I'm using Zephyr with nrf52 and want to setup watchdog support with multiple channels (different timer settings for separate different threads).
I can add 1 channel, but adding two, get's me a fail, error.
This should not happen on the 52, it has support for at least 8 channels I see in the wdt spec for the chip.
I get error when creating the 2nd channel.
Code looks like this:
#define PERIPH_WATCHDOG_TIMEOUT_MS (30 * 1000U) #define NETWORK_QUEUE_WATCHDOG_TIMEOUT_MS (10 * 1000U) int watchdog_init() { int error_code = 0; LOG_INF("Watchdog starting"); wdt = device_get_binding(WDT_DEV_NAME); if (!wdt) { LOG_ERR("Cannot get WDT device\n"); return -ENXIO; } return error_code; } int watchdog_add_channel_timeout(u32_t timeout_ms) { /* Reset SoC when watchdog timer expires. */ struct wdt_timeout_cfg wdt_config; wdt_config.flags = WDT_FLAG_RESET_SOC; /* Expire watchdog after 30*1000 milliseconds. */ wdt_config.window.min = 0U; wdt_config.window.max = timeout_ms; // 30 * 1000U; /* Set up watchdog callback. Jump into it when watchdog expired. */ wdt_config.callback = wdt_callback; int wdt_channel_id = wdt_install_timeout(wdt, &wdt_config); if (wdt_channel_id == -ENOTSUP) { wdt_config.callback = NULL; wdt_channel_id = wdt_install_timeout(wdt, &wdt_config); } if (wdt_channel_id < 0) { LOG_ERR("Watchdog install error"); return -ENXIO; } return wdt_channel_id; } int watchdog_start() { int error_code = wdt_setup(wdt, 0); if (error_code < 0) { LOG_ERR("Watchdog setup error"); return error_code; } return error_code; } From main I setup like this: main() { ... int error_code = watchdog_init(); if (error_code < 0) { LOG_ERR("Failed to init watchdog"); } // install periph watchdog channel int periph_channel_id = -1; periph_channel_id = watchdog_add_channel_timeout(PERIPH_WATCHDOG_TIMEOUT_MS); if (periph_channel_id < 0) { LOG_ERR("Failed to setup periph watchdog timer"); } // install network_queue watchdog channel int network_queue_channel_id = -1; network_queue_channel_id = watchdog_add_channel_timeout(NETWORK_QUEUE_WATCHDOG_TIMEOUT_MS); if (network_queue_channel_id < 0) { LOG_ERR("Failed to setup network_queue watchdog timer"); } // Finally start the watchdog timer watchdog_start(); ... }
