How to Bond the device ( through bluetooth ) to my app?
I am trying to have a bluetooth bond between the device and the app,
how to set a security key to bond it with the android app? and also can I know how to encrypt all the data that are to be sent through this device?
    Most of our SDK BLE examples are already configured to support the pairing and bonding, which both are BT defined procedures to exchange encryption keys. You may for instance try the Glucose Application example with our nRF connect app on Android.
    As per the link you sent, I referred to it.
    I hence checked out the given example:
    But I get an error in this code after I added it to my program :
    Below attached my code for your reference:
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * Peripheral: SAADC
     * Compatibility: nRF52832 rev 2/nRF52840 rev 1, SDK 15.2.0
     * Softdevice used: S132 v6.1.0/S140 v6.1.0
     * This SAADC example samples on 4 different input pins, and enables scan mode to do that. It is otherwise an
     * offsprint from the standard ble_app_uart example available in nRF5 SDK 15.2.0
     * Works together with softdevice S132 v6.1.0 on nRF52832 and S140 v6.1.0 on nRF52840
     * Transmits SAADC output to hardware UART and over BLE via Nordic UART Servive (NUS).
     * Info on NUS -> http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v13.0.0/ble_sdk_app_nus_eval.html?cp=4_0_0_4_1_2_17
     * Info on hardware UART settings -> http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v13.0.0/uart_example.html?cp=4_0_0_4_4_41
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "nrf_drv_twi.h"
    #include "nrf_delay.h"
    #include "app_pwm.h"
    #include "nrf_calendar.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "IEDC_BRD2"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    #define SAADC_SAMPLES_IN_BUFFER         4
    #define SAADC_SAMPLE_RATE		250                                         /**< SAADC sample rate in ms. */
    #define BRD_LED1 8
    #define BRD_LED2 11
    #define BRD_LED3 12
    #define BRD_LED4 14
    #define MOT_CTL 7
    #define BAT_STATE 6
    #define KEY_PIN 30
    #define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
    #define SEC_PARAM_MITM                  1                                           /**< Man In The Middle protection required (applicable when display module is detected). */
    #define SEC_PARAM_LESC                  1                                           /**< LE Secure Connections enabled. */
    #define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_DISPLAY_ONLY                /**< Display I/O capabilities. */
    #define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
    #define PASSKEY_TXT                     "Passkey:"                                  /**< Message to be displayed together with the pass-key. */
    #define PASSKEY_TXT_LENGTH              8                                           /**< Length of message to be displayed together with the pass-key. */
    #define PASSKEY_LENGTH                  6                                           /**< Length of pass-key received by the stack for display. */
    static pm_peer_id_t m_peer_to_be_deleted = PM_PEER_ID_INVALID;
    static uint16_t     m_conn_handle        = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static void pm_evt_handler(pm_evt_t const * p_evt)
        ret_code_t err_code;
        pm_handler_on_pm_evt(p_evt);
        pm_handler_disconnect_on_sec_failure(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
            case PM_EVT_CONN_SEC_SUCCEEDED:
                pm_conn_sec_status_t conn_sec_status;
                // Check if the link is authenticated (meaning at least MITM).
                err_code = pm_conn_sec_status_get(p_evt->conn_handle, &conn_sec_status);
                if (conn_sec_status.mitm_protected)
                    NRF_LOG_INFO("Link secured. Role: %d. conn_handle: %d, Procedure: %d",
                                 ble_conn_state_role(p_evt->conn_handle),
                                 p_evt->conn_handle,
                                 p_evt->params.conn_sec_succeeded.procedure);
                    // The peer did not use MITM, disconnect.
