020-08-04T20:38:29.716Z DEBUG   301/ 0 <-  [02 38 00 00 00 00 00 00 00 0f 00 01 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:6 ack#:1 payload_length:10 data_integrity:1 header_checksum:23 err_code:0x0
2020-08-04T20:38:29.716Z DEBUG      304 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:7 payload_length:0 data_integrity:0 err_code:0x0
2020-08-04T20:38:29.716Z DEBUG GATTC_EVT_WRITE_RSP time:2020-08-04T20:38:29.717Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:15 writeOp:1 offset:0 len:0
2020-08-04T20:38:29.716Z INFO Attribute value changed, handle: 0x0F, value (0x): 04
2020-08-04T20:38:29.860Z DEBUG   302/ 0 <-  [02 39 00 00 00 00 00 00 00 0f 00 01 03 00 60 04 01 ] type:     VENDOR_SPECIFIC reliable:yes seq#:7 ack#:1 payload_length:11 data_integrity:1 header_checksum:12 err_code:0x0
2020-08-04T20:38:29.861Z DEBUG      305 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:0 payload_length:0 data_integrity:0 err_code:0x0
2020-08-04T20:38:29.861Z DEBUG GATTC_EVT_HVX time:2020-08-04T20:38:29.862Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:15 type:1 len:3
2020-08-04T20:38:29.861Z INFO Attribute value changed, handle: 0x0F, value (0x): 60-04-01
2020-08-04T20:38:29.873Z DEBUG      306 ->  [00 9c 00 00 01 01 00 0f 00 00 00 02 00 01 06 02 ] type:     VENDOR_SPECIFIC reliable:yes seq#:1 ack#:0 payload_length:10 data_integrity:1 header_checksum:30 err_code:0x0
2020-08-04T20:38:29.905Z DEBUG   303/ 0 <-  [N/A] type:                 ACK reliable: no seq#:0 ack#:2 payload_length:0 data_integrity:0 err_code:0x0
2020-08-04T20:38:29.906Z DEBUG   304/ 0 <-  [01 9c 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:0 ack#:2 payload_length:6 data_integrity:1 header_checksum:c2 err_code:0x0
2020-08-04T20:38:29.906Z DEBUG      307 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:1 payload_length:0 data_integrity:0 err_code:0x0
2020-08-04T20:38:49.901Z DEBUG   305/ 0 <-  [02 11 00 00 00 08 ] type:     VENDOR_SPECIFIC reliable:yes seq#:1 ack#:2 payload_length:6 data_integrity:1 header_checksum:c1 err_code:0x0
2020-08-04T20:38:49.901Z DEBUG      308 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:2 payload_length:0 data_integrity:0 err_code:0x0
2020-08-04T20:38:49.901Z DEBUG GAP_EVT_DISCONNECTED time:2020-08-04T20:38:49.903Z connHandle:0 reason:8 reasonName:connectionTimeout
2020-08-04T20:38:49.902Z DEBUG Destroying DFU transport.
2020-08-04T20:38:49.902Z ERROR DFU failed with error: When writing 'SELECT' command to Control Point Characteristic of DFU Target: Could not write SELECT command: Device disconnected.
Is there any hope it can still work, considering ATT_MTU example works? What error is at address 0x00014AA6?
UPDATE: I found this https://devzone.nordicsemi.com/f/nordic-q-a/47171/softdevice-assertion-failed-at-0x00014aa6
Which led me to this: https://devzone.nordicsemi.com/f/nordic-q-a/40088/sd_flash_write-cause-nrf_fault_id_sd_assert
It seems that SD v7.0.1 has a longer time allocated for flash operation, that's why it works.
Theoretically speaking, I can do the work around (split half-size for the write) and make v6.1.1 works.
Could you confirm if this is indeed the issue?
As I am not sure how SD scheduling works, I want to make sure I implement the workaround at the right place to be effective (to be able to return the time slice). Is it in nrf_dfu_settings_svci.c in any occurences of sd_flash_write()? Or is it in nrf_dfu_flash.c, in the nrf_dfu_flash_store()? Or is it somewhere else?
Also, for the flash erase, the minimum size is one page. Is the workaround splitting erase one page at a time and add delay in between?
