Interfacing a Sensor Hub with TWI drivers?
I am trying to adapt the read register function that use the TwoWire lib of Arduino in order to read a Sensor Hub Response Byte of a defined Host Command :
uint8_t readByte(uint8_t _familyByte, uint8_t _indexByte,\
                                           uint8_t _writeByte)
    uint8_t returnByte;
    uint8_t statusByte;
    _i2cPort->beginTransmission(_address);
    _i2cPort->write(_familyByte);
    _i2cPort->write(_indexByte);
    _i2cPort->write(_writeByte);
    _i2cPort->endTransmission();
    delay(CMD_DELAY);
    _i2cPort->requestFrom(_address, sizeof(returnByte) + sizeof(statusByte));
    statusByte = _i2cPort->read();
    if (statusByte)// SUCCESS (0x00)
        return statusByte; // Return the error, see: READ_STATUS_BYTE_VALUE
    returnByte = _i2cPort->read();
    return returnByte; // If good then return the actual byte.
to have a function that uses the nrf_dr_twi, like this:
uint32_t nrf_drv_read_registers(uint8_t reg, uint8_t* p_data, uint32_t length)
    uint32_t err_code;
    uint32_t timeout = OXI_TWI_TIMEOUT;
    err_code = nrf_drv_twi_tx(&m_twi_instance, OXI_ADDRESS, &reg, 1, false);
    if (err_code != NRF_SUCCESS) return err_code;
    while ((!twi_tx_done) && --timeout) ;
    if (!timeout) return NRF_ERROR_TIMEOUT;
    twi_tx_done = false;
    err_code = nrf_drv_twi_rx(&m_twi_instance, OXI_ADDRESS, p_data, length);
    while ((!twi_rx_done) && --timeout) ;
    twi_rx_done = false;
    return err_code;
Have you some ideas on how i can use the family and index byte of the Sensor Hub in order to retrieve the correct byte?
Thank you very much in advance,
Kind regards
  • polimarte said:
    Thanks a lot Karl!!
    No problem at all, Polimarte!
    polimarte said:
    I understand that there are several errors and i expected that so thanks to help me!!
    I am glad to hear that you took it this way, and that my comments was well received! :)
    polimarte said:
    My goal is to adapt code originally made for arduino in c++, using keil uvision, that's probably the reason why there is such confusion about the conventions.
    This is a clear, and achievable goal, great! For starters, I would recommend adopting a similar coding style as demonstrated in the SDK examples, if possible.
    Since the particular variable and function names wont matter following compilation, there is no reason not to write out descriptive names for each variable and function. This will also make it much easier for you to 'get back into the code' if you should take a break at any time, or come back to the code after having worked on another project for a while.
    polimarte said:
    Unfortunately i am a total beginner to embedded systems and i have to admit that i am lacking of some important basics here.I am sure that i ll understand a bit more now with your hints.
    No worries, we all were new to this at some point, and the best way to get better is to keep trying! I will say this though, Nordic SoC's might not be the easiest starting place to learn embedded programming. Mainly, this is because our SoC's are pretty high-end, with a lot of customizable functionality, configurations, and optimizations.
    This makes the learning curve for developing with out SoC's pretty steep - but because of this, once you get the hang of it you will have plenty of tools and functionality at your disposal!
    It is great that you are starting out with the TWI drivers, and are working on how to interface with a sensor. This is a good way to start.
    Especially the BLE parts of the nRF5 SDK examples' code might seem daunting when you first come across it, but once you get familiar with it it will be just as straight forward as the TWI drivers!
    Please do not hesitate to ask, if you should get stuck anywhere in your project.
    polimarte said:
    I ll ask help again, hope to present a more reasonable code in the future.
    Great! That sounds like a good plan, I look forward to hearing how you progress with your project.
    Karl
  • Nordic SoC's might not be the easiest starting place to learn embedded programming. Mainly, this is because our SoC's are pretty high-end, with a lot of customizable functionality
    Absolutely! The fact that the nRF52 is not just a microcontroller but also integrates a complete radio systems adds a whole lot of complication.
    (not picking on Nordic here - the same would apply to any comparable SoC)
    I would strongly suggest that you spend some time on a simpler, "conventional" microcontroller to learn the basics of embedded development.
    eg, as noted above, I2C comms and  your Sensor Hub are not at all related to BLE - that's just an unnecessary extra complication at the learning stage.
    Here are some general beginner "getting started" tips for microcontrollers:
    https://www.avrfreaks.net/comment/2079906#comment-2079906
  • Hi awneil thanks for the hint!