                    NRF_LOG_INFO("Collector did not use MITM, disconnecting");
                    err_code = pm_peer_id_get(m_conn_handle, &m_peer_to_be_deleted);
                    err_code = sd_ble_gap_disconnect(m_conn_handle,
            } break;
            case PM_EVT_CONN_SEC_FAILED:
                advertising_start(false);
    typedef struct
        int16_t z;
        int16_t y;
        int16_t x;
    }accel_values_t;
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /*< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    static dc = 50;
    static kk = 0;
    static button = 0;
    volatile uint8_t state = 1;
    volatile uint16_t Battery_voltage,Battery_current,FSR_voltage;
    #define TIMER_INTERVAL_ACCEL_UPDATE     APP_TIMER_TICKS(5000) // 2000 ms intervals
    volatile bool start_accel_update_flag = false;
    APP_TIMER_DEF(m_timer_accel_update_id);
    #define TIMER_INTERVAL_ADC_UPDATE     APP_TIMER_TICKS(3000) // 3000 ms intervals
    volatile bool start_adc_update_flag = false;
    APP_TIMER_DEF(m_timer_adc_update_id);
    #define TIMER_INTERVAL_PWM_UPDATE     APP_TIMER_TICKS(500) // 500 ms intervals
    APP_TIMER_DEF(m_timer_pwm_update_id);
    volatile bool start_pwm_update_flag = false;
    volatile bool bat_low = 0,charge=0,vibrate_on = 0;
    volatile uint16_t Vibrate_value , Temp_value ,Vibrate_value2;
    #ifdef NRF52810_XXAA
    static const nrf_drv_timer_t   m_timer = NRF_DRV_TIMER_INSTANCE(2);
    #else
    static const nrf_drv_timer_t   m_timer = NRF_DRV_TIMER_INSTANCE(3);
    static nrf_saadc_value_t       m_buffer_pool[2][SAADC_SAMPLES_IN_BUFFER];
    static nrf_ppi_channel_t       m_ppi_channel;
    static uint32_t                m_adc_evt_counter;
    volatile uint32_t vibrate_count;
    volatile uint32_t right;
    volatile uint32_t left;
    static bool bl_command=0;
    static uint8_t bluetooth_command[4];
    static uint8_t accel_values_array[6];
    /* TWI instance ID. */
    #define TWI_INSTANCE_ID     0
    /* Common addresses definition for sensor. */
    #define ICM20948_ADDR          0x68 //(0x90U >> 1)
    #define MPU_REG_ACCEL_XOUT_H   0x2D
    /* Indicates if operation on TWI has ended. */
    static volatile bool m_xfer_done = false;
    /* TWI instance. */
    static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
    extern void Convert_to_ascii(uint16_t num,uint8_t *num_array,uint8_t n);
    extern void  Convert_Ascii_array_to_int(uint8_t *ascii_array, uint8_t c);
    /* Buffer for samples read from sensor. */
    static uint8_t m_sample;
    APP_PWM_INSTANCE(PWM1,1);                   // Create the instance "PWM1" using TIMER1.
    static volatile bool ready_flag;            // A flag indicating PWM status.
