Interfacing a Sensor Hub with TWI drivers?
I am trying to adapt the read register function that use the TwoWire lib of Arduino in order to read a Sensor Hub Response Byte of a defined Host Command :
uint8_t readByte(uint8_t _familyByte, uint8_t _indexByte,\
                                           uint8_t _writeByte)
    uint8_t returnByte;
    uint8_t statusByte;
    _i2cPort->beginTransmission(_address);
    _i2cPort->write(_familyByte);
    _i2cPort->write(_indexByte);
    _i2cPort->write(_writeByte);
    _i2cPort->endTransmission();
    delay(CMD_DELAY);
    _i2cPort->requestFrom(_address, sizeof(returnByte) + sizeof(statusByte));
    statusByte = _i2cPort->read();
    if (statusByte)// SUCCESS (0x00)
        return statusByte; // Return the error, see: READ_STATUS_BYTE_VALUE
    returnByte = _i2cPort->read();
    return returnByte; // If good then return the actual byte.
to have a function that uses the nrf_dr_twi, like this:
uint32_t nrf_drv_read_registers(uint8_t reg, uint8_t* p_data, uint32_t length)
    uint32_t err_code;
    uint32_t timeout = OXI_TWI_TIMEOUT;
    err_code = nrf_drv_twi_tx(&m_twi_instance, OXI_ADDRESS, &reg, 1, false);
    if (err_code != NRF_SUCCESS) return err_code;
    while ((!twi_tx_done) && --timeout) ;
    if (!timeout) return NRF_ERROR_TIMEOUT;
    twi_tx_done = false;
    err_code = nrf_drv_twi_rx(&m_twi_instance, OXI_ADDRESS, p_data, length);
    while ((!twi_rx_done) && --timeout) ;
    twi_rx_done = false;
    return err_code;
Have you some ideas on how i can use the family and index byte of the Sensor Hub in order to retrieve the correct byte?
Thank you very much in advance,
Kind regards
  • Hi i'am sorry to have given a very vague question. I have understood a bit more, now i can describe well my problem, maybe.
    The read and write action on my sensor hub are described as:
    and i want to use the nrf_drv_tx and rx in order to implement these actions.
    If i have the function
    ret_code_t nrf_drv_twi_tx	(	nrf_drv_twi_t const * 	p_instance,
            uint8_t 	address,
            uint8_t const * 	p_data,
            uint8_t 	length,
            bool 	no_stop
    where
    [in] p_instance Pointer to the driver instance structure.
    [in] address Address of a specific slave device (only 7 LSB).
    [in] p_data Pointer to a transmit buffer.
    [in] length Number of bytes to send.
    [in] no_stop If set, the stop condition is not generated on the bus after the transfer has completed successfully (allowing for a repeated start in the next transfer).
    If i need to transmit a series if byte as for example only the Family and Index Byte in order to write,  would i need a buffer (p_data) as an array of dimension 2, able to store these two bytes?
    and so for the reception if i want to retrieve the Status and the Response byte would i need another buffer with same dimension?
    Hope to hear you again and thanks for help me!
    polimarte
  • Hello Polimarte,
    Sorry for my late reply.
    Do not worry, asking the right questions is an art in and of itself. :)
    Great! Let us see if we can't get to the bottom of this issue then.
    With the information you have provided above, it seems to me that your device requires the start of a typical write to contain ADDR - FAMILY - INDEX - content.
    Based on this  I would recommend that you implement this as an array of commands in an array, which you then queue for transfer. You can do this by providing the NRFX_TWIM_XFER_DESC_TX macro with this array of commands, and then passing this this to the nrfx_twim_xfer function.
    Alternatively, if if you do not intend to use the nrfx_twim driver, you could take a look at how some other TWI master drivers for specific components have been implemented. You could see some examples of this in the SDK/components/driver_ext folder of the SDK.
    For example, you could see the external driver for the lis2dh12, located in SDK/components/drivers_ext/lis2dh12
    Especially, note how all the registers are defined in the internal file - this makes writing the driver a lot easier - and how there are functions for specific tasks. Implementing these config and control functions makes using your driver much easier.
    Even if you are planning to use the nrfx_twim driver, you could use the same general structure / approach from this driver, in your driver.
    Lastly, I also recommend that you do a search on github for the specific component you are working with, if the internal registers file is not provided by the component manufacturer - chances are that someone already have transcribed all the register addresses for your particular component, which greatly reduce the time you have to sit and 'transcribe' these addressees from the datasheet directly.
    Karl
  • Hi Karl, thanks for answering to my question.
    I ll use definitely the NRFX_TWIM drivers, but Why i cannot use the normal TWI drivers and define by myself the primary and secondary buffer (and merge them) each time? Is there some problem with communication?
