Can I use P0.21 as a regular GPIO ? When I power the chip up, will it start correctly ? Is there any problem if I connect it to a LED and resistor ? How do I configure this port?
Regards
Andre
Regards
Andre
Hi
The P0.21/nRESET pin can be used as a GPIO, then is should not be a problem to use it for LED\resistor combo.
Here is a link to the nordic.infocenter whit the where you can find the pin assignment and GPIO list.
Here are some links to other devzone post regarding same issue:
https://devzone.nordicsemi.com/f/nordic-q-a/16195/nrf52832-p0-21-reset-pin
https://devzone.nordicsemi.com/f/nordic-q-a/18170/how-can-i-disable-reset-of-p0-21
https://devzone.nordicsemi.com/f/nordic-q-a/28821/disabling-pin-21-of-nrf52832
https://devzone.nordicsemi.com/f/nordic-q-a/29328/using-nrf52832-configuring-p0-21-reset-as-output
Jonathan