    void pwm_ready_callback(uint32_t pwm_id)    // PWM callback function
        ready_flag = true;
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    void timer_accel_update_handler(void * p_context)
        start_accel_update_flag = true;
    void timer_adc_update_handler(void * p_context)
        start_adc_update_flag = true;
    void timer_pwm_update_handler(void * p_context)
        start_pwm_update_flag = true;
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
        err_code = app_timer_create(&m_timer_accel_update_id, APP_TIMER_MODE_REPEATED, timer_accel_update_handler);
         err_code = app_timer_create(&m_timer_adc_update_id, APP_TIMER_MODE_REPEATED, timer_adc_update_handler);
        err_code = app_timer_create(&m_timer_pwm_update_id, APP_TIMER_MODE_REPEATED, timer_pwm_update_handler);
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
    static volatile bool send_time_update = false;
    NRF_LOG_INFO("BLINKY START\n");
          uint8_t vib_cnt_buf[5],vibrate_count_array[3],vvv[3];
          uint16_t length = 8,i=0,len1=2,len2=6,ha = 3,lendt = 16;
          uint8_t message1[]= "OK" ;
          uint8_t message2[]= "NOT OK" ;
            uint32_t err_code;
          if (p_evt->params.rx_data.p_data[0]=='O')
          {   button = 1;
    if(p_evt->params.rx_data.p_data[0] == 'T')
                send_time_update = true;
    //----------------------------higher and lower threshold--------------------------------------
          if (p_evt->params.rx_data.p_data[0]=='L')
              memcpy(&vvv[0], (&p_evt->params.rx_data.p_data[1]),3);
                 Convert_Ascii_array_to_int(&vvv[0],3);
                 Vibrate_value2 = Temp_value;
          if (p_evt->params.rx_data.p_data[0]=='H')
                 Vibrate_value = Temp_value;
                 Convert_to_ascii(Temp_value,(&vib_cnt_buf[0]),3);
    //-------------------------leg??-----------------------------------------------
        if ((p_evt->params.rx_data.p_data[0]=='l')&&(p_evt->params.rx_data.p_data[1]=='e')&&(p_evt->params.rx_data.p_data[2]=='g'))
          if(p_evt->params.rx_data.p_data[3]=='L')
            kk = 1;
            kk = 0;
           if(p_evt->params.rx_data.p_data[0]=='P')
              dc = Temp_value;
           if((p_evt->params.rx_data.p_data[0]=='a')&&(p_evt->params.rx_data.p_data[1]=='a'))
                  bl_command = 1;
                  if (kk == 0)
                  Convert_to_ascii(right,(&vib_cnt_buf[0]),8);
                  Convert_to_ascii(left,(&vib_cnt_buf[2]),2);
                  //err_code = ble_nus_data_send(&m_nus, (&vib_cnt_buf[0]), &length, m_conn_handle);
                  err_code = ble_nus_data_send(&m_nus, (&vib_cnt_buf), &length, m_conn_handle);
               else if((p_evt->params.rx_data.p_data[0]=='*')&&(p_evt->params.rx_data.p_data[1]=='*'))
               //  for(i=0;i<3;i++)
               //   vibrate_count_array[i] = p_evt->params.rx_data.p_data[1+i];
                 memcpy(&vibrate_count_array[0], (&p_evt->params.rx_data.p_data[2]),3);
                 Convert_Ascii_array_to_int(&vibrate_count_array[0],3);
                if((Temp_value > 150 ) & (Temp_value < 999 ))
                   Vibrate_value = Temp_value ;
                  err_code = ble_nus_data_send(&m_nus, message1, &len1, m_conn_handle);
                  err_code = ble_nus_data_send(&m_nus, message2, &len2, m_conn_handle);
              else if((p_evt->params.rx_data.p_data[0]=='&')&&(p_evt->params.rx_data.p_data[1]=='&'))
               //  for(i=0;i<3;i++)
                if((Temp_value > 50 ) & (Temp_value < 150 ))
                   Vibrate_value2 = Temp_value ;
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    /**@brief Clear bond information from persistent storage.
