Interfacing a Sensor Hub with TWI drivers?
I am trying to adapt the read register function that use the TwoWire lib of Arduino in order to read a Sensor Hub Response Byte of a defined Host Command :
uint8_t readByte(uint8_t _familyByte, uint8_t _indexByte,\
                                           uint8_t _writeByte)
    uint8_t returnByte;
    uint8_t statusByte;
    _i2cPort->beginTransmission(_address);
    _i2cPort->write(_familyByte);
    _i2cPort->write(_indexByte);
    _i2cPort->write(_writeByte);
    _i2cPort->endTransmission();
    delay(CMD_DELAY);
    _i2cPort->requestFrom(_address, sizeof(returnByte) + sizeof(statusByte));
    statusByte = _i2cPort->read();
    if (statusByte)// SUCCESS (0x00)
        return statusByte; // Return the error, see: READ_STATUS_BYTE_VALUE
    returnByte = _i2cPort->read();
    return returnByte; // If good then return the actual byte.
to have a function that uses the nrf_dr_twi, like this:
uint32_t nrf_drv_read_registers(uint8_t reg, uint8_t* p_data, uint32_t length)
    uint32_t err_code;
    uint32_t timeout = OXI_TWI_TIMEOUT;
    err_code = nrf_drv_twi_tx(&m_twi_instance, OXI_ADDRESS, &reg, 1, false);
    if (err_code != NRF_SUCCESS) return err_code;
    while ((!twi_tx_done) && --timeout) ;
    if (!timeout) return NRF_ERROR_TIMEOUT;
    twi_tx_done = false;
    err_code = nrf_drv_twi_rx(&m_twi_instance, OXI_ADDRESS, p_data, length);
    while ((!twi_rx_done) && --timeout) ;
    twi_rx_done = false;
    return err_code;
Have you some ideas on how i can use the family and index byte of the Sensor Hub in order to retrieve the correct byte?
Thank you very much in advance,
Kind regards
