Not able to load the soft device by using external debugger(i-Jet) in nRF52840 board
Hi Team,
We are using the nRF52840 board for our development purpose. We are using the external debugger(i-jet) for our development purpose.
We are able to connect the debugger and load the active application, but when we try to load the soft device hex file we are getting error like " The flash loader program reported an error".
1. Able to connect and debug the application with out soft device.
2. Able to load the active application from IAR using the option Project=>Download=>Download Active application   == success
3. Same set up if we give the option like Project=>Download=>Download File (Select the Soft Device .hex file) it is giving the error like " The flash loader program reported an error".
4. Is there any other setting we need to do for loading Soft device like loader and any linker settings.
Attached the error screen shot for reference:
Srinivas.V
  • Hi Srinivas
    Are you able to get an error message that provides some more information in the debug log? Here at Nordic we're generally used to the J-Link debuggers, can you show me how your board is connected to the debugger you're using?
    Please try doing a full flash erase of your device, then flash the SoftDevice onto your chip. Make sure that your application's RAM and Flash memory start addresses are set correctly according to the SoftDevice before flashing the application data onto your device as well. Check out this guide to see how this is done.
    Simon
  • Hi Simonr,
    Thanks for your reply.
    The error message I already shared in previous post "The flash loader program reported an error".
    1. I did the same steps what you have suggested, like erasing the entire flash and Flash and RAM Start address also correct.
    2. The issue is with IAR with I-JET debugger, we are able to load the application and debug the same.When it comes to SD hex file we are not able to load with IAR with I-Jet Debugger.
    3. Not getting clarity on what i am missing. The application without SD i am able debug and it is working fine.
    4. Application with SD dependent and needs to flash SD file before application is not happening. Means we are not able to load the SD .hex file individually and combine with application as well.
    5. We need one mechanism to load the SD .hex file before application with the help of IAR i-jet debugger not with J-Link debuggers.
    Srinivas.V
  • Hi
    Can you try enabling flash loaders in the debug settings when using the i-jet? What MDK version are you using? There was a bug in the versions prior to v8.31.0, so please make sure that you're using a version that's later than this one.
    Simon
  • Hi Simon,
    I have enabled the flash loaders in debug settings and i am using 8.35.0 IAR 5-Clause Nordic License.
    Apart from these is there some thing we need to do settings in IAR to make it work other debuggers like IAR i-jet and other.
    Is there any precautions we need to take while connecting the nrf52840 DK through usb connector, in terms usb type and current rating for that. We are facing issues with these boards. Recently we bought new boards and connected through J2 connector and one day it works fine, next when i connect usb cable power led is not glowing and on board debugger also not detected and SOC led also not blinking.
    When we connected through Coin battery soc led is blinking , what further steps we need to take on this issue, it is very much helpful to us , almost we lost three boards with same issue.Even we are not able to entered into Bootloader mode also.
    Srinivas.V
     If you connect them to a computer with a USB cable, the only precautions necessary should be to make sure all switches are in the correct places. If they're not working for some reason, you can try nrfjprog --recover with the nRF Command Line Tools. It might also be the case that the Interface MCU has been flashed with incorrect firmware, in which case you can see how to enter the bootloader mode on the Interface MCU here, and download the MCU firmware from here (the .bin file).
    I'm sorry, but we don't have too much experience with the IAR i-jet debuggers, so I'm running out of suggestions regarding the i-jet troubles you're having. It seems it is also important if you're using the SoftDevice that this is present in extra options (see picture below).
    Can you make sure the debugger resets the custom board properly when entering debug mode? Does the custom board rout the RESET to the SWD connector?
    Simon