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
               // sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                //err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
                //APP_ERROR_CHECK(err_code);
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        nrf_pwr_mgmt_run();
    static void advertising_start(bool erase_bonds)
        if (erase_bonds == true)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    uint32_t bluetooth_sleep(void)
    	uint32_t err_code;
    	// If connected, disconnect
    	if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
    		if (err_code != NRF_SUCCESS) return err_code;
    	// Stop advertising
    	err_code = sd_ble_gap_adv_stop(m_advertising.adv_handle);
    	// Disable the radio tasks as scytulip suggested
    	// devzone.nordicsemi.com/.../
    	NRF_RADIO->TASKS_DISABLE;
    	return NRF_SUCCESS;
        uint8_t _i;
    	_i = n;
         // _i = 0;
    	do{
    	_i-- ;
    	num_array[_i] = (num % 10)+'0';
           	num /= 10 ;
           // _i++;
    	}while(_i != 0);
       uint16_t value=0;
       uint8_t i,hex;
       uint16_t mf = 1;
     i = c;
    	 do{
    	i--;
    	hex = ascii_array[i]-'0';
    	value = value + hex*mf ;
            mf = mf*10 ;
    	}while(i != 0);
    //return(value);
    Temp_value = value ;
    void timer_handler(nrf_timer_event_t event_type, void* p_context)
        nrf_drv_timer_config_t timer_config = NRF_DRV_TIMER_DEFAULT_CONFIG;
        timer_config.frequency = NRF_TIMER_FREQ_31250Hz;
        err_code = nrf_drv_timer_init(&m_timer, &timer_config, timer_handler);
        /* setup m_timer for compare event */
        uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer,SAADC_SAMPLE_RATE);
        nrf_drv_timer_extended_compare(&m_timer, NRF_TIMER_CC_CHANNEL0, ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
        uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer, NRF_TIMER_CC_CHANNEL0);
        uint32_t saadc_sample_event_addr = nrf_drv_saadc_sample_task_get();
        err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, timer_compare_event_addr, saadc_sample_event_addr);
            uint16_t adc_value,mV;
            float  mV_value_digit;
            uint8_t value[SAADC_SAMPLES_IN_BUFFER*2];
            uint16_t bytes_to_send;
            uint8_t mV_values[20] = {"    ,    ,    ,     "};
            uint16_t send_bytes = 20;
            // set buffers
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER);
            // print samples on hardware UART and parse data for BLE transmission
           // printf("ADC event number: %d\r\n",(int)m_adc_evt_counter);
            for (int i = 0; i < SAADC_SAMPLES_IN_BUFFER; i++)
               // printf("%d\r\n", p_event->data.done.p_buffer[i]);
                adc_value = p_event->data.done.p_buffer[i];
                if(adc_value > 4096)
                    adc_value = 0;
                mV_value_digit = adc_value ;
                switch(i)
                    case 0:
                          mV_value_digit = mV_value_digit * 1.75 ;
                          Battery_voltage = mV_value_digit;
                   case 1:
                          mV_value_digit = mV_value_digit * 0.88 ;
                          Battery_current = mV_value_digit;
                   case 3:
                          FSR_voltage = mV_value_digit;
               // mV_value_digit = mV_value_digit / 4096 ;
               // mV_value_digit = mV_value_digit/ 1000 ;
                 mV = mV_value_digit ;
                Convert_to_ascii(mV,(&mV_values[i*5]),4);
                value[i*2] = adc_value;
                value[(i*2)+1] = adc_value >> 8;
            // Send data over BLE via NUS service. Makes sure not to send more than 20 bytes.
            if((SAADC_SAMPLES_IN_BUFFER*2) <= 20)
                bytes_to_send = (SAADC_SAMPLES_IN_BUFFER*2);
                bytes_to_send = 20;
           // err_code = ble_nus_data_send(&m_nus, value, &bytes_to_send, m_conn_handle);
         /* err_code = ble_nus_data_send(&m_nus, (&mV_values[0]), &send_bytes, m_conn_handle);
          if ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_NOT_FOUND))
            m_adc_evt_counter++;
    void saadc_init(void)
        nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
        saadc_config.resolution = NRF_SAADC_RESOLUTION_12BIT;
        nrf_saadc_channel_config_t channel_0_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN2);
        channel_0_config.gain = NRF_SAADC_GAIN1_6;
        channel_0_config.reference = NRF_SAADC_REFERENCE_INTERNAL;
        nrf_saadc_channel_config_t channel_1_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN3);
        channel_1_config.gain = NRF_SAADC_GAIN1_6;
        channel_1_config.reference = NRF_SAADC_REFERENCE_INTERNAL;
        nrf_saadc_channel_config_t channel_2_config =
         NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN4);
        channel_2_config.gain = NRF_SAADC_GAIN1_6;
        channel_2_config.reference = NRF_SAADC_REFERENCE_INTERNAL;
        nrf_saadc_channel_config_t channel_3_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN5);
        channel_3_config.gain = NRF_SAADC_GAIN1_6;
        channel_3_config.reference = NRF_SAADC_REFERENCE_INTERNAL;
        err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
        err_code = nrf_drv_saadc_channel_init(0, &channel_0_config);
        err_code = nrf_drv_saadc_channel_init(1, &channel_1_config);
        err_code = nrf_drv_saadc_channel_init(2, &channel_2_config);
        err_code = nrf_drv_saadc_channel_init(3, &channel_3_config);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAADC_SAMPLES_IN_BUFFER);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAADC_SAMPLES_IN_BUFFER);
     * @brief Function for handling data from temperature sensor.