    Unfortunately I will have to use ANT modules in a following part of my project, but i have some source code that can be very helpful to me when i ll arrive at that point. I have little experience with ATMega and STmicrocontoller but you are right this SoC's are not easy at all. Thanks to the excellent Nordic costumer service I am sure i ll made it.
    polimarte
  • Hi Karl!
    I followed your hints and i modified my code, hope to present a better solution now. What i wanted to do is to modify the read and write function for Arduino, that use the library Wire.h to implement the transactions TXRX. The read function of the Arduino code is in my original question. The write function is implemented in this way:
    uint8_t SparkFun_Bio_Sensor_Hub::writeByte(uint8_t _familyByte,uint8_t _indexByte,uint8_t _writeByte)
      delay(CMD_DELAY);
      // Status Byte, success or no? 0x00 is a successful transmit
      _i2cPort->requestFrom(_address, static_cast<uint8_t>(1));
      uint8_t statusByte = _i2cPort->read();
      return statusByte;
    and i have used the NRFX_TWIM_XFER_DESC_TXRX in this way for Read:
    uint8_t readByte_WB(uint8_t familyByte, uint8_t indexByte, uint8_t writeByte)
    		nrfx_err_t err_code
    		uint8_t StatusByte;
            uint8_t ReturnByte;
            uint8_t rx_buffer[2];
    		size_t rx_lenght =2;
    		uint8_t tx_buffer[] = {familyByte, indexByte, writeByte};
    		size_t tx_lenght = sizeof(familyByte) + sizeof(indexByte) + sizeof(writeByte);
    		nrfx_twim_xfer_desc_t transferType = NRFX_TWIM_XFER_DESC_TXRX(address, tx_buffer, tx_lenght, rx_buffer,rx_lenght);
    		err_code = nrfx_twim_xfer(&twim_instance, &transferType, 0);
    		NRF_LOG_INFO("Xfer error code: %s \n", errorcode_printer(err_code));
    		StatusByte = int(rx_buffer[0]);
            NRF_LOG_INFO("Status Byte: %lu \n",StatusByte); //0x00 for SUCCESS
    		ReturnByte = rx_buffer[1];
    		return ReturnByte;
    and for write:
    uint8_t writeByte( uint8_t familyByte, uint8_t indexByte, uint8_t writeByte)
    		nrfx_err_t err_code
    		uint8_t StatusByte;
    		uint8_t rx_buffer[1];
    		size_t rx_lenght =1;
    		StatusByte = rx_buffer[0];
            return StatusByte;
    I understand that formally it would be more correct use pointers in order to retrieve the bytes with buffers but i need a non void return function for my adaptation to the original code. I use the StatusByte only to check the SUCCESS the TXRX and eventually i return the unsigned integer whose Byte length is predetermined (the bytes that follow the StatusByte). This Write function only write Family, Index and Write Byte, checking the StatusByte. The Read function in this case is used only to retrieve the first byte after the StatusByte which value luckly will be 0x00 (SUCCESS Transmission). I made other similar functions (following the method of the Arduino Code) in case of the need to retrieve different byte lengths (uint16_t,uint32_t..) or to fill arrays passed as input.
    It is the right way for the implementation or i am missing something?
    Thanks to help me again!
    polimarte
  • Hello Polimarte,
    Sorry for my late reply, I was out of office for some days.
    I am happy to hear you say that, thank you!
    I am glad to see the changes you have made to your functions, they are huge improvements!
    I will include some comments below:
    You are absolutely on the right track here, this looks a lot better!
    I understand, and I see that you function still returns the StatusByte instead of the err_code. I assume this is done for compatibility with other ported functions from the Arduino Library.
    However, I would suggest that you include an APP_ERROR_CHECK on the err_code returned from nrfx_twim_xfer, to catch any errors being generated.
    I also notice your use of magic numbers for the size/length of rx_buffer - I would advise against doing this for any piece of code. Preferably, if you have a static array length that your twim transactions always will return, then it is preferable that you create a define for this, for increased readability.
    Other than that, this use of the nrfx_twim driver seems fine!
    However, I am not sure that this will behave as expected, since when you are using the TXRX transfer description there is no STOP condition generated in between the TX and RX - this is not as shown in the illustration you posted earlier. From the illustration, it seems very much like you will need a stop condition before doing the next operation.
    So, you might have to do this in separate transfers after all ( first completing a TX of length three, then completing a RX of length two )  - Sorry that I did not catch this when I recommended you the TXRX description, my mistake.
    Your usage of the nrfx_twim driver seems to be implemented correctly now.
    What are you seeing when you run this code - are you getting any errors, or unexpected behavior?
    Make sure to give these functions clear and descriptive names, to differentiate them from each other.
    Karl