    I have implemented the read and write function using nrf_drv_twi with rx and tx buffer, whose lengths depens on how many bytes i need each time. Here an Example of Write byte function, Does it make any sense to you?
    uint8_t writeByte( uint8_t _familyByte, uint8_t _indexByte, uint8_t _writeByte)
            uint32_t err_code;
            uint32_t timeout = TWI_TIMEOUT;
            uint8_t StatusByte=0;
            uint8_t lenght = sizeof(_familyByte) + sizeof(_indexByte) + sizeof(_writeByte);
            uint8_t rx_buffer;
            uint8_t tx_buffer[] = {_familyByte, _indexByte, _writeByte};   //cazzo devo fare qua
            err_code = nrf_drv_twi_tx(&m_twi_instance, address, tx_buffer, lenght, true);
            err_code = nrf_drv_twi_rx(&m_twi_instance, address, &rx_buffer, sizeof(rx_buffer));
            StatusByte = rx_buffer;
            return StatusByte;
    Sorry this can be a stupid question but i have just started to study the TWI config and to use nordic components.
    Thanks a lot,
    polimarte
  • Hello Polimarte,
    No problem at all, I am happy to help!
    No need to apologize - we were all new to these things at one point or another. It is great that you are familiarizing with the TWI protocol and the drivers and libraries supplied with the SDK on your own! The forum is here whenever you should encounter any issues or questions with any of these, there is no harm in asking! :)
    I am not sure I understand what you mean when you ask why you can not use the "normal TWI drivers" - are you here referring to the legacy nrf_drv_twi_* driver?
    As you can see in the NRFX_TWIM_XFER_DESC_TX documentation, you may very well set up more than 1 byte for TX with this description. As you can see from the nrfx_twim_xfer function documentation you may use the different flag option to initiate different types of transfers - such as the NRFX_TWIM_FLAG_TX_NO_STOP flag, to signal that the TX transfer is not done yet.
    If you are going to do a TXRX ( or another of the transfer options ) sending ( which might require the secondary buffer that you mention ), you should instead use the NRFX_TWIM_XFER_DESC_TXRX.
    You have only shared your writeByte implementation, so I can not say anything about your function for reading.
    Regarding the writeByte function code you shared above, I have the following comments:
    - The return type of your function is incorrect since you sometimes intend to return error codes, such as those possibly returned by nrf_drv_twi_tx with is an ret_code_t which is uint32_t type.
    - You are also mixing what you might be returning, you should not do this as it will make it very hard to use the functions return value ( you will not know if the function returns an error or the status byte). Instead, you should provide the function with a buffer, in which it may place the statusbyte, or whatever else it outputs.
    - Your usage of the timeout might not be as intended, since it will run down the while using CPU cycles, not ms or us or anything "human readable". So, the timeout feature might not work quite as you have intended, but this is just a guess from my side, since I neither know the value nor calculation used to disern TWI_TIMEOUT.
    - Your rx_buffer is used as an array, but is not declared and instantiated as such.
    - You are returning if the result of nrf_drv_twi_tx is != NRF_SUCCESS, this is good. But, since you also might be returning the status register, I am not sure that you are passing the returned value of writeByte through an APP_ERROR_CHECK. Do you do this?
    - I am guessing that the twi_rx_done and twi_tx_done variables are set to true in the twi event handler, is this correct?
    - You are not declaring "StatusByte" at the end, and you are setting it equal to what I am guessing should have been a pointer to an uint8_t array ( which it is not ).
    - Broadly speaking, it also seems that you are not following a particular convention with your variable and function naming, and I highly recommend doing so. For example, you sometimes use Pascal, sometimes camel, and you also use underscores in front of your function parameters - you should be consistent here, and you should not use underscores as a prefix for variable names.
    - Your call to nrf_drv_twi_tx looks all right, if your "address" parameter is as intended. I am guessing that you forgot to replace it with the _writeByte parameter.
    - Your call to nrf_drv_twi_rx also looks ok, but here you are again passing the variable "address" which I think might be incorrect ( but I do not know what address actually points to, so I might be wrong about this ).
    I do not mean to sound crass, I am just trying to help.
    Please take a look at the above comments, and let me know if you should have any questions.
    If you review your code with these comments in mind, feel free to share the updated version here, and I will take a look at it again! :)
    Karl
  • Thanks a lot Karl!!
    I understand that there are several errors and i expected that so thanks to help me!!
    My goal is to adapt code originally made for arduino in c++, using keil uvision, that's probably the reason why there is such confusion about the conventions.
    Unfortunately i am a total beginner to embedded systems and i have to admit that i am lacking of some important basics here.I am sure that i ll understand a bit more now with your hints.
    I ll ask help again, hope to present a more reasonable code in the future.
    polimarte