     * @param[in] temp          Temperature in Celsius degrees read from sensor.
    __STATIC_INLINE void data_handler(uint8_t temp)
        //NRF_LOG_INFO("Temperature: %d Celsius degrees.", temp);
     * @brief TWI events handler.
    void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
        switch (p_event->type)
            case NRF_DRV_TWI_EVT_DONE:
                if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                    data_handler(m_sample);
                m_xfer_done = true;
     * @brief twi initialization.
    void twi_init (void)
        const nrf_drv_twi_config_t twi_ICM20948_config = {
           .scl                = ARDUINO_SCL_PIN,
           .sda                = ARDUINO_SDA_PIN,
           .frequency          = NRF_DRV_TWI_FREQ_100K,
           .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
           .clear_bus_init     = false
        err_code = nrf_drv_twi_init(&m_twi, &twi_ICM20948_config, twi_handler, NULL);
        nrf_drv_twi_enable(&m_twi);
    static void application_timers_start(void)
      uint32_t err_code;
        //uint32_t err_code = app_timer_start(m_timer_accel_update_id, TIMER_INTERVAL_ACCEL_UPDATE, NULL);
        err_code = app_timer_start(m_timer_adc_update_id, TIMER_INTERVAL_ACCEL_UPDATE, NULL);
    void Port_init(void)
              nrf_gpio_cfg_output(BRD_LED1);
    	  nrf_gpio_cfg_output(BRD_LED2);
              nrf_gpio_cfg_output(BRD_LED3);
    	 // nrf_gpio_cfg_output(BRD_LED4);
            //  nrf_gpio_cfg_output(MOT_CTL);
    	/*  nrf_gpio_pin_set(BRD_LED1);
              nrf_gpio_pin_set(BRD_LED2);
              nrf_gpio_pin_set(BRD_LED3);
              nrf_gpio_pin_set(BRD_LED4);*/
            //  nrf_gpio_pin_clear(MOT_CTL);
              nrf_gpio_cfg_input(BAT_STATE, BUTTON_PULL);
              nrf_gpio_cfg_input(KEY_PIN, BUTTON_PULL);
    void ICM20948_set_mode(void)
        /* Writing to LM75B_REG_CONF "0" set temperature sensor in NORMAL mode. */
        uint8_t reg[2] = {0x6, 00};
        err_code = nrf_drv_twi_tx(&m_twi, ICM20948_ADDR, reg, sizeof(reg), false);
        while (m_xfer_done == false);
        /* Writing to pointer byte. */
      //  reg[0] = LM75B_REG_TEMP;
      //  m_xfer_done = false;
      //  err_code = nrf_drv_twi_tx(&m_twi, MPU_ADDR, reg, 1, false);
      //  APP_ERROR_CHECK(err_code);
      //  while (m_xfer_done == false);
    uint32_t app_mpu_read_accel(accel_values_t * accel_values)
        uint32_t err_code;
        uint8_t raw_values[6];
        uint8_t *data;
        uint8_t reg = 0x2D;
       // err_code = nrf_drv_mpu_read_registers(MPU_REG_ACCEL_XOUT_H, raw_values, 6);
       // if(err_code != NRF_SUCCESS) return err_code;
        err_code = nrf_drv_twi_tx(&m_twi, ICM20948_ADDR, &reg, 1, false);
         nrf_delay_ms(100);
         err_code = nrf_drv_twi_rx(&m_twi, ICM20948_ADDR,( &raw_values[0]), 7);
         memcpy(accel_values_array,raw_values,6);
       /* data = (uint8_t*)accel_values;
        for(uint8_t i = 0; i<6; i++)
            *data = raw_values[5-i];
             accel_values_array[i] =  raw_values[i] ;
            data++;
        return NRF_SUCCESS;
    void pwm_init(void)
      app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(1000L,MOT_CTL );
      pwm1_cfg.pin_polarity[0] = APP_PWM_POLARITY_ACTIVE_HIGH;
       /* Initialize and enable PWM. */
        err_code = app_pwm_init(&PWM1,&pwm1_cfg,pwm_ready_callback);
        app_pwm_enable(&PWM1);
    /**@brief Application main function.
        //NRF_LOG_INFO("BSP example started.");
        //NRF_LOG_FLUSH();
        bool erase_bonds;
        bool pwm_on;
         uint16_t send_bytes= 4;
         uint8_t message[] = {"Hello"};
         uint8_t vib_cnt_buf[5];
          accel_values_t accel_values;
          Vibrate_value = 800;
          Vibrate_value2 = 80;
        // Initialize.
       // uart_init();
       // log_init();
        timers_init();
        Port_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        peer_manager_init();
        saadc_sampling_event_init();
        saadc_init();
        twi_init();
        nrf_gpio_pin_clear(BRD_LED3);
        nrf_gpio_pin_clear(BRD_LED1);
        pwm_init();
        application_timers_start();
          advertising_start(erase_bonds);
        //  ICM20948_set_mode();
    nrf_cal_set_time(2020, 7, 20, 12, 30, 0);
    nrf_delay_ms(1000);
        // Enter main loop.
        for (;;)
         if(button == 1) {
        uint32_t h = bluetooth_sleep();}
    if(send_time_update)
                char *time_string;
                uint16_t length;
                time_string = nrf_cal_get_time_string(true);
                length = strlen(time_string);
                uint32_t err_code = ble_nus_data_send(&m_nus, time_string, &length, m_conn_handle);
    if((FSR_voltage >= Vibrate_value) | (FSR_voltage < Vibrate_value2))
    	if(vibrate_on  != 1)
                vibrate_on = 1;
                nrf_delay_ms(1000);
               err_code = app_timer_start(m_timer_pwm_update_id, TIMER_INTERVAL_PWM_UPDATE, NULL);
               pwm_on = 1;
                while (app_pwm_channel_duty_set(&PWM1, 0, dc) == NRF_ERROR_BUSY);
              if(FSR_voltage >= Vibrate_value)
               if (kk==0)
                right++;
               left++;
                else if(FSR_voltage < Vibrate_value2)
                  if (kk==0)
                  left++;
                  right++;
    	if(vibrate_on  == 1)
                      vibrate_on  = 0 ;
                     app_pwm_disable(&PWM1);
                      err_code = app_timer_stop(m_timer_pwm_update_id);
    if(vibrate_on  == 1)
    if(start_pwm_update_flag == 1)
      if(pwm_on == 1)
         pwm_on = 0;
       pwm_on = 1;
      start_pwm_update_flag = 0;
      if(start_adc_update_flag == true){
      if(nrf_gpio_pin_read(BAT_STATE)){
                charge = 0;
          if(Battery_voltage < 3300)
          if(bat_low != 1)
              bat_low = 1 ;
          else{
          if(bat_low == 1)
              bat_low = 0 ;
            else{
               if(charge != 1){
                charge = 1;
  • Hi, can you please help me out with this error that i get
